# # ChangeLog for trunk/GSASIIstrMain.py # # Generated by Trac 1.0.13 # Jul 9, 2025 12:40:05 PM Wed, 23 Apr 2014 21:32:15 GMT vondreele [1297] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIsasd.py (modified) * trunk/GSASIIstrMain.py (modified) setup sequential small angle refinements & display includes copy & ... Mon, 21 Apr 2014 19:48:45 GMT toby [1291] * trunk/GSASIIstrMain.py (modified) add Rfactors to SeqRef; check variables for consistency after constraints Sat, 19 Apr 2014 23:37:07 GMT toby [1289] * trunk/GSASIIstrMain.py (modified) Fix bug in copy of histogram parms on Copy Next Fri, 18 Apr 2014 15:22:29 GMT toby [1282] * trunk/GSASII.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIImath.py (modified) * trunk/GSASIIobj.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIstrMain.py (modified) sequential refinement updates Thu, 13 Mar 2014 19:16:20 GMT vondreele [1248] * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimage.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwd.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIsasd.py (modified) * trunk/GSASIIstrIO.py (modified) * trunk/GSASIIstrMain.py (modified) * trunk/GSASIIstrMath.py (modified) add setscale for SASD data don't square the 1/cos(2-theta) ... Wed, 12 Mar 2014 20:46:47 GMT toby [1247] * trunk/GSASIIconstrGUI.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIImapvars.py (modified) * trunk/GSASIIobj.py (modified) * trunk/GSASIIstrMain.py (modified) allow wildcarded-histogram constraint input; implement for seq ... Mon, 10 Mar 2014 19:06:56 GMT toby [1243] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIImapvars.py (modified) * trunk/GSASIIstrMain.py (modified) fix constraints use in sequential refinements Mon, 10 Mar 2014 14:30:49 GMT vondreele [1242] * trunk/GSASIIstrIO.py (modified) * trunk/GSASIIstrMain.py (modified) minor mods to sequential refinement print controls output Sat, 08 Mar 2014 17:19:45 GMT vondreele [1241] * trunk/GSASIIstrMain.py (modified) copy next now allows reverse & skipped histograms Fri, 07 Mar 2014 22:18:27 GMT vondreele [1240] * trunk/GSASIIgrid.py (modified) * trunk/GSASIIstrMain.py (modified) add control for copying parms from one histogram to next in a ... Fri, 07 Mar 2014 19:59:58 GMT vondreele [1239] * trunk/GSASIIddataGUI.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIstrMain.py (modified) * trunk/GSASIIstrMath.py (modified) wx.ALIGN_CENTER_VERTICAL to WACV in G2ddataGUI fix data frame size ... Thu, 06 Mar 2014 03:59:35 GMT toby [1238] * trunk/GSASIIstrMain.py (modified) improve seq. ref. error msg; add debug printing Mon, 11 Nov 2013 02:32:26 GMT toby [1143] * trunk/GSASII.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIImapvars.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIstrIO.py (modified) * trunk/GSASIIstrMain.py (modified) rework constraints to handle names and refine flag for new var (input ... Thu, 07 Nov 2013 20:46:36 GMT toby [1141] * trunk/GSASII.py (modified) * trunk/GSASIIconstrGUI.py (modified) * trunk/GSASIIobj.py (modified) * trunk/GSASIIstrIO.py (modified) * trunk/GSASIIstrMain.py (modified) minor tweaks: move indexing of Ids to histogram load, remove Type ... Thu, 07 Nov 2013 18:14:41 GMT toby [1139] * trunk/GSASIIstrMain.py (modified) missing def Thu, 07 Nov 2013 18:12:55 GMT toby [1138] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIconstrGUI.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIImapvars.py (modified) * trunk/GSASIIobj.py (modified) * trunk/GSASIIstrIO.py (modified) * trunk/GSASIIstrMain.py (modified) major constraints revision Mon, 28 Oct 2013 20:32:05 GMT vondreele [1125] * trunk/GSASII.py (modified) * trunk/GSASIIElem.py (modified) * trunk/GSASIIstrIO.py (modified) * trunk/GSASIIstrMain.py (modified) * trunk/GSASIIstrMath.py (modified) StructureFactor2 does SF calculation for entire block of reflection - ... Thu, 03 Oct 2013 18:11:47 GMT toby [1077] * trunk/FormFactors.py (modified) * trunk/GSASII.py (modified) * trunk/GSASIIconstrGUI.py (modified) * trunk/GSASIIdata.py (modified) * trunk/GSASIIddataGUI.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIobj.