# ChangeLog for trunk
# Generated by Trac 1.0.13
# Jul 4, 2025 11:55:33 AM
Thu, 16 Jul 2020 14:30:05 GMT vondreele [4522]
	* trunk/exports/G2export_csv.py (modified)
	* trunk/exports/G2export_examples.py (modified)
	* trunk/exports/G2export_pwdr.py (modified)
	fix exporters for pink reflection data
Wed, 15 Jul 2020 20:08:04 GMT vondreele [4521]
	* trunk/GSASIImpsubs.py (modified)
	* trunk/GSASIIobj.py (modified)
	* trunk/GSASIIpwdGUI.py (modified)
	* trunk/GSASIIstrMath.py (modified)
	* trunk/testDeriv.py (modified)
	complete pink Rietveld refinement
	fix problem with weights
	enhance ...
Tue, 14 Jul 2020 21:08:55 GMT vondreele [4520]
	* trunk/GSASIIpwd.py (modified)
	* trunk/GSASIIstrIO.py (modified)
	some corrections for pink beam single peak fits
	implement pink beam ...
Mon, 13 Jul 2020 18:27:06 GMT vondreele [4519]
	* trunk/GSASIIfpaGUI.py (modified)
	* trunk/GSASIIlattice.py (modified)
	* trunk/GSASIImath.py (modified)
	* trunk/GSASIIplot.py (modified)
	G2fpaGUI - minor cleanup
	G2lattice - test on 'T' instead of 'C' so ...
Mon, 13 Jul 2020 01:59:57 GMT toby [4518]
	* trunk/GSASIIphsGUI.py (modified)
	* trunk/GSASIIscriptable.py (modified)
	start on fullrmc update for 5.0; fix for rigid bodies
Wed, 08 Jul 2020 14:23:37 GMT toby [4517]
	doc build issues
Tue, 07 Jul 2020 23:08:08 GMT toby [4516]
	doc build problem
Tue, 07 Jul 2020 22:42:34 GMT toby [4515]
	* trunk/GSASIIdataGUI.py (modified)
	* trunk/GSASIIpath.py (modified)
	new capability: general parameter access
Mon, 06 Jul 2020 18:35:05 GMT vondreele [4514]
	remove non gpx entries from recent projects
	continue work on magnetism
Fri, 03 Jul 2020 15:18:43 GMT vondreele [4513]
	fix problem after setting 1-->2 transformation. A block of code ...
Mon, 29 Jun 2020 13:25:28 GMT vondreele [4512]
	* trunk/imports/G2img_1TIF.py (modified)
	fix to tif image importer
Sat, 27 Jun 2020 19:46:20 GMT toby [4511]
	fix rename, make sure hist is not used
Sat, 27 Jun 2020 15:57:38 GMT vondreele [4510]
	* trunk/GSASIIspc.py (modified)
	fix magnetic site sym bug
Wed, 24 Jun 2020 16:42:12 GMT vondreele [4509]
	fix texture refinement error - incorrect azimuth values
Tue, 23 Jun 2020 22:41:27 GMT vondreele [4508]
	fix the select tab menu list in phases
Tue, 23 Jun 2020 00:55:35 GMT vondreele [4507]
	alow plotting of non integer HKL planes
	make planes partially ...
Sun, 21 Jun 2020 13:49:20 GMT toby [4505]
	* trunk/GSASIIconstrGUI.py (modified)
	more fixes to Res RB edit; tweak RB atom assignment displays
Sun, 21 Jun 2020 01:47:15 GMT toby [4504]
	restore error for deleting RB atoms
Sun, 21 Jun 2020 00:39:59 GMT toby [4503]
	fix problems wit multiple instances of a single RB and with adding ...
Sat, 20 Jun 2020 21:08:34 GMT vondreele [4502]
	Eliminate the Hatom radius & moved Bond search factor to be under ...
Sat, 20 Jun 2020 15:37:16 GMT vondreele [4501]
	move void plotting to be before slice plotting so that voids behind ...
