# ChangeLog for trunk
# Generated by Trac 1.0.13
# Jul 4, 2025 11:55:33 AM
Fri, 19 Feb 2021 20:24:19 GMT toby [4821]
	* trunk/GSASIIpwd.py (modified)
	* trunk/GSASIIscriptable.py (modified)
	new peakfit mode in scripting: allow peak width terms to remain ...
Wed, 17 Feb 2021 21:05:30 GMT vondreele [4820]
	* trunk/GSASIIimage.py (modified)
	* trunk/GSASIIimgGUI.py (modified)
	* trunk/GSASIIphsGUI.py (modified)
	* trunk/GSASIIplot.py (modified)
	remove masks from argument list for MakeGainMap - not used
	Tweak ...
Wed, 17 Feb 2021 18:52:34 GMT toby [4819]
	* trunk/GSASIIctrlGUI.py (modified)
	* trunk/GSASIIdataGUI.py (modified)
	* trunk/GSASIIddataGUI.py (modified)
	* trunk/GSASIImath.py (modified)
	* trunk/GSASIIpwdGUI.py (modified)
	* trunk/GSASIIstrMain.py (modified)
	seq ref: fix & edit phase vars for 1 hist; spyder conveniences; ...
Tue, 16 Feb 2021 21:17:35 GMT vondreele [4818]
	* trunk/GSASIIlattice.py (modified)
	Add new routine RBsymCheck to G2lat - it checks RB atom positions for ...
Sun, 14 Feb 2021 17:16:10 GMT vondreele [4817]
	fix a contour level bug - crash when there isn't any
Sat, 13 Feb 2021 16:12:59 GMT vondreele [4816]
	fix crash in RepaintRBInfo for Vector RBs
Sat, 13 Feb 2021 15:41:56 GMT vondreele [4815]
	fix problem of shifting RB origin; changed atom fractions!
Sat, 13 Feb 2021 02:29:48 GMT toby [4814]
	* trunk/GSASIIstrIO.py (modified)
	Add 'V' option (vector only) for rigid body fitting -- cleanup
Fri, 12 Feb 2021 21:11:08 GMT toby [4813]
Fri, 12 Feb 2021 19:58:06 GMT vondreele [4812]
	* trunk/GSASIIconstrGUI.py (modified)
	Add Cycle XYZ button on residue RB GUI & add description to help text ...
Fri, 12 Feb 2021 16:59:21 GMT toby [4811]
	more wx4.1 & help button fixes; fix OnLeave if called when a window ...
Fri, 12 Feb 2021 15:51:39 GMT vondreele [4810]
	* trunk/GSASIIindex.py (modified)
	* trunk/GSASIIspc.py (modified)
	fix depreciation warning in G2indx.findMV
	fix numpy round bug in ...
Wed, 10 Feb 2021 21:49:46 GMT toby [4809]
	* trunk/GSASIIobj.py (modified)
	display more Residue rigid body info; better docs
Wed, 10 Feb 2021 18:26:29 GMT vondreele [4808]
	* trunk/FormFactors.py (modified)
	Correct values in Compton table as pointed out by Laszlo Temleitner.
Tue, 09 Feb 2021 16:29:39 GMT vondreele [4807]
	improvement to excluded region operation - now will immediately ...
Mon, 08 Feb 2021 21:32:39 GMT vondreele [4806]
	remove bigSizer from UpdatePWHKPlot - use mainSizer = vertical box ...
Mon, 08 Feb 2021 20:37:16 GMT toby [4805]
	* trunk/G2compare.py (modified)
	start replacing dataWindow.GetSizer with .SetSizer since Sizer could ...
Mon, 08 Feb 2021 02:03:04 GMT toby [4804]
	fix change in MPL posy & posx to nonpositive
Mon, 08 Feb 2021 01:35:35 GMT toby [4803]
	don't reuse dataWindow sizer for background or PWDR; plotting: reset ...
Sat, 06 Feb 2021 16:39:39 GMT vondreele [4802]
	* trunk/GSASIIIO.py (modified)
	upon integration add Dark, Background & Gain map info to Comments
Sat, 06 Feb 2021 04:14:23 GMT toby [4801]
	Cleanup deleted hists in Phase/data; improve help button location; ...