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpy3.py (modified) * trunk/GSASIIrestrGUI.py (modified) * trunk/GSASIIstrIO.py (modified) * trunk/GSASIIstrMain.py (modified) * trunk/GSASIIstrMath.py (modified) * trunk/GSASIItestplot.py (modified) * trunk/ImageCalibrants.py (modified) * trunk/ReadMarCCDFrame.py (modified) * trunk/exports/G2cif.py (modified) * trunk/gltext.py (modified) * trunk/imports/G2phase.py (modified) * trunk/imports/G2phase_CIF.py (modified) * trunk/imports/G2phase_GPX.py (modified) * trunk/imports/G2pwd_CIF.py (modified) * trunk/imports/G2pwd_GPX.py (modified) * trunk/imports/G2pwd_fxye.py (modified) * trunk/imports/G2pwd_xye.py (modified) * trunk/imports/G2sfact.py (modified) * trunk/imports/G2sfact_CIF.py (modified) * trunk/makeMacApp.py (modified) * trunk/scanCCD.py (modified) * trunk/sphinxdocs/build/html/GSASII.html (modified) * trunk/sphinxdocs/build/html/GSASIIGUI.html (modified) * trunk/sphinxdocs/build/html/GSASIIGUIr.html (modified) * trunk/sphinxdocs/build/html/GSASIImath.html (modified) * trunk/sphinxdocs/build/html/GSASIIobj.html (modified) * trunk/sphinxdocs/build/html/GSASIIplot.html (modified) * trunk/sphinxdocs/build/html/GSASIIpwd.html (modified) * trunk/sphinxdocs/build/html/GSASIIstruc.html (modified) * trunk/sphinxdocs/build/html/GSASIIutil.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASII.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIElem.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIElemGUI.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIIO.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIconstrGUI.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIddataGUI.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIgrid.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIimage.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIimgGUI.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIlattice.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIImapvars.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIImath.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIobj.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIpath.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIphsGUI.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIplot.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIpwd.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIpwdGUI.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIpy3.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIspc.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIstrIO.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIstrMain.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIstrMath.html (modified) * trunk/sphinxdocs/build/html/genindex.html (modified) * trunk/sphinxdocs/build/html/index.html (modified) * trunk/sphinxdocs/build/html/searchindex.js (modified) * trunk/sphinxdocs/build/latex/GSASIIdoc.pdf (modified) * trunk/testDeriv.py (modified) * trunk/unit_tests.py (modified) cleanup plot & svn bugs; set missing keywords; CIF export done; ... Wed, 18 Sep 2013 17:17:34 GMT vondreele [1058] * trunk/GSASIImath.py (modified) * trunk/GSASIIstrMain.py (modified) implement save of Pawley covariances for MC/SA Mon, 12 Aug 2013 16:44:25 GMT toby [1028] * trunk/GSASIIgrid.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIstrMain.py (modified) print/export distances & angles Mon, 05 Aug 2013 02:35:54 GMT vondreele [1016] * trunk/Exercises/kryptonite/kryptonite.gpx (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIstrMain.py (modified) remove PawleyDelete - not used fix floating point error in vcov ... Sat, 29 Jun 2013 16:39:57 GMT vondreele [975] * trunk/Exercises/kryptonite/kryptonite.gpx (modified) * trunk/GSASIImath.py (modified) * trunk/GSASIIstrMain.py (modified) a few mods to HessianLSQ Wed, 19 Jun 2013 22:51:24 GMT toby [960] * trunk/GSASIIIO.py (modified) * trunk/GSASIImath.py (modified) * trunk/GSASIIstrIO.py (modified) * trunk/GSASIIstrMain.py (modified) * trunk/exports/G2cif.py (modified) check in CIF dev snapshot Wed, 19 Jun 2013 02:44:58 GMT toby [956] * trunk/GSASIIIO.py (modified) * trunk/GSASIImath.py (modified) * trunk/GSASIIobj.py (modified) * trunk/GSASIIspc.py (modified) * trunk/GSASIIstrMain.py (modified) * trunk/exports/G2cif.py (modified) snapshot of CIF dev Tue, 18 Jun 2013 21:10:07 GMT vondreele [955] * trunk/ElementTable.py (modified) * trunk/GSASIIstrMain.py (modified) fix periodic table (B & Al in wrong column!) Tue, 18 Jun 2013 20:53:19 GMT vondreele [954] * trunk/GSASIImath.py (modified) * trunk/GSASIIstrMain.py (modified) * trunk/GSASIIstrMath.py (modified) fix to Hessian LSQ to stop if lam > 10e5! fix to rigid body ... Tue, 11 Jun 2013 15:08:43 GMT toby [946] * trunk/GSASIIobj.py (added) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIspc.py (modified) * trunk/GSASIIstrIO.py (modified) * trunk/GSASIIstrMain.py (modified) * trunk/exports/G2cif.py (modified) * trunk/sphinxdocs/build/html/GSASIIGUI.html (modified) * trunk/sphinxdocs/build/html/GSASIIstruc.html (modified) * trunk/sphinxdocs/build/html/GSASIIutil.html (modified) * trunk/sphinxdocs/build/html/_modules/index.html (modified) * trunk/sphinxdocs/build/html/genindex.html (modified) * trunk/sphinxdocs/build/html/index.html (modified) * trunk/sphinxdocs/build/html/py-modindex.html (modified) * trunk/sphinxdocs/build/html/searchindex.js (modified) * trunk/sphinxdocs/source/index.rst (modified) update self-docs, start work on constraints object Mon, 03 Jun 2013 04:07:35 GMT toby [939] * trunk/ElementTable.py (modified) * trunk/FormFactors.py (modified) * trunk/GSASIIElem.py (modified) * trunk/GSASIIdata.