# ChangeLog for trunk
# Generated by Trac 1.0.13
# Jun 17, 2025 10:58:54 AM
Fri, 22 May 2015 16:08:59 GMT vondreele [1864]
	* trunk/GSASIIstrMath.py (modified)
	revise single crystal derivatives - now same as for old GSAS
	Scale & ...
Fri, 22 May 2015 13:28:03 GMT vondreele [1863]
	* trunk/GSASIIIO.py (modified)
	fix file name in error msg
Thu, 21 May 2015 13:52:52 GMT vondreele [1862]
	remove print
Tue, 19 May 2015 16:59:25 GMT vondreele [1861]
	* trunk/GSASII.py (modified)
	* trunk/GSASIIstrIO.py (modified)
	fix missing data error messages
Mon, 18 May 2015 20:09:55 GMT vondreele [1860]
	* trunk/GSASIItestplot.py (modified)
	* trunk/testDeriv.py (modified)
Mon, 18 May 2015 15:15:43 GMT toby [1859]
	* trunk/makeBat.py (modified)
	fix for windows files with spaces
Sun, 17 May 2015 04:58:51 GMT toby [1858]
	* trunk/makeBat.py (added)
	add windows installer
Sat, 16 May 2015 20:20:58 GMT vondreele [1857]
	worki on derivatives - Fix Uij derivative (i!=j)
Thu, 14 May 2015 15:31:16 GMT vondreele [1852]
	* trunk/GSASIIctrls.py (modified)
	* trunk/GSASIIgrid.py (modified)
	* trunk/GSASIIphsGUI.py (modified)
	* trunk/GSASIIstrMain.py (modified)
	addmtexture analysis tutorial to list in G2ctrls
	remove Clear ...
Wed, 13 May 2015 22:03:37 GMT toby [1850]
	* trunk/Exercises (added)
	* trunk/Exercises/2DCalibration (added)
	* trunk/Exercises/2DIntegration (added)
	* trunk/Exercises/2DStrain (added)
	* trunk/Exercises/2DTexture (added)
	* trunk/Exercises/CFjadarite (added)
	* trunk/Exercises/CFsucrose (added)
	* trunk/Exercises/CWCombined (added)
	* trunk/Exercises/CWNeutron (added)
	* trunk/Exercises/FitPeaks (added)
	* trunk/Exercises/LabData (added)
	* trunk/Exercises/MCsimanneal (added)
	* trunk/Exercises/SAfit (added)
	* trunk/Exercises/SAimages (added)
	* trunk/Exercises/SAseqref (added)
	* trunk/Exercises/SAsize (added)
	* trunk/Exercises/SeqParametric (added)
	* trunk/Exercises/SeqRefine (added)
	* trunk/Exercises/StartingGSASII (added)
	* trunk/Exercises/TOF Calibration (added)
	* trunk/Exercises/TOF Charge Flipping (added)
	* trunk/Exercises/TOF Single Crystal Refinement (added)
	* trunk/Exercises/TOF-CW Joint Refinement (added)
	* trunk/help/2DTexture (added)
	fix empty directories
Wed, 13 May 2015 19:45:07 GMT vondreele [1845]
	* trunk/GSASIImath.py (modified)
	fix to texture refine weights
Wed, 13 May 2015 13:44:05 GMT vondreele [1844]
	* trunk/GSASIIplot.py (modified)
	fix math error in inverse pole figure OnMotion - needed Bmat not Amat
Mon, 11 May 2015 17:51:04 GMT vondreele [1843]
	* trunk/GSASIIimgGUI.py (modified)
	put ';' in Debye fxn background terms (was ':')
	fix mask issue with ...
Fri, 08 May 2015 14:17:44 GMT vondreele [1842]
	typo! not setRef should be seqRef
Thu, 07 May 2015 21:20:21 GMT vondreele [1841]
	* trunk/GSASIIpwdGUI.py (modified)
	small fix in ExportCells
	seqRefine now ignores phase texture
Thu, 07 May 2015 16:40:53 GMT vondreele [1840]
	Add an export routine (NB: not in exports!) for Unit Cell results as ...
Wed, 06 May 2015 21:42:51 GMT vondreele [1839]
	* trunk/defaultIparms.py (modified)
	provide graphical display for texture fit, change weighting scheme & ...
Wed, 06 May 2015 17:19:35 GMT vondreele [1838]
	fix problem reading TOF powder data
Tue, 05 May 2015 21:28:26 GMT vondreele [1837]
	* trunk/GSASIIddataGUI.py (modified)
	fix Mass problem on 1st LS if General not visited after atoms added ...