Wed, 03 Feb 2021 17:50:38 GMT toby [4800]
	* trunk/GSASII.py (modified)
	* trunk/GSASIIlog.py (modified)
	* trunk/GSASIImpsubs.py (modified)
	* trunk/ReadMarCCDFrame.py (modified)
	* trunk/docs/source/GSASIIGUIr.rst (modified)
	* trunk/docs/source/GSASIIutil.rst (modified)
	finish up docs cleanups
Wed, 03 Feb 2021 17:25:36 GMT toby [4799]
	work on docs
Wed, 03 Feb 2021 17:13:40 GMT toby [4798]
	work on docs
Wed, 03 Feb 2021 17:05:41 GMT toby [4797]
	work on docs
Wed, 03 Feb 2021 16:59:11 GMT vondreele [4796]
	patch for missing 'Gain map' data item
Wed, 03 Feb 2021 16:54:16 GMT toby [4795]
	work on docs
Wed, 03 Feb 2021 16:45:21 GMT toby [4794]
	work on docs
Wed, 03 Feb 2021 16:32:14 GMT toby [4793]
	* trunk/docs/source/index.rst (modified)
	work on docs
Tue, 02 Feb 2021 17:01:51 GMT toby [4792]
	check in changes to allow cctbx to use !DoIndexPeaks and !refinePeaks
Tue, 02 Feb 2021 15:37:33 GMT toby [4791]
	* trunk/docs/source/indices.rst (added)
	docs chapter numbering
Mon, 01 Feb 2021 23:06:20 GMT vondreele [4790]
	fix aspect for hkl plots - reflections now circles independent of ...
Mon, 01 Feb 2021 19:36:50 GMT toby [4789]
	* trunk/GSASIImath_new.py (deleted)
	* trunk/fprime.py (modified)
	switch to new HessianLSQ; Ouch#4 msg in GUI; misc wx4.1 fixes; docs ...
Sun, 31 Jan 2021 19:31:58 GMT vondreele [4788]
	a bit more cleanup of toolbar
Sat, 30 Jan 2021 00:14:00 GMT vondreele [4787]
	cleanup of toolbar handling - for mpl 3.3.2 at least. remove ...
Thu, 28 Jan 2021 19:05:18 GMT vondreele [4786]
	use set_box_aspect to make 3D plot scales correct. one in four ...
Wed, 27 Jan 2021 21:27:25 GMT toby [4785]
	new table for text w/sorting
Tue, 26 Jan 2021 22:54:52 GMT toby [4784]
	* trunk/help/gsasII.html (modified)
	more help prose
Tue, 26 Jan 2021 18:48:52 GMT toby [4783]
	* trunk/exports/G2export_CIF.py (modified)
	wx4.1 updates; new CIF data item; scripting: peak fit details ...
Wed, 20 Jan 2021 20:35:12 GMT toby [4782]
	scripting fix; wx4.1 RB fixes
Tue, 19 Jan 2021 17:34:26 GMT vondreele [4781]
	2D map contouring now fixed for matplotlib 3.3.2 - should work for ...
Sun, 17 Jan 2021 21:12:29 GMT toby [4780]
	* trunk/GSASIImath_new.py (modified)
	separate hard & SVD singularities, new code in GSASIImath_new.py not ...
Sat, 16 Jan 2021 16:16:55 GMT vondreele [4770]
	reinstitute final call to Hess after convergence - required for ...
Thu, 14 Jan 2021 20:10:10 GMT vondreele [4767]
	comment out recalculatin if LS matrix after convergence - faster LS ...
Thu, 14 Jan 2021 17:15:32 GMT vondreele [4766]
	* trunk/gltext.py (modified)
	modify atom labeling routine to allow specified offset as ...
Thu, 14 Jan 2021 04:44:23 GMT toby [4765]
	MPL 3.3.x fix; scripting docs
Thu, 14 Jan 2021 03:42:03 GMT toby [4764]
	HessianLSQ: force vars to float; small wx 4.1 fixes; scriptable: more ...
