# # ChangeLog for trunk/GSASIIimgGUI.py # # Generated by Trac 1.0.13 # Jul 14, 2025 2:19:06 AM Fri, 26 Apr 2013 20:45:31 GMT vondreele [892] * trunk/GSASIIimage.py (modified) * trunk/GSASIIimgGUI.py (modified) develop new correction for detector penetration effects. (1-cos2Q) ... Fri, 11 Jan 2013 20:55:47 GMT vondreele [827] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIimgGUI.py (modified) added gonio angles to image GUI for transfer to powder data sample ... Sat, 29 Sep 2012 02:25:04 GMT toby [765] * trunk/GSASII.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIpwdGUI.py (modified) refactor menus on Mac, clean up main menu generation Sun, 23 Sep 2012 21:57:51 GMT toby [762] * trunk/ElementTable.py (modified) * trunk/FormFactors.py (modified) * trunk/GSASII.py (modified) * trunk/GSASIIElem.py (modified) * trunk/GSASIIElemGUI.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimage.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIindex.py (modified) * trunk/GSASIIlattice.py (modified) * trunk/GSASIImapvars.py (modified) * trunk/GSASIImath.py (modified) * trunk/GSASIIpath.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwd.py (modified) * trunk/GSASIIsolve.py (modified) * trunk/GSASIIspc.py (modified) * trunk/GSASIIstruct.py (modified) * trunk/GSASIItestplot.py (modified) * trunk/ImageCalibrants.py (modified) * trunk/imports/G2phase.py (modified) * trunk/imports/G2phase_CIF.py (modified) * trunk/imports/G2phase_GPX.py (modified) * trunk/imports/G2pwd_CIF.py (modified) * trunk/imports/G2pwd_fxye.py (modified) * trunk/imports/G2pwd_xye.py (modified) * trunk/imports/G2sfact.py (modified) * trunk/imports/G2sfact_CIF.py (modified) * trunk/scanCCD.py (modified) * trunk/testGSASIIstruct.py (modified) * trunk/unit_tests.py (modified) update py files to use native line ends, add update from svn to help ... Tue, 07 Aug 2012 19:54:06 GMT vondreele [699] * trunk/GSASII.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimage.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwdGUI.py (modified) implement restore data window after refine implement sample ... Fri, 03 Aug 2012 20:50:30 GMT vondreele [698] * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimage.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIphsGUI.py (modified) implement Pawley update from reflection list a bit more for stress/atrain Fri, 03 Aug 2012 18:34:38 GMT vondreele [697] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIstruct.py (modified) add ranId to PWDR histograms & each PhaseSelector implement 'Use' ... Mon, 30 Jul 2012 17:54:13 GMT vondreele [696] * trunk/GSASII.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIstruct.py (modified) begin implementation of image strain analysis - GUI stuff first make ... Tue, 10 Jul 2012 15:23:32 GMT vondreele [683] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIImath.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIplot.py (modified) fix dlg.Destroy as needed continue restraints work Tue, 03 Jul 2012 18:34:51 GMT vondreele [675] * trunk/GSASIIimage.py (modified) * trunk/GSASIIimgGUI.py (modified) refactor image controls GUI add oblique detector absorption ... Fri, 29 Jun 2012 21:24:59 GMT toby [661] * trunk/GSASIIElem.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimage.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIindex.py (modified) * trunk/GSASIImath.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwd.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIsolve.py (modified) * trunk/GSASIIspc.py (modified) complete revision number tracking Thu, 03 May 2012 16:35:40 GMT vondreele [584] * trunk/ElementTable.py (modified) * trunk/FormFactors.py (modified) * trunk/G2importphase.py (modified) * trunk/G2importphase_CIF.py (modified) * trunk/G2importphase_GPX.py (modified) * trunk/G2importsfact.py (modified) * trunk/G2importsfact_CIF.py (modified) * trunk/GSASII.py (modified) * trunk/GSASIIElem.py (modified) * trunk/GSASIIElemGUI.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimage.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIindex.py (modified) * trunk/GSASIIlattice.py (modified) * trunk/GSASIImapvars.py (modified) * trunk/GSASIImath.py (modified) * trunk/GSASIIpath.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIsolve.py (modified) * trunk/GSASIIspc.py (modified) * trunk/GSASIIstruct.py (modified) add coding line everywhere more options in sample parm copy Tue, 01 May 2012 20:35:03 GMT vondreele [582] * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIlattice.py (modified) fix to load image controls fix to sph harmonics calc Mon, 23 Apr 2012 21:17:29 GMT vondreele [569] * trunk/GSASII.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIImath.py (modified) change image default to 'Paired' fix mismatch for 'rotation' Mon, 09 Apr 2012 19:54:22 GMT vondreele [536] * trunk/GSASII.py (modified) * trunk/GSASIIimage.