# # ChangeLog for trunk/help/Starting GSAS.htm # # Generated by Trac 1.0.13 # May 25, 2022 4:32:38 AM Mon, 07 May 2012 15:59:37 GMT toby [591] * trunk/help/Calibration of an area detector in GSAS.htm (modified) * trunk/help/Fit Peaks.htm (modified) * trunk/help/Integration of area detector data in GSAS.htm (modified) * trunk/help/Starting GSAS.htm (modified) * trunk/help/gsasII.html (modified) use svn propset svn:keywords Author Date Revision Id help/*.htm* Mon, 07 May 2012 15:55:51 GMT toby [590] * trunk/help/Calibration of an area detector in GSAS.htm (modified) * trunk/help/Fit Peaks.htm (modified) * trunk/help/Integration of area detector data in GSAS.htm (modified) * trunk/help/Starting GSAS.htm (modified) * trunk/help/gsasII.html (modified) use svn propset svn:mime-type text/html help/*.htm* Sun, 06 May 2012 20:14:22 GMT vondreele [588] * trunk/help/Calibration of an area detector in GSAS.htm (modified) * trunk/help/Calibration of an area detector in GSAS_files/filelist.xml (modified) * trunk/help/Calibration of an area detector in GSAS_files/image001.png (modified) * trunk/help/Calibration of an area detector in GSAS_files/image006.png (modified) * trunk/help/Calibration of an area detector in GSAS_files/image007.png (modified) * trunk/help/Calibration of an area detector in GSAS_files/image008.png (modified) * trunk/help/Calibration of an area detector in GSAS_files/image009.png (modified) * trunk/help/Calibration of an area detector in GSAS_files/image010.png (modified) * trunk/help/Fit Peaks.htm (modified) * trunk/help/Fit Peaks_files/filelist.xml (modified) * trunk/help/Fit Peaks_files/themedata.thmx (modified) * trunk/help/Integration of area detector data in GSAS.htm (modified) * trunk/help/Integration of area detector data in GSAS_files/filelist.xml (modified) * trunk/help/Integration of area detector data in GSAS_files/themedata.thmx (modified) * trunk/help/Starting GSAS.htm (modified) * trunk/help/Starting GSAS_files/filelist.xml (modified) * trunk/help/Starting GSAS_files/image002.jpg (modified) * trunk/help/Starting GSAS_files/themedata.thmx (modified) * trunk/help/gsasII.html (modified) * trunk/help/gsasII.html - Shortcut.lnk (deleted) * trunk/help/gsasII_files/filelist.xml (modified) * trunk/help/gsasII_files/props011.xml (modified) * trunk/help/gsasII_files/themedata.thmx (modified) Sat, 05 May 2012 15:26:06 GMT vondreele [586] * trunk/help/Fit Peaks.htm (modified) * trunk/help/Fit Peaks_files/themedata.thmx (modified) * trunk/help/Integration of area detector data in GSAS.htm (modified) * trunk/help/Integration of area detector data in GSAS_files/filelist.xml (modified) * trunk/help/Integration of area detector data in GSAS_files/image008.png (added) * trunk/help/Integration of area detector data in GSAS_files/image009.png (added) * trunk/help/Integration of area detector data in GSAS_files/themedata.thmx (modified) * trunk/help/Starting GSAS.htm (added) * trunk/help/Starting GSAS_files (added) * trunk/help/Starting GSAS_files/colorschememapping.xml (added) * trunk/help/Starting GSAS_files/filelist.xml (added) * trunk/help/Starting GSAS_files/image001.png (added) * trunk/help/Starting GSAS_files/image002.jpg (added) * trunk/help/Starting GSAS_files/item0001.xml (added) * trunk/help/Starting GSAS_files/props0002.xml (added) * trunk/help/Starting GSAS_files/themedata.thmx (added) * trunk/help/gsasII.dotx (added) * trunk/help/gsasII.html (modified) * trunk/help/gsasII.html - Shortcut.lnk (added) * trunk/help/gsasII_files/filelist.xml (modified) * trunk/help/gsasII_files/props0011.xml (added) * trunk/help/gsasII_files/themedata.thmx (modified) * trunk/help/~$libration of an area detector in GSAS.htm (added) tutorial stuff
