# ChangeLog for trunk
# Generated by Trac 1.0.13
# Jun 17, 2025 10:18:27 AM
Tue, 19 Mar 2019 14:18:53 GMT toby [3858]
	* trunk/GSASII.py (modified)
	* trunk/GSASIIimage.py (modified)
	* trunk/docs/source/index.rst (modified)
	* trunk/docs/source/packages.rst (modified)
	stupid Py3 syntax error; docs updates
Mon, 18 Mar 2019 17:09:57 GMT toby [3857]
	* trunk/GSASIIscriptable.py (modified)
	* trunk/docs/source/packages.rst (added)
	Fix scriptable to work w/o wx & mpl; reorg of docs
Sat, 16 Mar 2019 13:46:42 GMT vondreele [3856]
	* trunk/GSASIIrestrGUI.py (modified)
	small mods to GUI for general restraints
Sat, 16 Mar 2019 00:53:57 GMT toby [3855]
	* trunk/GSASIIIO.py (modified)
	* trunk/GSASIIdataGUI.py (modified)
	* trunk/GSASIIpwdGUI.py (modified)
	* trunk/GSASIIstrIO.py (modified)
	* trunk/GSASIIstrMain.py (modified)
	major speed up with very big sequential fits
Fri, 15 Mar 2019 18:50:18 GMT toby [3854]
	* trunk/GSASIIplot.py (modified)
	fix bug including zero in legend in publ. plot
Fri, 15 Mar 2019 13:37:20 GMT vondreele [3853]
	* trunk/GSASIImath.py (modified)
	* trunk/GSASIIstrMath.py (modified)
	incomm.mag. mods
Thu, 14 Mar 2019 13:33:19 GMT vondreele [3852]
	* trunk/GSASIIctrlGUI.py (modified)
	implement fix (modified) to open in G2ctrGUI as per Bo Hau Chen
	(Taiwan)
Wed, 13 Mar 2019 21:58:05 GMT vondreele [3851]
	incommensurate mag. str. fctr. agaiin - now close
Mon, 11 Mar 2019 20:36:11 GMT vondreele [3850]
	* trunk/GSASIIphsGUI.py (modified)
	replace all 0 with 0. in atom insert or add routines
	incomm. mag. ...
Mon, 11 Mar 2019 02:21:51 GMT toby [3849]
	finish sequential ref. via scripting; doc updates
Sat, 09 Mar 2019 20:58:21 GMT vondreele [3848]
	* trunk/GSASIIElemGUI.py (modified)
	* trunk/GSASIIddataGUI.py (modified)
	* trunk/GSASIIimgGUI.py (modified)
	* trunk/GSASIIpwd.py (modified)
	* trunk/GSASIIspc.py (modified)
	since id is a python routine which could be useful in debugging, ...
Fri, 08 Mar 2019 21:59:23 GMT toby [3847]
	speed contour plotting
Fri, 08 Mar 2019 21:19:10 GMT vondreele [3846]
	add plot timing for single plots
Fri, 08 Mar 2019 18:59:26 GMT toby [3845]
	more sequential timing; doc fixes for scriptable
Fri, 08 Mar 2019 17:13:04 GMT vondreele [3844]
	blksize = 256 in scriptable as well
Fri, 08 Mar 2019 17:07:55 GMT vondreele [3843]
	change image integration block size to 256 from 1024 - 3x faster ...
Thu, 07 Mar 2019 20:15:49 GMT vondreele [3842]
	force number of integration bins to be divisible by 4 - solves crash ...
Thu, 07 Mar 2019 19:50:32 GMT vondreele [3841]
	fix problem if image calibrant isn't in local calibration files
	fix ...
Thu, 07 Mar 2019 00:18:01 GMT toby [3840]
	fix scriptable read of TOF; fraction editor for wx 3.0
Wed, 06 Mar 2019 21:56:01 GMT vondreele [3839]
	add some timing for plot patterns - controlled by showTiming
	more ...
Wed, 06 Mar 2019 19:03:59 GMT toby [3838]
	fix previous
Wed, 06 Mar 2019 18:49:44 GMT vondreele [3837]
	more on incomm. mag. str. fctr.