Tue, 05 May 2015 14:22:56 GMT vondreele [1836]
	* trunk/exports/G2export_csv.py (modified)
	* trunk/exports/G2export_examples.py (modified)
	add Prfo to export powder reflections as txt & csv
	fix G2ctrls ...
Mon, 04 May 2015 21:44:41 GMT vondreele [1835]
	fix problem with deleting/inserting data into phases
	fix plot ...
Mon, 04 May 2015 14:10:23 GMT vondreele [1834]
	* trunk/GSASIIimage.py (modified)
	* trunk/imports/G2pwd_fxye.py (modified)
	redefine azimuthal angle in Sample Parms as the center of the ...
Sat, 02 May 2015 22:32:05 GMT toby [1833]
	* trunk/GSASIIobj.py (modified)
	prev. ver. also fixed linux menu problem; missed one doc correction
Sat, 02 May 2015 22:30:05 GMT toby [1832]
	* sphinxdocs/build/html/GSASII.html (modified)
	* sphinxdocs/build/html/GSASIIGUIr.html (modified)
	* sphinxdocs/build/html/GSASIImapvars.html (modified)
	* sphinxdocs/build/html/GSASIIobj.html (modified)
	* sphinxdocs/build/html/GSASIIplot.html (modified)
	* sphinxdocs/build/html/GSASIIstruc.html (modified)
	* sphinxdocs/build/html/GSASIIutil.html (modified)
	* sphinxdocs/build/html/_modules/G2export_CIF.html (modified)
	* sphinxdocs/build/html/_modules/G2export_csv.html (modified)
	* sphinxdocs/build/html/_modules/G2export_examples.html (modified)
	* sphinxdocs/build/html/_modules/G2phase.html (modified)
	* sphinxdocs/build/html/_modules/G2phase_CIF.html (modified)
	* sphinxdocs/build/html/_modules/G2phase_GPX.html (modified)
	* sphinxdocs/build/html/_modules/G2pwd_fxye.html (modified)
	* sphinxdocs/build/html/_modules/G2sfact.html (modified)
	* sphinxdocs/build/html/_modules/G2sfact_CIF.html (modified)
	* sphinxdocs/build/html/_modules/GSASII.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIIO.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIconstrGUI.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIctrls.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIddataGUI.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIexprGUI.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIgrid.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIimgGUI.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIlattice.html (modified)
	* sphinxdocs/build/html/_modules/GSASIImapvars.html (modified)
	* sphinxdocs/build/html/_modules/GSASIImath.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIobj.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIpath.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIphsGUI.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIplot.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIpwd.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIpwdGUI.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIrestrGUI.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIsasd.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIspc.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIstrIO.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIstrMain.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIstrMath.html (modified)
	* sphinxdocs/build/html/_modules/config_example.html (modified)
	* sphinxdocs/build/html/genindex.html (modified)
	* sphinxdocs/build/html/searchindex.js (modified)
	* sphinxdocs/build/latex/GSASIIdoc.pdf (modified)
	* trunk/GSASIIspc.py (modified)
	* trunk/doc (deleted)
	* trunk/imports/G2sfact.py (modified)
	bug fix in unused grid code; doc fixes and cleanup
Fri, 01 May 2015 23:38:23 GMT toby [1831]
	* trunk/GSASIIconstrGUI.py (modified)
	* trunk/GSASIIrestrGUI.py (modified)
	* trunk/exports/G2export_CIF.py (modified)
	move remaining generic controls to G2ctrls
Fri, 01 May 2015 15:30:34 GMT vondreele [1830]
	change ftol on texture refinement - stop on real convergence
	improve ...
Thu, 30 Apr 2015 21:34:19 GMT vondreele [1829]
	fix importers for HIPD & HIPPO data
Thu, 30 Apr 2015 20:36:24 GMT toby [1828]
	more tweaks on phase data; keeps selected histogram across phase
Thu, 30 Apr 2015 19:38:20 GMT toby [1827]
	fix scrollbar problems in many places; phase data in particular
Thu, 30 Apr 2015 17:50:20 GMT vondreele [1826]
	some adjustments to DDataGUI.
Thu, 30 Apr 2015 16:37:15 GMT toby [1825]
	move Texture index
Thu, 30 Apr 2015 16:34:35 GMT toby [1824]
	move Texture index
Thu, 30 Apr 2015 16:28:12 GMT toby [1823]
	* trunk/config_example.py (modified)
	revise paint of data tab
Thu, 30 Apr 2015 16:27:28 GMT vondreele [1822]
	selections on tree now update properly
	Refine now returns to ...