Fri, 19 Jun 2020 21:58:08 GMT toby [4500]
	Add sphere of atoms arround view point; show distances to peaks and ...
Fri, 19 Jun 2020 21:19:13 GMT toby [4499]
	* trunk/GSASIIctrlGUI.py (modified)
Fri, 19 Jun 2020 02:32:02 GMT toby [4498]
	* trunk/GSASIIIO.py (modified)
	cleanup errors and cruft noted in spyder
Thu, 18 Jun 2020 23:44:24 GMT toby [4496]
	pkg new versions of fullrmc support packages
Thu, 18 Jun 2020 17:03:52 GMT vondreele [4495]
	Improve lighting for unit cell box & view point cross
Thu, 18 Jun 2020 15:10:00 GMT vondreele [4494]
	make voids permanent,add show options for map & voids, draw voids as ...
Thu, 18 Jun 2020 13:07:24 GMT vondreele [4493]
	strip valences from atoms in RMCProfile & fullrmc - both are blind to ...
Thu, 18 Jun 2020 01:46:08 GMT vondreele [4492]
	* trunk/GSASIIexprGUI.py (modified)
	* trunk/GSASIIimgGUI.py (modified)
	cleanup here & there
Wed, 17 Jun 2020 22:46:20 GMT toby [4491]
	* trunk/GSASIIIntPDFtool.py (modified)
	* trunk/GSASIIddataGUI.py (modified)
	Add VoidMap; change min/max in ValidatedTextCtrl to xmin/xmax; new ...
Wed, 17 Jun 2020 17:58:02 GMT vondreele [4490]
	replace all single value TextCtrl with ValidatedTextCtrl; remove thus ...
Tue, 16 Jun 2020 15:23:33 GMT vondreele [4489]
	further fixup of incommensurate mag moment drawings. Now correct.
Tue, 16 Jun 2020 14:39:08 GMT vondreele [4488]
	another try at incommensurate magnetic SF; fix bug in plotting mag ...
Sat, 13 Jun 2020 20:50:13 GMT toby [4487]
	* install/bootstrap.py (modified)
	abort on Complete Molecule optional; bypass decode error
Sat, 13 Jun 2020 18:50:27 GMT vondreele [4486]
	fix status bar atom label problem when picking atoms from drawing
Sat, 13 Jun 2020 14:44:53 GMT vondreele [4485]
	fix plotting of BNS centered modulated magnetic moment plotting
Sat, 13 Jun 2020 01:41:52 GMT vondreele [4484]
	fix setting RB thermal to 'None'
	replace call to ...
Fri, 12 Jun 2020 19:19:25 GMT vondreele [4483]
	fix to MagMod /2 error
	fix bug in HKLF reflection list
Fri, 12 Jun 2020 14:06:19 GMT toby [4482]
	2nd mpl.cm.ScalarMappable() fix
Thu, 11 Jun 2020 21:06:22 GMT vondreele [4481]
	Fix appearance of FileDialog in GetImportFile - CenterOnParent() ...
Thu, 11 Jun 2020 02:27:35 GMT toby [4480]
	fix colormap problem w/3.0.x
Thu, 11 Jun 2020 02:10:31 GMT toby [4479]
	changes to unique map peaks & plotting after selection
Tue, 09 Jun 2020 16:00:17 GMT vondreele [4476]
	* trunk/imports/G2phase_CIF.py (modified)
	make sure if Uij = None that it is zero, type is 'I' and that after a ...
Tue, 09 Jun 2020 15:36:09 GMT vondreele [4475]
	fix prolem in cif files where anisotropic params are as ...... --> ...
Tue, 09 Jun 2020 15:11:45 GMT vondreele [4474]
	* trunk/exports/G2export_CIF.py (modified)
	fix minor cif problem - order of "source" and "neutron"
Tue, 09 Jun 2020 03:24:17 GMT toby [4473]
	allow adding of rigid body atoms to atoms list
Mon, 08 Jun 2020 15:57:13 GMT vondreele [4471]
	restore FillCoordSphere from G2 version #4379
Mon, 08 Jun 2020 15:02:59 GMT vondreele [4470]
	Add option to fade by 50% symmetry equivalent atoms, bonds, etc. in ...
