Search:
Login
Help/Guide
About Trac
Preferences
Wiki
Timeline
Roadmap
Browse Source
View Tickets
Search
Context Navigation
View Latest Revision
source:
branches
Revision Log Mode:
Stop on copy
Follow copies
Show only adds and deletes
View log starting at
and back to
Show at most
revisions per page.
Show full log messages
Legend:
Added
Modified
Copied or renamed
Diff
Rev
Age
Author
Log Message
(edit)
@1017
15 years
toby
read default radii from AFAC records
(edit)
@1016
15 years
toby
read & edit DISAGL distance/angle radii
(edit)
@1015
15 years
toby
mapexp: set expgui(mapstat) to trigger trace; move tab disable from …
(edit)
@1014
15 years
toby
add home for single xtal work
(edit)
@1013
15 years
chlake
save exp file changes before DISAGL
(edit)
@1012
15 years
chlake
1 - Atom filters show only atom types present in the phase. 2 - Added …
(edit)
@1011
15 years
chlake
Fixed phase choice problems and traces. Added grab restore to fix …
(edit)
@1010
15 years
chlake
Fixed bug in SR_Write_Restraint Procedure
(edit)
@1009
15 years
chlake
Final?? File
(edit)
@1008
15 years
chlake
cleanup indents, etc. add Fill_Display on change of phase
(edit)
@1007
15 years
chlake
relabel constraints tab (need a better label!) readexp: breakup lines …
(edit)
@1006
15 years
chlake
Fixed refresh problems after leaving Restraint Editor Window
(edit)
@1005
15 years
chlake
Made SR_Sort generic and added sort routine to restraint list box. …
(edit)
@1004
15 years
chlake
Added restraint only list to main restraints window.
(edit)
@1003
15 years
chlake
Fixed bugs in ::sr_restraintdist and ::sr_lookuplist variables.
(edit)
@1002
15 years
chlake
Renamed sr_all_bonds to sr_bond_list removed global variable prsort, …
(edit)
@1001
15 years
chlake
cleanup, add bell for error
(edit)
@1000
15 years
toby
readexp: fix return list distrest: new routines for s.c. editing
(edit)
@999
15 years
toby
Add Distance Rest to Constraints (sandbox)
(edit)
@998
15 years
toby
tag Copy head version to create a branch to play with
(add)
@2
16 years
toby
initial setup
Note:
See
TracRevisionLog
for help on using the revision log.
Download in other formats:
RSS Feed
ChangeLog
