source: trunk
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Diff Rev Age Author Log Message
(edit) @4985   4 years vondreele fix mag sp gp special pos determination for P3m1 & P321 mag groups.
(edit) @4984   4 years vondreele fix excluded regions for q- & d-plots
(edit) @4983   4 years toby fix initialization problem when EQUIV are changed to constraints; …
(edit) @4982   4 years toby fix check on non-zero multipliers
(edit) @4981   4 years vondreele modify mag str fctr math. fix bug in PlotCovariance? - labels needed to …
(edit) @4980   4 years toby Fix coeff. display for EQUIV
(edit) @4979   4 years vondreele add new function UpdateSelection?() to G2TreeCtrl, used it in a few …
(edit) @4978   4 years vondreele fix to UpdateHKLFdata to include sg extinct flag for each reflection
(edit) @4977   4 years vondreele fix bad crash (blown out of python!) in OnDataDelete?. Remove CallAfter?
(edit) @4976   4 years toby Mac M1 changes
(edit) @4974   4 years vondreele fix single crystal merge routines (missing Instrument Parameters) add …
(edit) @4973   4 years vondreele fix wx.pyValidator error
(edit) @4972   4 years vondreele hide intensity related variables & set their refinement flags to False …
(edit) @4971   4 years vondreele
(edit) @4970   4 years vondreele fix PlotAAProb bugs - leftover pickradius & an xpos error fix scale …
(edit) @4969   4 years toby move hist/phase docs to Phase/Data? section; cleanup
(edit) @4968   4 years toby finish hist/phase tree entry; create new help file for it(incomplete)
(edit) @4967   4 years vondreele rearrange atom editing menus
(edit) @4966   4 years vondreele revise help items - new enties
(edit) @4965   4 years toby start work on option to move Phase/Data? to 1st level in tree
(edit) @4964   4 years toby divide up help into a few files
(edit) @4963   4 years vondreele
(edit) @4960   4 years vondreele update documentation for "Texture implementation"
(edit) @4959   4 years toby add NIST spectrum kludge for incident beam mono
(edit) @4958   4 years vondreele put floor onn histogram scale = 1e-4 (might be too big?) set …
(edit) @4957   4 years vondreele remove "Reflection list not ready" message; set GeneralData?['Data plot …
(edit) @4956   4 years vondreele fix tif reader bug for old gpx files.
(edit) @4955   4 years toby allow for different size fonts in CIF entry
(edit) @4954   4 years toby minor fullrmc improvements from Bachir, etc.
(edit) @4953   4 years toby fix fullrmc rmax bug
(edit) @4952   4 years toby switch to native fullrmc input modes rather than convert files
(edit) @4951   4 years toby working fullrmc implementation. Much more to do (see TODO in phsGUI), …
(edit) @4950   4 years vondreele remove aspect='eual' from a plot contour call - no longer allowed put …
(edit) @4924   4 years vondreele fix texture coordinate system description
(edit) @4922   4 years toby improve version notice display
(edit) @4921   4 years vondreele make version info number match new version number (it was one less).
(edit) @4920   4 years vondreele fix import of 2nd type of Pilatus images.
(edit) @4919   4 years vondreele change powder peak shape functions to include effect of varying step …
(edit) @4918   4 years toby add mechanism for posting a notice when G2 versions are updated
(edit) @4917   4 years toby split G2 & pillow readers for TIF; document
(edit) @4916   4 years toby fix Map OnPeaksMove? bug
(edit) @4915   4 years vondreele add some doc strings for profile functions in G2pwd rename …
(edit) @4914   4 years toby ignore & highlight bad General Restraints; minor GUI fixes
(edit) @4913   4 years toby Add mult, divide & incr. options to GridFracEdit?; make GridFracEdit?
