@3951
6 years |
vondreele |
fix a pickid bug in ReplotPattern?
@3950
6 years |
vondreele |
fix issues with 'N' & 'P' atom plot selection key
@3949
6 years |
vondreele |
suppress green dot density plotting for 4D maps - they aren't correct …
@3946
6 years |
vondreele |
correction to contouring for cells out side reference; needed a %1. on …
@3945
6 years |
vondreele |
fix 4D display of contour maps; now properly track with atom modulations
@3942
6 years |
vondreele |
force matplotlib backend to be wxAgg (not pyQt) - then contouring …
@3939
6 years |
vondreele |
check if old GSASII.bat file in registry exists; if not change …
@3928
6 years |
vondreele |
fix bug in ReplotPattern? if pattern missing (deleted)
@3914
6 years |
vondreele |
change OnComputePDF argument from None to tc.event in SampleSizer? - …
@3913
6 years |
toby |
Update Rietveld cycle-by-cycle
@3909
6 years |
vondreele |
Add new menu item to Map Peaks - Invert peak position; inverts map and …
@3907
6 years |
vondreele |
add 'k' option to structure plot key box for toggle of contours
@3906
6 years |
toby |
implement fixed backgound file in Riteveld Fit; show Rietveld & peak …
@3900
6 years |
vondreele |
cursor now reports position/density on contour slice. Contour control …
@3899
6 years |
toby |
Improve changing plot labels size etc, & Tie zero and diff in …
@3898
6 years |
toby |
Add manual scaling of plots, allow changes to plot labels size etc, & …
@3895
6 years |
vondreele |
bit of cleanup
@3893
6 years |
vondreele |
remove commented lines & "improve" getRhos - more numpy oriented - not …
@3892
6 years |
vondreele |
set "facecolor" alpha to 0.5 for contour plots; lines are now alpha=1.0
@3891
6 years |
vondreele |
change alpha for e-density texture to 50% - looks better than 25%
@3890
6 years |
vondreele |
contour maps finished
@3889
6 years |
vondreele |
contour map complete but not faded
@3888
6 years |
vondreele |
provide contour plot (not finished yet) on structure drawing
@3868
6 years |
toby |
Fix possible overwrite of PWDR children
@3854
6 years |
toby |
fix bug including zero in legend in publ. plot
@3848
6 years |
vondreele |
since id is a python routine which could be useful in debugging, …
@3847
6 years |
toby |
speed contour plotting
@3846
6 years |
vondreele |
add plot timing for single plots
@3841
6 years |
vondreele |
fix problem if image calibrant isn't in local calibration files
fix …
@3839
6 years |
vondreele |
add some timing for plot patterns - controlled by showTiming
more inn. …
@3836
6 years |
toby |
add timing for SeqRef?; error msg for unlinked hists in scriptable
@3825
6 years |
vondreele |
create csv exporter for small angle data - includes size distribution …
@3819
6 years |
vondreele |
fix cursor for old wx versions
@3818
6 years |
vondreele |
implement sqrt(I) plots for multiplots & contour plots - key 's' to …
@3817
6 years |
vondreele |
Add Setcursor utility that presents different cursors on the plot …
@3816
6 years |
vondreele |
Change plot cursor if zoom or pan buttons are pressed
@3804
6 years |
vondreele |
implement grid in Instrument parms plot
@3799
6 years |
vondreele |
make sure plot grin is off by default
@3798
6 years |
vondreele |
add toggle for grid lines for most plots
@3794
6 years |
toby |
add routine to turn off zoom/pan
@3770
7 years |
vondreele |
fix limits for Crenel coeff.
Fix plot of calculated waves
@3768
7 years |
vondreele |
name fix for single crystal 1D plots
remove ZigZag? & Block from …
@3763
7 years |
vondreele |
improvements to 1D structure factor plots - now much faster, 'q' & 'f' …
@3762
7 years |
vondreele |
updates to plot1D structure factors; q & d plots, F & F2 plots, hkls …
@3761
7 years |
vondreele |
avoid replotting structure if atom refine flags are changed
add new …
@3759
7 years |
vondreele |
add fullIntegrate = True to configuration stuff
add input control for …
@3712
7 years |
vondreele |
add new configuration item: PDF_Rmax maximum radius for G(r) …
@3681
7 years |
vondreele |
change Panalytical importer to read multi xrdMeasurement blocks - can …
@3652
7 years |
toby |
add keys to cycle through magnetic cells
@3592
7 years |
toby |
add Igor Pro export to publication plot -- thanks to Jan Ilavsky
@3588
7 years |
vondreele |
fix old style wx.CHANGE_DIR to wx.DR_CHANGE_DIR in several places.
