# ChangeLog for trunk/GSASIIElem.py
# Generated by Trac 1.0.13
# Jun 29, 2025 6:20:34 AM
Thu, 17 Jan 2019 20:31:32 GMT vondreele [3786]
	* trunk/GSASIIElem.py (modified)
	* trunk/GSASIIpwdGUI.py (modified)
	* trunk/imports/G2pwd_CIF.py (modified)
	fix problem of import ElementTable inside spyder
	allow import o ...
Mon, 17 Sep 2018 15:03:54 GMT vondreele [3605]
	fix bug in neutron resonant form factor calculation
Thu, 22 Feb 2018 17:01:07 GMT vondreele [3295]
	* trunk/GSASIIphsGUI.py (modified)
	* trunk/GSASIIplot.py (modified)
	* trunk/GSASIIspc.py (modified)
	* trunk/atmdata.py (modified)
	remove superfluous calls to SpcGroup after SGData has been defined ...
Wed, 13 Dec 2017 14:26:51 GMT vondreele [3191]
	* trunk/GSASIIdataGUI.py (modified)
	* trunk/imports/G2phase_CIF.py (modified)
	fix integer divides in responding to unit cell changes on Unit Cells ...
Tue, 28 Nov 2017 17:32:31 GMT vondreele [3164]
	* trunk/GSASIImath.py (modified)
	* trunk/GSASIIpwd.py (modified)
	fix neutron resonant scattering factor calcs. - neglected constant ...
Mon, 23 Oct 2017 16:39:16 GMT vondreele [3136]
	* trunk/GSASIIElemGUI.py (modified)
	* trunk/GSASIIIO.py (modified)
	* trunk/GSASIIconstrGUI.py (modified)
	* trunk/GSASIIctrlGUI.py (modified)
	* trunk/GSASIIddataGUI.py (modified)
	* trunk/GSASIIexprGUI.py (modified)
	* trunk/GSASIIfiles.py (modified)
	* trunk/GSASIIimage.py (modified)
	* trunk/GSASIIimgGUI.py (modified)
	* trunk/GSASIIindex.py (modified)
	* trunk/GSASIIlattice.py (modified)
	* trunk/GSASIIlog.py (modified)
	* trunk/GSASIImapvars.py (modified)
	* trunk/GSASIImpsubs.py (modified)
	* trunk/GSASIIobj.py (modified)
	* trunk/GSASIIpath.py (modified)
	* trunk/GSASIIpy3.py (modified)
	* trunk/GSASIIrestrGUI.py (modified)
	* trunk/GSASIIsasd.py (modified)
	* trunk/GSASIIscriptable.py (modified)
	* trunk/GSASIIstrIO.py (modified)
	* trunk/GSASIIstrMain.py (modified)
	* trunk/GSASIIstrMath.py (modified)
	* trunk/ImageCalibrants.py (modified)
	* trunk/exports/G2export_CIF.py (modified)
	* trunk/exports/G2export_FIT2D.py (modified)
	* trunk/exports/G2export_PDB.py (modified)
	* trunk/exports/G2export_csv.py (modified)
	* trunk/exports/G2export_examples.py (modified)
	* trunk/exports/G2export_image.py (modified)
	* trunk/exports/G2export_map.py (modified)
	* trunk/exports/G2export_pwdr.py (modified)
	* trunk/exports/G2export_shelx.py (modified)
	* trunk/fsource/SConstruct (modified)
	* trunk/fsource/pack_f.for (modified)
	* trunk/gltext.py (modified)
	* trunk/imports/G2img_1TIF.py (modified)
	* trunk/imports/G2img_ADSC.py (modified)
	* trunk/imports/G2img_CBF.py (modified)
	* trunk/imports/G2img_CheMin.py (modified)
	* trunk/imports/G2img_EDF.py (modified)
	* trunk/imports/G2img_GE.py (modified)
	* trunk/imports/G2img_HDF5.py (modified)
	* trunk/imports/G2img_MAR.py (modified)
	* trunk/imports/G2img_Rigaku.py (modified)
	* trunk/imports/G2img_SumG2.py (modified)
	* trunk/imports/G2pdf_gr.py (modified)
	* trunk/imports/G2phase.py (modified)
	* trunk/imports/G2phase_GPX.py (modified)
	* trunk/imports/G2phase_INS.py (modified)
	* trunk/imports/G2pwd_BrukerRAW.py (modified)
	* trunk/imports/G2pwd_FP.py (modified)
	* trunk/imports/G2pwd_GPX.py (modified)
	* trunk/imports/G2pwd_Panalytical.py (modified)
	* trunk/imports/G2pwd_csv.py (modified)
	* trunk/imports/G2pwd_fxye.py (modified)
	* trunk/imports/G2pwd_rigaku.py (modified)
	* trunk/imports/G2pwd_xye.py (modified)
	* trunk/imports/G2rfd_xye.py (modified)
	* trunk/imports/G2sad_xye.py (modified)
	* trunk/imports/G2sfact.py (modified)
	* trunk/imports/G2sfact_CIF.py (modified)
	* trunk/scanCCD.py (modified)
	make GSAS-II python 3.6 compliant & preserve python 2.7 use;changes: ...