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimage.py (modified) * trunk/GSASIIindex.py (modified) * trunk/GSASIIlattice.py (modified) * trunk/GSASIImath.py (modified) * trunk/GSASIIpath.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwd.py (modified) * trunk/GSASIIsolve.py (modified) * trunk/GSASIIspc.py (modified) * trunk/GSASIIstrIO.py (modified) * trunk/GSASIIstrMain.py (modified) * trunk/GSASIIstrMath.py (modified) * trunk/ImageCalibrants.py (modified) * trunk/ReadMarCCDFrame.py (modified) * trunk/sphinxdocs/build/html/GSASII.html (modified) * trunk/sphinxdocs/build/html/GSASIIGUI.html (modified) * trunk/sphinxdocs/build/html/GSASIIGUIr.html (modified) * trunk/sphinxdocs/build/html/GSASIIimage.html (added) * trunk/sphinxdocs/build/html/GSASIIindex.html (added) * trunk/sphinxdocs/build/html/GSASIImapvars.html (modified) * trunk/sphinxdocs/build/html/GSASIImath.html (added) * trunk/sphinxdocs/build/html/GSASIIplot.html (added) * trunk/sphinxdocs/build/html/GSASIIpwd.html (added) * trunk/sphinxdocs/build/html/GSASIIsolve.html (added) * trunk/sphinxdocs/build/html/GSASIIstruc.html (added) * trunk/sphinxdocs/build/html/GSASIIutil.html (added) * trunk/sphinxdocs/build/html/_modules/GSASII.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIElem.html (added) * trunk/sphinxdocs/build/html/_modules/GSASIIElemGUI.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIIO.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIconstrGUI.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIddataGUI.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIgrid.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIimage.html (added) * trunk/sphinxdocs/build/html/_modules/GSASIIimgGUI.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIindex.html (added) * trunk/sphinxdocs/build/html/_modules/GSASIIlattice.html (added) * trunk/sphinxdocs/build/html/_modules/GSASIImath.html (added) * trunk/sphinxdocs/build/html/_modules/GSASIIpath.html (added) * trunk/sphinxdocs/build/html/_modules/GSASIIphsGUI.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIplot.html (added) * trunk/sphinxdocs/build/html/_modules/GSASIIpwd.html (added) * trunk/sphinxdocs/build/html/_modules/GSASIIpwdGUI.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIpy3.html (added) * trunk/sphinxdocs/build/html/_modules/GSASIIrestrGUI.html (modified) * trunk/sphinxdocs/build/html/_modules/GSASIIsolve.html (added) * trunk/sphinxdocs/build/html/_modules/GSASIIspc.html (added) * trunk/sphinxdocs/build/html/_modules/GSASIIstrIO.html (added) * trunk/sphinxdocs/build/html/_modules/GSASIIstrMain.html (added) * trunk/sphinxdocs/build/html/_modules/GSASIIstrMath.html (added) * trunk/sphinxdocs/build/html/_modules/index.html (modified) * trunk/sphinxdocs/build/html/genindex.html (modified) * trunk/sphinxdocs/build/html/index.html (modified) * trunk/sphinxdocs/build/html/py-modindex.html (modified) * trunk/sphinxdocs/build/html/searchindex.js (modified) * trunk/sphinxdocs/build/latex/GSASIIdoc.pdf (modified) * trunk/sphinxdocs/find_undoc.py (added) * trunk/sphinxdocs/source/GSASIIGUIr.rst (modified) * trunk/sphinxdocs/source/GSASIIimage.rst (added) * trunk/sphinxdocs/source/GSASIIindex.rst (added) * trunk/sphinxdocs/source/GSASIImath.rst (added) * trunk/sphinxdocs/source/GSASIIplot.rst (added) * trunk/sphinxdocs/source/GSASIIpwd.rst (added) * trunk/sphinxdocs/source/GSASIIsolve.rst (added) * trunk/sphinxdocs/source/GSASIIstruc.rst (added) * trunk/sphinxdocs/source/GSASIIutil.rst (added) * trunk/sphinxdocs/source/index.rst (modified) * trunk/testinp/spctestinp.py (modified) * trunk/unit_tests.py (modified) fix & cleanup unit tests; add/change doc strings for sphinx; add all ... Mon, 20 May 2013 19:49:06 GMT vondreele [930] * trunk/GSASIIstrMain.py (modified) another missing link Mon, 20 May 2013 16:39:48 GMT vondreele [928] * trunk/GSASIIstrMain.py (modified) set debug to false Mon, 20 May 2013 15:39:07 GMT vondreele [926] * trunk/GSASII.py (modified) * trunk/GSASIIstrIO.py (added) * trunk/GSASIIstrMain.py (added) * trunk/GSASIIstrMath.py (added) * trunk/GSASIIstruct.py (deleted) * trunk/testDeriv.py (modified) split GSASIIstruct.py into 3 pieces