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/help/gsasII.html (modified) add more text to help file refactor image GUI stuff add centerAzm ... Thu, 02 Feb 2012 17:27:53 GMT vondreele [468] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwdGUI.py (modified) changed self to G2frame everywhere in all "sub" files that use it ... Wed, 01 Feb 2012 22:03:51 GMT vondreele [467] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/ImageCalibrants.py (modified) more on file directories fix for image controls & mask save modify ... Mon, 09 Jan 2012 19:01:20 GMT vondreele [450] * trunk/GSASIIIO.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIItestplot.py (modified) * trunk/fsource/histogram2d.for (modified) Mon, 12 Dec 2011 15:54:18 GMT vondreele [442] * trunk/GSASIIimgGUI.py (modified) fix to mask bug in image integration with background subtraction Sun, 11 Dec 2011 19:55:19 GMT vondreele [440] * trunk/GSASII.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIstruct.py (modified) fix the mustrain ve microstrain title problem = GSASII.py take ... Fri, 09 Dec 2011 17:35:43 GMT vondreele [437] * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIpwdGUI.py (modified) use wx.CallAfter() - a few places it didn't work! possible new ... Wed, 02 Nov 2011 18:11:04 GMT vondreele [406] * trunk/GSASII.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIstruct.py (modified) implement background subtraction during image integration implement ... Tue, 25 Oct 2011 21:53:33 GMT vondreele [399] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIstruct.py (modified) Implement sequential refinement remove print "load" & "save" for ... Fri, 21 Oct 2011 19:33:37 GMT vondreele [398] * trunk/GSASIIimgGUI.py (modified) missed updating the GUI after recalibrate Fri, 21 Oct 2011 17:15:50 GMT vondreele [397] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimage.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIstruct.py (modified) collect default settings for Sample in one routine add recalibrate ... Fri, 05 Aug 2011 19:35:43 GMT vondreele [342] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIindex.py (modified) * trunk/GSASIIlattice.py (modified) * trunk/GSASIImapvars.py (added) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwd.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIspc.py (modified) * trunk/GSASIIstruct.py (modified) major modifications to get 1st "working" version of Refine Add ... Thu, 09 Jun 2011 21:02:38 GMT vondreele [296] * trunk/GSASIIIO.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIlattice.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwd.py (modified) * trunk/GSASIIpwdGUI.py (modified) major change to peak fitting in GSASIIpwd.py & GSASIIpwdGUI.py "Auto ... Thu, 26 May 2011 16:02:42 GMT vondreele [294] * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimgGUI.py (modified) implement mask save & load implement copy to all for masks refactor ... Thu, 05 May 2011 20:42:32 GMT vondreele [283] * trunk/GSASIIimgGUI.py (modified) Thu, 28 Apr 2011 18:11:32 GMT vondreele [271] * trunk/GSASII.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimage.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwd.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/binwin2.7/fellipse.pyd (modified) * trunk/binwin2.7/histogram2d.pyd (modified) * trunk/binwin2.7/pack_f.pyd (modified) * trunk/binwin2.7/polymask.pyd (modified) * trunk/binwin2.7/pypowder.pyd (modified) * trunk/binwin2.7/pyspg.pyd (modified) * trunk/fsource/histogram2d.for (modified) make g77 versions of fortran for binwin2.7 - faster than gfortran! ... Thu, 21 Apr 2011 17:59:52 GMT vondreele [268] * trunk/GSASIIimage.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIplot.py (modified) fix integration limits issues changes to full image integration control Wed, 20 Apr 2011 18:09:53 GMT vondreele [267] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIimage.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIpeak.py (modified) * trunk/GSASIIplot.py (modified) * trunk/ImageCalibrants.py (modified) removed azm rotation - didn't work fix azimuthal polarization Tue, 19 Apr 2011 20:12:37 GMT vondreele [265] * trunk/GSASII.py (modified) * trunk/GSASIIElem.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimage.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIpeak.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwdGUI.py (modified) further progress on implementing pdf calculations optionally put ... Thu, 31 Mar 2011 21:41:13 GMT vondreele [264] * trunk/GSASII.py (modified) * trunk/GSASIIElem.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimage.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIlattice.py (modified) * trunk/GSASIIpeak.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwdGUI.py (modified) begin implementation of pdf generation - work in progress modify ... Fri, 11 Mar 2011 20:06:54 GMT vondreele [261] * trunk/GSASIIimage.