source: trunk
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Diff Rev Age Author Log Message
(edit) @4822   8 months toby Warn if param limits on constrained vars
(edit) @4821   8 months toby new peakfit mode in scripting: allow peak width terms to remain …
(edit) @4820   8 months vondreele remove masks from argument list for MakeGainMap? - not used Tweak gain …
(edit) @4819   8 months toby seq ref: fix & edit phase vars for 1 hist; spyder conveniences; …
(edit) @4818   8 months vondreele Add new routine RBsymCheck to G2lat - it checks RB atom positions for …
(edit) @4817   8 months vondreele fix a contour level bug - crash when there isn't any
(edit) @4816   8 months vondreele fix crash in RepaintRBInfo for Vector RBs
(edit) @4815   8 months vondreele fix problem of shifting RB origin; changed atom fractions!
(edit) @4814   8 months toby Add 'V' option (vector only) for rigid body fitting -- cleanup
(edit) @4813   8 months toby Add 'V' option (vector only) for rigid body fitting
(edit) @4812   8 months vondreele Add Cycle XYZ button on residue RB GUI & add description to help text …
(edit) @4811   8 months toby more wx4.1 & help button fixes; fix OnLeave? if called when a window is …
(edit) @4810   8 months vondreele fix depreciation warning in G2indx.findMV fix numpy round bug in …
(edit) @4809   8 months toby display more Residue rigid body info; better docs
(edit) @4808   8 months vondreele Correct values in Compton table as pointed out by Laszlo Temleitner.
(edit) @4807   8 months vondreele improvement to excluded region operation - now will immediately …
(edit) @4806   8 months vondreele remove bigSizer from UpdatePWHKPlot - use mainSizer = vertical box …
(edit) @4805   8 months toby start replacing dataWindow.GetSizer? with .SetSizer? since Sizer could …
(edit) @4804   8 months toby fix change in MPL posy & posx to nonpositive
(edit) @4803   8 months toby don't reuse dataWindow sizer for background or PWDR; plotting: reset f …
(edit) @4802   8 months vondreele upon integration add Dark, Background & Gain map info to Comments
(edit) @4801   8 months toby Cleanup deleted hists in Phase/data; improve help button location; …
(edit) @4800   9 months toby finish up docs cleanups
(edit) @4799   9 months toby work on docs
(edit) @4798   9 months toby work on docs
(edit) @4797   9 months toby work on docs
(edit) @4796   9 months vondreele patch for missing 'Gain map' data item
(edit) @4795   9 months toby work on docs
(edit) @4794   9 months toby work on docs
(edit) @4793   9 months toby work on docs
(edit) @4792   9 months toby check in changes to allow cctbx to use DoIndexPeaks and !refinePeaks
(edit) @4791   9 months toby docs chapter numbering
(edit) @4790   9 months vondreele fix aspect for hkl plots - reflections now circles independent of …
(edit) @4789   9 months toby switch to new HessianLSQ; Ouch#4 msg in GUI; misc wx4.1 fixes; docs …
(edit) @4788   9 months vondreele a bit more cleanup of toolbar
(edit) @4787   9 months vondreele cleanup of toolbar handling - for mpl 3.3.2 at least. remove …
(edit) @4786   9 months vondreele use set_box_aspect to make 3D plot scales correct. one in four places. …
(edit) @4785   9 months toby new table for text w/sorting
(edit) @4784   9 months toby more help prose
(edit) @4783   9 months toby wx4.1 updates; new CIF data item; scripting: peak fit details …
(edit) @4782   9 months toby scripting fix; wx4.1 RB fixes
(edit) @4781   9 months vondreele 2D map contouring now fixed for matplotlib 3.3.2 - should work for …
(edit) @4780   9 months toby separate hard & SVD singularities, new code in GSASIImath_new.py not …
(edit) @4770   9 months vondreele reinstitute final call to Hess after convergence - required for proper esds
(edit) @4767   9 months vondreele comment out recalculatin if LS matrix after convergence - faster LS …
(edit) @4766   9 months vondreele modify atom labeling routine to allow specified offset as wx.RealPoint?
