# ChangeLog for trunk
# Generated by Trac 1.0.13
# Jun 17, 2025 10:09:13 AM
Mon, 15 Mar 2021 19:51:46 GMT vondreele [4853]
	* trunk/GSASIIstrIO.py (modified)
	* trunk/GSASIIstrMath.py (modified)
	fix to development of Uij constraints for atoms on 3 folds; lines ...
Fri, 12 Mar 2021 18:35:11 GMT vondreele [4852]
	* trunk/GSASIIctrlGUI.py (modified)
	* trunk/GSASIIdataGUI.py (modified)
	* trunk/GSASIImapvars.py (modified)
	clarify text about constraints in ShowLSParms
	put a wx.Raise in for ...
Fri, 12 Mar 2021 02:35:23 GMT toby [4851]
	* trunk/GSASIIconstrGUI.py (modified)
	reformat equivalence pairs as Bob prefers
Thu, 11 Mar 2021 17:32:08 GMT vondreele [4850]
	* trunk/GSASIIplot.py (modified)
	* trunk/GSASIIstrMain.py (modified)
	* trunk/testSytSym.py (added)
	fix LeBail test to skip HKLF histograms in G2strMain
	fix DBW access ...
Thu, 11 Mar 2021 03:07:37 GMT toby [4849]
	* trunk/GSASIIphsGUI.py (modified)
	apply symmetry constraints on rigid body origin; show position vars ...
Tue, 09 Mar 2021 18:43:26 GMT vondreele [4848]
	* trunk/GSASIIpwdGUI.py (modified)
	implement the show/hide systematic absences in single crystal ...
Tue, 09 Mar 2021 14:34:13 GMT vondreele [4847]
	* trunk/imports/G2sfact.py (modified)
	Add (TBD) hide/showtoggle for single crystal systematic extinctions ...
Mon, 08 Mar 2021 23:05:59 GMT toby [4846]
	* trunk/GSASIIddataGUI.py (modified)
	* trunk/makeTutorial.py (modified)
	save GPX before OnFileSave
Mon, 08 Mar 2021 19:02:40 GMT toby [4845]
	* trunk/help/Tutorials.html (modified)
	Tutorial !#50 now in web page
Mon, 08 Mar 2021 18:34:29 GMT toby [4844]
	* Tutorials/LeBail (added)
	* Tutorials/LeBail/LeBailSucrose.fld (added)
	* Tutorials/LeBail/LeBailSucrose.fld/colorschememapping.xml (added)
	* Tutorials/LeBail/LeBailSucrose.fld/filelist.xml (added)
	* Tutorials/LeBail/LeBailSucrose.fld/image002.png (added)
	* Tutorials/LeBail/LeBailSucrose.fld/image005.png (added)
	* Tutorials/LeBail/LeBailSucrose.fld/image006.png (added)
	* Tutorials/LeBail/LeBailSucrose.fld/image007.png (added)
	* Tutorials/LeBail/LeBailSucrose.fld/image008.png (added)
	* Tutorials/LeBail/LeBailSucrose.fld/image009.png (added)
	* Tutorials/LeBail/LeBailSucrose.fld/image010.png (added)
	* Tutorials/LeBail/LeBailSucrose.fld/image011.png (added)
	* Tutorials/LeBail/LeBailSucrose.fld/image012.png (added)
	* Tutorials/LeBail/LeBailSucrose.fld/image013.png (added)
	* Tutorials/LeBail/LeBailSucrose.fld/image014.png (added)
	* Tutorials/LeBail/LeBailSucrose.fld/themedata.thmx (added)
	* Tutorials/LeBail/LeBailSucrose.htm (added)
	* Tutorials/LeBail/data (added)
	* Tutorials/LeBail/data/11bmb_8716.fxye (added)
	* Tutorials/LeBail/data/11bmb_8716.prm (added)
	* Tutorials/LeBail/data/start.gpx (added)
	Le Bail tutorial; pretty up tutorial table
Sun, 07 Mar 2021 23:46:32 GMT toby [4843]
	fix Le Bail issues: LB before refinement; bug for combined fits; ...
Sun, 07 Mar 2021 17:35:19 GMT toby [4842]
	fix Refine Cell enable after cell copy; misc wx4.1 fixes
Sat, 06 Mar 2021 17:23:19 GMT toby [4841]
	fix bind problem w/Sequential plots; open sequential fit tree item on ...
Fri, 05 Mar 2021 19:54:34 GMT toby [4840]
	* trunk/GSASIImath.py (modified)
	LeBail issues: bug on zero cycles fixed; new LeBail fit menu item; ...
