source: trunk
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Diff Rev Age Author Log Message
(edit) @4098   6 years vondreele speedup of SHAPES
(edit) @4097   6 years vondreele implement a fast version of set_box in G2shapes
(edit) @4096   6 years toby fix broken plot arrow keys; add some debug for where drag of ticks fails
(edit) @4095   6 years vondreele improve dmax estimation - use proper selected weights ditto P(R) …
(edit) @4094   6 years vondreele SHAPES now complete, but slow.
(edit) @4093   6 years toby more work on menu hot keys & ask to save on exit
(edit) @4092   6 years vondreele fix crash when Add Substance is aborted fix plot rescales after …
(edit) @4091   6 years toby delay close process until after update on Linux & Mac
(edit) @4090   6 years vondreele small revision to the absent lines code - works better now
(edit) @4089   6 years vondreele implement an "absent" list for image calibrants - especially Silicon SRM640
(edit) @4088   6 years toby Add scripting peak retrieval & document
(edit) @4087   6 years toby Fix Andrey's bug: remove cell parms for unused phases in seq res table
(edit) @4086   6 years toby Add menu accelerator keys & recently used menu
(edit) @4085   6 years toby Add menu accelerator keys & recently used menu
(edit) @4084   6 years vondreele fixes to SHAPES results table fix remaining plot amnesia problems
(edit) @4083   6 years vondreele
(edit) @4082   6 years vondreele
(edit) @4081   6 years vondreele
(edit) @4080   6 years vondreele fix to ellipsoid size math & GUI revisions
(edit) @4079   6 years vondreele modify SHAPES for better output to GSAS-II begin plotting capability …
(edit) @4078   6 years vondreele some finish uo on SHAPES
(edit) @4077   6 years vondreele add SHAPES capability & all the interface stuff
(edit) @4076   6 years vondreele fix axes amnesia for PDF plots add plotting of P(R) pair distribution …
(edit) @4075   6 years vondreele fixes to import old (e.g. HIPD) TOF date from fxye
(edit) @4074   6 years vondreele fix size/mustrain plots so diameters match coefficients
(edit) @4073   6 years vondreele minor typos & allow import PDB to read no unit cell dummy PDBs from …
(edit) @4072   6 years vondreele fix a missing G2frame.PickId? problem in G2imgGUI fix SAS plotting …
(edit) @4071   6 years vondreele fix bug exporting fxye file for TOF data - can't write iparm file
(edit) @4070   6 years vondreele more cleanup of PWDR plots
(edit) @4069   6 years vondreele bit more cleanup of background subtracted powder pattern plotting
(edit) @4068   6 years vondreele fix bug in CalcBack? when no background file specified
(edit) @4067   6 years vondreele background plotting options now fixed completely for PWDR data.
(edit) @4066   6 years vondreele some fixes to sub. back plots
(edit) @4065   6 years vondreele background plotting stuff (incomplete)
(edit) @4064   6 years vondreele fix background editing; now immediately shows effect on background …
(edit) @4063   6 years vondreele fix triclinic indexing change "Load cell from phase" to "Load Phase"
(edit) @4062   6 years vondreele small fixes to G2plot - make indexed lines 3,3 dashed orange lines, …
(edit) @4061   6 years toby revise PNG files for "libpng warning: iCCP: known incorrect sRGB …
(edit) @4060   6 years toby Work on Index Unit Cell display: narrower, allow dragging limits, add …
(edit) @4059   6 years vondreele IMSF stuff
(edit) @4058   6 years vondreele G2math now has "right" stuff for mag. str. fctr. calc.
(edit) @4057   6 years vondreele tweaks of the mag. str. fctr. code
(edit) @4056   6 years vondreele use config value of default spot size for spot masks
(edit) @4055   6 years vondreele minor changes to incomm. mag. srt. fctr. stuff. Still wrong.
