# ChangeLog for trunk
# Generated by Trac 1.0.13
# Jul 4, 2025 12:29:33 PM
Mon, 05 Dec 2011 22:00:00 GMT vondreele [432]
	* trunk/GSASIIIO.py (modified)
	* trunk/GSASIIlattice.py (modified)
	* trunk/GSASIIphsGUI.py (modified)
	* trunk/GSASIIplot.py (modified)
	* trunk/GSASIIpwd.py (modified)
	* trunk/GSASIIstruct.py (modified)
	remove test prints from GSASIIIO
	new Gmat2AB routine
	work on the ...
Thu, 01 Dec 2011 15:49:50 GMT vondreele [431]
	3D plots for mustrain & size now have correct aspect ratio
	title ...
Wed, 30 Nov 2011 23:02:08 GMT vondreele [430]
	* trunk/GSASIIgrid.py (modified)
	* trunk/help/gsasII.html (modified)
	NB: There are a few stray print statements in this version
	Some work ...
Mon, 28 Nov 2011 16:32:08 GMT vondreele [429]
	* trunk/GSASIIindex.py (modified)
	* trunk/GSASIIpwdGUI.py (modified)
	set 'browser' as default help display
	fix zero & zero offset to be ...
Tue, 22 Nov 2011 21:59:22 GMT vondreele [428]
	* trunk/GSASII.py (modified)
	begin something for plotting size & PO figures as well as mustrain ...
Tue, 22 Nov 2011 21:21:38 GMT toby [427]
	* trunk/binmac2.7/pypowder.so (added)
	* trunk/gsas2.png (added)
	* trunk/help (added)
	* trunk/help/gsas2logo.png (added)
	* trunk/help/gsasII.html (added)
	implement HTML help
Mon, 21 Nov 2011 20:11:03 GMT vondreele [426]
	allow repositioning of reflection markers (up or down)
Mon, 21 Nov 2011 15:32:14 GMT vondreele [425]
	* trunk/GSASIImapvars.py (modified)
	get As from Dijs in seqdata plotting
Fri, 18 Nov 2011 20:31:18 GMT vondreele [424]
	remove 'Back'ground from consideration for constraints
	add a bit ...
Fri, 18 Nov 2011 20:19:01 GMT vondreele [423]
	Add help to all dataDisplay menus
	remove ring fit points from ...
Thu, 17 Nov 2011 23:31:16 GMT vondreele [422]
	fixes to position related derivatives
Thu, 17 Nov 2011 22:12:10 GMT toby [421]
	determine uncertainties on constrained variables
Thu, 17 Nov 2011 19:35:34 GMT vondreele [420]
	small fixes including
	move msg = '' in SetVaryFlags outside loop ...
Thu, 17 Nov 2011 19:25:51 GMT toby [419]
	print constraint-generated variables
Wed, 16 Nov 2011 22:18:11 GMT toby [418]
	fix compute derivs for constrained vars
Wed, 16 Nov 2011 20:42:49 GMT toby [417]
Tue, 15 Nov 2011 20:41:30 GMT toby [416]
	use unicode with backslash x (micron symbol)
Tue, 15 Nov 2011 15:07:55 GMT toby [415]
	* trunk/binmac2.7/fellipse.so (modified)
	* trunk/binmac2.7/histogram2d.so (modified)
	* trunk/binmac2.7/pack_f.so (modified)
	* trunk/binmac2.7/polymask.so (modified)
	* trunk/binmac2.7/pyspg.so (modified)
	* trunk/binmac2.7/pytexture.so (modified)
	* trunk/fsource/pypowder.for (modified)
	implement refinement of constrained parameters; fix minor bugs; add ...
Mon, 14 Nov 2011 16:04:25 GMT vondreele [414]
	* trunk/binwin2.7/fellipse.pyd (modified)
	* trunk/binwin2.7/histogram2d.pyd (modified)
	* trunk/binwin2.7/pack_f.pyd (modified)
	* trunk/binwin2.7/polymask.pyd (modified)
	* trunk/binwin2.7/pypowder.pyd (modified)
	* trunk/binwin2.7/pyspg.pyd (modified)
	* trunk/binwin2.7/pytexture.pyd (modified)
	new pyd files
Sat, 12 Nov 2011 18:04:15 GMT vondreele [413]
	add plotting of new atom coordinates to sequential refinement plots
Fri, 11 Nov 2011 20:14:35 GMT vondreele [411]
	* trunk/GSASIIElem.py (modified)
	* trunk/fsource/powsubs/psvfcj.for (modified)
	fix very old (!) bug in psvfcj.for
	implement neutron scattering ...