Thu, 04 Mar 2021 18:42:09 GMT vondreele [4839]
	change formatting for scale/phase fraction in G2ddataGUI & G2strIO ...
Thu, 04 Mar 2021 00:17:59 GMT vondreele [4838]
	comment out MakeDrawAtom in G2constrGUI & make the call to ...
Wed, 03 Mar 2021 21:02:07 GMT vondreele [4837]
	* trunk/fprime.py (modified)
	change line styles in fprme f' & f" plot.
	add a Raise for the ...
Tue, 02 Mar 2021 21:54:39 GMT vondreele [4836]
	Change status bar to show useful message about right click when ...
Mon, 01 Mar 2021 22:53:48 GMT toby [4835]
	* trunk/GSASIIseqGUI.py (modified)
	fix tick animation with weight (w) plot; unable to fix seq plot ...
Mon, 01 Mar 2021 15:49:38 GMT vondreele [4834]
	* trunk/GSASIIobj.py (modified)
	change 'RBf' to 'RBVf' & 'RBRf' as appropriate.
Mon, 01 Mar 2021 14:32:50 GMT toby [4833]
	* trunk/GSASIIseqGUI.py (added)
	* trunk/docs/source/GSASIIGUI.rst (modified)
	* trunk/help/gsasII.html (modified)
	popup menu for GSGrids; split off sequential display; rename File ...
Mon, 01 Mar 2021 14:31:47 GMT vondreele [4832]
	* trunk/GSASIIimage.py (modified)
	* trunk/imports/G2phase_CIF.py (modified)
	fix gaim map calc to include cylindrical sample absorption
	fix phase ...
Sat, 27 Feb 2021 17:59:43 GMT vondreele [4831]
	Fix SHELX hkl importer to deal with 3 digit hkls
Fri, 26 Feb 2021 22:49:53 GMT vondreele [4830]
	* trunk/Absorb.py (modified)
	* trunk/GSASIIimgGUI.py (modified)
	* trunk/GSASIIpwd.py (modified)
	show more places in Absorb output
	improve image absorption calcs for ...
Thu, 25 Feb 2021 23:16:59 GMT toby [4829]
	minor bugs: site sym for wrong RB; GUI stuff; force RB edit before ...
Wed, 24 Feb 2021 19:03:50 GMT vondreele [4828]
	another fix to delete vector RB
Wed, 24 Feb 2021 18:20:42 GMT vondreele [4827]
	fix bug deleting vector RB
Tue, 23 Feb 2021 21:34:12 GMT vondreele [4826]
	* trunk/GSASIIlattice.py (modified)
	fix PDF GUI stuff  transmission as percent, plot limits for g(r)
	fix ...
Tue, 23 Feb 2021 19:57:49 GMT toby [4825]
	remove unused & deleted hists from seq ref; option to remove hists ...
Sat, 20 Feb 2021 20:44:46 GMT vondreele [4824]
	add new refinable RB parameter for atom site fraction - always there; ...
Sat, 20 Feb 2021 19:25:23 GMT toby [4823]
	fix naming of new variable constraints; label them & improve ...
Sat, 20 Feb 2021 15:43:32 GMT toby [4822]
	Warn if param limits on constrained vars
Fri, 19 Feb 2021 20:24:19 GMT toby [4821]
	* trunk/GSASIIscriptable.py (modified)
	new peakfit mode in scripting: allow peak width terms to remain ...
Wed, 17 Feb 2021 21:05:30 GMT vondreele [4820]
	remove masks from argument list for MakeGainMap - not used
	Tweak ...
Wed, 17 Feb 2021 18:52:34 GMT toby [4819]
	seq ref: fix & edit phase vars for 1 hist; spyder conveniences; ...
Tue, 16 Feb 2021 21:17:35 GMT vondreele [4818]
	Add new routine RBsymCheck to G2lat - it checks RB atom positions for ...
Sun, 14 Feb 2021 17:16:10 GMT vondreele [4817]
	fix a contour level bug - crash when there isn't any
Sat, 13 Feb 2021 16:12:59 GMT vondreele [4816]
	fix crash in RepaintRBInfo for Vector RBs
Sat, 13 Feb 2021 15:41:56 GMT vondreele [4815]
	fix problem of shifting RB origin; changed atom fractions!
Sat, 13 Feb 2021 02:29:48 GMT toby [4814]
	Add 'V' option (vector only) for rigid body fitting -- cleanup
Fri, 12 Feb 2021 21:11:08 GMT toby [4813]
Fri, 12 Feb 2021 19:58:06 GMT vondreele [4812]
	Add Cycle XYZ button on residue RB GUI & add description to help text ...