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/fsource/fellipse.for (added) new fortran fellipse - for fitting ellipses! GSASIIplot.py - change ... Thu, 10 Mar 2011 14:54:16 GMT vondreele [258] * trunk/GSASIIimgGUI.py (modified) minor fix Wed, 09 Mar 2011 19:09:55 GMT vondreele [257] * trunk/GSASIIimage.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIplot.py (modified) change plotting during calibration - now at end - faster make image ... Wed, 09 Mar 2011 17:33:59 GMT vondreele [256] * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIplot.py (modified) remove popup message box for 2D image calibration add delete line ... Mon, 07 Mar 2011 21:31:18 GMT vondreele [254] * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimgGUI.py (modified) removed "Save Integration" rearranged stuff in the Image Controls window Fri, 04 Mar 2011 22:29:22 GMT toby [253] * trunk/GSASIIimgGUI.py (modified) * trunk/fsource/Makefile (modified) fix mouse labeling; makefile cleaning (not done) Tue, 01 Mar 2011 19:16:27 GMT vondreele [251] * trunk/GSASIIIO.py (modified) * trunk/GSASIIimage.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/ImageCalibrants.py (modified) Add NaCl even hkl to ImageCalibrants.py Fix bug in polygon mask in ... Thu, 17 Feb 2011 19:33:02 GMT vondreele [248] * trunk/GSASII.py (modified) * trunk/GSASIIimage.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/binwin2.6/histogram2d.pyd (modified) * trunk/fsource/cf2py32.bat (modified) * trunk/fsource/histogram2d.for (modified) histogram2d.for - cleaned up add azmthOff - as for a rotation of a ... Mon, 14 Feb 2011 00:20:15 GMT vondreele [246] * trunk/GSASIIIO.py (modified) * trunk/GSASIIimgGUI.py (modified) fix copy controls for images - needed deepcopy multi frame GE ... Sun, 13 Feb 2011 22:57:10 GMT vondreele [245] * trunk/GSASIIimage.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/ImageCalibrants.py (modified) Tue, 08 Feb 2011 21:47:07 GMT vondreele [243] * trunk/GSASIIIO.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIpeak.py (modified) * trunk/GSASIIplot.py (modified) GSASIIpeak.py - added factorize for future use in finding good ... Thu, 20 Jan 2011 21:56:37 GMT vondreele [240] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/ImageCalibrants.py (modified) * trunk/binwin64-2.6/polymask.pyd (modified) reworked menu of image file types in FileDialog allow nonsquare ... Thu, 13 Jan 2011 19:34:07 GMT vondreele [239] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIimage.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/ImageCalibrants.py (modified) add 'any image file' to image file menu add calibration skip & dmin ... Tue, 11 Jan 2011 18:17:17 GMT vondreele [238] * trunk/GSASIIimgGUI.py (modified) add new image data types SXAS & REFL make image controls save file a ... Fri, 07 Jan 2011 19:27:24 GMT vondreele [230] * trunk/ElementTable.py (modified) * trunk/GSASII.BAT (modified) * trunk/GSASII.py (modified) * trunk/GSASIIElem.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimage.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIindex.py (modified) * trunk/GSASIIlattice.py (modified) * trunk/GSASIIpath.py (modified) * trunk/GSASIIpeak.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIsolve.py (modified) * trunk/GSASIIspc.py (modified) * trunk/GSASIIstruct.py (modified) * trunk/unit_tests.py (modified) add svn keywords & add log intensity plotting Wed, 22 Dec 2010 20:29:41 GMT vondreele [193] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIlattice.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIspc.py (modified) various fixes, but still bugs. GSASII.py - add more sample ... Mon, 22 Nov 2010 17:06:57 GMT vondreele [184] * binaries/binwin2.6/pack_f.pyd (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwdGUI.py (modified) fixes to min/max image sliders fixes to polygon mask interface Mon, 22 Nov 2010 15:22:32 GMT vondreele [183] * trunk/GSASIIimgGUI.py (modified) Sat, 31 Jul 2010 22:30:17 GMT vondreel [139] * trunk/GSASIIimgGUI.py (modified) Add "limits" dmin,pixLimit & cutOff Tue, 27 Jul 2010 23:01:58 GMT vondreel [134] * trunk/GSASIIimgGUI.py (modified) modify image intensity sliders Mon, 19 Jul 2010 13:09:34 GMT vondreel [124] * trunk/GSASIIimgGUI.py (modified) Integrate All fixes Fri, 16 Jul 2010 15:15:20 GMT vondreel [115] * trunk/GSASIIimgGUI.py (modified) implement "KILL_FOCUS" for all TextCtrl windows Thu, 01 Jul 2010 16:32:40 GMT vondreel [98] * trunk/GSASIIimage.py (modified) * trunk/GSASIIimgGUI.py (modified) new fortran polymask used Thu, 01 Jul 2010 14:25:08 GMT vondreel [94] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimage.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/fsource (added) * trunk/fsource/fitellipse.for (added) * trunk/fsource/pack_f.for (added) * trunk/fsource/pypowder.for (added) * trunk/fsource/pyspg.for (added) move all fortran to fsource add gray for readonly textctrl do ... Mon, 21 Jun 2010 11:05:11 GMT vondreel [90] * trunk/GSASIIimgGUI.py (added) first commit
