source: trunk/GSASIIplot.py
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Diff Rev Age Author Log Message
(edit) @193   15 years vondreele various fixes, but still bugs. GSASII.py - add more sample parameters …
(edit) @184   15 years vondreele fixes to min/max image sliders fixes to polygon mask interface
(edit) @180   15 years vondreele fix image mask plots
(edit) @174   15 years vondreele improve powder pattern contour plotting
(edit) @173   15 years vondreele fix atom selection clearing fix contour plotting
(edit) @172   15 years vondreele
(edit) @171   15 years vondreele GSASIIIO.py: read phase from cif file fix esd output for powder data …
(edit) @169   15 years vondreele remove undo from GSASII.py make numpy arrays of xyz powder data fixup …
(edit) @167   15 years vondreele image fixes for offset detector drawing/phase fixes
(edit) @166   15 years vondreele fixups of atom editing/atom drawing
(edit) @165   15 years vondreele patches for atom plotting & phase/histogram edits
(edit) @164   15 years vondreele more parameters
(edit) @163   15 years vondreele new versions
(edit) @161   15 years vondreele implement hardcopy (jpeg, tiff & bmp) output of structure drawings
(edit) @158   15 years vondreele implement drawing options: select atom hilites movable test point & …
(edit) @157   15 years vondreele much faster bond finding
(edit) @155   15 years vondreele changes for structure drawing
(edit) @137   15 years vondreel improve hkl selection in OnMotion?. Now gets tighter as zoom is used.
(edit) @132   15 years vondreel implement tool tips giving hkl of generated reflections & give fo, fc, …
(edit) @125   15 years vondreel fix polygon mask creation
(edit) @121   15 years vondreel more cleanup
(edit) @120   15 years vondreel cleanup
(edit) @118   15 years vondreel implement busy cursor for image plotting get right focus behavior for …
(edit) @108   15 years vondreel fix to GenHlaue?; add Hx2Rh & Rh2Hx mod to ReadPDBPhase to use np.inner …
(edit) @94   15 years vondreel move all fortran to fsource add gray for readonly textctrl do polygon …
(edit) @89   15 years vondreel make arc masks bigger
(edit) @88   15 years vondreel complete ring & arc masks
(edit) @87   15 years vondreel "Spots" in Masks is really "Points" Start of "points" for masks
(edit) @85   15 years vondreel threshold masks operational add index peak list load/reload menu & …
(edit) @82   15 years vondreel split powder GUI stuff out of G2gd & put in new GSASIIpwdGUI.py - all …
(edit) @81   15 years vondreel split out image stuff into GSASIIimage.py
(edit) @77   15 years vondreel a few missing G2lat in ranAbyV removed an extra print from G2plot
(edit) @72   15 years vondreel add "Integrate all" option for integrating a set of images
(edit) @68   15 years vondreel improvements in powder pattern plot options
(edit) @65   15 years vondreel remove all path setup code & replace with a simple import of GSASIIpath.
(edit) @64   15 years vondreel refactoring remove SH/L from peak list modify powder plot to offset …
(edit) @63   15 years vondreel some refactoring of integrate routines in prep for an "integrate all" …
(edit) @62   15 years vondreel more cleanup of image integration; force 32 bit arrays to reduce …
(edit) @56   15 years vondreel major modification for images - not stored in project file. Now read …
(edit) @55   15 years vondreel 3rd try - reduce meatrices in integration
(edit) @54   15 years vondreel pick, motion bugs fixed
(edit) @53   15 years vondreel finish image integration problems still with motion, picking pts., …
(edit) @51   15 years vondreel integration working & plotted
(edit) @50   15 years vondreel fix graphics zoom, redraw, home issues now OK for powder, single …
(edit) @49   15 years vondreel resolved zoom issues with peak picking, etc. further steps for image …
(edit) @48   15 years vondreel finished ellipse fitting finished integration range display
(edit) @47   15 years vondreel eliminate fitellipse.for fitting with scipy.optimize.leastsq some mods …
(add) @40   15 years vondreel 1st commit of separate plot module
Note: See TracRevisionLog for help on using the revision log.