Wed, 07 Dec 2016 17:53:18 GMT vondreele [2563]
	* trunk/GSASII.py (modified)
	Speed up image integration on Mac by reducing ProgressBar calls from ...
Tue, 22 Nov 2016 19:08:48 GMT vondreele [2546]
	* trunk/GSASIIctrls.py (modified)
	* trunk/GSASIIgrid.py (modified)
	cleanup of all GSASII main routines - remove unused variables, dead ...
Sat, 15 Oct 2016 16:20:33 GMT vondreele [2492]
	fix handling of Lande g factor
	fix Mag structure factor calcs - now ...
Wed, 12 Oct 2016 18:06:57 GMT vondreele [2486]
	* trunk/ElementTable.py (modified)
	fix mag form factor lookup - some aren't chemical valences (e.g. ...
Fri, 23 Sep 2016 18:43:24 GMT vondreele [2478]
	work up to magnetic structure factor calcs.
Tue, 20 Sep 2016 18:58:10 GMT vondreele [2473]
	work on magnetic structures - import from EXP, plotting, LS refine ...
Mon, 01 Dec 2014 18:39:26 GMT toby [1589]
	2 bugs: import phase w/invalid element; prevent 3 overlapped buttons ...
Fri, 01 Aug 2014 20:19:48 GMT vondreele [1453]
	* trunk/Exercises/single crystal/IB3.EXP (modified)
	get HKLF data type into RefDict
	create a SetDefaultDData routine in ...
Tue, 22 Jul 2014 20:45:19 GMT vondreele [1428]
	* trunk/help/Fitting Small Angle Scattering Data.htm (modified)
	* trunk/help/ParametricFitting.htm (modified)
	* trunk/help/ParametricFitting_files/filelist.xml (modified)
	* trunk/help/ParametricFitting_files/image069.png (modified)
	* trunk/help/SequentialTutorial.htm (deleted)
	* trunk/help/SequentialTutorial_files (deleted)
	fixes to element stuff
	cleanout old parametric fitting files
Sun, 06 Jul 2014 17:53:47 GMT toby [1413]
	* trunk/DefaultExpressions.txt (added)
	Add config support; default expressions
Mon, 23 Jun 2014 21:18:14 GMT vondreele [1392]
	Speedup GetTthAzmDsp - ~40% improvement
	add size item to UpdateImageData
Fri, 20 Jun 2014 18:43:42 GMT vondreele [1391]
	remove stray prints
	Breit-Wigner & Lynn & Seeger neutron anomalous ...
Wed, 28 May 2014 16:57:03 GMT vondreele [1365]
	fix atmdata.py for Rh (& other anomalous b isotopes)
	fix powder ...
Tue, 27 May 2014 17:14:59 GMT vondreele [1364]
	read TOPAZ structure factor files
Thu, 22 May 2014 19:09:17 GMT vondreele [1362]
	mag form factors now modernized; atmdata.dat no longer needed in
	GSAS-II
Thu, 22 May 2014 18:07:10 GMT vondreele [1360]
	add SRM660b to ImageCalibrants.py
	revamp element stuff to use ...
Tue, 22 Apr 2014 14:37:51 GMT vondreele [1295]
	disable plotting while multiple PWDR & SASD data sets are imported - ...
Mon, 28 Oct 2013 20:32:05 GMT vondreele [1125]
	StructureFactor2 does SF calculation for entire block of reflection - ...
Mon, 24 Jun 2013 17:21:37 GMT vondreele [967]
	periodic table
Wed, 05 Jun 2013 14:26:36 GMT vondreele [942]
	mods for MC/SA:
	moved scat fac routines from GSASIIstrIO.py & ...
