@584
16 years |
toby |
# on 2002/04/12 21:21:18, toby did:
remove id info; update format
@583
16 years |
toby |
@582
16 years |
toby |
@581
16 years |
toby |
# on 2002/04/12 19:51:40, toby did:
remove identification stuff
@580
16 years |
toby |
# on 2002/04/12 19:49:04, toby did:
@579
16 years |
toby |
@578
16 years |
toby |
@577
16 years |
toby |
@576
16 years |
toby |
@575
16 years |
toby |
@574
16 years |
toby |
@573
16 years |
toby |
@572
16 years |
toby |
@571
16 years |
toby |
@570
16 years |
toby |
@569
16 years |
toby |
@568
16 years |
toby |
@567
16 years |
toby |
@566
16 years |
toby |
@565
16 years |
toby |
@564
16 years |
toby |
@563
16 years |
toby |
# on 2002/02/11 19:32:02, toby did:
add cursor display (livecursor) -- …
@562
16 years |
toby |
# on 2002/02/11 19:30:57, toby did:
make sure file gets closed
@561
16 years |
toby |
# on 2002/02/11 17:33:41, toby did:
Change quote processing of CIF's …
@560
16 years |
toby |
# on 2002/02/11 17:32:15, toby did:
Bug fix -- repeat is was not set …
@559
16 years |
toby |
# on 2002/01/25 21:30:39, toby did:
more absorption correction terms
@558
16 years |
toby |
# on 2002/01/25 21:30:17, toby did:
neaten
@557
16 years |
toby |
# on 2002/01/25 21:26:41, toby did:
Add absorption correction to …
@556
16 years |
toby |
# on 2002/01/25 21:17:48, toby did:
add absorption & reorganize page
@555
16 years |
toby |
# on 2002/01/25 21:17:16, toby did:
add absorption box
@554
16 years |
toby |
# on 2002/01/24 15:34:43, toby did:
bug fix: update plot after "Apply" …
@553
16 years |
toby |
# on 2002/01/23 20:53:36, toby did:
fix bugs related to adding …
@552
16 years |
toby |
# on 2002/01/23 20:00:50, toby did:
clean up font references
@551
16 years |
toby |
@550
16 years |
toby |
@549
16 years |
toby |
# on 2002/01/23 19:59:56, toby did:
reference the self-installer …
@548
16 years |
toby |
# on 2002/01/23 19:59:22, toby did:
reference the RPM file
cleanup font use
@547
16 years |
toby |
# on 2002/01/23 19:59:05, toby did:
thanks John!
@546
16 years |
toby |
# on 2002/01/23 19:58:35, toby did:
note reflection labeling request
@545
16 years |
toby |
# on 2002/01/22 23:12:36, toby did:
don't dump mm phases
@544
16 years |
toby |
# on 2002/01/22 23:02:55, toby did:
writing of real values: if a field …
@543
16 years |
toby |
# on 2002/01/22 22:55:35, toby did:
Major changes to add MM …
@542
16 years |
toby |
# on 2002/01/22 22:53:34, toby did:
support absplt in widplt routine …
@541
16 years |
toby |
# on 2002/01/22 22:50:33, toby did:
add absplt, remove export routines …
@540
16 years |
toby |
# on 2002/01/22 22:45:19, toby did:
Major revision
Add ABSPLT …
@539
16 years |
toby |
# on 2002/01/22 22:29:18, toby did:
Significant change in display of …
@538
16 years |
toby |
# on 2002/01/22 22:28:53, toby did:
more complete space group checking
@537
16 years |
toby |
# on 2002/01/22 22:16:51, toby did:
Major revision:
export to GRACE
@536
16 years |
toby |
# on 2002/01/22 22:10:48, toby did:
support changes MM phases (where …
@535
16 years |
toby |
# on 2002/01/22 21:52:22, toby did:
Major revisions
