# ChangeLog for trunk/config_example.py
# Generated by Trac 1.0.13
# Jun 26, 2025 7:54:22 AM
Fri, 06 Mar 2020 21:05:22 GMT toby [4345]
	* trunk/G2compare.py (modified)
	* trunk/GSASIIIO.py (modified)
	* trunk/GSASIIautoInt.py (modified)
	* trunk/GSASIIctrlGUI.py (modified)
	* trunk/GSASIIimgGUI.py (modified)
	* trunk/config_example.py (modified)
	Add more image settings to preferences; prevent save of config.py ...
Sat, 10 Aug 2019 15:22:02 GMT toby [4085]
	* trunk/GSASIIdataGUI.py (modified)
	* trunk/GSASIIpath.py (modified)
	Add menu accelerator keys & recently used menu
Mon, 13 May 2019 03:21:49 GMT toby [3974]
	* trunk/GSASIIfiles.py (modified)
	more minor doc updates
Mon, 13 May 2019 03:08:22 GMT toby [3973]
	Load all fix; doc updates
Sun, 10 Feb 2019 22:40:06 GMT toby [3814]
	* trunk/GSASIIscriptable.py (modified)
	* trunk/GSASIIstrIO.py (modified)
	refactor to move some IO-only routines; add initial image support to ...
Tue, 11 Dec 2018 20:11:02 GMT vondreele [3759]
	* trunk/GSASIImath.py (modified)
	* trunk/GSASIIphsGUI.py (modified)
	* trunk/GSASIIplot.py (modified)
	* trunk/GSASIIstrMath.py (modified)
	add fullIntegrate = True to configuration stuff
	add input control ...
Tue, 30 Oct 2018 13:50:07 GMT vondreele [3712]
	* trunk/GSASIIpwd.py (modified)
	* trunk/GSASIIpwdGUI.py (modified)
	add new configuration item: PDF_Rmax maximum radius for G(r) ...
Tue, 15 May 2018 17:24:54 GMT vondreele [3388]
	added Plot Colors to configuration to allow user color selection for ...
Tue, 17 Apr 2018 22:00:36 GMT vondreele [3348]
	add new configuration for selecting instprm first
	add save.load for ...
Thu, 15 Feb 2018 22:30:05 GMT vondreele [3286]
	* trunk/GSASIIspc.py (modified)
	add modulation movies to structure drawings; makes gif files for both ...
Mon, 18 Dec 2017 21:18:15 GMT toby [3195]
	* trunk/imports/G2img_1TIF.py (modified)
	generalize 1ID metadata import to column-oriented; add routine to ...
Sun, 10 Dec 2017 16:34:39 GMT toby [3189]
	minor docs updates
Sun, 10 Dec 2017 16:14:04 GMT toby [3187]
	* trunk/GSASIIobj.py (modified)
	* trunk/docs/source/GSASIIscripts.rst (modified)
	* trunk/docs/source/GSASIIutil.rst (modified)
	* trunk/docs/source/index.rst (modified)
	* trunk/makeTutorial.py (modified)
	misc docs cleanups; add 1-ID metadata reader & new config variable
Fri, 01 Dec 2017 18:36:31 GMT vondreele [3170]
	* trunk/testSSymbols.py (modified)
	implement saving of data & plot window sizes (along with positions) ...
Thu, 21 Sep 2017 19:42:50 GMT vondreele [3095]
	* trunk/GSASIIstrMain.py (modified)
	add new confit parm: Show_timing
	enable editing of the Use column in ...
Wed, 06 Sep 2017 19:58:12 GMT vondreele [3051]
	* trunk (modified)
	* trunk/binwin2.7 (deleted)
	modify text for Contour_color
Tue, 05 Sep 2017 21:00:51 GMT vondreele [3048]
	remove item from config_example.py
	fix bug in FindAtomsDraw ...
Sun, 03 Sep 2017 16:18:33 GMT toby [3041]
	* trunk/GSASIImpsubs.py (modified)
	Fully implement multiprocessing on reflection loops, but currently ...
