source: trunk
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Diff Rev Age Author Log Message
(edit) @662   16 years toby # on 2002/12/27 18:25:35, toby did: fix MM read bug
(edit) @661   16 years toby # on 2002/10/31 17:32:06, toby did: trap gsas_config errors & write to …
(edit) @660   16 years toby # on 2002/10/31 17:29:18, toby did: do better job reporting …
(edit) @659   16 years toby # on 2002/10/31 17:28:17, toby did: trap gsas_config errors & write to …
(edit) @658   16 years toby # on 2002/10/31 17:26:56, toby did: trap gsas_config errors prevent …
(edit) @657   16 years toby # on 2002/10/24 19:26:49, toby did: fix broken help link
(edit) @656   16 years toby # on 2002/10/24 19:26:20, toby did: .csv plotting
(edit) @655   16 years toby # on 2002/10/24 19:24:01, toby did: Add export capability to comma …
(edit) @654   16 years toby # on 2002/09/24 20:49:58, toby did: quote reserved "words" (DATA_ …
(edit) @653   16 years toby # on 2002/09/06 19:42:17, toby did: update with recent request & …
(edit) @652   16 years toby # on 2002/09/05 21:18:57, toby did: more updates
(edit) @651   16 years toby # on 2002/09/05 21:18:37, toby did: new msg
(edit) @650   16 years toby # on 2002/09/05 21:03:37, toby did: Major revision. Implement undo …
(edit) @649   16 years toby # on 2002/09/05 20:59:20, toby did: Revise to use updated browsecif: …
(edit) @648   16 years toby # on 2002/09/05 18:29:19, toby did: make sure a phase & histogram is …
(edit) @647   16 years toby # on 2002/09/05 18:28:06, toby did: comments
(edit) @646   16 years toby # on 2002/09/05 18:24:04, toby did: add categories to loops improve …
(edit) @645   16 years toby # on 2002/09/05 18:22:20, toby did: trap error in localconfig and …
(edit) @644   16 years toby # on 2002/09/05 18:21:33, toby did: minor update: eliminate reference …
(edit) @643   16 years toby # on 2002/09/05 18:17:58, toby did: Major rework to use text-based …
(edit) @642   16 years toby # on 2002/09/05 18:16:49, toby did: remove octave stuff
(edit) @641   16 years toby # on 2002/09/05 18:16:00, toby did: why did I do this? Deal with …
(edit) @640   16 years toby # on 2002/08/09 16:44:11, toby did: Used to select distances & angles …
(edit) @639   16 years toby # on 2002/08/09 16:43:35, toby did: Routine to fill ? fields in CIF …
(edit) @638   16 years toby # on 2002/08/09 16:43:07, toby did: CIF support library
(edit) @637   16 years toby # on 2002/08/09 16:40:59, toby did: fix table size sync. add …
(edit) @636   16 years toby # on 2002/08/09 16:39:59, toby did: correct labels on pref. orient. …
(edit) @635   16 years toby # on 2002/07/31 00:33:41, toby did: document CIFselect
(edit) @634   16 years toby # on 2002/07/18 20:52:41, toby did: fix excluded region read error (in …
(edit) @633   16 years toby # on 2002/07/18 20:51:26, toby did: remove iconify from excledt -- …
(edit) @632   16 years toby # on 2002/07/18 20:51:04, toby did: GSAS2CIF & FillCIF changes
(edit) @631   16 years toby # on 2002/07/18 20:50:45, toby did: GSAS2CIF & fillCIF changes
(edit) @630   16 years toby # on 2002/07/18 20:50:04, toby did: fix binding with yet newer …
(edit) @629   16 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @628   16 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @627   16 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @626   16 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @625   16 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @624   16 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @623   16 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @622   16 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @621   16 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @620   16 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @619   16 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @618   16 years toby # on 2002/07/18 20:44:05, toby did: NIST alumina tutorial
(edit) @617   16 years toby # on 2002/07/18 20:44:05, toby did: NIST alumina tutorial
(edit) @616   16 years toby # on 2002/07/18 20:39:14, toby did: Export routine for FOX
(edit) @615   16 years toby # on 2002/07/18 20:27:39, toby did: new tutorial
(edit) @614   16 years toby # on 2002/07/18 20:21:51, toby did: spell out more
(edit) @613   16 years toby # on 2002/07/18 20:21:34, toby did: GSAS2CIF stuff
(edit) @612   16 years toby # on 2002/07/18 20:02:14, toby did: make gsas+expgui.exe more obvious
(edit) @611   16 years toby # on 2002/07/18 20:01:41, toby did: add gsas2cif reference
