@706
14 years |
jemian |
work-in-progress
@705
14 years |
jemian |
make PV connections; properties
@704
14 years |
jemian |
getting further along
@703
14 years |
jemian |
software license
@702
14 years |
jemian |
making some real progress with the Traits-based GUI
@701
14 years |
jemian |
sketch out some of the basics
@700
14 years |
jemian |
prepare to restart this project using Traits
@699
14 years |
jemian |
replace lengthy+obvious with compact+obtuse+efficient code
@698
14 years |
jemian |
add some more examples and test code: test3 is getting close …
@697
14 years |
jemian |
Separator(), not Separator -- also removed threading since it did not …
@696
14 years |
jemian |
start on the menu bar, indicating what to do, stopped when …
@695
14 years |
jemian |
pick colors directly from interface
pull all wx calls into the …
@694
14 years |
jemian |
additional comment
@693
14 years |
jemian |
revert back to showing DMOV state using color - good suggestion from …
@692
14 years |
jemian |
restore code removed in [689] that set widget background color when …
@691
14 years |
jemian |
tidy
@690
14 years |
jemian |
Ok, colors are out for now, ... got to find a way ... ... …
@689
14 years |
jemian |
try to show motor moving a different way
@688
14 years |
jemian |
cleanup and better comments
@687
14 years |
jemian |
same problem, GUI fails when trying to set widget background color
@686
14 years |
jemian |
This works and does not jam up
@685
14 years |
jemian |
minor changes to simplify code, GUI updates get jammed when motors …
@644
14 years |
jemian |
added a runner, initialize PV and RBV widgets on Connect, rebrand two …
@643
14 years |
jemian |
add threading
@642
14 years |
jemian |
converted CaPython code to PyEpics? - still need to handle widget …
@641
14 years |
jemian |
most code moved over to PyEpics? -- moxy.py is next
@640
14 years |
jemian |
not needed for this project
@635
14 years |
jemian |
fix the imports, add some TODO items - more to come
@634
14 years |
jemian |
trunk is now a PyDev? project
@633
14 years |
jemian |
rebrand the SVN repo as well, was wxmtxy, becomes moxy
copied from wxmtxy:
@632
14 years |
jemian |
continuing…
