# # ChangeLog for trunk/bindist # # Generated by Trac 1.0.13 # May 22, 2022 11:29:28 PM Thu, 07 Jan 2021 05:19:21 GMT toby [4733] * trunk/bindist/emptydir.txt (added) add placeholder Fri, 11 Aug 2017 22:34:54 GMT toby [3000] * trunk (modified) * trunk/AllBinaries (copied) * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIconstrGUI.py (modified) * trunk/GSASIIctrlGUI.py (copied) * trunk/GSASIIctrls.py (deleted) * trunk/GSASIIdataGUI.py (copied) * trunk/GSASIIddataGUI.py (modified) * trunk/GSASIIexprGUI.py (modified) * trunk/GSASIIfiles.py (copied) * trunk/GSASIIgrid.py (deleted) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIlattice.py (modified) * trunk/GSASIIlog.py (modified) * trunk/GSASIImath.py (modified) * trunk/GSASIImpsubs.py (copied) * trunk/GSASIIobj.py (modified) * trunk/GSASIIpath.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwd.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIrestrGUI.py (modified) * trunk/GSASIIscriptable.py (modified) * trunk/GSASIIstrIO.py (modified) * trunk/GSASIIstrMain.py (modified) * trunk/GSASIIstrMath.py (modified) * trunk/basinhopping.py (modified) * trunk/bindist (copied) * trunk/binlinux2.7 (deleted) * trunk/binlinux64-2.7 (deleted) * trunk/binmac2.7 (deleted) * trunk/binmac64-2.7 (deleted) * trunk/binwin2.7 (deleted) * trunk/binwin64-2.7 (deleted) * trunk/config_example.py (modified) * trunk/docs/source/GSASIIGUI.rst (modified) * trunk/docs/source/GSASIIGUIr.rst (modified) * trunk/docs/source/GSASIIscripts.rst (modified) * trunk/docs/source/conf.py (modified) * trunk/docs/source/index.rst (modified) * trunk/exports/G2export_CIF.py (modified) * trunk/exports/G2export_PDB.py (modified) * trunk/exports/G2export_examples.py (modified) * trunk/exports/G2export_map.py (modified) * trunk/gltext.py (modified) * trunk/imports/G2phase_GPX.py (modified) * trunk/testSSymbols.py (modified) make the two frame version the trunk as we hit version 3000 Mon, 03 Jul 2017 00:27:09 GMT toby [2895] * branch/2frame/ElementTable.py (copied) * branch/2frame/FormFactors.py (copied) * branch/2frame/GSASII.py (modified) * branch/2frame/GSASIIctrls.py (modified) * branch/2frame/GSASIIgrid.py (modified) * branch/2frame/GSASIImapvars.py (copied) * branch/2frame/GSASIIobj.py (copied) * branch/2frame/GSASIIpath.py (copied) * branch/2frame/GSASIIphsGUI.py (modified) * branch/2frame/GSASIIplot.py (modified) * branch/2frame/GSASIIpy3.py (copied) * branch/2frame/GSASIIscriptable.py (copied) * branch/2frame/GSASIIspc.py (copied) * branch/2frame/GSASIIstrMain.py (copied) * branch/2frame/GSASIIstrMath.py (copied) * branch/2frame/GSASIItestplot.py (copied) * branch/2frame/ImageCalibrants.py (copied) * branch/2frame/ReadMarCCDFrame.py (copied) * branch/2frame/Substances.py (copied) * branch/2frame/atmdata.py (copied) * branch/2frame/basinhopping.py (copied) * branch/2frame/bindist (added) * branch/2frame/makeBat.py (copied) * branch/2frame/makeMacApp.py (copied) * branch/2frame/scanCCD.py (copied) * branch/2frame/testDeriv.py (copied) * branch/2frame/testSSymbols.py (copied) merge trunk changes to 2984
