source: trunk
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Diff Rev Age Author Log Message
(edit) @1501   11 years vondreele Change window behavior so that dataFrame is put on top after any tree …
(edit) @1500   11 years vondreele Improve drag/drop - put terse instruction in tree window status bar & …
(edit) @1499   11 years vondreele Drag/drop of tree items now works; one odd bit if trying to drag to …
(edit) @1498   11 years vondreele try to implement drag/drop of tree items - commented out as it doesn't …
(edit) @1496   11 years vondreele Add sequential peak fitting. Change Back:n to Back;n for background …
(edit) @1495   11 years vondreele add warning message (ouch #4) for bad peaks
(edit) @1494   11 years vondreele add traps for bad peak profiles where iBeg > iFin caused crash
(edit) @1493   11 years vondreele set move=True for GenAtom? call for FillUnitCell? show bin width in …
(edit) @1492   11 years vondreele fix import of multiple SNT data sets & assigning them to the phase
(edit) @1491   11 years vondreele DEBUG = False & remove stray print TOF single xtal extinction & …
(edit) @1490   11 years vondreele fix TOF t-bar reference "fix" TOF single xtal extinction?
(edit) @1489   11 years vondreele correct Uij to U6 conversions Uij = Uk/2 for i != j; k > 2 in …
(edit) @1488   11 years toby 64bit mac build on BHT3 (10.6) using …
(edit) @1487   11 years toby 32 bit mac build on BHT3
(edit) @1486   11 years toby minor bugs
(edit) @1485   11 years vondreele remove 1/2 azimuth bin offset done in error.
(edit) @1484   11 years vondreele change lower limit of LGmix to 0 from 0.1 - recompile Win-32 & Win-64 …
(edit) @1483   11 years vondreele fix Export of HKLs from PWDR histograms
(edit) @1482   11 years vondreele change comment about sign of Dij application fix TOF derivatives for …
(edit) @1481   11 years toby reverse sign for application of Dij values
(edit) @1480   11 years vondreele reset mustrain now gives correct SHKL coefficients for a 1000 mustrain …
(edit) @1479   11 years vondreele fix Stephens model for mustrain, fxn & CW derivs are correct
(edit) @1478   11 years vondreele Fix CW & TOF hydrostatic strain calculations & change disply formats …
(edit) @1476   11 years vondreele fix handling of zero powder profile intensities; set w=0. (not 1.)
(edit) @1475   11 years vondreele add MCSA tutorial to main gsasII.html web page change difB tern from …
(edit) @1474   11 years vondreele 1st MC/SA tutorial various MC/SA fixes fix to background peak fitting …
(edit) @1473   11 years toby fix repaint problem; 2.9, mac only?
(edit) @1472   11 years toby fix wx3 bug: no wx.CB_SORT on Mac
(edit) @1471   11 years vondreele fix the Move=True stuff in G2spc.GenAtom? & force molecule centers to …
(edit) @1470   11 years vondreele fix missing 'outChannels' from imtrl files fix bug re missing …
(edit) @1469   11 years vondreele still mixed up
(edit) @1468   11 years vondreele whoops wrong file
(edit) @1467   11 years vondreele Add MCSA example files
(edit) @1466   11 years vondreele make extinction math use FcTsq? not Fcsq fix 3D HKL point lighting fix …
(edit) @1465   11 years vondreele added mod to ImageIntegrate? requested by Steven Weigand - return NST …
(edit) @1464   11 years vondreele change sig-q & beta-q functionality to be 1/d2 - seems to work better
(edit) @1463   11 years vondreele fix motion position in q & d plots
(edit) @1462   11 years vondreele add sig-2 to TOF profile coeff. new d-spacing plot option
(edit) @1461   11 years vondreele modify xye import to not divide by CW (channel width)for TOF data. NB: …
(edit) @1460   11 years vondreele fix missing radius Factor for MC/SA plots add Prfo, Abs & xt to …
(edit) @1459   11 years vondreele add instrument parameters (flight path & detector 2-theta) needed for …
(edit) @1456   11 years vondreele consolidate HKLF parts of dervRefine & HessRefine? into new routine dervHKLF
(edit) @1455   11 years vondreele fix ddata copy flags so it copies extinction models as well as refine …
(edit) @1454   11 years vondreele corrections to SC extinction - now better
(edit) @1453   11 years vondreele get HKLF data type into RefDict? create a SetDefaultDData routine in …
(edit) @1452   11 years toby fix bug that shows up in numpy 1.8
(edit) @1451   11 years toby Cleanup Instrument Parms bug due to reformat of peak list
(edit) @1450   11 years toby minor cleanups of Phase GUI
(edit) @1449   11 years toby print pillow version
(edit) @1448   11 years toby quick wx2.9+ fixes
(edit) @1447   11 years toby address strange EPD7.3.2 bug with : in float formatting
(edit) @1446   11 years vondreele add new import routine for JANA2000 single xtal files from ISIS
(edit) @1445   11 years vondreele add error bars to calibration plot disable Autosearch if peaks already …
(edit) @1444   11 years toby update 32-bit mac binaries (from Aug 2013)
(edit) @1443   11 years vondreele add calibration of lam, difC, etc. from index peak positions new …
(edit) @1442   11 years vondreele Add 3D plotting for structure factors for both HKLF & PWDR
(edit) @1441   11 years vondreele include option to plot unit structure factors (equal circles)
(edit) @1440   11 years vondreele missing stuff in Fit peaks tutorial & add comment about Show hkl positions.