fix …
@3584
7 years |
toby |
more fixes to masking for Grace export
@3582
7 years |
toby |
deal with mask being set to a single False value; fix wx.Colour in a …
@3581
7 years |
toby |
fix wx4 wx.Colour issue & take stab at l.get_xdata().mask not …
@3580
7 years |
toby |
add tube tails to FPA; add grace export to Publ. plot
@3576
7 years |
toby |
improve active legend code; FPA: add oversampling & remove smoother …
@3571
7 years |
toby |
Add FPA peak fitting
@3567
7 years |
vondreele |
fix wx.wx bug in G2constrGUI
better formatting of Platform: line on …
@3565
7 years |
vondreele |
G2ctrls: change MultiFloatDialog? to accept bool arguments - maybe …
@3561
7 years |
vondreele |
add Print operators option to SGMessageBox for showing operators on …
@3543
7 years |
toby |
try to fix Linux hang in G2PlotNoteBook.clear
@3509
7 years |
svnjenkins |
initial drawingData more completely to avoid errors with CF
@3507
7 years |
svnjenkins |
bug fixes: checking phase frac constraint, when histograms not in a …
@3506
7 years |
svnjenkins |
fix scriptable problem due to change in Restraints; update Tutorials; …
@3496
7 years |
vondreele |
fix issues with masks & powder patterns
remove stray print
@3474
7 years |
vondreele |
remove wx.Validator_IsSilent(): wx.Bell() from 2 places in G2ctrlGUI; …
@3453
7 years |
toby |
avoid bug on missing linescan var
@3438
7 years |
vondreele |
g2strIO
fix magnetic hkl extinctions in reflection generation
remove …
@3429
7 years |
vondreele |
add np.int64 to objectScanInnore list
fix order problems in …
@3428
7 years |
vondreele |
fix warning about NavigationToolBar2WxAgg & get tooltips to show in wx …
@3426
7 years |
toby |
Add scan of .gpx objects; try to fix bug on drag
@3425
7 years |
vondreele |
use nxs = np.newaxis in G2spc.
Add 2 functions for checking symm …
@3403
7 years |
vondreele |
fix a deleted phase problem in powder plots
fix uaniso transformation …
@3402
7 years |
vondreele |
fix missing 'linescan' problem in old files
fix cell/atom …
@3396
7 years |
vondreele |
set refList=False for a couple of calls to GetHistogramPhaseData? where …
@3392
7 years |
vondreele |
fix issues with multiphase refinements & multiphase plots, etc.
move …
@3388
7 years |
vondreele |
added Plot Colors to configuration to allow user color selection for …
@3384
7 years |
vondreele |
previous: fix isotropic size derivative & fix names for ellipsoidal …
@3378
7 years |
vondreele |
fix seq refine movie of structure
fix hide columns in seq table - …
@3372
7 years |
vondreele |
disable printing of debug info for binary location & config controls …
@3366
7 years |
vondreele |
add linescan for expanded plot region
@3365
7 years |
vondreele |
remove qplot,dplot, etc from PWDR data[0] dict - weren't ever used …
@3364
7 years |
vondreele |
remove plotStyle from G2frame & put it in Page so now there is a set …
@3362
7 years |
vondreele |
fix azimuth offset problems with linescan
add sqrt & log (scanline) options
@3361
7 years |
vondreele |
use label to identify integration limit lines in image plots
change …
@3359
7 years |
vondreele |
small fix to linescan plots
@3358
7 years |
vondreele |
implement new feature for image plotting - linescan; produces 1D plot …
@3356
7 years |
vondreele |
remove commented out SetTitle? & SetLabel? for data window from various …
@3355
7 years |
toby |
name main & plot window against project name, remove other SetTitle? calls
@3353
7 years |
vondreele |
remove call to paint after selecting all atoms. (paint cleared …
@3352
7 years |
toby |
add optional histogram label (shown only as plot title so far); set up …
@3351
7 years |
toby |
fix publication plot in Q & d-space modes
@3349
7 years |
toby |
allow publication plot to work with older MPL versions
@3347
7 years |
toby |
fix X offset in waterfall plots
@3344
7 years |
toby |
add more publication plot options
@3325
7 years |
vondreele |
add importer for Bruker image FORMAT 100 files
fix AAprobability plots …
@3324
7 years |
toby |
fix plot 'w' option for mpl >=1.1 & restore axis save
@3323
7 years |
toby |
fix image plotting at expense of 'w' plots; note code to be obsoleted
@3320
7 years |
vondreele |
implement new delt/sig subplot for PWDR & SASD plots - nvoked with 'w' …
@3316
7 years |
toby |
simplify plot toolbar code; continue on missing icon
