# ChangeLog for trunk/GSASIImapvars.py
# Generated by Trac 1.0.13
# Jun 30, 2025 4:48:19 AM
Mon, 26 Jun 2017 02:51:06 GMT toby [2876]
	* trunk/GSASIIgrid.py (modified)
	* trunk/GSASIImapvars.py (modified)
	* trunk/GSASIIstrMain.py (modified)
	allow variables to change during seq. ref.; fix error w/unused phases
Sat, 24 Jun 2017 14:33:04 GMT toby [2874]
	Sequential refinement fixes where # of phases change
Tue, 22 Nov 2016 19:08:48 GMT vondreele [2546]
	* trunk/GSASIIElem.py (modified)
	* trunk/GSASIIElemGUI.py (modified)
	* trunk/GSASIIIO.py (modified)
	* trunk/GSASIIconstrGUI.py (modified)
	* trunk/GSASIIctrls.py (modified)
	* trunk/GSASIIddataGUI.py (modified)
	* trunk/GSASIIexprGUI.py (modified)
	* trunk/GSASIIimage.py (modified)
	* trunk/GSASIIindex.py (modified)
	* trunk/GSASIIlattice.py (modified)
	* trunk/GSASIImath.py (modified)
	* trunk/GSASIIobj.py (modified)
	* trunk/GSASIIphsGUI.py (modified)
	* trunk/GSASIIplot.py (modified)
	* trunk/GSASIIpwd.py (modified)
	* trunk/GSASIIpwdGUI.py (modified)
	* trunk/GSASIIpy3.py (modified)
	* trunk/GSASIIrestrGUI.py (modified)
	* trunk/GSASIIsasd.py (modified)
	* trunk/GSASIIspc.py (modified)
	* trunk/GSASIIstrIO.py (modified)
	* trunk/GSASIIstrMath.py (modified)
	* trunk/imports/G2img_1TIF.py (modified)
	cleanup of all GSASII main routines - remove unused variables, dead ...
Wed, 09 Nov 2016 20:48:37 GMT vondreele [2519]
	bug fix in PDF calculations
	add option to suppress G(0) ringing in PDF
Wed, 29 Apr 2015 17:22:48 GMT toby [1819]
	fix constraints for all test cases
Tue, 28 Apr 2015 19:49:55 GMT toby [1818]
	fix immediate constraint problem; need to double check on skipped ...
Fri, 24 Apr 2015 02:54:49 GMT toby [1805]
	* trunk/GSASII.py (modified)
	fix bug on with unused constraints and with chained equivalences; ...
Mon, 06 Apr 2015 18:33:00 GMT vondreele [1778]
	allow Refine texture menu item to appear; use DestroyChildren to ...
Sat, 28 Feb 2015 03:46:37 GMT toby [1676]
	* trunk/GSASIIpath.py (modified)
	Ignore equivalences that are not in use; start on svn switch ...
Thu, 18 Sep 2014 16:18:32 GMT toby [1502]
	Fix problem with constraint editing of floats converted to strings
Mon, 15 Sep 2014 00:48:39 GMT vondreele [1496]
	* trunk/exports/G2export_CIF.py (modified)
	Add sequential peak fitting.
	Change Back:n to Back;n for background ...
Sun, 07 Sep 2014 18:37:26 GMT vondreele [1489]
	correct Uij to U6 conversions Uij = Uk/2 for i != j; k > 2 in ...
Fri, 11 Apr 2014 19:31:29 GMT toby [1276]
	seq. ref. bugs: wrong file name on msg; fix wildcarded constraints.
Wed, 12 Mar 2014 20:46:47 GMT toby [1247]
	allow wildcarded-histogram constraint input; implement for seq ...
Mon, 10 Mar 2014 19:06:56 GMT toby [1243]
	fix constraints use in sequential refinements
Fri, 29 Nov 2013 03:16:02 GMT toby [1160]
	* trunk/imports/G2phase_ISO.py (modified)
	finish ISODISPLACE fixes; improve show var window; improve help ...
Mon, 11 Nov 2013 02:32:26 GMT toby [1143]
	rework constraints to handle names and refine flag for new var (input ...