(edit) @1439   11 years vondreele add difB as a term in d3 for TOF - trial a patch for old files for …
(edit) @1438   11 years vondreele missed the code for the Alt key fix
(edit) @1437   11 years vondreele try again
(edit) @1436   11 years vondreele new binaries
(edit) @1435   11 years vondreele modify comments about use of Alt key
(edit) @1434   11 years vondreele fix properties
(edit) @1433   11 years vondreele fix?
(edit) @1432   11 years vondreele fix?
(edit) @1431   11 years vondreele add new files
(edit) @1430   11 years vondreele remove old files
(edit) @1429   11 years vondreele put in new parametric fit files
(edit) @1428   11 years vondreele fixes to element stuff cleanout old parametric fitting files
(edit) @1427   11 years vondreele revised tutorial
(edit) @1426   11 years vondreele new stress/strain tutorial
(edit) @1425   11 years vondreele still more tutorial cleanup
(edit) @1424   11 years vondreele more tutorial cleanup
(edit) @1423   11 years vondreele remove old tutorials
(edit) @1422   11 years vondreele update Calib area det tutorial
(edit) @1421   11 years vondreele add missing figures
(edit) @1420   11 years vondreele fix plot error with sqrt fix image use default problem with detdepth …
(edit) @1419   11 years vondreele stop copy of threshold masks from one image to another
(edit) @1418   11 years vondreele fix HKLF imports for mmcif data fix some nDig entries for …
(edit) @1417   11 years vondreele missed a couple of lines
(edit) @1416   11 years vondreele fix wx c++ error in Constraints after a Refine
(edit) @1415   11 years vondreele fixed errors in G2strIO: missing exclude of 'Source' for Iparm I/O …
(edit) @1414   11 years toby Add use column to sequential fitting; remove unused points from fit
(edit) @1413   11 years toby Add config support; default expressions
(edit) @1412   11 years vondreele fix theta vs 2-theta error in peak fitting; gave wrong sig,gam vs …
(edit) @1411   11 years vondreele remove unused reference to z-matrix RBs noted in comment about …
(edit) @1410   11 years toby fix number formatting in FormatValue? to be closer to Fortran, but …
(edit) @1409   11 years toby more problems with older GPX files
(edit) @1408   11 years toby now really fix Mike's problem
(edit) @1407   11 years vondreele implement copy equation in parametric stuff
(edit) @1406   11 years toby bug fix for older GPX files with tuples in instrument parameters
(edit) @1405   11 years vondreele fix strain math - remove extra tan(theta) term now [111] & [222] match
(edit) @1404   11 years toby Add edit single value for Inst & Sample prms; new Select1Var dialog
(edit) @1403   11 years vondreele allow renaming of multiple columns in seq refinement results allow …
(edit) @1402   11 years vondreele make pseudovariables work for strain seq. results fix Pos2dsp for TOF …
(edit) @1401   11 years vondreele trap keystrokes for powder plots when data window not on powder info.
(edit) @1400   11 years toby validatedtextcrtl fixes; add checkbox to scrolledmultieditor; print …
(edit) @1399   11 years vondreele allow D (&T) for hydrogen atom types allow ge* for image extensions …
(edit) @1398   11 years toby add event.Skip to focus event handler, as per recommendation from Robin
Note: See TracRevisionLog for help on using the revision log.