Tue, 08 Nov 2011 22:27:01 GMT vondreele [409]
	make it do CW neutrons - 1st pass at it
Mon, 07 Nov 2011 21:13:29 GMT vondreele [408]
	add copy to limits menu
	more constraint GUI stuff
Sat, 05 Nov 2011 22:30:24 GMT vondreele [407]
	constraints round 2
Wed, 02 Nov 2011 18:11:04 GMT vondreele [406]
	* trunk/GSASIIimgGUI.py (modified)
	implement background subtraction during image integration
	implement ...
Sat, 29 Oct 2011 13:54:52 GMT vondreele [405]
	* trunk/fsource (modified)
	finish refactor of DData
Fri, 28 Oct 2011 18:59:03 GMT vondreele [404]
	* trunk/GSASIIspc.py (modified)
	put error bars on seq refinement plots
	add cubic elastic strain ...
Thu, 27 Oct 2011 21:34:28 GMT vondreele [403]
	speedup GetUsedHistogramsAndPhases
Thu, 27 Oct 2011 19:12:00 GMT vondreele [402]
	refactor some of DData stuff
Thu, 27 Oct 2011 15:26:50 GMT vondreele [400]
	new default for Vcov contour plot - RdYlGn
	faster cleanup on ...
Tue, 25 Oct 2011 21:53:33 GMT vondreele [399]
	Implement sequential refinement
	remove print "load" & "save" for ...
Fri, 21 Oct 2011 19:33:37 GMT vondreele [398]
	missed updating the GUI after recalibrate
Fri, 21 Oct 2011 17:15:50 GMT vondreele [397]
	* trunk/GSASIIimage.py (modified)
	collect default settings for Sample in one routine
	add recalibrate ...
Thu, 20 Oct 2011 16:38:12 GMT vondreele [396]
	make image calibration 0-360 (not -180-180) to match usual ...
Thu, 20 Oct 2011 14:25:32 GMT vondreele [395]
	Add goniometer omega, chi & phi to sample data
	put SH texture in ...
Thu, 13 Oct 2011 19:12:16 GMT vondreele [392]
	put parmNames on y-axis of covariance plot
Thu, 13 Oct 2011 15:48:51 GMT vondreele [391]
	set default atom frac=1 for cif files
	store covMatrix not normalized ...
Mon, 10 Oct 2011 21:32:58 GMT vondreele [390]
	Add tooltip to covariance plot
	clean up LS output formats
	Add Fobs ...
Sun, 09 Oct 2011 14:34:43 GMT vondreele [388]
	add SGPolax to SGData dictionary - marks arbitrary axes in polar ...
Fri, 07 Oct 2011 22:12:31 GMT vondreele [386]
	concatenate error fixed
Fri, 07 Oct 2011 18:24:50 GMT vondreele [385]
	* trunk/GSASII.BAT (modified)
	fix gsasii.bat so clicking on a gpx file runs gsasii
Fri, 07 Oct 2011 18:12:38 GMT vondreele [384]
	add constraint & restraint items to tree - now empty
	fix noncentro ...
Wed, 05 Oct 2011 18:40:37 GMT vondreele [383]
	small fixes
Mon, 03 Oct 2011 20:43:49 GMT vondreele [380]
	completed Rietveld refinement version
Thu, 22 Sep 2011 15:11:18 GMT vondreele [379]
	* trunk/fsource/pytexture.for (modified)
	* trunk/fsource/texturesubs/plmpsi.for (modified)
	finish spherical harmonics preferred orientation
Tue, 20 Sep 2011 20:33:06 GMT vondreele [378]
	a Pawley intensity fix, format fixes & Sph. Harm PO correction
Tue, 20 Sep 2011 18:51:43 GMT vondreele [377]
	better fix & some reorg. of GSASIIstruct.py
Tue, 20 Sep 2011 18:42:17 GMT vondreele [376]
	fix intensity type derivatives - scale, polarization, pref. ori.,
	etc.