Thu, 07 Nov 2013 18:12:55 GMT toby [1138]
	major constraints revision
Thu, 29 Aug 2013 19:47:35 GMT vondreele [1046]
	* trunk/GSASIIdata.py (modified)
	* trunk/imports/G2phase.py (modified)
	* trunk/imports/G2phase_CIF.py (modified)
	* trunk/imports/G2phase_GPX.py (modified)
	* trunk/imports/G2pwd_CIF.py (modified)
	* trunk/imports/G2pwd_GPX.py (modified)
	* trunk/imports/G2pwd_fxye.py (modified)
	* trunk/imports/G2pwd_xye.py (modified)
	* trunk/imports/G2sfact.py (modified)
	* trunk/imports/G2sfact_CIF.py (modified)
	put in missing GSASIIpath & version finder
Sun, 14 Jul 2013 03:21:12 GMT toby [989]
	* trunk/GSASIIimgGUI.py (modified)
	* trunk/exports/G2cif.py (modified)
	add constraint derivs for single xtal; allow cellFill to work without ...
Mon, 13 May 2013 20:18:21 GMT toby [903]
	Fix problem with large constraints; Change binding of data item menus ...
Sun, 23 Sep 2012 21:57:51 GMT toby [762]
	* trunk/ElementTable.py (modified)
	* trunk/FormFactors.py (modified)
	* trunk/GSASIIsolve.py (modified)
	* trunk/GSASIIstruct.py (modified)
	* trunk/GSASIItestplot.py (modified)
	* trunk/ImageCalibrants.py (modified)
	* trunk/scanCCD.py (modified)
	* trunk/testGSASIIstruct.py (modified)
	* trunk/unit_tests.py (modified)
	update py files to use native line ends, add update from svn to help ...
Tue, 24 Jul 2012 19:14:17 GMT vondreele [694]
	remove error check on use of variable in constraint & equivalence - ...
Sat, 21 Jul 2012 18:44:56 GMT vondreele [693]
	LS refinement results now printed to a separate file "name.lst"; it ...
Sat, 30 Jun 2012 17:26:06 GMT vondreele [668]
	add properties
Fri, 15 Jun 2012 06:57:29 GMT vondreele [648]
	1st stab at a unique atoms picker - mostly GUI
	format fix for ...
Thu, 03 May 2012 16:35:40 GMT vondreele [584]
	* trunk/G2importphase.py (modified)
	* trunk/G2importphase_CIF.py (modified)
	* trunk/G2importphase_GPX.py (modified)
	* trunk/G2importsfact.py (modified)
	* trunk/G2importsfact_CIF.py (modified)
	add coding line everywhere
	more options in sample parm copy
Fri, 27 Apr 2012 14:45:26 GMT toby [577]
	fix error in reporting constraint errors
Tue, 24 Apr 2012 17:19:19 GMT toby [570]
	Add checks on constraints: if problems display error window when ...
Fri, 20 Apr 2012 20:34:58 GMT toby [567]
	more work on constraints
Wed, 15 Feb 2012 20:36:53 GMT vondreele [484]
	* trunk/GSASIIElemGUI.py (added)
	change authorship
	split GSASIIelem into a GUI & non-GUI parts ...
Mon, 21 Nov 2011 15:32:14 GMT vondreele [425]
	get As from Dijs in seqdata plotting
Thu, 17 Nov 2011 22:12:10 GMT toby [421]
	determine uncertainties on constrained variables
Thu, 17 Nov 2011 19:35:34 GMT vondreele [420]
	small fixes including
	move msg = '' in SetVaryFlags outside loop ...
Thu, 17 Nov 2011 19:25:51 GMT toby [419]
	print constraint-generated variables
Wed, 16 Nov 2011 22:18:11 GMT toby [418]
	fix compute derivs for constrained vars
Wed, 16 Nov 2011 20:42:49 GMT toby [417]
Tue, 15 Nov 2011 15:07:55 GMT toby [415]
	* trunk/binmac2.7/fellipse.so (modified)
	* trunk/binmac2.7/histogram2d.so (modified)
	* trunk/binmac2.7/pack_f.so (modified)
	* trunk/binmac2.7/polymask.so (modified)
	* trunk/binmac2.7/pyspg.so (modified)
	* trunk/binmac2.7/pytexture.so (modified)
	* trunk/fsource/pypowder.for (modified)
	implement refinement of constrained parameters; fix minor bugs; add ...
Fri, 11 Nov 2011 20:14:35 GMT vondreele [411]
	* trunk/fsource/powsubs/psvfcj.for (modified)
	fix very old (!) bug in psvfcj.for
	implement neutron scattering ...
Sat, 05 Nov 2011 22:30:24 GMT vondreele [407]
	constraints round 2
Fri, 05 Aug 2011 19:35:43 GMT vondreele [342]
	* trunk/GSASIImapvars.py (added)
	major modifications to get 1st "working" version of Refine
	Add ...