Wed, 29 Apr 2015 23:05:07 GMT vondreele [1821]
	fix to Refine behavior when finished - now recovers last seen data ...
Wed, 29 Apr 2015 19:04:05 GMT vondreele [1820]
	* trunk/GSASIIlattice.py (modified)
	fix issues in reading powder peak lists (since TOF added)
	force ...
Wed, 29 Apr 2015 17:22:48 GMT toby [1819]
	* trunk/GSASIImapvars.py (modified)
	fix constraints for all test cases
Tue, 28 Apr 2015 19:49:55 GMT toby [1818]
	fix immediate constraint problem; need to double check on skipped ...
Tue, 28 Apr 2015 18:28:45 GMT vondreele [1817]
	Add plotting of all HKLF data sets together in one 3D plot
Tue, 28 Apr 2015 17:33:47 GMT vondreele [1816]
	fix penalty fxn bug
Tue, 28 Apr 2015 16:06:58 GMT vondreele [1815]
	revise MovePatternTreeToGrid to have PickId set near top & not in ...
Mon, 27 Apr 2015 22:11:13 GMT toby [1814]
	save selected tree text name at time of selection (see
	G2frame.PickId)
Mon, 27 Apr 2015 21:55:12 GMT vondreele [1813]
	revise GSAS-II exception handling - traps user aborts & I hope the ...
Mon, 27 Apr 2015 18:22:06 GMT vondreele [1812]
	* trunk/imports/G2phase_GPX.py (modified)
	make new ranId for phases imported from gpx files
	eliminate all ...
Mon, 27 Apr 2015 18:12:18 GMT toby [1811]
	allow comma as valid character in floats
Sat, 25 Apr 2015 20:05:10 GMT vondreele [1810]
	texture PO penalty fxn. now active
Sat, 25 Apr 2015 14:46:08 GMT vondreele [1809]
	fix crash in texture GUI
	fix shift arrow problem at end of sequence
Fri, 24 Apr 2015 19:20:41 GMT vondreele [1808]
	fix to sift-arrow on 1st tree level
Fri, 24 Apr 2015 19:10:50 GMT vondreele [1807]
	remove some (now) dead code
	fix shift-arrow for stepping thru tree ...
Fri, 24 Apr 2015 15:03:39 GMT vondreele [1806]
	add 'L' option to plot/not plot lines between points in seqPlots
Fri, 24 Apr 2015 02:54:49 GMT toby [1805]
	fix bug on with unused constraints and with chained equivalences; ...
Wed, 22 Apr 2015 21:46:47 GMT vondreele [1804]
	fix bug on Copy sel sample parms (bad plot)
	implement 3D pole ...
Wed, 22 Apr 2015 21:29:05 GMT toby [1803]
	fix range selection in G2MultiChoiceDialog
Tue, 21 Apr 2015 20:29:42 GMT vondreele [1802]
	change 'all' to 'Seq. ref.' for '*' items in variable lists
	remove ...
Tue, 21 Apr 2015 19:01:23 GMT toby [1801]
	fix selection problem in G2MultiChoiceDialog; range selection broken ...
Tue, 21 Apr 2015 17:16:53 GMT vondreele [1800]
	show no. space group extinct reflections in HKLF data - rejected from ...
Mon, 20 Apr 2015 21:05:49 GMT vondreele [1799]
	trap missing data error
	numpy array sph.harm. texture fit function & ...
Sat, 18 Apr 2015 22:50:54 GMT vondreele [1798]
	fix a problem witj Ka1/Ka2 data when last reflection Ka2 falls out ...
Sat, 18 Apr 2015 14:18:31 GMT vondreele [1797]
	flag HKLF space group extinct reflections (mul=0) & not count them
Fri, 17 Apr 2015 20:26:10 GMT vondreele [1796]
	fix to selected copy - bug if nothing selected!
Fri, 17 Apr 2015 19:27:53 GMT vondreele [1795]
	fix for when new PWDR data sets are created by integration & aren't ...
Fri, 17 Apr 2015 18:50:37 GMT toby [1794]
	* trunk/help/gsasII.html (modified)
	remove older tutorial section -- long overdue
Fri, 17 Apr 2015 17:31:34 GMT vondreele [1793]
	a few more corrections to texture stuff
Fri, 17 Apr 2015 16:50:01 GMT vondreele [1792]
	remove Exceptions from seqRefine; now returns & makes Message dialog ...