add plot of R's & …
@534
16 years |
toby |
# on 2002/01/22 21:51:33, toby did:
Add small checkbutton font for …
@533
16 years |
toby |
# on 2002/01/22 21:45:59, toby did:
import coordinates from MSI .xtl …
@532
16 years |
toby |
import coordinates from PLATON …
@531
16 years |
toby |
Export plots to GRACE (aka xmgr & …
@530
16 years |
toby |
Export coordinates in MSI .xtl …
@529
16 years |
toby |
export coordinates in PLATON …
@528
16 years |
toby |
export coordinates in SHELX .INS format
@527
16 years |
toby |
example coordinate export routine
@526
16 years |
toby |
# on 2002/01/22 21:12:22, toby did:
reference coordinate import …
@525
16 years |
toby |
# on 2002/01/22 21:11:44, toby did:
lots of additions
@524
16 years |
toby |
# on 2002/01/22 21:08:12, toby did:
add coordinate export section …
@523
16 years |
toby |
# on 2002/01/22 21:06:17, toby did:
ABSPLT
improve utility section …
@522
16 years |
toby |
# on 2002/01/22 21:05:34, toby did:
add newer (mostly MM) programs
@521
16 years |
toby |
# on 2002/01/22 21:05:10, toby did:
MM constraints
@520
16 years |
toby |
# on 2002/01/22 21:02:55, toby did:
l-s in BKGEDT & support for …
@519
16 years |
toby |
# on 2001/12/19 18:55:42, toby did:
reformat to match NCNR style
@518
16 years |
toby |
@517
16 years |
toby |
@516
16 years |
toby |
@515
16 years |
toby |
@514
16 years |
toby |
@513
16 years |
toby |
@512
16 years |
toby |
@511
16 years |
toby |
@510
16 years |
toby |
@509
16 years |
toby |
@508
16 years |
toby |
@507
16 years |
toby |
@506
16 years |
toby |
@505
16 years |
toby |
@504
16 years |
toby |
@503
16 years |
toby |
@502
16 years |
toby |
@501
16 years |
toby |
# on 2001/12/16 20:13:10, toby did:
make top of window a bit smaller
@500
16 years |
toby |
@499
16 years |
toby |
# on 2001/12/16 19:40:06, toby did:
don't check for excledt file -- …
@498
16 years |
toby |
# on 2001/12/16 19:38:52, toby did:
bug fix: ignore update if .EXP …
@497
16 years |
toby |
# on 2001/12/16 18:17:32, toby did:
change GSAS version reference
Add …
@496
16 years |
toby |
# on 2001/12/16 18:16:37, toby did:
note showing .EXP status
@495
16 years |
toby |
# on 2001/12/16 18:15:31, toby did:
liveplot: explain the "FORTRAN" error
@494
16 years |
toby |
# on 2001/12/16 18:09:18, toby did:
Major revisions:
add braces for …
@493
16 years |
toby |
# on 2001/12/16 18:08:28, toby did:
Add "D" as a valid element type
@492
16 years |
toby |
# on 2001/12/16 18:06:53, toby did:
make -outline BLT version …
@491
16 years |
toby |
# on 2001/12/16 17:31:47, toby did:
fix fileinfobox error in open .EXP …
@490
16 years |
toby |
# on 2001/11/19 19:50:58, toby did:
include Rfactors on file lookup
@489
16 years |
toby |
# on 2001/11/19 19:50:05, toby did:
improve error message
deal with …
@488
16 years |
toby |
# on 2001/11/19 19:49:33, toby did:
new smallfont default
@487
16 years |
toby |
# on 2001/11/08 16:00:44, toby did:
fix update flag after Uiso/Uaniso? …
@486
16 years |
toby |
# on 2001/11/07 19:02:53, toby did:
new release (1.51)
@485
16 years |
toby |
# on 2001/11/07 18:22:57, toby did:
remove echo in archive
add get …