Sun, 07 Jun 2020 01:28:26 GMT toby [4469]
	* trunk/help/gsasII.html (modified)
	fix for TOF simulation scripting; improve peak selection status line ...
Sat, 06 Jun 2020 20:52:50 GMT toby [4468]
	add status msg on Shift-Click atom selection; error message with RB ...
Sat, 06 Jun 2020 20:02:17 GMT vondreele [4467]
	fix map peak selection
Sat, 06 Jun 2020 19:46:07 GMT vondreele [4466]
	* trunk/GSASIIindex.py (modified)
	change Pawley refinement menu items for setting/unsetting refine ...
Fri, 05 Jun 2020 15:26:26 GMT vondreele [4465]
	fix atom selection from figure for Atoms - now it the same as for ...
Fri, 05 Jun 2020 14:32:31 GMT vondreele [4464]
	reinstate the old FindCoordination as FindCoordination2 - was used in ...
Thu, 04 Jun 2020 20:40:34 GMT toby [4463]
	Redisplay structure after a shift-click to select an atom; update ...
Thu, 04 Jun 2020 14:57:58 GMT vondreele [4462]
	fix bug for not installed RMCProfile
Wed, 03 Jun 2020 22:09:35 GMT vondreele [4461]
	fix bugs in MakeRMC6f & MakefullrmcPDB
Tue, 02 Jun 2020 18:04:03 GMT vondreele [4460]
	correct plots for RMCProfile & fullrmc S(Q) & G(R) plots.
Tue, 02 Jun 2020 01:13:23 GMT vondreele [4456]
	* trunk/GSASIIstrMain.py (modified)
	fix bug in SytSym
Tue, 02 Jun 2020 00:16:10 GMT toby [4455]
	fix and speed up the "Complete Molecule" command; w/o for mult calc
	bug
Mon, 01 Jun 2020 19:12:13 GMT vondreele [4454]
	allow selection by atom name (same as by type)
Mon, 01 Jun 2020 18:49:42 GMT vondreele [4453]
	cleanup fixes to G2pshGUI
Mon, 01 Jun 2020 17:40:11 GMT vondreele [4451]
	Add Histogram distances & angles to Phase/Atom/Compute menu
	fix ...
Sun, 31 May 2020 17:06:22 GMT vondreele [4450]
	Add Histogram bonds & angles to Atoms/Compute menu - makes histogram ...
Fri, 29 May 2020 16:31:32 GMT vondreele [4449]
	fix atom pick routine in structure drawing
Fri, 29 May 2020 14:36:54 GMT toby [4448]
	add complete molecule (slow) & fix use of radii
Wed, 27 May 2020 16:56:18 GMT vondreele [4447]
	change RMCProfie chi^2 to log10 chi^2 to match fulrmc chi^2 plot
	fix ...
Tue, 26 May 2020 19:38:22 GMT toby [4442]
	* install/g2complete/meta.yaml.template (modified)
	* install/g2full/construct.yaml.template (modified)
	better atom selection; try to fix packaging bug
Tue, 26 May 2020 16:44:22 GMT vondreele [4441]
	cleanup  of GenAtom
	fix Dist Angle calcs for an imported phase with ...
Tue, 26 May 2020 15:44:15 GMT vondreele [4440]
	fix atom draw update problem when atoms not in unit cell2Arelated ...
Tue, 26 May 2020 14:34:42 GMT toby [4439]
	* install/g2complete/build.sh (modified)
	* install/g2complete/src/bootstrap.py (modified)
	bootstrap w/selected binary; update svn switch cmd; save build output
Tue, 26 May 2020 02:11:33 GMT toby [4437]
	* Binaries/macRelink.py (moved)
	add fix for paths in libraries
Tue, 26 May 2020 02:06:05 GMT toby [4436]
	* trunk/macRelink.py (added)
Tue, 26 May 2020 01:57:49 GMT vondreele [4435]
	fix MakeRMC6f for fractional atom fracs
Tue, 26 May 2020 01:56:02 GMT vondreele [4434]
	Change Force=True for anisotropic atms in call to GenAtom in ...