Wed, 30 Aug 2017 20:09:56 GMT vondreele [3033]
	* trunk (modified)
	fixes to protein validate, "old" works; not "old" close but not
	perfect
Fri, 11 Aug 2017 22:34:54 GMT toby [3000]
	* trunk (modified)
	* trunk/AllBinaries (copied)
	* trunk/GSASII.py (modified)
	* trunk/GSASIIconstrGUI.py (modified)
	* trunk/GSASIIctrlGUI.py (copied)
	* trunk/GSASIIctrls.py (deleted)
	* trunk/GSASIIdataGUI.py (copied)
	* trunk/GSASIIddataGUI.py (modified)
	* trunk/GSASIIexprGUI.py (modified)
	* trunk/GSASIIfiles.py (copied)
	* trunk/GSASIIgrid.py (deleted)
	* trunk/GSASIIlattice.py (modified)
	* trunk/GSASIIlog.py (modified)
	* trunk/GSASIImpsubs.py (copied)
	* trunk/GSASIIrestrGUI.py (modified)
	* trunk/basinhopping.py (modified)
	* trunk/bindist (copied)
	* trunk/binlinux2.7 (deleted)
	* trunk/binlinux64-2.7 (deleted)
	* trunk/binmac2.7 (deleted)
	* trunk/binmac64-2.7 (deleted)
	* trunk/binwin64-2.7 (deleted)
	* trunk/docs/source/GSASIIGUI.rst (modified)
	* trunk/docs/source/GSASIIGUIr.rst (modified)
	* trunk/docs/source/conf.py (modified)
	* trunk/exports/G2export_CIF.py (modified)
	* trunk/exports/G2export_PDB.py (modified)
	* trunk/exports/G2export_examples.py (modified)
	* trunk/exports/G2export_map.py (modified)
	* trunk/gltext.py (modified)
	* trunk/imports/G2phase_GPX.py (modified)
	make the two frame version the trunk as we hit version 3000
Wed, 14 Jun 2017 21:11:42 GMT vondreele [2863]
	* trunk/GSASIIctrls.py (modified)
	* trunk/GSASIIsasd.py (modified)
	* trunk/fsource/SConstruct (modified)
	* trunk/scanCCD.py (modified)
	extend contour color selection to include reversed ones (doubles the ...
Wed, 19 Apr 2017 18:03:32 GMT toby [2796]
	adjustments for tickmarks
Fri, 14 Apr 2017 15:45:44 GMT vondreele [2782]
	add autoscaling to autointegration
	impose check on rescale limits - ...
Mon, 10 Apr 2017 16:33:13 GMT toby [2775]
	make autoint polltime adjustable
Mon, 26 Dec 2016 20:24:57 GMT toby [2603]
	* trunk/help/gsasII.html (modified)
	more editing of masks: Put up more title, allow RB to cancel; create ...
Sat, 27 Aug 2016 13:30:30 GMT vondreele [2455]
	implement Clip_on as config parameter with True as default
Fri, 22 Jan 2016 19:05:12 GMT toby [2133]
	* trunk/atmdata.py (modified)
	* trunk/defaultIparms.py (modified)
	* trunk/exports/G2export_FIT2D.py (modified)
	* trunk/imports/G2img_ADSC.py (modified)
	* trunk/imports/G2img_CheMin.py (modified)
	* trunk/imports/G2img_EDF.py (modified)
	* trunk/imports/G2img_GE.py (modified)
	* trunk/imports/G2img_HDF5.py (modified)
	* trunk/imports/G2img_MAR.py (modified)
	* trunk/imports/G2img_Rigaku.py (modified)
	* trunk/imports/G2img_SumG2.py (modified)
	* trunk/imports/G2pwd_csv.py (modified)
	* trunk/makeBat.py (modified)
	fix svn settings for revisions & line ends
Sun, 27 Dec 2015 04:22:09 GMT toby [2109]
	* trunk/GSASIIgrid.py (modified)
	Andrey's enhancement: keep track of last GPX, import & export ...
Mon, 12 Oct 2015 22:31:16 GMT toby [2003]
	* trunk/imports/G2img_1TIF.py (moved)
	* trunk/imports/G2img_CheMin.py (moved)
	* trunk/imports/G2img_SumG2.py (moved)
	Make Transpose a config opt; new routine to read images with import ...
Mon, 07 Sep 2015 18:25:13 GMT toby [1971]
	Add preferences option to edit configuration options
Thu, 30 Apr 2015 16:28:12 GMT toby [1823]
	revise paint of data tab
Tue, 17 Mar 2015 18:34:37 GMT toby [1729]
	switch default download dir; remove old tutorial help item; pretty-up ...