Fri, 12 Feb 2021 16:59:21 GMT toby [4811]
	more wx4.1 & help button fixes; fix OnLeave if called when a window ...
Fri, 12 Feb 2021 15:51:39 GMT vondreele [4810]
	* trunk/GSASIIindex.py (modified)
	* trunk/GSASIIspc.py (modified)
	fix depreciation warning in G2indx.findMV
	fix numpy round bug in ...
Wed, 10 Feb 2021 21:49:46 GMT toby [4809]
	display more Residue rigid body info; better docs
Wed, 10 Feb 2021 18:26:29 GMT vondreele [4808]
	* trunk/FormFactors.py (modified)
	Correct values in Compton table as pointed out by Laszlo Temleitner.
Tue, 09 Feb 2021 16:29:39 GMT vondreele [4807]
	improvement to excluded region operation - now will immediately ...
Mon, 08 Feb 2021 21:32:39 GMT vondreele [4806]
	remove bigSizer from UpdatePWHKPlot - use mainSizer = vertical box ...
Mon, 08 Feb 2021 20:37:16 GMT toby [4805]
	* trunk/G2compare.py (modified)
	start replacing dataWindow.GetSizer with .SetSizer since Sizer could ...
Mon, 08 Feb 2021 02:03:04 GMT toby [4804]
	fix change in MPL posy & posx to nonpositive
Mon, 08 Feb 2021 01:35:35 GMT toby [4803]
	don't reuse dataWindow sizer for background or PWDR; plotting: reset ...
Sat, 06 Feb 2021 16:39:39 GMT vondreele [4802]
	* trunk/GSASIIIO.py (modified)
	upon integration add Dark, Background & Gain map info to Comments
Sat, 06 Feb 2021 04:14:23 GMT toby [4801]
	Cleanup deleted hists in Phase/data; improve help button location; ...
Wed, 03 Feb 2021 17:50:38 GMT toby [4800]
	* trunk/GSASII.py (modified)
	* trunk/GSASIIlog.py (modified)
	* trunk/GSASIImpsubs.py (modified)
	* trunk/ReadMarCCDFrame.py (modified)
	* trunk/docs/source/GSASIIGUIr.rst (modified)
	* trunk/docs/source/GSASIIutil.rst (modified)
	finish up docs cleanups
Wed, 03 Feb 2021 17:25:36 GMT toby [4799]
	work on docs
Wed, 03 Feb 2021 17:13:40 GMT toby [4798]
	work on docs
Wed, 03 Feb 2021 17:05:41 GMT toby [4797]
	work on docs
Wed, 03 Feb 2021 16:59:11 GMT vondreele [4796]
	patch for missing 'Gain map' data item
Wed, 03 Feb 2021 16:54:16 GMT toby [4795]
	work on docs
Wed, 03 Feb 2021 16:45:21 GMT toby [4794]
	work on docs
Wed, 03 Feb 2021 16:32:14 GMT toby [4793]
	* trunk/docs/source/index.rst (modified)
	work on docs
Tue, 02 Feb 2021 17:01:51 GMT toby [4792]
	check in changes to allow cctbx to use !DoIndexPeaks and !refinePeaks
Tue, 02 Feb 2021 15:37:33 GMT toby [4791]
	* trunk/docs/source/indices.rst (added)
	docs chapter numbering
Mon, 01 Feb 2021 23:06:20 GMT vondreele [4790]
	fix aspect for hkl plots - reflections now circles independent of ...
Mon, 01 Feb 2021 19:36:50 GMT toby [4789]
	* trunk/GSASIImath_new.py (deleted)
	switch to new HessianLSQ; Ouch#4 msg in GUI; misc wx4.1 fixes; docs ...
Sun, 31 Jan 2021 19:31:58 GMT vondreele [4788]
	a bit more cleanup of toolbar
Sat, 30 Jan 2021 00:14:00 GMT vondreele [4787]
	cleanup of toolbar handling - for mpl 3.3.2 at least. remove ...
Thu, 28 Jan 2021 19:05:18 GMT vondreele [4786]
	use set_box_aspect to make 3D plot scales correct. one in four ...
Wed, 27 Jan 2021 21:27:25 GMT toby [4785]
	new table for text w/sorting
Tue, 26 Jan 2021 22:54:52 GMT toby [4784]
	more help prose
Tue, 26 Jan 2021 18:48:52 GMT toby [4783]
	* trunk/exports/G2export_CIF.py (modified)
	wx4.1 updates; new CIF data item; scripting: peak fit details ...
Wed, 20 Jan 2021 20:35:12 GMT toby [4782]
	scripting fix; wx4.1 RB fixes
Tue, 19 Jan 2021 17:34:26 GMT vondreele [4781]
	2D map contouring now fixed for matplotlib 3.3.2 - should work for ...