(edit) @4765   9 months toby MPL 3.3.x fix; scripting docs
(edit) @4764   9 months toby HessianLSQ: force vars to float; small wx 4.1 fixes; scriptable: more …
(edit) @4763   9 months vondreele cleanup tif import for PIL use - remove commented lines move …
(edit) @4762   9 months vondreele fix TIF importer for bad images that use PIL/pillow instead.
(edit) @4761   9 months toby refinements with no variables or no cycles
(edit) @4760   9 months toby fix zero cycle bug
(edit) @4759   9 months toby wx4.1 & mpl3.3 fixes
(edit) @4756   9 months toby more mac work
(edit) @4754   9 months toby new approach for MacOS AppleScripting?
(edit) @4752   9 months vondreele add scattering density to status bar when P/N are selected for …
(edit) @4749   9 months toby fine-tune Mac installer for 11.0
(edit) @4741   9 months toby deal with install python not matching target system
(edit) @4740   9 months toby more install work
(edit) @4736   9 months toby more install work
(edit) @4735   9 months vondreele reduce printed precision of bon valence sum from 3 to 2. connect +/- …
(edit) @4733   9 months toby add placeholder
(edit) @4732   9 months toby workarounds for missing files
(edit) @4731   9 months toby add file to binary directories so that conda-build keeps them
(edit) @4725   9 months toby add ScriptEditor? save to makeMacApp
(edit) @4724   9 months toby add Big Sur patch for OpenGL.GL bug
(edit) @4723   9 months vondreele add automatic valence bond sum calculator to dist/angle calculator in …
(edit) @4720   10 months vondreele trimmed some plot k-box commands; they blocked the 2nd status line box
(edit) @4719   10 months vondreele add number/cell to site fraction apportion routine
(edit) @4717   10 months toby remove mpl 3.3 warning
(edit) @4713   10 months toby more installer work; xmgrace enhance from Carlo
(edit) @4712   10 months vondreele fix plotting of image limit ellipses - wrong call (GetDetectorXY) …
(edit) @4711   10 months toby remove fellipse, not used for a long time
(edit) @4709   10 months vondreele new (BT mostly) version of HessianLSQ & additions; fix nan problem in …
(edit) @4699   10 months toby improve refinement warnings
(edit) @4698   10 months vondreele forgot the 'color' change for gain map
(edit) @4697   10 months vondreele move superminusone definition to header block in G2pwdrGUI replace …
(edit) @4695   10 months toby back out zero xfer
(edit) @4694   10 months toby Cell test: update reflection positions after zero or Bravais change
(edit) @4693   10 months toby updates to math_new after testing; improve output
(edit) @4692   10 months vondreele improve gain map calc - more steps for integration step
(edit) @4691   10 months toby major updates to trial version of HessianLSQ
(edit) @4690   10 months toby major updates to trial version of HessianLSQ
(edit) @4689   10 months vondreele fix formatting issues on Covariance tab
(edit) @4688   10 months toby correct setting of singular vars in old HessianLSQ
(edit) @4687   10 months toby Add e key for excluded region creation; switch to hist in tree after m …
(edit) @4686   10 months vondreele fix bug in fix background file handling
(edit) @4685   10 months vondreele Add gain map calculator
(edit) @4683   10 months toby include trial version of G2math with reworked HessianLSQ
(edit) @4682   10 months toby improve refinement messages; help info
(edit) @4681   10 months toby density format corrected
(edit) @4680   10 months toby add UTF to config.py; covariance: add reduced Chi2 & help button; …
(edit) @4674   10 months vondreele fix background fitting from fixed points - now will also fir fixed …
(edit) @4672   10 months vondreele remove all wx.ALIGN from wx Add with wx.EXPAND - invalid combination …
(edit) @4671   10 months vondreele add refinable multiplier for a fixed background; multiplier is now …
(edit) @4670   11 months vondreele change Tc-98 to Tc-99
(edit) @4669   11 months vondreele Add '?' help button to upper right for phase tabs General, etc.
(edit) @4668   11 months toby updates to refinement options
(edit) @4667   11 months vondreele Add '?' help button to upper right hand corner of various PWDR data …
(edit) @4666   11 months vondreele Add output of resonant neutron scattering lengths for CW powder & …
Note: See TracRevisionLog for help on using the revision log.