Mon, 16 Mar 2015 21:20:06 GMT toby [1719]
	implement default starting and import directories
Sat, 14 Mar 2015 22:35:03 GMT toby [1709]
	* sphinxdocs/addnew.sh (modified)
	* sphinxdocs/build/html/GSASIIGUI.html (modified)
	* sphinxdocs/build/html/GSASIIGUIr.html (modified)
	* sphinxdocs/build/html/GSASIIindex.html (modified)
	* sphinxdocs/build/html/GSASIImath.html (modified)
	* sphinxdocs/build/html/GSASIIobj.html (modified)
	* sphinxdocs/build/html/GSASIIplot.html (modified)
	* sphinxdocs/build/html/GSASIIpwd.html (modified)
	* sphinxdocs/build/html/GSASIIstruc.html (modified)
	* sphinxdocs/build/html/GSASIIutil.html (modified)
	* sphinxdocs/build/html/_modules/G2export_CIF.html (modified)
	* sphinxdocs/build/html/_modules/G2export_csv.html (modified)
	* sphinxdocs/build/html/_modules/G2export_pwdr.html (modified)
	* sphinxdocs/build/html/_modules/G2export_shelx.html (modified)
	* sphinxdocs/build/html/_modules/G2phase.html (modified)
	* sphinxdocs/build/html/_modules/G2pwd_GPX.html (modified)
	* sphinxdocs/build/html/_modules/G2pwd_fxye.html (modified)
	* sphinxdocs/build/html/_modules/G2pwd_xye.html (modified)
	* sphinxdocs/build/html/_modules/G2sfact.html (modified)
	* sphinxdocs/build/html/_modules/G2sfact_CIF.html (modified)
	* sphinxdocs/build/html/_modules/GSASII.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIElem.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIElemGUI.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIIO.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIconstrGUI.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIctrls.html (added)
	* sphinxdocs/build/html/_modules/GSASIIddataGUI.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIexprGUI.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIgrid.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIimage.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIimgGUI.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIindex.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIlattice.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIlog.html (modified)
	* sphinxdocs/build/html/_modules/GSASIImapvars.html (modified)
	* sphinxdocs/build/html/_modules/GSASIImath.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIobj.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIpath.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIphsGUI.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIplot.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIpwd.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIpwdGUI.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIpy3.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIrestrGUI.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIspc.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIstrIO.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIstrMain.html (modified)
	* sphinxdocs/build/html/_modules/GSASIIstrMath.html (modified)
	* sphinxdocs/build/html/_modules/config_example.html (modified)
	* sphinxdocs/build/html/_modules/index.html (modified)
	* sphinxdocs/build/html/exports.html (modified)
	* sphinxdocs/build/html/genindex.html (modified)
	* sphinxdocs/build/html/imports.html (modified)
	* sphinxdocs/build/html/index.html (modified)
	* sphinxdocs/build/html/py-modindex.html (modified)
	* sphinxdocs/build/html/searchindex.js (modified)
	* sphinxdocs/build/latex/GSASIIdoc.pdf (modified)
	* sphinxdocs/source/GSASIIGUIr.rst (modified)
	* sphinxdocs/source/_static (added)
	change sphinx docs links; rebuild & fixing minor formatting
Thu, 12 Mar 2015 04:30:57 GMT toby [1696]
	more work on seq. ref. with differing variables; rework svn ...
Tue, 03 Mar 2015 21:01:18 GMT toby [1688]
	allow non-identical sequential refinement when copynext is not used ...
Mon, 16 Feb 2015 20:46:06 GMT toby [1657]
	migrate help from G2grid; set instparms in Powder imports; seach for ...
Mon, 03 Nov 2014 22:13:39 GMT vondreele [1560]
	fix Dij calculations & derivatives
Mon, 03 Nov 2014 04:11:53 GMT toby [1558]
	add some debug options with pdb and IPython
Thu, 02 Oct 2014 21:06:45 GMT toby [1513]
	* trunk/config_example.py (moved)
	* trunk/imports/G2phase.py (modified)
	* trunk/sphinxdocs/build/html/GSASII.html (modified)
	* trunk/sphinxdocs/build/html/GSASIIGUI.html (modified)
	* trunk/sphinxdocs/build/html/GSASIIGUIr.html (modified)
	* trunk/sphinxdocs/build/html/GSASIIimage.html (modified)
	* trunk/sphinxdocs/build/html/GSASIIindex.html (modified)
	* trunk/sphinxdocs/build/html/GSASIImapvars.html (modified)
	* trunk/sphinxdocs/build/html/GSASIImath.html (modified)
	* trunk/sphinxdocs/build/html/GSASIIobj.html (modified)
	* trunk/sphinxdocs/build/html/GSASIIplot.html (modified)
	* trunk/sphinxdocs/build/html/GSASIIpwd.html (modified)
	* trunk/sphinxdocs/build/html/GSASIIscripts.html (modified)
	* trunk/sphinxdocs/build/html/GSASIIstruc.html (modified)