Sun, 17 Jan 2021 21:12:29 GMT toby [4780]
	* trunk/GSASIImath_new.py (modified)
	separate hard & SVD singularities, new code in GSASIImath_new.py not ...
Sat, 16 Jan 2021 16:16:55 GMT vondreele [4770]
	reinstitute final call to Hess after convergence - required for ...
Thu, 14 Jan 2021 20:10:10 GMT vondreele [4767]
	comment out recalculatin if LS matrix after convergence - faster LS ...
Thu, 14 Jan 2021 17:15:32 GMT vondreele [4766]
	* trunk/gltext.py (modified)
	modify atom labeling routine to allow specified offset as ...
Thu, 14 Jan 2021 04:44:23 GMT toby [4765]
	MPL 3.3.x fix; scripting docs
Thu, 14 Jan 2021 03:42:03 GMT toby [4764]
	HessianLSQ: force vars to float; small wx 4.1 fixes; scriptable: more ...
Wed, 13 Jan 2021 22:34:34 GMT vondreele [4763]
	* trunk/imports/G2img_1TIF.py (modified)
	cleanup tif import for PIL use - remove commented lines
	move ...
Tue, 12 Jan 2021 18:47:56 GMT vondreele [4762]
	fix TIF importer for bad images that use PIL/pillow instead.
Mon, 11 Jan 2021 19:57:49 GMT toby [4761]
	refinements with no variables or no cycles
Mon, 11 Jan 2021 15:15:15 GMT toby [4760]
	fix zero cycle bug
Sun, 10 Jan 2021 23:12:01 GMT toby [4759]
	* install/g2full/g2postinstall.sh.template (modified)
	* install/setversion.py (modified)
	* trunk/GSASIIrestrGUI.py (modified)
	wx4.1 & mpl3.3 fixes
Sun, 10 Jan 2021 03:32:48 GMT toby [4756]
	* trunk/g2app.tar.gz (modified)
	* trunk/makeMacApp.py (modified)
	more mac work
Sun, 10 Jan 2021 01:34:21 GMT toby [4754]
	* trunk/g2app.tar.gz (added)
	new approach for MacOS AppleScripting
Sat, 09 Jan 2021 14:55:00 GMT vondreele [4752]
	add scattering density to status bar when P/N are selected for ...
Fri, 08 Jan 2021 21:34:01 GMT toby [4749]
	* install/g2full/g2postinstall.sh (modified)
	* install/g2full/g2postinstall.sh.template (added)
	fine-tune Mac installer for 11.0
Fri, 08 Jan 2021 00:06:12 GMT toby [4741]
	* install/bootstrap.py (modified)
	* install/g2complete/build.sh.template (modified)
	* trunk/GSASIIpath.py (modified)
	deal with install python not matching target system
Thu, 07 Jan 2021 23:22:35 GMT toby [4740]
	* install/g2complete/post-link.sh (modified)
	more install work
Thu, 07 Jan 2021 21:53:49 GMT toby [4736]
	* install/g2complete/src/bootstrap.py (modified)
	* trunk/makeLinux.py (modified)
	more install work
Thu, 07 Jan 2021 17:21:15 GMT vondreele [4735]
	reduce printed precision of bon valence sum from 3 to 2.
	connect +/- ...
Thu, 07 Jan 2021 05:19:21 GMT toby [4733]
	* trunk/bindist/emptydir.txt (added)
	add placeholder
Thu, 07 Jan 2021 05:13:16 GMT toby [4732]
	* install (modified)
	* install/g2pkg/src/bootstrap.py (modified)
	workarounds for missing files
Thu, 07 Jan 2021 04:57:11 GMT toby [4731]
	* Binaries/mac_64_p3.7_n1.18/emptydir.txt (added)
	* trunk/AllBinaries/emptydir.txt (added)
	add file to binary directories so that conda-build keeps them
Wed, 06 Jan 2021 21:34:14 GMT toby [4725]
	add ScriptEditor save to makeMacApp
Wed, 06 Jan 2021 16:43:56 GMT toby [4724]
	add Big Sur patch for OpenGL.GL bug
Tue, 05 Jan 2021 22:22:19 GMT vondreele [4723]
	* trunk/atmdata.py (modified)
	add automatic valence bond sum calculator to dist/angle calculator in ...
Tue, 05 Jan 2021 18:36:05 GMT vondreele [4720]
	trimmed some plot k-box commands; they blocked the 2nd status line
	box
Tue, 05 Jan 2021 15:28:53 GMT vondreele [4719]
	add number/cell to site fraction apportion routine