Mon, 19 Sep 2011 18:20:32 GMT vondreele [375]
	GSASIIgrid.py - add Pawley estimator to menu
	GSASIIlattice.py - fix ...
Fri, 16 Sep 2011 20:53:20 GMT vondreele [374]
	remove stray print
Fri, 16 Sep 2011 20:51:06 GMT vondreele [373]
	new covariance item in tree
	new covariance matrix plotting
	save cov ...
Thu, 15 Sep 2011 20:33:53 GMT vondreele [372]
	Add new background functions & rework background GUI
	Add hydrostatic ...
Tue, 13 Sep 2011 17:59:50 GMT vondreele [371]
Mon, 12 Sep 2011 19:13:51 GMT toby [370]
	* trunk/binlinux64-2.7 (added)
	* trunk/binlinux64-2.7/fellipse.so (added)
	* trunk/binlinux64-2.7/histogram2d.so (added)
	* trunk/binlinux64-2.7/pack_f.so (added)
	* trunk/binlinux64-2.7/polymask.so (added)
	* trunk/binlinux64-2.7/pypowder.so (added)
	* trunk/binlinux64-2.7/pyspg.so (added)
	* trunk/binlinux64-2.7/pytexture.so (added)
	* trunk/fsource/SConstruct (modified)
	Edits to build on 64-bit linux (RH Enterprise 5)
Sat, 10 Sep 2011 14:52:32 GMT vondreele [369]
	remove wx from GSASIIstruct.py
Fri, 09 Sep 2011 14:59:47 GMT vondreele [368]
	fix controls setup & refine enable/disable
	add print option to ...
Thu, 08 Sep 2011 20:27:13 GMT vondreele [367]
	make Factor lower limit 0.00001
Wed, 07 Sep 2011 20:47:11 GMT vondreele [366]
	comment out debug stuff
Wed, 07 Sep 2011 20:46:10 GMT vondreele [365]
	fixed to make size & mustrain sizers work (maybe just better).
	Issue ...
Wed, 07 Sep 2011 18:38:20 GMT toby [364]
	warn if f2py is not found
Mon, 05 Sep 2011 02:52:34 GMT toby [363]
	revise scons file to work on windows with epd gfortran
Sun, 04 Sep 2011 13:04:31 GMT vondreele [362]
	add shift factor to LS controls
Sat, 03 Sep 2011 22:07:52 GMT vondreele [361]
	* trunk/binwin2.7/pypowder.pyd (added)
Fri, 02 Sep 2011 12:45:38 GMT vondreele [360]
	just backup before trip
Wed, 31 Aug 2011 19:49:14 GMT vondreele [359]
	* trunk/fsource/powsubs/psvfcjo.for (added)
Tue, 30 Aug 2011 17:33:09 GMT vondreele [358]
	small fixes
Tue, 30 Aug 2011 14:38:39 GMT vondreele [357]
	GSASIIpwd.py - add polarization derivative
	GSASIIstruct.py - almost ...
Thu, 25 Aug 2011 17:15:53 GMT vondreele [356]
	update windows 2.7 lib
Thu, 25 Aug 2011 17:14:25 GMT vondreele [355]
	done with peak fitting
Thu, 25 Aug 2011 15:11:29 GMT vondreele [354]
	more cleanup of derivatives
Wed, 24 Aug 2011 21:07:29 GMT vondreele [353]
	modify psvfcj.for to use sh/l only
	add derivative routine to ...
Sat, 20 Aug 2011 17:11:35 GMT vondreele [352]
Sat, 20 Aug 2011 17:06:06 GMT vondreele [351]
Sat, 20 Aug 2011 16:18:31 GMT vondreele [350]
	implement fortran psVoigt routine - faster by 2X over python fft
	version
Sat, 20 Aug 2011 16:16:52 GMT vondreele [349]
	* trunk/fsource/powsubs (copied)
	* trunk/fsource/pypowder.for (copied)
	restore psVoight fortran powder peak routine - faster than fft python
Sat, 20 Aug 2011 13:24:50 GMT vondreele [348]
	fixes to GSASIIstruct.py for aniso profile broadening
	suppress ...
