source: branches
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Diff Rev Age Author Log Message
(edit) @1019   15 years toby Fix Save as bug
(edit) @1018   15 years toby Set DISAGL dist/angle options
(edit) @1017   15 years toby read default radii from AFAC records
(edit) @1016   15 years toby read & edit DISAGL distance/angle radii
(edit) @1015   15 years toby mapexp: set expgui(mapstat) to trigger trace; move tab disable from …
(edit) @1014   15 years toby add home for single xtal work
(edit) @1013   15 years chlake save exp file changes before DISAGL
(edit) @1012   15 years chlake 1 - Atom filters show only atom types present in the phase. 2 - Added …
(edit) @1011   15 years chlake Fixed phase choice problems and traces. Added grab restore to fix …
(edit) @1010   15 years chlake Fixed bug in SR_Write_Restraint Procedure
(edit) @1009   15 years chlake Final?? File
(edit) @1008   15 years chlake cleanup indents, etc. add Fill_Display on change of phase
(edit) @1007   15 years chlake relabel constraints tab (need a better label!) readexp: breakup lines …
(edit) @1006   15 years chlake Fixed refresh problems after leaving Restraint Editor Window
(edit) @1005   15 years chlake Made SR_Sort generic and added sort routine to restraint list box. …
(edit) @1004   15 years chlake Added restraint only list to main restraints window.
(edit) @1003   15 years chlake Fixed bugs in ::sr_restraintdist and ::sr_lookuplist variables.
(edit) @1002   15 years chlake Renamed sr_all_bonds to sr_bond_list removed global variable prsort, …
(edit) @1001   15 years chlake cleanup, add bell for error
(edit) @1000   15 years toby readexp: fix return list distrest: new routines for s.c. editing
(edit) @999   15 years toby Add Distance Rest to Constraints (sandbox)
(edit) @998   15 years toby tag Copy head version to create a branch to play with
(add) @2   16 years toby initial setup
Note: See TracRevisionLog for help on using the revision log.