Mon, 25 May 2020 20:08:15 GMT toby [4433]
	fix problem where histogram has reflections, but is not in phase; ...
Mon, 25 May 2020 16:07:21 GMT vondreele [4432]
	change ifConstraint flag in Transform to False
	flag missing ...
Sun, 24 May 2020 22:19:15 GMT toby [4431]
	new code for locating RBs; redo GUI for RB extractor
Thu, 21 May 2020 17:21:57 GMT vondreele [4430]
	some cleanup of fullrmc stuff
Thu, 21 May 2020 12:56:29 GMT toby [4429]
	not that change yet
Thu, 21 May 2020 12:42:24 GMT toby [4428]
	minor RB stuff in prep for new add RB code
Thu, 21 May 2020 00:33:57 GMT vondreele [4427]
	fullrmc fixes
Wed, 20 May 2020 13:36:33 GMT vondreele [4426]
	* trunk/GSASIIrestrGUI.py (modified)
	fix bug in bond restraint import
Sun, 17 May 2020 21:31:21 GMT vondreele [4425]
	* trunk/imports/G2pdf_gr.py (modified)
	fix generation of fullrmc pdb file for structures with partial ...
Sun, 17 May 2020 18:36:19 GMT toby [4424]
	fix RB selection with 1 RB
Sat, 16 May 2020 18:36:48 GMT vondreele [4423]
	fix to RMC stuff
Sat, 16 May 2020 16:49:02 GMT vondreele [4422]
	more fullrmc stuff
Sat, 16 May 2020 13:55:12 GMT toby [4421]
	add R.B. extractor; misc doc updates; plt bug after strip Hs; grid ...
Sat, 16 May 2020 01:05:40 GMT vondreele [4420]
	improvements to fullrmc interface
Fri, 15 May 2020 01:25:30 GMT toby [4419]
	Allow plotting to show selected atoms; reorder some code to put ...
Wed, 13 May 2020 23:58:36 GMT vondreele [4418]
	change macromolecular default drawing from sticks (slow) to van der ...
Tue, 12 May 2020 22:03:59 GMT vondreele [4417]
	further enhancements of the fullrmc - GSAS-II interface; now does ...
Sat, 09 May 2020 19:14:54 GMT vondreele [4416]
	fix 3D surface problem when changing mystrain/size axis
	remove ...
Thu, 07 May 2020 17:17:26 GMT vondreele [4415]
	* trunk/GSASIIimage.py (modified)
	* trunk/exports/G2export_PDB.py (modified)
	* trunk/imports/G2phase.py (modified)
	change export_PDB to handle fullrmc pdb files
	implement Wenqian's ...
Sat, 25 Apr 2020 02:52:46 GMT toby [4413]
	* trunk/NIST_profile/atan_windowed_FP_profile.py (modified)
	add texture docs and fix build problem
Fri, 24 Apr 2020 22:32:58 GMT toby [4412]
	update tree item display after delete data tree entry
Fri, 24 Apr 2020 16:27:10 GMT toby [4411]
	bug in CIF export; misc cleanup
Fri, 24 Apr 2020 16:06:35 GMT toby [4410]
	* trunk/imports/G2phase_GPX.py (modified)
	* trunk/imports/G2pwd_CIF.py (modified)
	* trunk/imports/G2sfact_CIF.py (modified)
	do much more cleanup after phase delete; refactor some importer ...
Thu, 23 Apr 2020 22:53:38 GMT toby [4409]
	select bank for scripting simulation
Wed, 22 Apr 2020 16:17:11 GMT toby [4408]
	warning for MPL 3.1 & 3.2