Thu, 16 Apr 2015 15:17:53 GMT vondreele [1791]
	use sample angles in sp.harm. PO refinement for non Bragg-Brentano ...
Wed, 15 Apr 2015 21:20:11 GMT vondreele [1790]
	remove unused FORPI from G2strMath
	New fitTexture routine to use seq ...
Tue, 14 Apr 2015 13:36:10 GMT vondreele [1789]
	fix to POData & peak picking
Mon, 13 Apr 2015 18:33:29 GMT vondreele [1788]
	fix error analysis for HKLF data
	raise upper limit on delt-F/sig to 1000
Mon, 13 Apr 2015 17:59:34 GMT vondreele [1787]
	remove user reject HKL selection from Reflection List
	implement rule ...
Fri, 10 Apr 2015 18:14:03 GMT vondreele [1786]
	fix anomalous dispersion calcs.
	fix SC weights on derivatives
Fri, 10 Apr 2015 13:59:24 GMT vondreele [1785]
	Add new routine to GSAS.py, StartProject, called by both OpenFile & ...
Thu, 09 Apr 2015 16:40:32 GMT vondreele [1784]
	Make F refinement the default
	Add a clearreject option for HKLF ...
Thu, 09 Apr 2015 13:48:20 GMT vondreele [1783]
	fix missing Azimuth error in Sample parms
Wed, 08 Apr 2015 16:42:52 GMT vondreele [1782]
	fix display of fixed wavelength selection
	show no. user rejected ...
Wed, 08 Apr 2015 15:13:30 GMT vondreele [1781]
	fix bug from old Pref.Ori. not having penalty items
	Implement colors ...
Tue, 07 Apr 2015 22:14:33 GMT vondreele [1780]
	force collapse of all children when main tree item is collapsed ...
Mon, 06 Apr 2015 20:45:25 GMT vondreele [1779]
	Add FWHM to exported peak lists
	change default F**2 refinement to ...
Mon, 06 Apr 2015 18:33:00 GMT vondreele [1778]
	allow Refine texture menu item to appear; use DestroyChildren to ...
Mon, 06 Apr 2015 00:00:17 GMT vondreele [1777]
	fixes to SH texture penalty fxn
Sun, 05 Apr 2015 00:31:34 GMT vondreele [1776]
	remove Copy, Copy flags buttons from Data display; add them as menu ...
Thu, 02 Apr 2015 20:43:31 GMT vondreele [1775]
	fix to SH texture stuff
Thu, 02 Apr 2015 18:11:03 GMT vondreele [1774]
	fix missing offset problem & the '+' command problem
Thu, 02 Apr 2015 15:56:59 GMT vondreele [1773]
	* trunk/imports/G2sfact_CIF.py (modified)
	provide sig,gam & FWHM in export of PWDR reflection set as csv & txt ...
Tue, 31 Mar 2015 17:44:58 GMT vondreele [1772]
	fix a copy flags error in DData
	add Compute average for columns in ...
Mon, 30 Mar 2015 19:04:51 GMT vondreele [1771]
	revise spherical harmonics lst output to have reasonable line lengths
Mon, 30 Mar 2015 18:39:46 GMT vondreele [1770]
	* trunk/GSASIIexprGUI.py (modified)
	moved MultipleChoicesDialog and SingleChoiceDialog from G2grid to
	G2ctrls
Mon, 30 Mar 2015 14:31:58 GMT vondreele [1769]
	remove 'All', etc. from DeleteData
Mon, 30 Mar 2015 13:24:32 GMT vondreele [1768]
	replace wx.MultiChoiceDialog with G2MultiChoiceDialog for data delete
Mon, 30 Mar 2015 12:39:25 GMT vondreele [1767]
	fix texture calculation - now matches GSAS
Fri, 27 Mar 2015 19:46:30 GMT vondreele [1766]
	correct old LANSCE/HIPD import to give correct Omega, chi & phi from ...
Thu, 26 Mar 2015 18:19:41 GMT vondreele [1765]
	fixes to peak indexing stuff
Thu, 26 Mar 2015 17:28:50 GMT vondreele [1764]
	final touches on Flat Bkg image option
Wed, 25 Mar 2015 22:25:15 GMT vondreele [1763]
	new item in imgGUI - Flat Bkg; subtracted from image on display & ...
Wed, 25 Mar 2015 20:42:15 GMT vondreele [1762]
	* trunk/imports/G2phase.py (modified)
	* trunk/imports/G2phase_CIF.py (modified)
	fix exports of reflection csv & txt files to work for CW & TOF data ...
