@532
16 years |
toby |
# on 2002/01/22 21:45:59, toby did:
import coordinates from PLATON …
@531
16 years |
toby |
Export plots to GRACE (aka xmgr & …
@530
16 years |
toby |
Export coordinates in MSI .xtl …
@529
16 years |
toby |
export coordinates in PLATON …
@528
16 years |
toby |
export coordinates in SHELX .INS format
@527
16 years |
toby |
example coordinate export routine
@526
16 years |
toby |
# on 2002/01/22 21:12:22, toby did:
reference coordinate import …
@525
16 years |
toby |
# on 2002/01/22 21:11:44, toby did:
lots of additions
@524
16 years |
toby |
# on 2002/01/22 21:08:12, toby did:
add coordinate export section …
@523
16 years |
toby |
# on 2002/01/22 21:06:17, toby did:
ABSPLT
improve utility section …
@522
16 years |
toby |
# on 2002/01/22 21:05:34, toby did:
add newer (mostly MM) programs
@521
16 years |
toby |
# on 2002/01/22 21:05:10, toby did:
MM constraints
@520
16 years |
toby |
# on 2002/01/22 21:02:55, toby did:
l-s in BKGEDT & support for …
@519
16 years |
toby |
# on 2001/12/19 18:55:42, toby did:
reformat to match NCNR style
@518
16 years |
toby |
@517
16 years |
toby |
@516
16 years |
toby |
@515
16 years |
toby |
@514
16 years |
toby |
@513
16 years |
toby |
@512
16 years |
toby |
@511
16 years |
toby |
@510
16 years |
toby |
@509
16 years |
toby |
@508
16 years |
toby |
@507
16 years |
toby |
@506
16 years |
toby |
@505
16 years |
toby |
@504
16 years |
toby |
@503
16 years |
toby |
@502
16 years |
toby |
@501
16 years |
toby |
# on 2001/12/16 20:13:10, toby did:
make top of window a bit smaller
@500
16 years |
toby |
@499
16 years |
toby |
# on 2001/12/16 19:40:06, toby did:
don't check for excledt file -- …
@498
16 years |
toby |
# on 2001/12/16 19:38:52, toby did:
bug fix: ignore update if .EXP …
@497
16 years |
toby |
# on 2001/12/16 18:17:32, toby did:
change GSAS version reference
Add …
@496
16 years |
toby |
# on 2001/12/16 18:16:37, toby did:
note showing .EXP status
@495
16 years |
toby |
# on 2001/12/16 18:15:31, toby did:
liveplot: explain the "FORTRAN" error
@494
16 years |
toby |
# on 2001/12/16 18:09:18, toby did:
Major revisions:
add braces for …
@493
16 years |
toby |
# on 2001/12/16 18:08:28, toby did:
Add "D" as a valid element type
@492
16 years |
toby |
# on 2001/12/16 18:06:53, toby did:
make -outline BLT version …
@491
16 years |
toby |
# on 2001/12/16 17:31:47, toby did:
fix fileinfobox error in open .EXP …
@490
16 years |
toby |
# on 2001/11/19 19:50:58, toby did:
include Rfactors on file lookup
@489
16 years |
toby |
# on 2001/11/19 19:50:05, toby did:
improve error message
deal with …
@488
16 years |
toby |
# on 2001/11/19 19:49:33, toby did:
new smallfont default
@487
16 years |
toby |
# on 2001/11/08 16:00:44, toby did:
fix update flag after Uiso/Uaniso? …
@486
16 years |
toby |
# on 2001/11/07 19:02:53, toby did:
new release (1.51)
@485
16 years |
toby |
# on 2001/11/07 18:22:57, toby did:
remove echo in archive
add get …
@484
16 years |
toby |
# on 2001/11/07 18:17:37, toby did:
get rid of echo command
@483
16 years |
toby |
# on 2001/11/07 18:12:46, toby did:
change filename to avoid liveplot …
@482
16 years |
toby |
# on 2001/10/31 20:13:17, toby did:
new shortcuts: next histogram and …
@481
16 years |
toby |
# on 2001/10/31 20:12:15, toby did:
major revision for in-line routine
@480
16 years |
toby |
# on 2001/10/31 20:08:54, toby did:
support excledt
@479
16 years |
toby |
# on 2001/10/31 20:07:41, toby did:
change excledt to run "in-line"
@478
16 years |
toby |
# on 2001/10/31 20:06:10, toby did:
fix .Oxx bug when no files are …
@477
16 years |
toby |