(edit) @4054   6 years vondreele changes to incommensurate magnetism math
(edit) @4053   6 years toby complete multiprocessing & caching of maps; results not yet tested
(edit) @4052   6 years vondreele add option to remove Dysnomia files after it completes
(edit) @4051   6 years vondreele Correct error in PWDR extinction derivatives
(edit) @4050   6 years vondreele include extinction derivative for PWDR data
(edit) @4049   6 years toby better Export error msg
(edit) @4048   6 years vondreele Use extra reflections generated by Dysnomia in forming new Fourier map
(edit) @4047   6 years toby remove reflections if hist dropped from phase
(edit) @4046   6 years toby remove histograms that are not added to a phse from the Seq Ref …
(edit) @4045   6 years toby add autoread of G(r)
(edit) @4044   6 years vondreele remove restriction on doing selective copy of instrument type across …
(edit) @4043   6 years vondreele commented out unneeded block of code about getting CurLims? in lines …
(edit) @4042   6 years toby fix liveplotting in d-space
(edit) @4041   6 years vondreele fix issues with rigid body GUI controls - mostly proper assignment of rbId
(edit) @4040   6 years vondreele put rigid body Xsizers & Osizers into a dict in G2frame to keep them …
(edit) @4039   6 years toby turn off refinement for simulation
(edit) @4038   6 years vondreele set no. cycles to zero for simulated data.
(edit) @4037   6 years toby fix PWDR autoload for older Pythons
(edit) @4036   6 years toby add PWDR autoload
(edit) @4035   6 years vondreele xline & yline masks now correct
(edit) @4034   6 years vondreele implement xline & yline masks to integration - still checking it
(edit) @4033   6 years vondreele line masks now drawn on image
(edit) @4032   6 years vondreele fix 'Resolution' in old gpx to 'GridStep?' fix to bad logical operator …
(edit) @4031   6 years toby introduce external autoInt
(edit) @4030   6 years vondreele fix defaults for ka1-Ka2 powder data to be Bragg-Brentano for both GUI …
(edit) @4028   6 years vondreele fix triclinic indexing problem - leftover from expansion of possible …
(edit) @4027   6 years vondreele fix to non BNS centered magnetic space groups from Bilbao
(edit) @4026   6 years toby printing bugs
(edit) @4025   6 years toby more print filtering
(edit) @4024   6 years toby fix for print w/optional mode arg
(edit) @4023   6 years toby docs formatting
(edit) @4022   6 years toby oops, fix Python2 error
(edit) @4021   6 years toby implement filter for screen messages; start to replace print() with …
(edit) @4020   6 years vondreele comment out sell constraint build for transform & mag structures - …
(edit) @4019   6 years vondreele put directions for delete restraints in status bar; fix bug in G2spc
(edit) @4018   6 years vondreele set default to Bragg-Brentano for dual wavelength source & using …
(edit) @4017   6 years vondreele fix input of saved background parms with peaks
(edit) @4016   6 years vondreele fix problem if magcells True but no list of them (in Unit Cells List) …
(edit) @4015   6 years toby add setHAPvalues to scriptable; disable import G(r) because broken
(edit) @4014   6 years vondreele fix print bug in fourier map calculation
(edit) @4013   6 years vondreele another try at fix for cylindrical texture & single PWDR data
(edit) @4012   6 years vondreele reinstate texture model as possible with single histograms - skip the …
(edit) @4011   6 years toby test if texture is set non-zero w/o appropriate histograms
(edit) @4010   6 years toby add hidden diagnostic plot option (.) to show Y*W
(edit) @4009   6 years toby add convariance to recalibrate all, so esd's are computed properly …
(edit) @4008   6 years toby don't apply invalid plot limits
(edit) @4007   6 years vondreele fix crash on Plot1.set_ylim(CurLims?) when CurLims? is None or NAN?
(edit) @4006   6 years toby fix seq. plot where esd is None
(edit) @4005   6 years toby improve scripting for HAP vars; minor doc changes
(edit) @4004   6 years toby add file for Inst Parms plot
(edit) @4003   6 years toby fix subtle bug in plotCovar where cursor showed only initial vals; add …
(edit) @4002   6 years vondreele finish implementation of generating added reflections for Dysnomia. …
(edit) @4001   6 years toby add SeqRes? section to scriptable; minor docs cleanup; show cell even …
(edit) @4000   6 years vondreele begin adding "unobserved" reflections to Dysnomia input
(edit) @3999   6 years toby reorg PDF computation/save as non-GUI code, add PDF to scriptable, doc …
(edit) @3998   6 years vondreele make use of pgrid files from Dysnomia as prior & restart maps
Note: See TracRevisionLog for help on using the revision log.