Wed, 06 Mar 2019 18:16:47 GMT toby [3836]
	add timing for SeqRef; error msg for unlinked hists in scriptable
Tue, 05 Mar 2019 20:57:21 GMT vondreele [3835]
	* trunk/GSASIIconstrGUI.py (modified)
	Allow constraints on modulation vector
	changes to incommensurate ...
Mon, 04 Mar 2019 20:27:02 GMT toby [3834]
	set idstring for simulations as needed; thanx to Thomas Proffen
Sat, 02 Mar 2019 16:11:46 GMT toby [3833]
	add bkg peaks to ref dict & reorg docs
Fri, 01 Mar 2019 18:38:16 GMT vondreele [3832]
	fix reflection list & 3D HKL plots for modulated structures
Fri, 01 Mar 2019 16:32:38 GMT toby [3831]
	add background peaks set/control
Wed, 27 Feb 2019 16:20:33 GMT vondreele [3830]
	modify makeRing to allow optionally a multiplier on number of steps ...
Fri, 22 Feb 2019 16:14:19 GMT vondreele [3829]
	fix problem with selecting torsions in residue rigid bodies
Fri, 22 Feb 2019 15:35:29 GMT toby [3828]
	* trunk/docs/source/imports.rst (modified)
	* trunk/exports/G2export_CIF.py (modified)
	* trunk/imports/G2img_GE.py (modified)
	* trunk/imports/G2phase_GPX.py (modified)
	* trunk/imports/G2pwd_GPX.py (modified)
	* trunk/testDeriv.py (modified)
	fix cif export w/unused histogram; switch 3.x imports to pickle ...
Fri, 22 Feb 2019 15:10:31 GMT vondreele [3827]
	bad call to wx.FlexGridSizer in the RB torsion GUI - now fixed
Thu, 21 Feb 2019 16:15:15 GMT vondreele [3826]
	* trunk/Absorb.py (modified)
	* trunk/fprime.py (modified)
	* trunk/scanCCD.py (modified)
	* trunk/testSSymbols.py (modified)
	* trunk/testXNFF.py (modified)
	fix future problem with wx.NewId --> wx.NewIdRef
Fri, 15 Feb 2019 16:43:35 GMT vondreele [3825]
	* trunk/GSASIIpy3.py (modified)
	* trunk/exports/G2export_csv.py (modified)
	create csv exporter for small angle data - includes size distribution ...
Thu, 14 Feb 2019 15:31:11 GMT vondreele [3824]
	do ResetFlatBkg for changing PDF background/container files & ...
Wed, 13 Feb 2019 23:43:05 GMT toby [3823]
	* trunk/GSASIIobj.py (modified)
	attempt to fix more broken doc references
Wed, 13 Feb 2019 22:16:26 GMT toby [3822]
	fixing a broken doc reference?
Wed, 13 Feb 2019 22:11:20 GMT vondreele [3821]
	more changes for incommensurate mag str fctr
	remove GUI update after ...
Wed, 13 Feb 2019 21:48:23 GMT toby [3820]
	implement integration in scripting
Tue, 12 Feb 2019 19:03:36 GMT vondreele [3819]
	fix cursor for old wx versions
Tue, 12 Feb 2019 17:58:33 GMT vondreele [3818]
	implement sqrt(I) plots for multiplots & contour plots  - key 's' to ...
Tue, 12 Feb 2019 15:27:27 GMT vondreele [3817]
	Add Setcursor utility that presents different cursors on the plot ...
Mon, 11 Feb 2019 22:54:44 GMT vondreele [3816]
	Change plot cursor if zoom or pan buttons are pressed
Mon, 11 Feb 2019 17:26:52 GMT toby [3815]
	* trunk/GSASIIfiles.py (modified)
	Add recalibrate & more image load/set routines
Sun, 10 Feb 2019 22:40:06 GMT toby [3814]
	* trunk/config_example.py (modified)
	refactor to move some IO-only routines; add initial image support to ...
Thu, 07 Feb 2019 18:19:13 GMT vondreele [3813]
	fix problem with update of modulation vector after refinement
	change ...
