@484
16 years |
toby |
# on 2001/11/07 18:17:37, toby did:
get rid of echo command
@483
16 years |
toby |
# on 2001/11/07 18:12:46, toby did:
change filename to avoid liveplot …
@482
16 years |
toby |
# on 2001/10/31 20:13:17, toby did:
new shortcuts: next histogram and …
@481
16 years |
toby |
# on 2001/10/31 20:12:15, toby did:
major revision for in-line routine
@480
16 years |
toby |
# on 2001/10/31 20:08:54, toby did:
support excledt
@479
16 years |
toby |
# on 2001/10/31 20:07:41, toby did:
change excledt to run "in-line"
@478
16 years |
toby |
# on 2001/10/31 20:06:10, toby did:
fix .Oxx bug when no files are …
@477
16 years |
toby |
# on 2001/10/31 20:04:21, toby did:
add next histogram feature
@476
16 years |
toby |
# on 2001/10/31 20:02:37, toby did:
manual zoom option
@475
16 years |
toby |
# on 2001/10/31 19:28:03, toby did:
Very major rewrite
make excledt …
@474
16 years |
toby |
# on 2001/10/31 19:25:44, toby did:
initialization routine for EXCLEDT
@473
16 years |
toby |
# on 2001/10/31 19:24:11, toby did:
unsuccessful Win95 fixes
@472
16 years |
toby |
# on 2001/10/19 19:27:58, toby did:
Change use of $newhist(setnum) for …
@471
16 years |
toby |
# on 2001/10/19 19:27:09, toby did:
remove string replace for 8.0 …
@470
16 years |
toby |
# on 2001/10/18 23:30:15, toby did:
fix web page display problem in …
@469
16 years |
toby |
# on 2001/10/18 23:27:59, toby did:
describe new archiving
@468
16 years |
toby |
# on 2001/10/18 23:27:12, toby did:
remove unix support for compressed …
@467
16 years |
toby |
# on 2001/10/18 23:23:58, toby did:
add new peak labeling options
@466
16 years |
toby |
# on 2001/10/18 23:22:57, toby did:
update archiving
@465
16 years |
toby |
# on 2001/10/18 23:17:12, toby did:
updates
@464
16 years |
toby |
new key bindings for reflection labels
@463
16 years |
toby |
update archiving
@462
16 years |
toby |
update archiving
@461
16 years |
toby |
update archiving
@460
16 years |
toby |
# on 2001/10/14 05:37:32, toby did:
use dumpexp.tcl to import …
@459
16 years |
toby |
dump coordinates from a .EXP file
@458
16 years |
toby |
# on 2001/10/14 05:36:29, toby did:
blank out dummy histogram ranges …
@457
16 years |
toby |
# on 2001/10/14 05:34:23, toby did:
bug fix: fix so that new histogram …
@456
16 years |
toby |
# on 2001/10/14 05:33:15, toby did:
plug mailing list
@455
16 years |
toby |
# on 2001/10/14 05:32:26, toby did:
.EXP coord import
@454
16 years |
toby |
.EXP coord import
@453
16 years |
toby |
# on 2001/09/25 23:35:54, toby did:
Add "D" to all dummy histogram …
@452
16 years |
toby |
# on 2001/09/25 23:35:04, toby did:
resize all plot axes
@451
16 years |
toby |
# on 2001/09/25 23:34:32, toby did:
list only allowed histograms on submenu
@450
16 years |
toby |
# on 2001/09/25 23:31:59, toby did:
Add error highlight into …
@449
16 years |
toby |
# on 2001/09/25 23:30:11, toby did:
Add citations, as suggested by …
@448
16 years |
toby |
# on 2001/09/25 23:28:58, toby did:
add web error links
list only …
@447
16 years |
toby |
# on 2001/09/25 23:25:21, toby did:
add comments
improve error message …
@446
16 years |
toby |
# on 2001/09/25 23:22:48, toby did:
better web sequencing
@445
16 years |
toby |
# on 2001/09/25 23:21:52, toby did:
more links
@444
16 years |
toby |
# on 2001/09/25 23:21:11, toby did:
dummy histogram support
Setting …
@443
16 years |
toby |
# on 2001/09/25 23:20:06, toby did:
old GSAS warning
new EXPTOOL
@442
16 years |
toby |
# on 2001/09/25 23:18:12, toby did:
new GSAS website
new EXPTOOL …
@441
16 years |
toby |
# on 2001/09/25 23:17:30, toby did:
updates
@440
16 years |
toby |
# on 2001/09/25 23:16:40, toby did:
document EXCLEDT and Dummy …
@439
16 years |
toby |
# on 2001/09/25 23:16:11, toby did:
better integrate into progression …
@438
16 years |
toby |
# on 2001/09/25 23:15:31, toby did:
update and shorten
@437
16 years |
toby |
# on 2001/09/25 23:13:18, toby did:
improved
@436
16 years |
toby |
# on 2001/09/04 23:07:02, toby did:
links to EXCLEDT & BKGEDIT
spelling
@435
16 years |
toby |
