@3468
7 years |
vondreele |
define new function FindAllCons? to replace bits of identical code that …
@3467
7 years |
vondreele |
fix problem in constraints where a deleted constraint variable wasn't …
@3462
7 years |
toby |
move check of fractions/scale to OnRefine? and OnView?
@3456
7 years |
vondreele |
change delete constraint code
@3438
7 years |
vondreele |
g2strIO
fix magnetic hkl extinctions in reflection generation
remove …
@3413
7 years |
vondreele |
modify RefineCore? & Refine/SeqRefine? to use ifSeq parameter instead of …
@3411
7 years |
vondreele |
another transform constrint fix to atom nos.
@3410
7 years |
vondreele |
bad Uij names fixed in Transform constraints
@3409
7 years |
vondreele |
another fix to transformation constraints to skip equivalent …
@3406
7 years |
vondreele |
fix Transform to create correct(?) constraints between lattices, atom …
@3397
7 years |
vondreele |
fix Constraints problem when no histograms (or phases)
display new BNS …
@3396
7 years |
vondreele |
set refList=False for a couple of calls to GetHistogramPhaseData? where …
@3373
7 years |
toby |
make sequential refinement setting work like a global flag; add …
@3371
7 years |
toby |
constraint fixes: implement wild-card equivalences, fix use of all for …
@3356
7 years |
vondreele |
remove commented out SetTitle? & SetLabel? for data window from various …
@3355
7 years |
toby |
name main & plot window against project name, remove other SetTitle? calls
@3328
7 years |
vondreele |
reformat residue RB display to show residues one at a time
@3325
7 years |
vondreele |
add importer for Bruker image FORMAT 100 files
fix AAprobability plots …
@3317
7 years |
vondreele |
magnetic site symmetry restrictions on moments & magnetic site …
@3302
7 years |
vondreele |
mag sym fixes
@3239
7 years |
vondreele |
implement use of 2-site disordered amino acid residues in proteins: …
@3136
8 years |
vondreele |
make GSAS-II python 3.6 compliant & preserve python 2.7 use;changes: …
@3079
8 years |
vondreele |
implement rigid body reference vectors
@3065
8 years |
toby |
fix error introduced by variable sorting
@3061
8 years |
toby |
sort variable names
@3057
8 years |
toby |
more work on constraints: prevent use of perviously constrained …
@3056
8 years |
toby |
expand error reporting with constraints (no fixes yet to prevent them)
@3054
8 years |
vondreele |
fixes to MCSA gui routines; trap <3 atom RBs
fix missing AtLookup? …
@3000
8 years |
toby |
make the two frame version the trunk as we hit version 3000
@2753
8 years |
vondreele |
minor shuffling about for atom constraints - no discernable impact …
@2707
8 years |
vondreele |
some code layout changes
rework ShowLSParms to allow selection for display
@2691
8 years |
vondreele |
fix Transform - cell constraints were wrong
needed to clear …
@2583
9 years |
vondreele |
put default 'Plane' into drawing Data from old gpx files
fix frame …
@2551
9 years |
vondreele |
clean up G2imageGUI
Add start on autoSpot mask - not complete
some …
@2546
9 years |
vondreele |
cleanup of all GSASII main routines - remove unused variables, dead …
@2544
9 years |
vondreele |
major cleanup of unused variables, etc.
@2520
9 years |
vondreele |
remove unused & commented Srr fctr & deriv routines
Mag moment …
@2512
9 years |
vondreele |
remove 'constraint' and 'restraint' from Consraints & Restraints tabs …
@2506
9 years |
vondreele |
some work on automatic mag constraints
move a dlg.Destroy() in …
@2496
9 years |
vondreele |
small modification to fix of post Refine crash in ConstrGUI
@2495
9 years |
vondreele |
some cleanup of Data tab
fix (!) crash after Refine for Costraints & …
@2491
9 years |
vondreele |
fix bug for call to GetPhaseData? in export phase
put in stub for …
@2489
9 years |
vondreele |
also for D11, etc. allow all others to be used in equivalence
@2488
9 years |
vondreele |
Allow equivalence constraints between A0-A5 on one phase and any of …
@2482
9 years |
vondreele |
allow atom constraints between phases
@2481
9 years |
vondreele |
force Transform to delete nonmagnetic atoms if phase made magnetic & …
@2480
9 years |
vondreele |
add make magnetic phase to General/Transform? option
trap missing rigid …
@2473
9 years |
vondreele |
work on magnetic structures - import from EXP, plotting, LS refine …
@2434
9 years |
toby |
Fix constraint edit bug in wx3.0; relabel constraint menu items to …
@2431
9 years |
vondreele |
fix problem with wxPython 3.x with changing text entry focus. Needed a …
@2085
10 years |
vondreele |
allow constraints between Tmin & Tmax (ZigZag/Block? parms)
@2062
10 years |
vondreele |
exclude non variable SS parms from constraint lists
define ZigZag? & …
@1943
10 years |
vondreele |
remove H-atom riding constraint editing; unusable at present
@1925
10 years |
vondreele |
create AddHatomDialog? & work on OnHydAtomAdd?