Tue, 24 Mar 2015 21:10:52 GMT vondreele [1761]
	better fix to export csv reflections
	change default I/Ib for strain ...
Tue, 24 Mar 2015 14:05:08 GMT vondreele [1760]
	* trunk (modified)
	* trunk/Exercises (deleted)
	fix csv exporter for reflection lists
Mon, 23 Mar 2015 21:21:36 GMT vondreele [1759]
	* trunk/GSASIIpwd.py (modified)
	add two new background functions - power series in Q^2 & 1/Q^2 - from ...
Fri, 20 Mar 2015 23:33:42 GMT toby [1750]
	* trunk/Exercises/TOF_QPRR (deleted)
	* trunk/Exercises/kryptonite/KRYPTONITE.EXP (deleted)
	* trunk/Exercises/kryptonite/jadarite.cif (deleted)
	* trunk/Exercises/kryptonite/kryptonite.gpx (deleted)
	* trunk/Exercises/single crystal (deleted)
	* trunk/Exercises/sucrose (deleted)
	* trunk/Exercises/two phase (deleted)
	remove unused from trunk/Exercises
Fri, 20 Mar 2015 23:12:48 GMT toby [1748]
	* trunk/Exercises/LaB6 (deleted)
	* trunk/Exercises/MCSA (deleted)
	* trunk/Exercises/PbSO4 (deleted)
	* trunk/Exercises/Small angle (deleted)
	* trunk/Exercises/fluroapatite (deleted)
	* trunk/Exercises/garnet (deleted)
	* trunk/Exercises/images (deleted)
	* trunk/Exercises/kryptonite/11bmb_6231.fxye (deleted)
	* trunk/Exercises/kryptonite/11bmb_6231.fxye.zip (deleted)
	* trunk/Exercises/kryptonite/11bmb_6231.prm (deleted)
	* trunk/Exercises/sequential (deleted)
	* trunk/Exercises/strain-texture (deleted)
	* trunk/help/Calibration of an area detector in GSAS.htm (deleted)
	* trunk/help/Calibration of an area detector in GSAS_files (deleted)
	* trunk/help/Charge Flipping - sucrose.htm (deleted)
	* trunk/help/Charge Flipping - sucrose_files (deleted)
	* trunk/help/Charge Flipping in GSAS.htm (deleted)
	* trunk/help/Charge Flipping in GSAS_files (deleted)
	* trunk/help/Combined refinement.htm (deleted)
	* trunk/help/Combined refinement_files (deleted)
	* trunk/help/Fit Peaks.htm (deleted)
	* trunk/help/Fit Peaks_files (deleted)
	* trunk/help/Fitting Small Angle Scattering Data.htm (deleted)
	* trunk/help/Fitting Small Angle Scattering Data_files (deleted)
	* trunk/help/Integration of area detector data in GSAS.htm (deleted)
	* trunk/help/Integration of area detector data in GSAS_files (deleted)
	* trunk/help/Laboratory X.htm (deleted)
	* trunk/help/Laboratory X_files (deleted)
	* trunk/help/MCSA in GSAS.htm (deleted)
	* trunk/help/MCSA in GSAS_files (deleted)
	* trunk/help/Neutron CW Powder Data.htm (deleted)
	* trunk/help/Neutron CW Powder Data_files (deleted)
	* trunk/help/ParametricFitting.htm (deleted)
	* trunk/help/ParametricFitting_files (deleted)
	* trunk/help/Sequential Refinement of Small Angle Scattering Data.htm (deleted)
	* trunk/help/Sequential Refinement of Small Angle Scattering Data_files (deleted)
	* trunk/help/SequentialTutorial.htm (deleted)
	* trunk/help/SequentialTutorial_files (deleted)
	* trunk/help/Small Angle Image Processing.htm (deleted)
	* trunk/help/Small Angle Image Processing_files (deleted)
	* trunk/help/Small Angle Size Distribution.htm (deleted)
	* trunk/help/Small Angle Size Distribution_files (deleted)
	* trunk/help/Starting GSAS.htm (deleted)
	* trunk/help/Starting GSAS_files (deleted)
	* trunk/help/Strain fitting of 2D data in GSAS-II.htm (deleted)
	* trunk/help/Strain fitting of 2D data in GSAS-II_files (deleted)
	* trunk/help/gsasII_files (deleted)
	Major cleanup of Tutorials (help) and Exercises
Fri, 20 Mar 2015 18:44:28 GMT vondreele [1747]
	a few more SS site symmetries
