# # ChangeLog for trunk/GSASII.py # # Generated by Trac 1.0.13 # Jun 29, 2025 4:15:23 AM Wed, 03 Feb 2021 17:50:38 GMT toby [4800] * trunk/GSASII.py (modified) * trunk/GSASIIlog.py (modified) * trunk/GSASIImpsubs.py (modified) * trunk/GSASIIpwd.py (modified) * trunk/ReadMarCCDFrame.py (modified) * trunk/docs/source/GSASIIGUIr.rst (modified) * trunk/docs/source/GSASIIutil.rst (modified) finish up docs cleanups Wed, 11 Mar 2020 21:43:45 GMT toby [4361] * trunk/G2AutoInt.py (deleted) * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIIntPDFtool.py (modified) * trunk/GSASIIautoInt.py (deleted) * trunk/GSASIIimgGUI.py (modified) * trunk/docs/source/G2tools.rst (modified) * trunk/exports/G2export_CIF.py (modified) fix hist CIF export, remove dev. ver of IntPDFtool Mon, 09 Mar 2020 03:40:55 GMT toby [4349] * trunk/GSASII.py (modified) * trunk/GSASIIimage.py (modified) fix integration over azimuths with no pixels Wed, 18 Sep 2019 22:05:24 GMT toby [4154] * trunk/GSASII.py (modified) * trunk/GSASIIdataGUI.py (modified) * trunk/GSASIIpath.py (modified) allow open of multiple GPX files on Mac Fri, 13 Sep 2019 22:06:45 GMT toby [4148] * trunk/GSASII.py (modified) * trunk/GSASIIdataGUI.py (modified) refactor to create wx app before anything else gets done Tue, 19 Mar 2019 14:18:53 GMT toby [3858] * trunk/GSASII.py (modified) * trunk/GSASIIimage.py (modified) * trunk/docs/source/index.rst (modified) * trunk/docs/source/packages.rst (modified) stupid Py3 syntax error; docs updates Mon, 15 Oct 2018 16:45:38 GMT toby [3674] * trunk/GSASII.py (modified) * trunk/GSASIIdataGUI.py (modified) * trunk/GSASIIobj.py (modified) * trunk/fsource/SConstruct (modified) misc cosmetic & build changes Mon, 04 Jun 2018 19:18:05 GMT vondreele [3420] * trunk/GSASII.py (modified) * trunk/GSASIIpath.py (modified) * trunk/GSASIIpwdGUI.py (modified) update hkl lines after spin change (still does nothing, but this is ... Thu, 05 Oct 2017 20:00:45 GMT toby [3123] * trunk/GSASII.py (modified) * trunk/GSASIIpath.py (modified) * trunk/GSASIIscriptable.py (modified) do update when load of binaries fails; improve docs and bug fixes in ... Fri, 11 Aug 2017 22:34:54 GMT toby [3000] * trunk (modified) * trunk/AllBinaries (copied) * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIconstrGUI.py (modified) * trunk/GSASIIctrlGUI.py (copied) * trunk/GSASIIctrls.py (deleted) * trunk/GSASIIdataGUI.py (copied) * trunk/GSASIIddataGUI.py (modified) * trunk/GSASIIexprGUI.py (modified) * trunk/GSASIIfiles.py (copied) * trunk/GSASIIgrid.py (deleted) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIlattice.py (modified) * trunk/GSASIIlog.py (modified) * trunk/GSASIImath.py (modified) * trunk/GSASIImpsubs.py (copied) * trunk/GSASIIobj.py (modified) * trunk/GSASIIpath.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwd.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIrestrGUI.py (modified) * trunk/GSASIIscriptable.py (modified) * trunk/GSASIIstrIO.py (modified) * trunk/GSASIIstrMain.py (modified) * trunk/GSASIIstrMath.py (modified) * trunk/basinhopping.py (modified) * trunk/bindist (copied) * trunk/binlinux2.7 (deleted) * trunk/binlinux64-2.7 (deleted) * trunk/binmac2.7 (deleted) * trunk/binmac64-2.7 (deleted) * trunk/binwin2.7 (deleted) * trunk/binwin64-2.7 (deleted) * trunk/config_example.py (modified) * trunk/docs/source/GSASIIGUI.rst (modified) * trunk/docs/source/GSASIIGUIr.rst (modified) * trunk/docs/source/GSASIIscripts.rst (modified) * trunk/docs/source/conf.py (modified) * trunk/docs/source/index.rst (modified) * trunk/exports/G2export_CIF.py (modified) * trunk/exports/G2export_PDB.py (modified) * trunk/exports/G2export_examples.py (modified) * trunk/exports/G2export_map.py (modified) * trunk/gltext.py (modified) * trunk/imports/G2phase_GPX.py (modified) * trunk/testSSymbols.py (modified) make the two frame version the trunk as we hit version 3000 Sat, 08 Jul 2017 20:45:15 GMT toby [2925] * trunk/GSASII.py (modified) * trunk/GSASIIctrls.py (modified) * trunk/GSASIIpath.py (modified) add switch to 2frame; allow for latest G2path Thu, 29 Jun 2017 22:54:41 GMT toby [2887] * install/bootstrap.py (modified) * trunk/GSASII.py (modified) * trunk/GSASIIpath.py (modified) setup & use bindist location for downloaded binaries Mon, 26 Jun 2017 04:23:22 GMT toby [2877] * trunk/GSASII.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIstrMain.py (modified) Plot each histogram after fitting in a sequential refinement Wed, 21 Jun 2017 14:35:40 GMT vondreele [2871] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIImath.py (modified) * trunk/GSASIIobj.py (modified) * trunk/GSASIIplot.py (modified) * trunk/fsource/powsubs/psvfcj.for (modified) * trunk/scanCCD.py (modified) change ContourColor default back to Paired even if it is 12 color ... Mon, 19 Jun 2017 21:30:36 GMT toby [2870] * trunk/GSASII.py (modified) * trunk/GSASIIgrid.py (modified) Allow hiding of columns in Seq Table Wed, 14 Jun 2017 21:11:42 GMT vondreele [2863] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIctrls.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIImath.py (modified) * trunk/GSASIIobj.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIsasd.py (modified) * trunk/config_example.py (modified) * trunk/fsource/SConstruct (modified) * trunk/scanCCD.py (modified) extend contour color selection to include reversed ones (doubles the ... Fri, 02 Jun 2017 20:29:05 GMT toby [2851] * trunk/GSASII.py (modified) more for arrow keys; do not understand how this windows code works, ... Fri, 02 Jun 2017 03:53:13 GMT toby [2850] * trunk/GSASII.py (modified) * trunk/GSASIIgrid.py (modified) fix arrow key data tree traversal on Mac Tue, 30 May 2017 12:22:13 GMT vondreele [2843] * trunk/GSASII.py (modified) * trunk/GSASIIphsGUI.py (modified) fix focus issues from lists of histograms in tree Mon, 29 May 2017 20:23:29 GMT toby [2842] * Tutorials/SeqRefine/SequentialTutorial.htm (modified) * Tutorials/SeqRefine/SequentialTutorial_files/image013.png (modified) * Tutorials/SeqRefine/SequentialTutorial_files/image014.jpg (deleted) * Tutorials/SeqRefine/SequentialTutorial_files/image021.png (modified) * Tutorials/SeqRefine/SequentialTutorial_files/image099.jpg (modified) * Tutorials/SeqRefine/SequentialTutorial_files/image108.jpg (modified) * Tutorials/SeqRefine/SequentialTutorial_files/image115.png (modified) * Tutorials/SeqRefine/SequentialTutorial_files/image126.png (modified) * Tutorials/SeqRefine/SequentialTutorial_files/image138.png (modified) * trunk/GSASII.py (modified) * trunk/GSASIIctrls.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIphsGUI.py (modified) cleanups: crash in show LS params; show constraint vars; set filters ... Fri, 12 May 2017 21:26:07 GMT vondreele [2831] * trunk/GSASII.py (modified) fix to put azm on Sample Azimuth for PWDR data Fri, 05 May 2017 19:40:25 GMT vondreele [2821] * trunk/GSASII.py (modified) * trunk/GSASIIscriptable.py (modified) revisions to GSASIIscriptable - now works for reading PWDR data Thu, 04 May 2017 21:06:25 GMT vondreele [2820] * trunk/GSASII.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIobj.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIscriptable.py (modified) * trunk/imports/G2pwd_GPX.py (modified) * trunk/imports/G2pwd_fxye.py (modified) PWDR import now scriptable for single bank patterns Tue, 02 May 2017 18:39:22 GMT vondreele [2818] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIobj.py (modified) * trunk/docs/source/imports.rst (modified) add GetPhaseNames(fl) to G2obj - uses opened gpx file fix ... Tue, 02 May 2017 15:03:41 GMT vondreele [2817] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIobj.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIscriptable.py (modified) * trunk/docs/source/imports.rst (modified) * trunk/imports/G2img_1TIF.py (modified) * trunk/imports/G2img_ADSC.py (modified) * trunk/imports/G2img_CBF.py (modified) * trunk/imports/G2img_CheMin.py (modified) * trunk/imports/G2img_EDF.py (modified) * trunk/imports/G2img_GE.py (modified) * trunk/imports/G2img_HDF5.py (modified) * trunk/imports/G2img_MAR.py (modified) * trunk/imports/G2img_Rigaku.py (modified) * trunk/imports/G2img_SumG2.py (modified) * trunk/imports/G2pdf_gr.py (modified) * trunk/imports/G2phase.py (modified) * trunk/imports/G2phase_CIF.py (modified) * trunk/imports/G2phase_GPX.py (modified) * trunk/imports/G2phase_INS.py (modified) * trunk/imports/G2pwd_BrukerRAW.py (modified) * trunk/imports/G2pwd_CIF.py (modified) * trunk/imports/G2pwd_FP.py (modified) * trunk/imports/G2pwd_GPX.py (modified) * trunk/imports/G2pwd_Panalytical.py (modified) * trunk/imports/G2pwd_csv.py (modified) * trunk/imports/G2pwd_fxye.py (modified) * trunk/imports/G2pwd_rigaku.py (modified) * trunk/imports/G2pwd_xye.py (modified) * trunk/imports/G2rfd_xye.py (modified) * trunk/imports/G2sad_xye.py (modified) * trunk/imports/G2sfact.py (modified) * trunk/imports/G2sfact_CIF.py (modified) major revision - move all importers to GSASIIobj & make them ... Fri, 21 Apr 2017 13:36:17 GMT vondreele [2800] * trunk/GSASII.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIpwd.py (modified) fix a simulation output format use a couple of wx.CallAfter to fix ... Mon, 17 Apr 2017 19:12:29 GMT vondreele [2788] * trunk/GSASII.py (modified) * trunk/GSASIIimage.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/ImageCalibrants.py (modified) make I/Ib floats in ImageCalibrants.py fix issue for SASD seq. ... Sat, 15 Apr 2017 16:31:45 GMT vondreele [2783] * trunk/GSASII.py (modified) * trunk/GSASIIpwd.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/imports/G2pwd_xye.py (modified) * trunk/imports/G2rfd_xye.py (added) include imports/G2rfd_xye.py implement instrument smearing of ... Wed, 12 Apr 2017 20:28:20 GMT vondreele [2778] * trunk/GSASII.py (modified) fix diff pdf routine for imported pdfs Wed, 12 Apr 2017 20:12:45 GMT vondreele [2777] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwd.py (modified) * trunk/GSASIIpwdGUI.py (modified) implement import of getPDFx G(R) files NB: these have no matching ... Sun, 02 Apr 2017 13:15:22 GMT vondreele [2770] * trunk/GSASII.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIstrIO.py (modified) fix import new phase behavior - wasn't finishing properly fix HKL ... Mon, 20 Mar 2017 14:53:00 GMT vondreele [2755] * trunk/GSASII.py (modified) * trunk/GSASIIctrls.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIImath.py (modified) * trunk/GSASIIpwd.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIsasd.py (modified) extend Export HKLs for powder data to include most all columns in ... Tue, 14 Mar 2017 15:19:59 GMT vondreele [2754] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwd.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIstrMath.py (modified) fix "off-by-one" problem in powder profiles; calc missed last point - ... Fri, 10 Mar 2017 18:01:46 GMT vondreele [2753] * trunk/GSASII.py (modified) * trunk/GSASIIconstrGUI.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIspc.py (modified) * trunk/GSASIIstrIO.py (modified) * trunk/GSASIIstrMath.py (modified) minor shuffling about for atom constraints - no discernable impact ... Sat, 04 Mar 2017 15:56:49 GMT vondreele [2739] * trunk/GSASII.py (modified) * trunk/GSASIIddataGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIstrIO.py (modified) comment out "other self-updating plots" - caused failures in ... Fri, 03 Mar 2017 17:03:36 GMT toby [2736] * trunk/GSASII.py (modified) * trunk/imports/G2phase_INS.py (modified) more unicode fixes, fix shelx END problem Thu, 02 Mar 2017 18:48:10 GMT vondreele [2735] * trunk/GSASII.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIstrIO.py (modified) set default flight path = 20. in case FPATH0 missing from TOF Iparm ... Thu, 02 Mar 2017 15:36:12 GMT vondreele [2734] * trunk/GSASII.py (modified) * trunk/GSASIIgrid.py (modified) avoid spurious small phase data window after doing Refine. Phase data ... Mon, 27 Feb 2017 21:06:07 GMT vondreele [2727] * trunk/GSASII.py (modified) * trunk/GSASIIddataGUI.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIobj.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIstrIO.py (modified) * trunk/GSASIIstrMath.py (modified) fix issue with formula volume in PDF creation block Lebail selection ... Mon, 27 Feb 2017 16:24:00 GMT vondreele [2726] * trunk/GSASII.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIphsGUI.py (modified) fix data window resizing problem after DoRefine trap Pawley issues ... Wed, 22 Feb 2017 18:41:16 GMT vondreele [2719] * trunk/GSASII.py (modified) * trunk/GSASIIimgGUI.py (modified) clean up code formatting fix delete tree entry problem with names ... Tue, 21 Feb 2017 21:50:45 GMT vondreele [2717] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIpwd.py (modified) * trunk/GSASIIstrMain.py (modified) Sat, 18 Feb 2017 22:22:21 GMT vondreele [2715] * trunk/GSASII.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIstrIO.py (modified) * trunk/GSASIIstrMath.py (modified) put histogram numbers in sorted order for View LS parms remove some ... Fri, 17 Feb 2017 19:03:35 GMT vondreele [2712] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) add export of G(R) in a format suitable for pdfGUI import Thu, 16 Feb 2017 22:31:20 GMT vondreele [2710] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIpwdGUI.py (modified) improve ExportPDF with G2file selector & allow selection of I(Q), ... Tue, 14 Feb 2017 15:52:37 GMT vondreele [2703] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIpwdGUI.py (modified) fix problem with default Sample parms for lab data default selection Tue, 14 Feb 2017 15:21:32 GMT vondreele [2702] * trunk/GSASII.py (modified) * trunk/GSASIIrestrGUI.py (modified) fix bug in G2restrGUI Mon, 13 Feb 2017 20:58:18 GMT vondreele [2701] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwdGUI.py (modified) Rename ShowLSParms to OnShowLSParms Add [Ymin,Ymax] to PWDR data[0] ... Fri, 10 Feb 2017 19:43:02 GMT vondreele [2699] * trunk/GSASII.py (modified) fix bug involving input of lab data - Sample defaults for Bragg- ... Wed, 08 Feb 2017 18:31:24 GMT vondreele [2695] * trunk/GSASII.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIobj.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIstrMath.py (modified) use min(intensity) as default for PDF Flat Bkg - gives better start ... Tue, 07 Feb 2017 20:50:13 GMT vondreele [2694] * trunk/GSASII.