allow reading of .cor …
@1924
10 years |
vondreele |
work on H-atom riding constraints
extend "short" phase names to full …
@1915
10 years |
vondreele |
start on riding constraints - works for atom frac,x,y,z; skipping u's …
@1898
10 years |
vondreele |
new constraint option - constrain atom variables as a set; constrain …
@1831
10 years |
toby |
move remaining generic controls to G2ctrls
@1827
10 years |
toby |
fix scrollbar problems in many places; phase data in particular
@1770
10 years |
vondreele |
moved MultipleChoicesDialog? and SingleChoiceDialog? from G2grid to G2ctrls
@1657
10 years |
toby |
migrate help from G2grid; set instparms in Powder imports; seach for …
@1625
11 years |
vondreele |
add a parameter to result from G2stIO.GetPhaseData?
add modulation …
@1619
11 years |
toby |
add columnsorter for hetrogeneous seq ref; reorg to start moving …
@1545
11 years |
toby |
fix tab selection (again); clean up some menus
@1542
11 years |
vondreele |
put in missing Rigid body binds
@1512
11 years |
toby |
implement logging and config storage
@1417
11 years |
vondreele |
missed a couple of lines
@1416
11 years |
vondreele |
fix wx c++ error in Constraints after a Refine
@1411
11 years |
vondreele |
remove unused reference to z-matrix RBs
noted in comment about …
@1390
11 years |
toby |
revise start, sort out phase fraction vs scale factor label, add …
@1378
11 years |
toby |
wxPython 2.9 fixes: FlexGridSizer?, wx.Colour, MacOpenFile?; move bind …
@1359
11 years |
vondreele |
start allowing reading of multiple HKLF files.
put an IndexAllIds? into …
@1247
11 years |
toby |
allow wildcarded-histogram constraint input; implement for seq refinements
@1214
11 years |
toby |
fix use of RB vars in G2VarObj, etc.; Add select tab to restraints
@1209
11 years |
toby |
line up columns in parameter selection boxes; add a filter for …
@1160
12 years |
toby |
finish ISODISPLACE fixes; improve show var window; improve help …
@1147
12 years |
toby |
Complete initial ISODISPLACE implementation; mod. phase …
@1141
12 years |
toby |
minor tweaks: move indexing of Ids to histogram load, remove Type from …
@1138
12 years |
toby |
major constraints revision
@1077
12 years |
toby |
cleanup plot & svn bugs; set missing keywords; CIF export done; update docs
@1050
12 years |
vondreele |
Add error dialog for needing LS run once before setting constraints.
@961
12 years |
vondreele |
fix rb constraints - useCount
fix Uij2Ueqv
mods to anneal algorithms …
@934
12 years |
vondreele |
changes for MC/SA
@929
12 years |
vondreele |
one more G2str fix
@927
12 years |
vondreele |
more G2str fixes
@923
12 years |
toby |
more doc updates
@906
12 years |
toby |
switch to aui.notebook for data display window; work on phase data …
@904
12 years |
toby |
fix line endings
@889
12 years |
vondreele |
add torsion angle derivatives in RB
small fixes to other RB stuff
@885
12 years |
vondreele |
add 'Global' to constraints
remove a stray debug print
fix U6toUij so …
@883
12 years |
vondreele |
begin RB refinement mods & fixed so non-RB refinements still work
@881
12 years |
vondreele |
more RB editing & fixes
'+0' & '-0' (vice versa) removed from any cif …
@879
12 years |
vondreele |
complete rb input to refinement
@860
12 years |
vondreele |
more fixes to rigid body stuff
@859
12 years |
vondreele |
still more rigid body fixes
add thermal motion models
allow copy of RB …
@855
12 years |
vondreele |
RB input mostly finished; now has thermal motion models
@854
12 years |
vondreele |
more rigid body stuff
@852
12 years |
vondreele |
rigid body changes
@851
12 years |
vondreele |
more rigid body stuff, plotting, RB placement, import of more types of …
@850
12 years |
vondreele |
fix problem with atoms with An+ style of valence
more places for size …