Fri, 19 Aug 2011 02:22:29 GMT vondreele [347]
	small fix
Fri, 19 Aug 2011 02:00:13 GMT vondreele [346]
	GSASIIgrid.py - clear peaks from peak fit list & allow change from ...
Fri, 19 Aug 2011 01:54:16 GMT vondreele [345]
	put new banner in GSASII.BAT
	fix for vertical tilt & offset images ...
Mon, 08 Aug 2011 16:52:58 GMT vondreele [344]
	fix sizer issue in reflection lists
Mon, 08 Aug 2011 16:14:18 GMT vondreele [343]
	cosmetic
Fri, 05 Aug 2011 19:35:43 GMT vondreele [342]
	* trunk/GSASIImapvars.py (added)
	major modifications to get 1st "working" version of Refine
	Add ...
Fri, 05 Aug 2011 19:25:47 GMT vondreele [341]
	* trunk/fsource/pyspg.for (modified)
	* trunk/fsource/spsubs/genhkl.for (added)
	new GenHKL routine in fortran
Sat, 09 Jul 2011 15:45:30 GMT toby [337]
	a bit of cleanup
Sat, 09 Jul 2011 01:21:50 GMT toby [336]
	Make MKL optional
Thu, 07 Jul 2011 18:53:57 GMT vondreele [335]
	Add delete Pawley list; scratch "leBail" from things
	mods to texture ...
Wed, 06 Jul 2011 02:27:06 GMT toby [334]
	* trunk/GSAS2.rsrc (added)
	add Mac icon as resource file
Sun, 03 Jul 2011 15:53:05 GMT toby [328]
	remove hard-coded path from .BAT file
Fri, 01 Jul 2011 17:10:28 GMT vondreele [327]
	fix to path name for atomdata.dat
	fix to texture display - can't ...
Thu, 30 Jun 2011 16:38:20 GMT vondreele [326]
	* trunk/fsource/cf2py26.bat (deleted)
	* trunk/fsource/cf2py27.bat (deleted)
	remove cf2py
	add inverse polefigure
Thu, 30 Jun 2011 16:18:27 GMT vondreele [324]
	updated LDFLAGS for linux -- broken; commented
Thu, 30 Jun 2011 16:07:49 GMT toby [323]
	incorporate linux changes
Thu, 30 Jun 2011 15:30:03 GMT vondreele [322]
	works on Linux 64 now with right dir
Thu, 30 Jun 2011 15:26:26 GMT vondreele [321]
	works on Linux 64!
Thu, 30 Jun 2011 15:04:53 GMT vondreele [320]
	fixes
Thu, 30 Jun 2011 14:43:24 GMT toby [319]
	more work
Thu, 30 Jun 2011 14:24:48 GMT toby [318]
	more work
Thu, 30 Jun 2011 14:22:43 GMT toby [317]
	more work
Tue, 28 Jun 2011 18:02:15 GMT toby [316]
	scons fixes; copy win options from batch file
Tue, 28 Jun 2011 17:21:46 GMT toby [315]
	* trunk/binmac2.6/fellipse.so (added)
	* trunk/binmac2.6/histogram2d.so (modified)
	* trunk/binmac2.6/pack_f.so (modified)
	* trunk/binmac2.6/polymask.so (modified)
	* trunk/binmac2.6/pyspg.so (modified)
	* trunk/binmac2.6/pytexture.so (added)
	* trunk/binmac2.7 (added)
	* trunk/binmac2.7/fellipse.so (added)
	* trunk/binmac2.7/histogram2d.so (added)
	* trunk/binmac2.7/pack_f.so (added)
	* trunk/binmac2.7/polymask.so (added)
	* trunk/binmac2.7/pyspg.so (added)
	* trunk/binmac2.7/pytexture.so (added)
	* trunk/fsource/Makefile (modified)
	* trunk/fsource/SConstruct (added)
	* trunk/fsource/texturesubs/qlmn.for (modified)
	* trunk/fsource/texturesubs/qlmninit.for (modified)
	new scons file for compiling (needs linux & win work); update ...