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimage.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwdGUI.py (modified) after a repeat of a sequential fit, clear away old plot. Removes ... Tue, 31 Jan 2017 23:50:20 GMT toby [2683] * trunk/GSASII.py (modified) fix sum images Mon, 30 Jan 2017 20:38:50 GMT toby [2675] * trunk/GSASII.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIobj.py (modified) * trunk/GSASIIpwdGUI.py (modified) Make new PDF names unique; plot G(r); minor fixes Mon, 30 Jan 2017 20:25:48 GMT vondreele [2674] * trunk/GSASII.py (modified) * trunk/GSASIIElemGUI.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIpwdGUI.py (modified) prevent delete if PWDR if corresponding PDF exists use PickElements ... Sat, 28 Jan 2017 17:02:40 GMT vondreele [2669] * trunk/GSASII.py (modified) set lower limit selection in TOF patterns to be >= 0.4A dspacing. Fri, 27 Jan 2017 23:11:33 GMT toby [2667] * trunk/GSASII.py (modified) * trunk/GSASIIobj.py (modified) prevent Unicode in data tree names; move PDF setup to standalone routine Wed, 25 Jan 2017 22:06:39 GMT vondreele [2660] * trunk/GSASII.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwd.py (modified) * trunk/GSASIIpwdGUI.py (modified) fix issues with new pdf creation & fully trap missing elements ... Tue, 24 Jan 2017 19:58:38 GMT vondreele [2659] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwd.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/defaultIparms.py (modified) make lab data (2 x-ray wavelengths) instrument default 'Bragg- ... Mon, 23 Jan 2017 19:34:00 GMT toby [2658] * trunk/GSASII.py (modified) * trunk/GSASIIstrIO.py (modified) fix problem reporting histogram with Unicode chars Sun, 22 Jan 2017 20:35:40 GMT toby [2655] * trunk/GSASII.py (modified) * trunk/GSASIIctrls.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIphsGUI.py (modified) Close out grids before deleting in G2gr.SelectDataTreeItem; save ... Thu, 19 Jan 2017 18:18:51 GMT vondreele [2646] * trunk/GSASII.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIplot.py (modified) added waterfall colors to single & multiple I(Q)..G(r) plots a start ... Thu, 19 Jan 2017 01:00:20 GMT toby [2645] * trunk/GSASII.py (modified) * trunk/GSASIIctrls.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIpwdGUI.py (modified) improve PDF opt; add PDF opt to Compute All PDFs; rename to Setup PDFs Wed, 18 Jan 2017 16:02:17 GMT toby [2643] * trunk/GSASII.py (modified) labeling on Data items Wed, 18 Jan 2017 04:32:09 GMT toby [2641] * trunk/GSASII.py (modified) move and expand selected tree items Tue, 17 Jan 2017 18:13:28 GMT vondreele [2637] * trunk/GSASII.py (modified) * trunk/GSASIIctrls.py (modified) * trunk/GSASIIplot.py (modified) fix delete data item selection to include only data items expand the ... Tue, 17 Jan 2017 16:23:20 GMT toby [2636] * trunk/GSASII.py (modified) prevent reread of all images on ExpandAll Mon, 16 Jan 2017 23:03:18 GMT toby [2635] * trunk/GSASII.py (modified) * trunk/GSASIIgrid.py (modified) add Yield to allow grid update completion Mon, 16 Jan 2017 22:41:14 GMT vondreele [2634] * trunk/GSASII.py (modified) * trunk/GSASIIctrls.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwdGUI.py (modified) add ExpandAll to main File menu change PDF plotting to use color ... Fri, 13 Jan 2017 18:26:09 GMT toby [2629] * trunk/GSASII.py (modified) chmod u+x on GSASII.py via subversion Thu, 12 Jan 2017 21:50:49 GMT toby [2628] * trunk/GSASII.py (modified) force selection of new instparm when data limits/number of points ... Wed, 11 Jan 2017 04:25:29 GMT toby [2619] * trunk/GSASII.