source: trunk/GSASII.py
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Diff Rev Age Author Log Message
(edit) @2486   5 years vondreele fix mag form factor lookup - some aren't chemical valences (e.g. Fe+4) …
(edit) @2481   5 years vondreele force Transform to delete nonmagnetic atoms if phase made magnetic & …
(edit) @2479   5 years toby Rework plotting to refresh after refinements
(edit) @2457   5 years vondreele fix bug in PWDR selection for PDF
(edit) @2449   5 years toby Fix CIF exports; make sure exporters are imported only once (on Mac)
(edit) @2431   5 years vondreele fix problem with wxPython 3.x with changing text entry focus. Needed a …
(edit) @2422   5 years vondreele allow saving of plotted XY data from PlotXY as csv file
(edit) @2421   5 years vondreele name sequential results by type of sequence (peak fit, SASD, etc.) so …
(edit) @2420   5 years vondreele add "All scales value" to SumDialog?
(edit) @2416   5 years vondreele fix issues with summing images & powder patterns - SumDialog? is now a …
(edit) @2412   5 years vondreele fixes to PDF stuff
(edit) @2377   5 years toby add patch for locale mis-set on OSX machines
(edit) @2363   5 years toby fix minor bugs in sequential refinement
(edit) @2362   5 years toby fix bug due to addition of CorrectionCode? to InstParms?
(edit) @2360   5 years toby new Mac .so files, incorporate data corrections into .instprm file
(edit) @2344   5 years toby add option to correct data on import
(edit) @2342   5 years toby fix reading of CIF intensities with esds
(edit) @2341   5 years toby improve powder imports: suppress printing of binary data; improve …
(edit) @2304   5 years vondreele add Cancel to image integration ProgressDialog? - will do a Pause in …
(edit) @2297   5 years vondreele implement creation of summed file from multi-frame ge image files; …
(edit) @2290   5 years vondreele complex problem - fix summing of GE images; needed new item in Image …
(edit) @2275   5 years vondreele add warning for high Levenberg-Marquardt lambda.
(edit) @2272   5 years vondreele add Stacking Faults II tutorial add a Copy Phase command to Layers …
(edit) @2246   5 years vondreele trap another Id=0 problem after Refine finishes (G2.py) rearrange …
(edit) @2244   5 years vondreele two lines at end of OnSeqRefine? call things that don't exist …
(edit) @2238   5 years vondreele remove commented block from GSASII.py add Bruker RAW file importer for …
(edit) @2234   5 years toby implement code to select appropriate tree time when a plot tab is selected
(edit) @2215   6 years toby load images to tree as read in
(edit) @2214   6 years vondreele missing import copy
(edit) @2197   6 years vondreele replace pyd files for binwin2.7 & binwin64-2.7 implement new pyGetSpc …
(edit) @2196   6 years toby redo plot window graphics to redraw after refinement (need to update …
(edit) @2185   6 years vondreele fix PWDR import from zip problem when iparm/instparm file isn'r in zip.
(edit) @2174   6 years vondreele fix image integrate and integrate all with dark & background images …
(edit) @2160   6 years vondreele fix zip file problem
(edit) @2159   6 years vondreele add importer for FullProf? .dat powder files
(edit) @2153   6 years vondreele allow Cancel from Default profile parms - data not loaded
(edit) @2152   6 years vondreele all PWDR exporters will make file name from histogram name allow read …
(edit) @2151   6 years vondreele add Generic TOF to defaultIparms.py; forces user to set flight path & …
(edit) @2150   6 years vondreele incomplete mods to import powder - suggest not using until I fix it
(edit) @2148   6 years vondreele ReadPowderInstprm? modified to handle multibank instprm files. Fails if …
(edit) @2147   6 years vondreele handle TOF profile type=2 iparm files (e.g. for GEM) implement …
(edit) @2141   6 years vondreele add peak list d-spacing esds to exported peak lists tables for CW & TOF
(edit) @2135   6 years vondreele more fixes to peak exports to get correct FWHM refactor Merge GUI
(edit) @2134   6 years toby better display of G2 version number
(edit) @2132   6 years vondreele more rationalization of FWHM calculations
(edit) @2129   6 years vondreele revisions to FWHM calculations - some math errors fixed implement …
(edit) @2127   6 years vondreele Add Merge dialog (not working yet) Fix L & G+L peak width plots per …
(edit) @2113   6 years vondreele better cleanup when main window is closed add FlagSetDialog? class & …
(edit) @2109   6 years toby Andrey's enhancement: keep track of last GPX, import & export …