Wed, 06 Feb 2019 20:11:30 GMT vondreele [3812]
	incommensurate mag str fctr. closer but still not right
Mon, 04 Feb 2019 21:35:43 GMT toby [3811]
	scriptable: fix reading py2 gpx in py3 & use of multi-set instprm
	files
Sun, 03 Feb 2019 23:05:41 GMT toby [3810]
	fix range object in GPX file; fix spurious warning on tutorial update
Sun, 03 Feb 2019 16:35:00 GMT toby [3809]
	update scriptable to handle banks in data/inst files
Sun, 03 Feb 2019 13:35:59 GMT vondreele [3808]
	latest attempt at incommensurate mag str fctr & some cleanup of dead
	ends
Thu, 31 Jan 2019 16:29:12 GMT toby [3807]
	warn on numpy 1.16.0
Wed, 30 Jan 2019 23:15:41 GMT toby [3806]
	redo parameter lookup to provide numerical deriv step size (see ...
Mon, 28 Jan 2019 23:20:01 GMT vondreele [3805]
	fix normalization of mag moments --> Kvector
	add save of map peaks ...
Mon, 28 Jan 2019 15:40:57 GMT vondreele [3804]
	implement grid in Instrument parms plot
Mon, 28 Jan 2019 13:51:33 GMT vondreele [3803]
	fix print bug in twin refinement output
	a fix(?) to the alumina Uij ...
Sun, 27 Jan 2019 22:30:39 GMT toby [3802]
	generalized restraints completed
Sun, 27 Jan 2019 15:04:12 GMT vondreele [3801]
	* trunk/GSASIIlattice.py (modified)
	combine cell2AB & Gmat2AB in G2lat
	fixes to mag. str. fctr. math. ...
Sat, 26 Jan 2019 21:46:41 GMT toby [3800]
	remove duplicate _pd_proc_ls_profile_function entry
Fri, 25 Jan 2019 20:59:53 GMT vondreele [3799]
	make sure plot grin is off by default
Fri, 25 Jan 2019 20:34:25 GMT vondreele [3798]
	add toggle for grid lines for most plots
Fri, 25 Jan 2019 17:34:38 GMT vondreele [3797]
	let map peak search find negative peaks.
Thu, 24 Jan 2019 18:46:07 GMT toby [3796]
	fix problem of empty distance/angle table
Thu, 24 Jan 2019 18:14:33 GMT vondreele [3795]
	fix space group & incommensurate space group displays for mag. ...
Wed, 23 Jan 2019 22:59:06 GMT toby [3794]
	add routine to turn off zoom/pan
Tue, 22 Jan 2019 20:05:27 GMT toby [3793]
	* trunk/exports/template_phase.cif (modified)
	add density to CIF
Tue, 22 Jan 2019 16:46:05 GMT vondreele [3792]
	Add density to lst output
Sun, 20 Jan 2019 04:03:27 GMT toby [3791]
	cleanup constraint display more
Sun, 20 Jan 2019 03:42:46 GMT toby [3790]
	make sure off-diagonal terms that must compute as 0 are fixed
Sun, 20 Jan 2019 02:38:49 GMT toby [3789]
	fix transpose error for lattice constraints
Fri, 18 Jan 2019 00:46:16 GMT toby [3788]
	* trunk/GSASIImapvars.py (modified)
	generate cell parm constraints for magnetic cells; fix errors in ...
Fri, 18 Jan 2019 00:10:20 GMT vondreele [3787]
	* trunk/GSASIIindex.py (modified)
	remove stray print statement
	fix issues with doing incommensurate ...
Thu, 17 Jan 2019 20:31:32 GMT vondreele [3786]
	* trunk/GSASIIElem.py (modified)
	* trunk/imports/G2pwd_CIF.py (modified)
	fix problem of import ElementTable inside spyder
	allow import o ...
Thu, 17 Jan 2019 01:09:58 GMT toby [3785]
	generate lattice constraints for mag. xform
Thu, 17 Jan 2019 01:03:59 GMT toby [3784]
Wed, 16 Jan 2019 13:56:58 GMT vondreele [3783]
	* trunk/imports/G2phase_CIF.py (modified)
	* trunk/imports/G2pwd_BrukerRAW.py (modified)
	fix Bruker read problem - checked with 1 & 2 block RAW 1.01 files ...