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIphsGUI.py (modified) note when Phase window is resized and use that size Mon, 09 Jan 2017 21:53:35 GMT vondreele [2618] * trunk/GSASII.py (modified) * trunk/GSASIIimage.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIplot.py (modified) implement spot mask delete from image command (also fix spot move & ... Fri, 06 Jan 2017 21:06:23 GMT toby [2615] * trunk/GSASII.py (modified) * trunk/GSASIIplot.py (modified) fix for plots w/o Data Item parent Thu, 05 Jan 2017 04:46:36 GMT toby [2611] * trunk/GSASII.py (modified) * trunk/GSASIIElemGUI.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/help/gsasII.html (modified) Change PDF defaults; option for multiple element addition (added to ... Sun, 01 Jan 2017 23:08:04 GMT toby [2607] * trunk/GSASII.py (modified) * trunk/GSASIIctrls.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIpath.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/help/gsasII.html (modified) redo help to use DataFrame helpKey; define .dataFrame.helpKey; rename ... Wed, 21 Dec 2016 14:46:09 GMT vondreele [2596] * trunk/GSASII.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIstrMath.py (modified) tidy up PDF setup - add IofQmin default something that works for 1D ... Sun, 18 Dec 2016 03:24:00 GMT toby [2593] * trunk/GSASII.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIphsGUI.py (modified) Add Pawley settings menu item; open Phases and selected data tree ... Fri, 16 Dec 2016 04:46:47 GMT toby [2586] * trunk/GSASII.py (modified) * trunk/GSASIIpwdGUI.py (modified) Add blank hist. for PDF; fix spinbox to step w/.01 on mac; trap ... Thu, 15 Dec 2016 15:12:10 GMT vondreele [2582] * trunk/GSASII.py (modified) * trunk/GSASIIpwd.py (modified) * trunk/GSASIIpwdGUI.py (modified) fix issue with Make PDF & 11BM data - 'formula' found but not ... Wed, 14 Dec 2016 21:40:34 GMT vondreele [2581] * trunk/GSASII.py (modified) * trunk/GSASIIpwdGUI.py (modified) Add Test button to Powder Sum popup - see plot of result by pressing Test Tue, 13 Dec 2016 22:08:43 GMT vondreele [2579] * trunk/GSASII.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwdGUI.py (modified) implement file selection for multi-PDF plots replace "type" with ... Tue, 13 Dec 2016 15:18:04 GMT vondreele [2577] * trunk/GSASII.py (modified) * trunk/GSASIIctrls.py (modified) * trunk/GSASIIplot.py (modified) new powder plot option to select patterns to plot in multi/contour plots Fri, 09 Dec 2016 21:17:43 GMT vondreele [2569] * trunk/GSASII.py (modified) * trunk/GSASIIctrls.py (modified) * trunk/GSASIIddataGUI.py (modified) * trunk/GSASIIexprGUI.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIpy3.py (modified) * trunk/GSASIIrestrGUI.py (modified) add 'f' or 'g' to maxdigits in FormatValue in G2py3 - should be ... Wed, 07 Dec 2016 17:53:18 GMT vondreele [2563] * trunk/GSASII.py (modified) * trunk/GSASIIElem.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIimage.py (modified) * trunk/GSASIIimgGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwdGUI.py (modified) Speed up image integration on Mac by reducing ProgressBar calls from ... Tue, 06 Dec 2016 16:43:26 GMT vondreele [2561] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIpwd.py (modified) * trunk/GSASIIpwdGUI.py (modified) add Rmax to PDF Controls; default = 100.; will not be exact PDF ... Mon, 28 Nov 2016 20:59:55 GMT vondreele [2550] * trunk/GSASII.