# # ChangeLog for trunk/help/gsasII.html # # Generated by Trac 1.0.13 # May 26, 2022 3:56:13 AM Mon, 07 May 2012 15:59:37 GMT toby [591] * trunk/help/Calibration of an area detector in GSAS.htm (modified) * trunk/help/Fit Peaks.htm (modified) * trunk/help/Integration of area detector data in GSAS.htm (modified) * trunk/help/Starting GSAS.htm (modified) * trunk/help/gsasII.html (modified) use svn propset svn:keywords Author Date Revision Id help/*.htm* Mon, 07 May 2012 15:55:51 GMT toby [590] * trunk/help/Calibration of an area detector in GSAS.htm (modified) * trunk/help/Fit Peaks.htm (modified) * trunk/help/Integration of area detector data in GSAS.htm (modified) * trunk/help/Starting GSAS.htm (modified) * trunk/help/gsasII.html (modified) use svn propset svn:mime-type text/html help/*.htm* Sun, 06 May 2012 20:14:22 GMT vondreele [588] * trunk/help/Calibration of an area detector in GSAS.htm (modified) * trunk/help/Calibration of an area detector in GSAS_files/filelist.xml (modified) * trunk/help/Calibration of an area detector in GSAS_files/image001.png (modified) * trunk/help/Calibration of an area detector in GSAS_files/image006.png (modified) * trunk/help/Calibration of an area detector in GSAS_files/image007.png (modified) * trunk/help/Calibration of an area detector in GSAS_files/image008.png (modified) * trunk/help/Calibration of an area detector in GSAS_files/image009.png (modified) * trunk/help/Calibration of an area detector in GSAS_files/image010.png (modified) * trunk/help/Fit Peaks.htm (modified) * trunk/help/Fit Peaks_files/filelist.xml (modified) * trunk/help/Fit Peaks_files/themedata.thmx (modified) * trunk/help/Integration of area detector data in GSAS.htm (modified) * trunk/help/Integration of area detector data in GSAS_files/filelist.xml (modified) * trunk/help/Integration of area detector data in GSAS_files/themedata.thmx (modified) * trunk/help/Starting GSAS.htm (modified) * trunk/help/Starting GSAS_files/filelist.xml (modified) * trunk/help/Starting GSAS_files/image002.jpg (modified) * trunk/help/Starting GSAS_files/themedata.thmx (modified) * trunk/help/gsasII.html (modified) * trunk/help/gsasII.html - Shortcut.lnk (deleted) * trunk/help/gsasII_files/filelist.xml (modified) * trunk/help/gsasII_files/props011.xml (modified) * trunk/help/gsasII_files/themedata.thmx (modified) Sat, 05 May 2012 15:26:06 GMT vondreele [586] * trunk/help/Fit Peaks.htm (modified) * trunk/help/Fit Peaks_files/themedata.thmx (modified) * trunk/help/Integration of area detector data in GSAS.htm (modified) * trunk/help/Integration of area detector data in GSAS_files/filelist.xml (modified) * trunk/help/Integration of area detector data in GSAS_files/image008.png (added) * trunk/help/Integration of area detector data in GSAS_files/image009.png (added) * trunk/help/Integration of area detector data in GSAS_files/themedata.thmx (modified) * trunk/help/Starting GSAS.htm (added) * trunk/help/Starting GSAS_files (added) * trunk/help/Starting GSAS_files/colorschememapping.xml (added) * trunk/help/Starting GSAS_files/filelist.xml (added) * trunk/help/Starting GSAS_files/image001.png (added) * trunk/help/Starting GSAS_files/image002.jpg (added) * trunk/help/Starting GSAS_files/item0001.xml (added) * trunk/help/Starting GSAS_files/props0002.xml (added) * trunk/help/Starting GSAS_files/themedata.thmx (added) * trunk/help/gsasII.dotx (added) * trunk/help/gsasII.html (modified) * trunk/help/gsasII.html - Shortcut.lnk (added) * trunk/help/gsasII_files/filelist.xml (modified) * trunk/help/gsasII_files/props0011.xml (added) * trunk/help/gsasII_files/themedata.thmx (modified) * trunk/help/~$libration of an area detector in GSAS.htm (added) tutorial stuff Fri, 04 May 2012 21:24:07 GMT vondreele [585] * trunk/help/Calibration of an area detector in GSAS.htm (added) * trunk/help/Calibration of an area detector in GSAS_files (added) * trunk/help/Calibration of an area detector in GSAS_files/colorschememapping.xml (added) * trunk/help/Calibration of an area detector in GSAS_files/filelist.xml (added) * trunk/help/Calibration of an area detector in GSAS_files/image001.png (added) * trunk/help/Calibration of an area detector in GSAS_files/image002.png (added) * trunk/help/Calibration of an area detector in GSAS_files/image003.jpg (added) * trunk/help/Calibration of an area detector in GSAS_files/image006.png (added) * trunk/help/Calibration of an area detector in GSAS_files/image007.png (added) * trunk/help/Calibration of an area detector in GSAS_files/image008.png (added) * trunk/help/Calibration of an area detector in GSAS_files/image009.png (added) * trunk/help/Calibration of an area detector in GSAS_files/image010.png (added) * trunk/help/Calibration of an area detector in GSAS_files/image011.png (added) * trunk/help/Calibration of an area detector in GSAS_files/image012.png (added) * trunk/help/Calibration