Search:
Login
Help/Guide
About Trac
Preferences
Wiki
Timeline
Roadmap
Browse Source
View Tickets
Search
Context Navigation
View Latest Revision
source:
trunk
GSASIIlattice.py
Revision Log Mode:
Stop on copy
Follow copies
Show only adds and deletes
View log starting at
and back to
Show at most
revisions per page.
Show full log messages
Legend:
Added
Modified
Copied or renamed
Diff
Rev
Age
Author
Log Message
(edit)
@158
15 years
vondreele
implement drawing options: select atom hilites movable test point & …
(edit)
@155
15 years
vondreele
changes for structure drawing
(edit)
@110
15 years
vondreel
resolved
(edit)
@109
15 years
toby
fix up GenHLaue
(edit)
@108
15 years
vondreel
fix to
GenHlaue?
; add Hx2Rh & Rh2Hx mod to ReadPDBPhase to use np.inner …
(edit)
@105
15 years
vondreel
fix doc in cell2AB
(edit)
@103
15 years
toby
add more Laue classes to self test (now fails); move source library
(edit)
@102
15 years
toby
add space group list; fix minor bugs in GenHLaue & add unit test
(edit)
@93
15 years
toby
G2lattice: add
GetBraviasNum?
to interface GenHBravais to …
(edit)
@78
15 years
vondreel
split
IndexPeaks?
, etc. from GSASIIcomp.py & put in new GSASIIindex.py
(edit)
@76
15 years
vondreel
After merge with BT mods
(edit)
@73
15 years
vondreel
remove Bob's bad code & simplify calc_rVsq
(edit)
@71
15 years
toby
Update orthogonalization routine w/unit-tests
(add)
@70
15 years
toby
move lattice operations into GSASIIlattice w/unit tests
Note:
See
TracRevisionLog
for help on using the revision log.
Download in other formats:
RSS Feed
ChangeLog