# on 2001/09/04 23:06:17, toby did:
spelling
Data Range & Excluded Regions
@434
16 years |
toby |
# on 2001/09/04 23:05:49, toby did:
Describes EXCLEDT
@433
16 years |
toby |
# on 2001/09/04 23:04:23, toby did:
cleanup html
select symbol/color/font
@432
16 years |
toby |
# on 2001/09/04 23:03:56, toby did:
updated
@431
16 years |
toby |
# on 2001/09/04 22:58:36, toby did:
add excledt
@430
16 years |
toby |
# on 2001/09/04 22:58:01, toby did:
add excledt
@429
16 years |
toby |
# on 2001/09/04 22:57:16, toby did:
set dmin
set histogram file name …
@428
16 years |
toby |
# on 2001/09/04 22:56:15, toby did:
Add Data Limits/Exclude? button
@427
16 years |
toby |
# on 2001/09/04 22:55:55, toby did:
larger optional font
@426
16 years |
toby |
# on 2001/09/04 22:53:53, toby did:
set colors/symbols
adjust fonts …
@425
16 years |
toby |
# on 2001/09/04 22:46:08, toby did:
Do a better job with BLT graphs
@424
16 years |
toby |
# on 2001/09/04 22:37:09, toby did:
Excluded Region and Data Limit Editor
@423
16 years |
toby |
# on 2001/09/04 22:13:06, toby did:
describe how to override the …
@422
16 years |
toby |
# on 2001/09/04 22:11:44, toby did:
adjustable fonts
@421
16 years |
toby |
# on 2001/09/04 22:11:06, toby did:
adjustable fonts
@420
16 years |
toby |
# on 2001/09/04 22:09:40, toby did:
reset bkgedit zoom
@419
16 years |
toby |
# on 2001/09/04 22:08:10, toby did:
adjustable font support
@418
16 years |
toby |
# on 2001/09/04 22:07:47, toby did:
adjustable fonts
@417
16 years |
toby |
# on 2001/09/04 22:06:41, toby did:
adjustable fonts
@416
16 years |
toby |
# on 2001/09/04 22:06:05, toby did:
adjustable fonts
@415
16 years |
toby |
# on 2001/09/04 22:04:24, toby did:
excluded region support
bank & …
@414
16 years |
toby |
# on 2001/09/04 22:03:57, toby did:
adjustable fonts
@413
16 years |
toby |
# on 2001/09/04 22:01:55, toby did:
adjust font
@412
16 years |
toby |
# on 2001/08/24 18:56:53, toby did:
updates
@411
16 years |
toby |
updates
@410
16 years |
toby |
updates
@409
16 years |
toby |
updates
@408
16 years |
toby |
updates
@407
16 years |
toby |
# on 2001/08/24 18:56:30, toby did:
updated
@406
16 years |
toby |
# on 2001/06/29 18:34:32, toby did:
document bkgedit
add cumulative …
@405
16 years |
toby |
# on 2001/06/29 18:29:04, toby did:
liveplot links
@404
16 years |
toby |
# on 2001/06/29 18:28:04, toby did:
add archived files access
@403
16 years |
toby |
# on 2001/06/29 18:26:19, toby did:
relabel "forward" button
@402
16 years |
toby |
# on 2001/06/29 18:23:57, toby did:
Add bkgedit button description
@401
16 years |
toby |
# on 2001/06/29 18:20:12, toby did:
major expansion -- explain page …
@400
16 years |
toby |
# on 2001/06/29 18:10:45, toby did:
Major revision: add bkgedit …
@399
16 years |
toby |
# on 2001/06/29 18:06:31, toby did:
Add Marquardt, convergence, LeBail? …
@398
16 years |
toby |
# on 2001/06/29 18:03:32, toby did:
Add bkgedit command
@397
16 years |
toby |
# on 2001/06/29 18:00:06, toby did:
add bkgedit program
@396
16 years |
toby |
# on 2001/06/29 17:54:33, toby did:
brace expr's for better speed …
@395
16 years |
toby |
# on 2001/05/23 20:11:12, toby did:
use …
@394
16 years |
toby |
# on 2001/05/23 20:06:32, toby did:
Use TOF-min for default when …
@393
16 years |
toby |
# on 2001/05/23 20:02:11, toby did:
allow help pages to be found on …
@392
16 years |
toby |
# on 2001/05/11 18:35:14, toby did:
test histograms before sending …
@391
16 years |
toby |
# on 2001/05/11 18:32:34, toby did:
Add support for WIF David's …
@390
16 years |
toby |
# on 2001/05/11 16:18:58, toby did:
change in location of PGPLOT font …
@389
16 years |
toby |
# on 2001/05/11 16:17:36, toby did:
Change max constrained atoms to 500
@388
16 years |
toby |
# on 2001/05/11 16:10:22, toby did:
button to display gzip'ed input …
@387
16 years |
toby |
# on 2001/05/11 16:09:08, toby did:
accomodate gzip'ed input files on Unix
@386
16 years |
toby |
# on 2001/05/11 04:15:34, toby did:
LIVEPLOT documentation
@385
16 years |
toby |
# on 2001/04/17 22:51:20, toby did:
Use CR/LF format files on all platforms