(edit) @2101   6 years toby Drop #1 from header in one-image files; revise HDF5 importer to read …
(edit) @2087   6 years toby change error handling if h5py not installed; add new condition …
(edit) @2084   6 years vondreele fix bug in TOF iparm reading remove extraneous code in G2imgGUI …
(edit) @2083   6 years toby Export multiple masks/controls
(edit) @2077   6 years vondreele refactor wave data display to do one atom at a time instead of a long GUI
(edit) @2075   6 years vondreele explicit plot destroy when GSAS2 closes work on scrolling on phase …
(edit) @2071   6 years toby allow standalone testing of image importer from GSASIIIO.py
(edit) @2068   6 years toby cleanup image reader documetation
(edit) @2065   6 years toby Allow reading of multiple images from single file
(edit) @2061   6 years vondreele modify export app peak lists to include d-spacing as a column fix 2x …
(edit) @2056   6 years vondreele peak list read/list/indexing now fixed
(edit) @2050   6 years vondreele include Bank no in Instrument parameters - no check yet expand range …
(edit) @2048   6 years toby move list of PWDR tree items to delete so they are saved
(edit) @2047   6 years toby revise autoint to implement Reset -- redoes integration; warn on old …
(edit) @2043   6 years vondreele some SS deriv work trap G2frame.PatternId? = None (or 0) in …
(edit) @2034   6 years vondreele remove block of commented out old code from OnRefine? fix contour …
(edit) @2026   6 years toby autoint minimal, but ready for testing; fixes to Exports
(edit) @2017   6 years toby update reload after refinement to make sure old Id is removed; also …
(edit) @2015   6 years toby redo image read to avoid reloads; prevent open of Edit image parms on …
(edit) @2003   6 years toby Make Transpose a config opt; new routine to read images with import …
(edit) @2002   6 years toby fix 1st import image 1st bug
(edit) @2001   6 years toby add initial Image imports code
(edit) @1997   6 years toby Add API for direct image read (G2IO.ExportPowderList?) and powder …
(edit) @1985   6 years toby fix CIF import where ? is used for Uiso value and where iso/aniso type …
(edit) @1971   6 years toby Add preferences option to edit configuration options
(edit) @1970   6 years vondreele Add pygauleg to pypowder.for - recompile Win2.7 & Win2.7-64 work on SS …
(edit) @1962   6 years vondreele made PackageVersions? a list so it comes out in same order as the other …
(edit) @1961   6 years toby save package info in GPX; display only in Debug mode
(edit) @1960   6 years toby add current version number to Controls dict on save; display on read
(edit) @1959   6 years toby fix crash with anaconda on Mac; allow for 2.7.xx version numbers
(edit) @1956   6 years vondreele fix (again) fill unit cell, dynamic SS drawing & GenAtom? issues - now …
(edit) @1949   6 years vondreele add image read for Rigaku R-Axis IV files
(edit) @1945   6 years vondreele fix another new histo in new phase error some cleanup in texture …
(edit) @1934   6 years vondreele fix on self.HKL error
(edit) @1932   6 years vondreele fix problems with plotting & phase handling when there is no structure …
(edit) @1931   6 years vondreele Autoupdate of atom drawing table and drawing after LS refinement and …
(edit) @1918   6 years vondreele further mods on twins
(edit) @1917   6 years vondreele better handling of nonmerohedral twins
(edit) @1915   6 years vondreele start on riding constraints - works for atom frac,x,y,z; skipping u's …
(edit) @1913   6 years vondreele fix sfact importers so twin id=1 by default GUI details for twins fixed
(edit) @1912   6 years vondreele more twin stuff - nonmerohedral mods refl[3] now twin id not mul.
(edit) @1910   6 years vondreele fix reading run-on numbers in Shelx HKLF 4 files implement all I/O for …
(edit) @1909   6 years vondreele fix import names for HKLF files - now explicit Shelx names fix …
(edit) @1907   6 years vondreele comment out the G2plotNB.clear in OnRefine? so that the new plot will …
(edit) @1902   6 years vondreele suppress editing of 1st twin element; it is always the identity matrix …
(edit) @1875   6 years vondreele add Flack parameter to GUI (commented out for now)
(edit) @1861   6 years vondreele fix missing data error messages
(edit) @1838   6 years vondreele fix problem reading TOF powder data
(edit) @1831   6 years toby move remaining generic controls to G2ctrls
(edit) @1829   6 years vondreele fix importers for HIPD & HIPPO data
(edit) @1828   6 years toby more tweaks on phase data; keeps selected histogram across phase
Note: See TracRevisionLog for help on using the revision log.