Mon, 03 Jun 2013 04:07:35 GMT toby [939]
	* trunk/FormFactors.py (modified)
	* trunk/GSASIIdata.py (modified)
	* trunk/GSASIIsolve.py (modified)
	* trunk/ReadMarCCDFrame.py (modified)
	* trunk/sphinxdocs/build/html/GSASII.html (modified)
	* trunk/sphinxdocs/build/html/GSASIIGUI.html (modified)
	* trunk/sphinxdocs/build/html/GSASIIGUIr.html (modified)
	* trunk/sphinxdocs/build/html/GSASIIimage.html (added)
	* trunk/sphinxdocs/build/html/GSASIIindex.html (added)
	* trunk/sphinxdocs/build/html/GSASIImapvars.html (modified)
	* trunk/sphinxdocs/build/html/GSASIImath.html (added)
	* trunk/sphinxdocs/build/html/GSASIIplot.html (added)
	* trunk/sphinxdocs/build/html/GSASIIpwd.html (added)
	* trunk/sphinxdocs/build/html/GSASIIsolve.html (added)
	* trunk/sphinxdocs/build/html/GSASIIstruc.html (added)
	* trunk/sphinxdocs/build/html/GSASIIutil.html (added)
	* trunk/sphinxdocs/build/html/_modules/GSASII.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIElem.html (added)
	* trunk/sphinxdocs/build/html/_modules/GSASIIElemGUI.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIIO.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIconstrGUI.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIddataGUI.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIgrid.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIimage.html (added)
	* trunk/sphinxdocs/build/html/_modules/GSASIIimgGUI.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIindex.html (added)
	* trunk/sphinxdocs/build/html/_modules/GSASIIlattice.html (added)
	* trunk/sphinxdocs/build/html/_modules/GSASIImath.html (added)
	* trunk/sphinxdocs/build/html/_modules/GSASIIpath.html (added)
	* trunk/sphinxdocs/build/html/_modules/GSASIIphsGUI.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIplot.html (added)
	* trunk/sphinxdocs/build/html/_modules/GSASIIpwd.html (added)
	* trunk/sphinxdocs/build/html/_modules/GSASIIpwdGUI.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIpy3.html (added)
	* trunk/sphinxdocs/build/html/_modules/GSASIIrestrGUI.html (modified)
	* trunk/sphinxdocs/build/html/_modules/GSASIIsolve.html (added)
	* trunk/sphinxdocs/build/html/_modules/GSASIIspc.html (added)
	* trunk/sphinxdocs/build/html/_modules/GSASIIstrIO.html (added)
	* trunk/sphinxdocs/build/html/_modules/GSASIIstrMain.html (added)
	* trunk/sphinxdocs/build/html/_modules/GSASIIstrMath.html (added)
	* trunk/sphinxdocs/build/html/_modules/index.html (modified)
	* trunk/sphinxdocs/build/html/genindex.html (modified)
	* trunk/sphinxdocs/build/html/index.html (modified)
	* trunk/sphinxdocs/build/html/py-modindex.html (modified)
	* trunk/sphinxdocs/build/html/searchindex.js (modified)
	* trunk/sphinxdocs/build/latex/GSASIIdoc.pdf (modified)
	* trunk/sphinxdocs/find_undoc.py (added)
	* trunk/sphinxdocs/source/GSASIIGUIr.rst (modified)
	* trunk/sphinxdocs/source/GSASIIimage.rst (added)
	* trunk/sphinxdocs/source/GSASIIindex.rst (added)
	* trunk/sphinxdocs/source/GSASIImath.rst (added)
	* trunk/sphinxdocs/source/GSASIIplot.rst (added)
	* trunk/sphinxdocs/source/GSASIIpwd.rst (added)
	* trunk/sphinxdocs/source/GSASIIsolve.rst (added)
	* trunk/sphinxdocs/source/GSASIIstruc.rst (added)
	* trunk/sphinxdocs/source/GSASIIutil.rst (added)
	* trunk/sphinxdocs/source/index.rst (modified)
	* trunk/testinp/spctestinp.py (modified)
	* trunk/unit_tests.py (modified)
	fix & cleanup unit tests; add/change doc strings for sphinx; add all ...
Thu, 04 Apr 2013 22:04:24 GMT vondreele [881]
	* trunk/GSASIIstruct.py (modified)
	more RB editing & fixes
	'+0' & '-0' (vice versa) removed from any ...
Tue, 12 Feb 2013 19:21:23 GMT vondreele [850]
	* trunk/Exercises/kryptonite/jadarite.cif (modified)
	fix problem with atoms with An+ style of valence
	more places for ...