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIstrMath.py (modified) * trunk/imports/G2pwd_BrukerRAW.py (modified) * trunk/testDeriv.py (modified) fix binary import for Bruker raw files fix issues for new atoms in ... Wed, 23 Nov 2016 16:15:47 GMT vondreele [2547] * trunk/GSASII.py (modified) * trunk/GSASIIplot.py (modified) * trunk/imports/G2pwd_BrukerRAW.py (modified) remove str() from some text handling - failed on non ascii characters ... Mon, 21 Nov 2016 22:40:02 GMT vondreele [2544] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIconstrGUI.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIImath.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIplot.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIspc.py (modified) major cleanup of unused variables, etc. Mon, 21 Nov 2016 19:52:48 GMT toby [2542] * trunk/GSASII.py (modified) deal a bit better with Unicode file names Mon, 21 Nov 2016 17:13:37 GMT vondreele [2539] * trunk/GSASII.py (modified) * trunk/GSASIIstrMath.py (modified) * trunk/imports/G2img_1TIF.py (modified) * trunk/imports/G2img_ADSC.py (modified) * trunk/imports/G2img_CBF.py (modified) * trunk/imports/G2img_GE.py (modified) * trunk/imports/G2phase.py (modified) * trunk/testDeriv.py (modified) fix to unicode character in directory name problem numerous unused ... Thu, 17 Nov 2016 20:43:50 GMT vondreele [2532] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/testDeriv.py (modified) clean up display of version info. etc. on console. Thu, 17 Nov 2016 17:43:57 GMT toby [2531] * trunk/GSASII.py (modified) * trunk/GSASIIctrls.py (modified) reopen tree items after a refinement Wed, 16 Nov 2016 22:10:58 GMT vondreele [2528] * trunk/GSASII.py (modified) * trunk/GSASIIgrid.py (modified) make all dataDisplay windows be right justified wrt last position. ... Mon, 14 Nov 2016 15:23:02 GMT vondreele [2522] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIimage.py (modified) * trunk/GSASIImath.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIpwd.py (modified) * trunk/GSASIIstrMath.py (modified) Do Ivo's changes & some more work on mag derivatives. Wed, 09 Nov 2016 16:06:10 GMT toby [2518] * trunk/GSASII.py (modified) bind for Sequential Refine in wrong place Mon, 07 Nov 2016 04:18:52 GMT toby [2516] * trunk/GSASII.py (modified) * trunk/GSASIIctrls.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/exports/G2export_CIF.py (modified) * trunk/imports/G2pwd_BrukerRAW.py (modified) * trunk/imports/G2pwd_CIF.py (modified) * trunk/imports/G2pwd_FP.py (modified) * trunk/imports/G2pwd_csv.py (modified) * trunk/imports/G2pwd_fxye.py (modified) * trunk/imports/G2pwd_rigaku.py (modified) * trunk/imports/G2pwd_xye.py (modified) revise import to not assume Bank 1 with multibank instparm files; ... Mon, 31 Oct 2016 23:18:14 GMT toby [2509] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIctrls.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIlog.py (modified) * trunk/help/gsasII.html (modified) fixes to help Mon, 24 Oct 2016 01:05:59 GMT toby [2502] * trunk/GSASII.py (modified) * trunk/GSASIIgrid.py (modified) prevent double-draw of data window after refinements Thu, 20 Oct 2016 15:03:57 GMT toby [2498] * trunk/GSASII.py (modified) * trunk/GSASIIctrls.py (modified) set Refine flag after linking hist & phase in import Thu, 13 Oct 2016 15:34:04 GMT vondreele [2491] * trunk/GSASII.py (modified) * trunk/GSASIIIO.py (modified) * trunk/GSASIIconstrGUI.py (modified) * trunk/GSASIIgrid.py (modified) * trunk/GSASIIphsGUI.py (modified) * trunk/GSASIIpwdGUI.py (modified) * trunk/GSASIIstrMath.py (modified) fix bug for call to GetPhaseData in export phase put in stub for ...