of an area detector in GSAS_files/image013.png (added) * trunk/help/Calibration of an area detector in GSAS_files/themedata.thmx (added) * trunk/help/Fit Peaks.htm (added) * trunk/help/Fit Peaks_files (added) * trunk/help/Fit Peaks_files/colorschememapping.xml (added) * trunk/help/Fit Peaks_files/filelist.xml (added) * trunk/help/Fit Peaks_files/themedata.thmx (added) * trunk/help/Integration of area detector data in GSAS.htm (added) * trunk/help/Integration of area detector data in GSAS_files (added) * trunk/help/Integration of area detector data in GSAS_files/colorschememapping.xml (added) * trunk/help/Integration of area detector data in GSAS_files/filelist.xml (added) * trunk/help/Integration of area detector data in GSAS_files/image001.png (added) * trunk/help/Integration of area detector data in GSAS_files/image002.png (added) * trunk/help/Integration of area detector data in GSAS_files/image003.png (added) * trunk/help/Integration of area detector data in GSAS_files/image004.png (added) * trunk/help/Integration of area detector data in GSAS_files/image005.png (added) * trunk/help/Integration of area detector data in GSAS_files/image006.png (added) * trunk/help/Integration of area detector data in GSAS_files/image007.png (added) * trunk/help/Integration of area detector data in GSAS_files/themedata.thmx (added) * trunk/help/gsasII.html (modified) * trunk/help/gsasII_files (added) * trunk/help/gsasII_files/colorschememapping.xml (added) * trunk/help/gsasII_files/filelist.xml (added) * trunk/help/gsasII_files/image001.png (added) * trunk/help/gsasII_files/image002.gif (added) * trunk/help/gsasII_files/image003.png (added) * trunk/help/gsasII_files/image004.gif (added) * trunk/help/gsasII_files/item0010.xml (added) * trunk/help/gsasII_files/props011.xml (added) * trunk/help/gsasII_files/themedata.thmx (added) add tutorials Fri, 20 Apr 2012 15:07:01 GMT vondreele [563] * trunk/ElementTable.py (modified) * trunk/GSASIIElemGUI.py (modified) * trunk/GSASIImath.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/help/gsasII.html (modified) add "None" element to table - used for charge flipping mods to ... Mon, 09 Apr 2012 19:54:22 GMT vondreele [536] * trunk/GSASII.py (modified) * trunk/GSASIIimage.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/help/gsasII.html (modified) add more text to help file refactor image GUI stuff add centerAzm ... Sun, 11 Mar 2012 17:50:03 GMT vondreele [519] * trunk/GSASII.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIstruct.py (modified) * trunk/help/gsasII.html (modified) fixes to ViewParmDialog try to get size right add copy of refinement ... Wed, 07 Mar 2012 19:27:17 GMT vondreele [516] * trunk/help/gsasII.html (modified) add to help Wed, 07 Mar 2012 16:30:29 GMT vondreele [515] * trunk/GSASII.py (modified) * trunk/GSASIIplot.py (modified) * trunk/help/gsasII.html (modified) add num variables to ViewLSparams final fixup of error analysis ... Fri, 24 Feb 2012 19:11:44 GMT vondreele [493] * trunk/GSASII.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIstruct.py (modified) * trunk/help/gsasII.html (modified) clean up help stuff - get OK respons from resize & now scrolls down a ... Fri, 17 Feb 2012 20:59:59 GMT vondreele [486] * trunk/GSASIIgrid.py (modified) * trunk/GSASIImath.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/help/gsasII.html (modified) edit help & fix references to it begin implementation of Fourier calcs. Tue, 31 Jan 2012 21:40:48 GMT vondreele [460] * trunk/GSASIIgrid.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIstruct.py (modified) * trunk/help/gsasII.html (modified) add more text to help/gsasII.html finish best plane calcs allow ... Wed, 25 Jan 2012 15:24:20 GMT vondreele [457] * trunk/GSASIIIO.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIImath.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIstruct.py (modified) * trunk/help/gsasII.html (modified) begin distance angle calcs move gpxfile routines from ... Wed, 04 Jan 2012 19:16:50 GMT toby [449] * trunk/GSASII.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIplot.py (modified) * trunk/help/gsasII.html (modified) Help updates: refactor help routine; use internal browser on Windows; ... Fri, 16 Dec 2011 21:30:04 GMT toby [445] * trunk/GSASIIgrid.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/help/gsasII.html (modified) 1st stop on help fixes Wed, 30 Nov 2011 23:02:08 GMT vondreele [430] * trunk/GSASIIIO.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/help/gsasII.html (modified) NB: There are a few stray print statements in this version Some work ... Tue, 22 Nov 2011 21:21:38 GMT toby [427] * trunk/GSASII.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/binmac2.7/pypowder.so (added) * trunk/gsas2.png (added) * trunk/help (added) * trunk/help/gsas2logo.png (added) * trunk/help/gsasII.html (added) implement HTML help