# on 2001/10/31 20:04:21, toby did:
add next histogram feature
@476
16 years |
toby |
# on 2001/10/31 20:02:37, toby did:
manual zoom option
@475
16 years |
toby |
# on 2001/10/31 19:28:03, toby did:
Very major rewrite
make excledt …
@474
16 years |
toby |
# on 2001/10/31 19:25:44, toby did:
initialization routine for EXCLEDT
@473
16 years |
toby |
# on 2001/10/31 19:24:11, toby did:
unsuccessful Win95 fixes
@472
16 years |
toby |
# on 2001/10/19 19:27:58, toby did:
Change use of $newhist(setnum) for …
@471
16 years |
toby |
# on 2001/10/19 19:27:09, toby did:
remove string replace for 8.0 …
@470
16 years |
toby |
# on 2001/10/18 23:30:15, toby did:
fix web page display problem in …
@469
16 years |
toby |
# on 2001/10/18 23:27:59, toby did:
describe new archiving
@468
16 years |
toby |
# on 2001/10/18 23:27:12, toby did:
remove unix support for compressed …
@467
16 years |
toby |
# on 2001/10/18 23:23:58, toby did:
add new peak labeling options
@466
16 years |
toby |
# on 2001/10/18 23:22:57, toby did:
update archiving
@465
16 years |
toby |
# on 2001/10/18 23:17:12, toby did:
updates
@464
16 years |
toby |
new key bindings for reflection labels
@463
16 years |
toby |
update archiving
@462
16 years |
toby |
update archiving
@461
16 years |
toby |
update archiving
@460
16 years |
toby |
# on 2001/10/14 05:37:32, toby did:
use dumpexp.tcl to import …
@459
16 years |
toby |
dump coordinates from a .EXP file
@458
16 years |
toby |
# on 2001/10/14 05:36:29, toby did:
blank out dummy histogram ranges …
@457
16 years |
toby |
# on 2001/10/14 05:34:23, toby did:
bug fix: fix so that new histogram …
@456
16 years |
toby |
# on 2001/10/14 05:33:15, toby did:
plug mailing list
@455
16 years |
toby |
# on 2001/10/14 05:32:26, toby did:
.EXP coord import
@454
16 years |
toby |
.EXP coord import
@453
16 years |
toby |
# on 2001/09/25 23:35:54, toby did:
Add "D" to all dummy histogram …
@452
16 years |
toby |
# on 2001/09/25 23:35:04, toby did:
resize all plot axes
@451
16 years |
toby |
# on 2001/09/25 23:34:32, toby did:
list only allowed histograms on submenu
@450
16 years |
toby |
# on 2001/09/25 23:31:59, toby did:
Add error highlight into …
@449
16 years |
toby |
# on 2001/09/25 23:30:11, toby did:
Add citations, as suggested by …
@448
16 years |
toby |
# on 2001/09/25 23:28:58, toby did:
add web error links
list only …
@447
16 years |
toby |
# on 2001/09/25 23:25:21, toby did:
add comments
improve error message …
@446
16 years |
toby |
# on 2001/09/25 23:22:48, toby did:
better web sequencing
@445
16 years |
toby |
# on 2001/09/25 23:21:52, toby did:
more links
@444
16 years |
toby |
# on 2001/09/25 23:21:11, toby did:
dummy histogram support
Setting …
@443
16 years |
toby |
# on 2001/09/25 23:20:06, toby did:
old GSAS warning
new EXPTOOL
@442
16 years |
toby |
# on 2001/09/25 23:18:12, toby did:
new GSAS website
new EXPTOOL …
@441
16 years |
toby |
# on 2001/09/25 23:17:30, toby did:
updates
@440
16 years |
toby |
# on 2001/09/25 23:16:40, toby did:
document EXCLEDT and Dummy …
@439
16 years |
toby |
# on 2001/09/25 23:16:11, toby did:
better integrate into progression …
@438
16 years |
toby |
# on 2001/09/25 23:15:31, toby did:
update and shorten
@437
16 years |
toby |
# on 2001/09/25 23:13:18, toby did:
improved
@436
16 years |
toby |
# on 2001/09/04 23:07:02, toby did:
links to EXCLEDT & BKGEDIT
spelling
@435
16 years |
toby |
# on 2001/09/04 23:06:17, toby did:
spelling
Data Range & Excluded Regions
@434
16 years |
toby |
# on 2001/09/04 23:05:49, toby did:
Describes EXCLEDT
@433
16 years |
toby |
# on 2001/09/04 23:04:23, toby did:
cleanup html
select symbol/color/font