Sun, 23 Sep 2012 21:57:51 GMT toby [762]
	* trunk/GSASIItestplot.py (modified)
	* trunk/testGSASIIstruct.py (modified)
	update py files to use native line ends, add update from svn to help ...
Fri, 29 Jun 2012 21:24:59 GMT toby [661]
	complete revision number tracking
Wed, 30 May 2012 18:08:00 GMT vondreele [642]
	add CheckElement
Thu, 03 May 2012 16:35:40 GMT vondreele [584]
	* trunk/G2importphase.py (modified)
	* trunk/G2importphase_CIF.py (modified)
	* trunk/G2importphase_GPX.py (modified)
	* trunk/G2importsfact.py (modified)
	* trunk/G2importsfact_CIF.py (modified)
	add coding line everywhere
	more options in sample parm copy
Wed, 22 Feb 2012 22:08:40 GMT vondreele [489]
	* trunk/GSASII.BAT (modified)
	fix to speed up scat fac calculations & skip texture calcs if order=0
Wed, 15 Feb 2012 20:36:53 GMT vondreele [484]
	* trunk/GSASIIElemGUI.py (added)
	change authorship
	split GSASIIelem into a GUI & non-GUI parts ...
Tue, 24 Jan 2012 20:31:27 GMT toby [456]
	determine path to GSAS files from __file__; trap & reset focus for ...
Fri, 11 Nov 2011 20:14:35 GMT vondreele [411]
	* trunk/fsource/powsubs/psvfcj.for (modified)
	fix very old (!) bug in psvfcj.for
	implement neutron scattering ...
Tue, 08 Nov 2011 22:27:01 GMT vondreele [409]
	make it do CW neutrons - 1st pass at it
Mon, 03 Oct 2011 20:43:49 GMT vondreele [380]
	* trunk/binwin2.7/fellipse.pyd (modified)
	* trunk/binwin2.7/histogram2d.pyd (modified)
	* trunk/binwin2.7/pack_f.pyd (modified)
	* trunk/binwin2.7/polymask.pyd (modified)
	* trunk/binwin2.7/pypowder.pyd (modified)
	* trunk/binwin2.7/pyspg.pyd (modified)
	* trunk/binwin2.7/pytexture.pyd (modified)
	completed Rietveld refinement version
Fri, 01 Jul 2011 17:10:28 GMT vondreele [327]
	fix to path name for atomdata.dat
	fix to texture display - can't ...
Tue, 10 May 2011 22:33:45 GMT jemian [291]
	* trunk/doc (added)
	* trunk/doc/Makefile (added)
	* trunk/doc/build (added)
	* trunk/doc/make.bat (added)
	* trunk/doc/source (added)
	* trunk/doc/source/_static (added)
	* trunk/doc/source/_templates (added)
	* trunk/doc/source/conf.py (added)
	* trunk/doc/source/index.rst (added)
	* trunk/doc/source/source (added)
	* trunk/doc/source/source/GSASIIElem.rst (added)
	added first documentation using sphinx
Tue, 19 Apr 2011 20:12:37 GMT vondreele [265]
	* trunk/GSASIIpeak.py (modified)
	further progress on implementing pdf calculations
	optionally put ...
Thu, 31 Mar 2011 21:41:13 GMT vondreele [264]
	begin implementation of pdf generation - work in progress
	modify ...
Fri, 07 Jan 2011 19:27:24 GMT vondreele [230]
	add svn keywords & add log intensity plotting
Tue, 26 Oct 2010 20:09:48 GMT vondreele [166]
	fixups of atom editing/atom drawing
Fri, 24 Sep 2010 21:07:24 GMT vondreele [155]
	changes for structure drawing
Mon, 09 Aug 2010 16:00:16 GMT vondreel [153]
	GetAtomColors & GetElemColor now deleted
Mon, 09 Aug 2010 15:56:35 GMT vondreel [151]
	removed ElTable - now in own ElementTable.py file, removed ...
Sat, 31 Jul 2010 22:41:28 GMT vondreel [141]
	fix path reference for atmdata.dat, etc.
Fri, 04 Jun 2010 16:33:02 GMT vondreel [83]
	* trunk/GSASIIphsGUI.py (added)
	further splits of G2gd --> GSASIIphsGUI.py & GSASIIimgGUI.py
	Modify ...
Wed, 27 Jan 2010 19:18:38 GMT vondreel [10]
	* trunk/GSASIIElem.py (added)