Wed, 13 Jan 2021 22:34:34 GMT vondreele [4763]
	* trunk/imports/G2img_1TIF.py (modified)
	cleanup tif import for PIL use - remove commented lines
	move ...
Tue, 12 Jan 2021 18:47:56 GMT vondreele [4762]
	fix TIF importer for bad images that use PIL/pillow instead.
Mon, 11 Jan 2021 19:57:49 GMT toby [4761]
	refinements with no variables or no cycles
Mon, 11 Jan 2021 15:15:15 GMT toby [4760]
	fix zero cycle bug
Sun, 10 Jan 2021 23:12:01 GMT toby [4759]
	* install/g2full/g2postinstall.sh.template (modified)
	* install/setversion.py (modified)
	* trunk/GSASIIrestrGUI.py (modified)
	wx4.1 & mpl3.3 fixes
Sun, 10 Jan 2021 03:32:48 GMT toby [4756]
	* trunk/g2app.tar.gz (modified)
	* trunk/makeMacApp.py (modified)
	more mac work
Sun, 10 Jan 2021 01:34:21 GMT toby [4754]
	* trunk/g2app.tar.gz (added)
	new approach for MacOS AppleScripting
Sat, 09 Jan 2021 14:55:00 GMT vondreele [4752]
	add scattering density to status bar when P/N are selected for ...
Fri, 08 Jan 2021 21:34:01 GMT toby [4749]
	* install/g2full/g2postinstall.sh (modified)
	* install/g2full/g2postinstall.sh.template (added)
	fine-tune Mac installer for 11.0
Fri, 08 Jan 2021 00:06:12 GMT toby [4741]
	* install/bootstrap.py (modified)
	* install/g2complete/build.sh.template (modified)
	* trunk/GSASIIpath.py (modified)
	deal with install python not matching target system
Thu, 07 Jan 2021 23:22:35 GMT toby [4740]
	* install/g2complete/post-link.sh (modified)
	more install work
Thu, 07 Jan 2021 21:53:49 GMT toby [4736]
	* install/g2complete/src/bootstrap.py (modified)
	* trunk/makeLinux.py (modified)
	more install work
Thu, 07 Jan 2021 17:21:15 GMT vondreele [4735]
	reduce printed precision of bon valence sum from 3 to 2.
	connect +/- ...
Thu, 07 Jan 2021 05:19:21 GMT toby [4733]
	* trunk/bindist/emptydir.txt (added)
	add placeholder
Thu, 07 Jan 2021 05:13:16 GMT toby [4732]
	* install (modified)
	* install/g2pkg/src/bootstrap.py (modified)
	workarounds for missing files
Thu, 07 Jan 2021 04:57:11 GMT toby [4731]
	* Binaries/mac_64_p3.7_n1.18/emptydir.txt (added)
	* trunk/AllBinaries/emptydir.txt (added)
	add file to binary directories so that conda-build keeps them
Wed, 06 Jan 2021 21:34:14 GMT toby [4725]
	add ScriptEditor save to makeMacApp
Wed, 06 Jan 2021 16:43:56 GMT toby [4724]
	add Big Sur patch for OpenGL.GL bug
Tue, 05 Jan 2021 22:22:19 GMT vondreele [4723]
	* trunk/atmdata.py (modified)
	add automatic valence bond sum calculator to dist/angle calculator in ...
Tue, 05 Jan 2021 18:36:05 GMT vondreele [4720]
	trimmed some plot k-box commands; they blocked the 2nd status line
	box
Tue, 05 Jan 2021 15:28:53 GMT vondreele [4719]
	add number/cell to site fraction apportion routine
Tue, 05 Jan 2021 14:55:39 GMT toby [4717]
	remove mpl 3.3 warning
Mon, 04 Jan 2021 22:08:43 GMT toby [4713]
	more installer work; xmgrace enhance from Carlo
Mon, 04 Jan 2021 20:46:25 GMT vondreele [4712]
	fix plotting of image limit ellipses - wrong call (GetDetectorXY) ...