Mon, 14 Jan 2019 04:12:05 GMT toby [3782]
	enable/disable export menu items rather than menu contents
Sun, 13 Jan 2019 23:33:03 GMT toby [3781]
	Add seq. results exports to main Export menu; enable/disable export ...
Fri, 11 Jan 2019 19:51:15 GMT toby [3780]
	* Tutorials/FPAfit/FPAfit.htm (modified)
	* Tutorials/FitPeaks/Fit Peaks.htm (modified)
	* Tutorials/RietPlot/PublicationPlot.htm (modified)
	fix typos; error in CIF Dij reporting; improve generalized restraint
	GUI
Fri, 11 Jan 2019 18:58:31 GMT vondreele [3779]
	fix problems with image sum
	fix problem with samplechangerpos
Thu, 10 Jan 2019 20:10:58 GMT vondreele [3778]
	correct calculation of FWHM for TOF data & fix the alp values in the ...
Wed, 09 Jan 2019 16:51:24 GMT vondreele [3777]
	fix wx.SAVE --> wx.FD_SAVE bug
	work on incommensurate magnetic ...
Mon, 07 Jan 2019 22:20:55 GMT toby [3776]
	* trunk/GSASIIpath.py (modified)
	match new bootstrap option
Thu, 03 Jan 2019 15:32:48 GMT vondreele [3774]
	fix super indexing problem in transposeHKLF
	fix reflection ...
Tue, 25 Dec 2018 15:55:33 GMT vondreele [3773]
	Uncomment lines 3534 & 3535 commented in rev 3004 - messed up Ka2 ...
Mon, 24 Dec 2018 00:02:12 GMT toby [3772]
	* trunk/GSASIIexprGUI.py (modified)
	add GUI (seen in debug mode only) for general (equation specified) ...
Sat, 22 Dec 2018 14:20:43 GMT vondreele [3771]
	cleanup of fprime & absorb
Thu, 20 Dec 2018 20:45:08 GMT vondreele [3770]
	fix limits for Crenel coeff.
	Fix plot of calculated waves
Thu, 20 Dec 2018 16:12:53 GMT toby [3769]
	GUI crash on latey entry/type
Wed, 19 Dec 2018 18:50:45 GMT vondreele [3768]
	name fix for single crystal 1D plots
	remove ZigZag & Block from ...
Tue, 18 Dec 2018 21:07:28 GMT vondreele [3767]
	* trunk/imports/G2img_1TIF.py (modified)
	add sample changer position as an image parameter & have it show up ...
Tue, 18 Dec 2018 17:56:16 GMT vondreele [3766]
	* trunk/Absorb.py (added)
	* trunk/fprime.py (added)
	Add Absorb and Fprime to the main Calculate menu
Sat, 15 Dec 2018 19:42:13 GMT vondreele [3765]
	allow a selected data copy of 'newLeBail' flag - facilitates ...
Fri, 14 Dec 2018 18:05:45 GMT vondreele [3764]
	fixes to nonFourier modulation & derivatives - zigzag works
Thu, 13 Dec 2018 16:00:16 GMT vondreele [3763]
	improvements to 1D structure factor plots - now much faster, 'q' & ...
Wed, 12 Dec 2018 22:46:33 GMT vondreele [3762]
	updates to plot1D structure factors; q & d plots, F & F^2 plots, hkls ...
Wed, 12 Dec 2018 20:38:33 GMT vondreele [3761]
	avoid replotting structure if atom refine flags are changed
	add new ...
Tue, 11 Dec 2018 21:11:13 GMT vondreele [3760]
	remove AwaveType,PwaveType,FwaveType & MwaveType from constraints ...
Tue, 11 Dec 2018 20:11:02 GMT vondreele [3759]
	add fullIntegrate = True to configuration stuff
	add input control ...
Mon, 10 Dec 2018 18:27:04 GMT toby [3758]
	* trunk/imports/G2pwd_FP.py (modified)
	more fullprof .dat fiddling