	* trunk/sphinxdocs/build/html/GSASIIutil.html (modified)
	* trunk/sphinxdocs/build/html/SAS.html (modified)
	* trunk/sphinxdocs/build/html/_modules/G2export_CIF.html (modified)
	* trunk/sphinxdocs/build/html/_modules/G2export_PDB.html (modified)
	* trunk/sphinxdocs/build/html/_modules/G2export_csv.html (modified)
	* trunk/sphinxdocs/build/html/_modules/G2export_examples.html (modified)
	* trunk/sphinxdocs/build/html/_modules/G2export_image.html (modified)
	* trunk/sphinxdocs/build/html/_modules/G2export_map.html (modified)
	* trunk/sphinxdocs/build/html/_modules/G2export_pwdr.html (modified)
	* trunk/sphinxdocs/build/html/_modules/G2export_shelx.html (modified)
	* trunk/sphinxdocs/build/html/_modules/G2phase.html (modified)
	* trunk/sphinxdocs/build/html/_modules/G2phase_CIF.html (modified)
	* trunk/sphinxdocs/build/html/_modules/G2phase_GPX.html (modified)
	* trunk/sphinxdocs/build/html/_modules/G2pwd_CIF.html (modified)
	* trunk/sphinxdocs/build/html/_modules/G2pwd_GPX.html (modified)
	* trunk/sphinxdocs/build/html/_modules/G2pwd_fxye.html (modified)
	* trunk/sphinxdocs/build/html/_modules/G2pwd_xye.html (modified)
	* trunk/sphinxdocs/build/html/_modules/G2sad_xye.html (modified)
	* trunk/sphinxdocs/build/html/_modules/G2sfact.html (modified)
	* trunk/sphinxdocs/build/html/_modules/G2sfact_CIF.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASII.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIElem.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIElemGUI.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIIO.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIconstrGUI.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIddataGUI.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIexprGUI.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIgrid.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIimage.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIimgGUI.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIindex.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIlattice.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIlog.html (added)
	* trunk/sphinxdocs/build/html/_modules/GSASIImapvars.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIImath.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIobj.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIpath.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIphsGUI.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIplot.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIpwd.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIpwdGUI.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIpy3.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIrestrGUI.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIsasd.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIspc.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIstrIO.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIstrMain.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIstrMath.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIItestplot.html (modified)
	* trunk/sphinxdocs/build/html/_modules/ReadMarCCDFrame.html (modified)
	* trunk/sphinxdocs/build/html/_modules/config_example.html (added)
	* trunk/sphinxdocs/build/html/_modules/gltext.html (modified)
	* trunk/sphinxdocs/build/html/_modules/index.html (modified)
	* trunk/sphinxdocs/build/html/_modules/makeMacApp.html (modified)
	* trunk/sphinxdocs/build/html/_modules/scanCCD.html (modified)
	* trunk/sphinxdocs/build/html/_modules/testDeriv.html (modified)
	* trunk/sphinxdocs/build/html/_modules/unit_tests.html (modified)
	* trunk/sphinxdocs/build/html/_static/basic.css (modified)
	* trunk/sphinxdocs/build/html/_static/default.css (modified)
	* trunk/sphinxdocs/build/html/_static/doctools.js (modified)
	* trunk/sphinxdocs/build/html/_static/jquery.js (modified)
	* trunk/sphinxdocs/build/html/_static/pygments.css (modified)
	* trunk/sphinxdocs/build/html/_static/searchtools.js (modified)
	* trunk/sphinxdocs/build/html/_static/sidebar.js (modified)
	* trunk/sphinxdocs/build/html/_static/underscore.js (modified)
	* trunk/sphinxdocs/build/html/_static/websupport.js (modified)
	* trunk/sphinxdocs/build/html/exports.html (modified)
	* trunk/sphinxdocs/build/html/genindex.html (modified)
	* trunk/sphinxdocs/build/html/imports.html (modified)
	* trunk/sphinxdocs/build/html/index.html (modified)
	* trunk/sphinxdocs/build/html/py-modindex.html (modified)
	* trunk/sphinxdocs/build/html/search.html (modified)
	* trunk/sphinxdocs/build/html/searchindex.js (modified)
	* trunk/sphinxdocs/build/latex/GSASIIdoc.pdf (modified)
	* trunk/sphinxdocs/find_undoc.py (modified)
	* trunk/sphinxdocs/source/GSASIIutil.rst (modified)
	update and rebuild docs
Thu, 02 Oct 2014 03:35:23 GMT toby [1512]
	* trunk/GSASIIlog.py (added)
	* trunk/config.py.example (added)
	implement logging and config storage