Mon, 04 Jan 2021 20:28:57 GMT toby [4711]
	* trunk/fsource/fellipse.for (deleted)
	remove fellipse, not used for a long time
Mon, 04 Jan 2021 16:41:46 GMT vondreele [4709]
	new (BT mostly) version of HessianLSQ & additions; fix nan problem in ...
Sat, 02 Jan 2021 17:46:35 GMT toby [4699]
	improve refinement warnings
Sat, 02 Jan 2021 15:34:38 GMT vondreele [4698]
	forgot the 'color' change for gain map
Sat, 02 Jan 2021 15:30:28 GMT vondreele [4697]
	move superminusone definition to header block in G2pwdrGUI
	replace ...
Fri, 01 Jan 2021 15:39:23 GMT toby [4695]
	back out zero xfer
Thu, 31 Dec 2020 23:46:53 GMT toby [4694]
	Cell test: update reflection positions after zero or Bravais change
Thu, 31 Dec 2020 22:11:48 GMT toby [4693]
	updates to math_new after testing; improve output
Thu, 31 Dec 2020 16:50:22 GMT vondreele [4692]
	improve gain map calc - more steps for integration step
Wed, 30 Dec 2020 23:53:44 GMT toby [4691]
	major updates to trial version of HessianLSQ
Wed, 30 Dec 2020 23:52:57 GMT toby [4690]
Wed, 30 Dec 2020 20:51:39 GMT vondreele [4689]
	fix formatting issues on Covariance tab
Wed, 30 Dec 2020 20:11:42 GMT toby [4688]
	correct setting of singular vars in old HessianLSQ
Wed, 30 Dec 2020 17:44:57 GMT toby [4687]
	* trunk/CifFile/CifFile.py (modified)
	* trunk/GSASIIfiles.py (modified)
	Add e key for excluded region creation; switch to hist in tree after ...
Wed, 30 Dec 2020 16:43:56 GMT vondreele [4686]
	fix bug in fix background file handling
Tue, 29 Dec 2020 18:37:31 GMT vondreele [4685]
	Add gain map calculator
Sat, 26 Dec 2020 19:28:42 GMT toby [4683]
	* trunk/GSASIImath_new.py (added)
	include trial version of G2math with reworked HessianLSQ
Sat, 26 Dec 2020 06:25:59 GMT toby [4682]
	* trunk/GSASIIstrMath.py (modified)
	improve refinement messages; help info
Tue, 22 Dec 2020 22:10:35 GMT toby [4681]
	density format corrected
Tue, 22 Dec 2020 22:09:47 GMT toby [4680]
	add UTF to config.py; covariance: add reduced Chi**2 & help button; ...
Thu, 17 Dec 2020 16:35:02 GMT vondreele [4674]
	fix background fitting from fixed points - now will also fir fixed ...
Mon, 14 Dec 2020 18:58:19 GMT vondreele [4672]
	* trunk/Absorb.py (modified)
	* trunk/GSASIIIntPDFtool.py (modified)
	* trunk/GSASIIexprGUI.py (modified)
	remove all wx.ALIGN from wx Add with wx.EXPAND - invalid combination ...
Sat, 12 Dec 2020 19:30:31 GMT vondreele [4671]
	* trunk/imports/G2phase_GPX.py (modified)
	add refinable multiplier for a fixed background; multiplier is now ...
Sat, 05 Dec 2020 16:32:45 GMT vondreele [4670]
	change Tc-98 to Tc-99
Wed, 02 Dec 2020 19:05:56 GMT vondreele [4669]
	Add '?' help button to upper right for phase tabs General, etc.
Wed, 02 Dec 2020 17:39:06 GMT toby [4668]
	updates to refinement options
Wed, 02 Dec 2020 17:18:21 GMT vondreele [4667]
	Add '?' help button to upper right hand corner of various PWDR data ...
Tue, 01 Dec 2020 18:48:35 GMT vondreele [4666]
	Add output of resonant neutron scattering lengths for CW powder & ...
Mon, 30 Nov 2020 03:43:54 GMT toby [4665]
	fix Circle() picking; remove unneeded diagnostic from LSQ error