(edit) @610   16 years toby # on 2002/07/18 19:59:42, toby did: clean spelling change DISAGL flag …
(edit) @609   16 years toby # on 2002/07/18 19:59:03, toby did: Add gsas2cif into chain
(edit) @608   16 years toby # on 2002/07/15 17:38:48, toby did: guide to the GSAS2CIF process
(edit) @607   16 years toby # on 2002/07/03 21:06:49, toby did: Bug fix: cancel button was broken …
(edit) @606   16 years toby # on 2002/07/03 21:04:31, toby did: catch invalid .EXP file names
(edit) @605   16 years toby # on 2002/07/03 21:02:35, toby did: minor stuff: 1) networked path …
(edit) @604   16 years toby # on 2002/07/03 21:01:45, toby did: minor bug fix
(edit) @603   16 years toby # on 2002/07/03 21:00:19, toby did: place only 1 TITL line in file (as …
(edit) @602   16 years toby # on 2002/04/12 21:34:08, toby did: remove id info; update format
(edit) @601   16 years toby # on 2002/04/12 21:34:08, toby did: remove id info; update format
(edit) @600   16 years toby # on 2002/04/12 21:34:08, toby did: remove id info; update format
(edit) @599   16 years toby # on 2002/04/12 21:34:08, toby did: remove id info; update format
(edit) @598   16 years toby # on 2002/04/12 21:34:08, toby did: remove id info; update format
(edit) @597   16 years toby # on 2002/04/12 21:34:08, toby did: remove id info; update format
(edit) @596   16 years toby # on 2002/04/12 21:34:08, toby did: remove id info; update format
(edit) @595   16 years toby # on 2002/04/12 21:34:08, toby did: remove id info; update format
(edit) @594   16 years toby # on 2002/04/12 21:34:08, toby did: remove id info; update format
(edit) @593   16 years toby # on 2002/04/12 21:34:08, toby did: remove id info; update format
(edit) @592   16 years toby # on 2002/04/12 21:21:18, toby did: remove id info; update format
(edit) @591   16 years toby # on 2002/04/12 21:21:18, toby did: remove id info; update format
(edit) @590   16 years toby # on 2002/04/12 21:21:18, toby did: remove id info; update format
(edit) @589   16 years toby # on 2002/04/12 21:21:18, toby did: remove id info; update format
(edit) @588   16 years toby # on 2002/04/12 21:21:18, toby did: remove id info; update format
(edit) @587   16 years toby # on 2002/04/12 21:21:18, toby did: remove id info; update format
(edit) @586   16 years toby # on 2002/04/12 21:21:18, toby did: remove id info; update format
(edit) @585   16 years toby # on 2002/04/12 21:21:18, toby did: remove id info; update format
(edit) @584   16 years toby # on 2002/04/12 21:21:18, toby did: remove id info; update format
(edit) @583   16 years toby # on 2002/04/12 21:21:18, toby did: remove id info; update format
(edit) @582   16 years toby # on 2002/04/12 21:21:18, toby did: remove id info; update format
(edit) @581   16 years toby # on 2002/04/12 19:51:40, toby did: remove identification stuff
(edit) @580   16 years toby # on 2002/04/12 19:49:04, toby did: remove identification stuff
(edit) @579   16 years toby # on 2002/04/12 19:49:04, toby did: remove identification stuff
(edit) @578   16 years toby # on 2002/04/12 19:49:04, toby did: remove identification stuff
(edit) @577   16 years toby # on 2002/04/12 19:49:04, toby did: remove identification stuff
(edit) @576   16 years toby # on 2002/04/12 19:49:04, toby did: remove identification stuff
(edit) @575   16 years toby # on 2002/04/12 19:49:04, toby did: remove identification stuff
(edit) @574   16 years toby # on 2002/04/12 19:49:04, toby did: remove identification stuff
(edit) @573   16 years toby # on 2002/04/12 19:49:04, toby did: remove identification stuff
(edit) @572   16 years toby # on 2002/04/12 19:49:04, toby did: remove identification stuff
(edit) @571   16 years toby # on 2002/04/12 19:49:04, toby did: remove identification stuff
(edit) @570   16 years toby # on 2002/04/12 19:49:04, toby did: remove identification stuff
(edit) @569   16 years toby # on 2002/04/12 19:49:04, toby did: remove identification stuff
(edit) @568   16 years toby # on 2002/04/12 19:49:04, toby did: remove identification stuff
(edit) @567   16 years toby # on 2002/04/12 19:49:04, toby did: remove identification stuff
(edit) @566   16 years toby # on 2002/04/12 19:49:04, toby did: remove identification stuff
(edit) @565   16 years toby # on 2002/04/12 19:49:04, toby did: remove identification stuff
(edit) @564   16 years toby # on 2002/04/12 19:49:04, toby did: remove identification stuff
(edit) @563   16 years toby # on 2002/02/11 19:32:02, toby did: add cursor display (livecursor) -- …
Note: See TracRevisionLog for help on using the revision log.