(edit) @4912   4 years toby allow , decimal in ValidatedTextCtrl?; Use ValidatedTextCtrl? in …
(edit) @4911   4 years toby implement european decimal (,) for grid fraction editor; use it for …
(edit) @4910   4 years vondreele Add Wilson statistics to Reflection list menu - computes Wilson plot, …
(edit) @4909   4 years toby fix CIF exports
(edit) @4908   4 years toby fix deleting of restraints
(edit) @4907   4 years vondreele use eigenvalue/vector math to find molecule orientation in onSetPlane
(edit) @4906   4 years vondreele
(edit) @4905   4 years toby fix delete for general; flag constraints where vars are removed
(edit) @4904   4 years toby for in-refinement plotting, get data limits for plotted histogram; …
(edit) @4903   4 years vondreele fix 2 issues in HessianLSQ for SVN LinAlgErrors? fix a typo in G2plot …
(edit) @4901   4 years toby add TOF corrections on read in scripts
(edit) @4900   4 years vondreele show space group info even if not changed in General tab - wasn't any …
(edit) @4899   4 years vondreele use ValidatedTxtCtrl? in MultiDataDialog? Let ValidatedTxtCtrl? use …
(edit) @4898   4 years toby NIST requests to pretty up FPA
(edit) @4897   4 years vondreele use our validatedtxtctrl for float input to MultiDataDialog?. Allows …
(edit) @4896   4 years toby minor updates powder plot help
(edit) @4895   4 years toby allow w to be on before publish; update powder plot help
(edit) @4894   4 years toby bug on aborted refinement; more on FPA
(edit) @4893   4 years toby FPA: add extra Save button (perhaps original should be removed)
(edit) @4892   4 years toby missed inage change; FPA: as per Cline, 5 line (4 w/mono) now default; …
(edit) @4890   4 years vondreele use os.path.dirname(filename) instead of G2G.GetImportPath? for iparm …
(edit) @4889   4 years toby do not change image formatName
(edit) @4888   4 years vondreele define Uani as 1/3 trace of diagonalized U matrix in export cif
(edit) @4887   4 years toby deal with 0 on elem sym; save binary path; support ..._exec in config
(edit) @4886   4 years vondreele fix reference to masked arrays x,yobs.…
(edit) @4885   4 years vondreele insert missing '\' in docs correct Sm154 neutron scattering length …
(edit) @4884   4 years toby add all cell params to CIF when Dij values are used
(edit) @4883   4 years toby CIF multiblock export: set temperature in Phase
(edit) @4882   4 years toby new routine: getCellSU
(edit) @4881   4 years vondreele color nonpositive definita thermal parameters in red in Atom list
(edit) @4880   4 years toby implement constraints in scriptable, part 3; misc docs fixes
(edit) @4879   4 years toby implement constraints in scriptable, part 2
(edit) @4878   4 years toby implement constraints in scriptable, part 1
(edit) @4877   4 years toby fix read w/blank name
(edit) @4876   4 years toby fix cell offsets in CIF export
(edit) @4875   4 years vondreele Add Nvar to Notebook entry for LS refinement result
(edit) @4874   4 years toby fix flag on new file
(edit) @4873   4 years toby add tutorial to index/web page
(edit) @4872   4 years toby export project to giant ASCII file; add CIF tutorial; set misc svn flags
(edit) @4871   4 years toby normalized plotting: reset scale
(edit) @4870   4 years toby problem with limits applied to plotting of wrong histogram; add …
(edit) @4869   4 years toby .Raise() is causing crashes, use only on wx.Dialog or wx.Frame
(edit) @4868   4 years toby fix back print issue + some CIF fixes
(edit) @4867   4 years vondreele fixes to incommensurate structure refinement
(edit) @4866   4 years vondreele monoclinic indexing returns proper reduced cells
(edit) @4865   4 years vondreele fixes to monoclinic A,C,I centered cell indexing (still need to do P) …
(edit) @4864   4 years vondreele proper fix to bond restraint bug
(edit) @4863   4 years vondreele fix 2 bugs in macromolecular restraints
(edit) @4862   4 years vondreele add A-centered monoclinic to list of indexable lattices. Fix a number …
(edit) @4861   4 years toby fix Bob's RB constraint fix
(edit) @4860   4 years vondreele change titles & labels for shift/esd plot since it plots intiial …
(edit) @4859   4 years vondreele use new symmetry constraint scheme in MakeRBParms
(edit) @4858   4 years vondreele undo "fix" to covariance plot y-axis tick labels
(edit) @4857   4 years vondreele Add new button to Covariance page - Show last shift/esd bar plot Add …
(edit) @4856   4 years toby full CIF fixes
(edit) @4855   4 years vondreele Add new option to AtomModify? in G2phsGUI - 'Uij' - converts Uiso to …
Note: See TracRevisionLog for help on using the revision log.
