# # ChangeLog for install # # Generated by Trac 1.0.13 # Jun 17, 2025 5:11:07 AM Mon, 17 Sep 2018 18:22:05 GMT toby [3606] * install/g2conda-py27/construct.yaml (modified) g2conda v1.0.2: use wxpython 3.x for Python 2.7 due to gl problem Mon, 30 Jul 2018 02:14:14 GMT toby [3515] * install/bootstrap.py (modified) * install/g2pkg/src/bootstrap.py (modified) fix bootstrap properties Mon, 30 Jul 2018 02:03:43 GMT svnjenkins [3514] * install/bootstrap.py (modified) * install/g2pkg/src/bootstrap.py (modified) fix bug with proxy input Sun, 22 Jul 2018 04:00:07 GMT svnjenkins [3499] * install/g2conda-py27 (added) * install/g2conda-py27/EULA.txt (added) * install/g2conda-py27/construct.yaml (added) * install/g2conda-py27/gsas2-welcome.png (added) * install/g2conda-py27/gsas2.png (added) Add package for Py2.7 installers Mon, 11 Jun 2018 22:53:52 GMT toby [3431] * install/GSASIIproxy.zip (deleted) * install/GSASIIsvn.zip (deleted) * install/GSASIIsvn17.zip (deleted) * install/g2conda-Mac.sh (deleted) * install/g2pkg/meta.yaml (modified) * install/g2pkg/src/bootstrap.py (modified) latest packaging/bootstrap mods Wed, 06 Jun 2018 03:43:47 GMT toby [3422] * install/g2pkg/bld.bat (modified) packaging corrections from anaconda support Mon, 28 May 2018 20:17:48 GMT toby [3408] * install/g2conda/construct.yaml (modified) fix for Mac; test on Linux Mon, 28 May 2018 19:02:07 GMT toby [3407] * install/g2conda/construct.yaml (modified) * install/g2pkg/meta.yaml (modified) trying build on Linux Mon, 28 May 2018 02:13:19 GMT toby [3405] * install/g2conda/construct.yaml (modified) * install/g2pkg/meta.yaml (modified) test changes to g2conda Mon, 28 May 2018 00:32:50 GMT toby [3404] * Binaries/linux_64_p3.6_n1.14 (added) * Binaries/linux_64_p3.6_n1.14/Build_notes (added) * Binaries/linux_64_p3.6_n1.14/fellipse.cpython-36m-x86_64-linux-gnu.so (added) * Binaries/linux_64_p3.6_n1.14/histogram2d.cpython-36m-x86_64-linux-gnu.so (added) * Binaries/linux_64_p3.6_n1.14/histosigma2d.cpython-36m-x86_64-linux-gnu.so (added) * Binaries/linux_64_p3.6_n1.14/pack_f.cpython-36m-x86_64-linux-gnu.so (added) * Binaries/linux_64_p3.6_n1.14/polymask.cpython-36m-x86_64-linux-gnu.so (added) * Binaries/linux_64_p3.6_n1.14/pydiffax.cpython-36m-x86_64-linux-gnu.so (added) * Binaries/linux_64_p3.6_n1.14/pypowder.cpython-36m-x86_64-linux-gnu.so (added) * Binaries/linux_64_p3.6_n1.14/pyspg.cpython-36m-x86_64-linux-gnu.so (added) * Binaries/linux_64_p3.6_n1.14/pytexture.cpython-36m-x86_64-linux-gnu.so (added) * Binaries/linux_64_p3.6_n1.14/spotmask.cpython-36m-x86_64-linux-gnu.so (added) * Binaries/linux_64_p3.6_n1.14/unpack_cbf.cpython-36m-x86_64-linux-gnu.so (added) * Binaries/mac_64_p3.6_n1.14 (added) * Binaries/mac_64_p3.6_n1.14/Build_notes (added) * Binaries/mac_64_p3.6_n1.14/fellipse.cpython-36m-darwin.so (added) * Binaries/mac_64_p3.6_n1.14/histogram2d.cpython-36m-darwin.so (added) * Binaries/mac_64_p3.6_n1.14/histosigma2d.cpython-36m-darwin.so (added) * Binaries/mac_64_p3.6_n1.14/pack_f.cpython-36m-darwin.so (added) * Binaries/mac_64_p3.6_n1.14/polymask.cpython-36m-darwin.so (added) * Binaries/mac_64_p3.6_n1.14/pydiffax.cpython-36m-darwin.so (added) * Binaries/mac_64_p3.6_n1.14/pypowder.cpython-36m-darwin.so (added) * Binaries/mac_64_p3.6_n1.14/pyspg.cpython-36m-darwin.so (added) * Binaries/mac_64_p3.6_n1.14/pytexture.cpython-36m-darwin.so (added) * Binaries/mac_64_p3.6_n1.14/spotmask.cpython-36m-darwin.so (added) * Binaries/mac_64_p3.6_n1.14/unpack_cbf.cpython-36m-darwin.so (added) * install/g2conda/construct.yaml (modified) * install/g2pkg/meta.yaml (modified) * install/g2pkg/src/bootstrap.py (modified) latest builds from jenkins & update to build g2conda Sat, 23 Dec 2017 01:11:41 GMT toby [3201] * install/bootstrap.py (modified) * install/g2conda/construct.yaml (modified) * install/g2pkg/meta.yaml (modified) update bootstrap for Py3 Mon, 02 Oct 2017 20:01:00 GMT toby [3107] * install/bootstrap.py (modified) more diagnostics; start improvements on Linux shortcut Thu, 24 Aug 2017 19:50:24 GMT toby [3025] * install/bootstrap.py (modified) * trunk/GSASIIpath.py (modified) work on installation issues Mon, 31 Jul 2017 00:37:08 GMT toby [2952] * branch/2frame/GSASIIpath.py (modified) * install/bootstrap.bat (deleted) * install/bootstrap.py (modified) GSASII installation: support downloading of all binaries Thu, 29 Jun 2017 22:54:41 GMT toby [2887] * install/bootstrap.py (modified) * trunk/GSASII.py (modified) * trunk/GSASIIpath.py (modified) setup & use bindist location for downloaded binaries Sat, 17 Jun 2017 22:38:22 GMT toby [2866] * install/bootstrap.py (modified) update bootstrap.py to perform 'svn switch' Sat, 03 Jun 2017 22:43:20 GMT toby [2855] * install/bootstrap.py (modified) * install/g2conda/construct.yaml (modified) * install/g2pkg/meta.yaml (modified) rework bootstrap.py for more diagnostics; require wxpython 3.x for ... Fri, 18 Nov 2016 22:54:14 GMT toby [2535] * install/bootstrap.py (modified) remove g2conda-specific stuff from stand-alone bootstrap Thu, 27 Oct 2016 00:06:33 GMT toby [2507] * install/g2conda/construct.yaml (modified) include missing h5py in builds Sun, 14 Aug 2016 17:06:38 GMT toby [2424] * install/g2conda/EULA.txt (modified) * install/g2pkg/bld.bat (modified) windows install fixes Sun, 07 Aug 2016 22:12:26 GMT toby [2410] * install/bootstrap.py (modified) * install/g2conda/construct.yaml (modified) * install/g2conda/g2install.bat (deleted) * install/g2pkg/meta.yaml (modified) * install/g2pkg/post-link.bat (modified) * install/g2pkg/src/bootstrap.py (modified) * install/g2pkg/src/install.bat (deleted) update for new mac build Tue, 12 Jul 2016 20:25:17 GMT toby [2371] * install/g2conda/g2install.bat (modified) * install/g2pkg/post-link.bat (modified) work on windows installation with constructor 1.3.0 Tue, 12 Jul 2016 20:15:53 GMT toby [2370] * install/g2conda/construct.yaml (modified) * install/g2conda/g2install.bat (added) * install/g2pkg/post-link.bat (modified) * install/windows_notes.txt (modified) work on windows installation with constructor 1.3.0 Sat, 02 Jul 2016 18:40:48 GMT toby [2359] * install/g2pkg/build.sh (modified) address problem in linux build Sat, 02 Jul 2016 18:38:10 GMT toby [2358] * install/g2pkg/build.sh (modified) * install/windows_notes.txt (modified) address problem in linux build Sun, 26 Jun 2016 23:27:23 GMT toby [2345] * install/g2conda/construct.yaml (modified) * install/g2pkg/build.sh (modified) * install/g2pkg/src/bootstrap.py (modified) fix for Windows directories with spaces Fri, 10 Jun 2016 23:16:17 GMT toby [2315] * install/bootstrap.py (modified) * install/g2conda/construct.yaml (modified) * install/g2conda/gsas2-welcome.png (added) * install/g2pkg/bld.bat (modified) * install/g2pkg/bootstrap.py (deleted) * install/g2pkg/meta.yaml (modified) * install/g2pkg/post-link.bat (added) * install/g2pkg/src (added) * install/g2pkg/src/bootstrap.py (added) * install/g2pkg/src/install.bat (added) * install/windows_notes.txt (added) seems to work, but problem in updating install.bat Tue, 15 Mar 2016 18:31:36 GMT toby [2171] * install/g2conda (added) * install/g2conda-Mac.sh (moved) * install/g2conda/.index.json (added) * install/g2conda/EULA.txt (added) * install/g2conda/construct.yaml (added) * install/g2conda/gsas2.png (added) * install/g2pkg (added) * install/g2pkg/bld.bat (added) * install/g2pkg/bootstrap.py (added) * install/g2pkg/build.sh (added) * install/g2pkg/meta.yaml (added) * install/g2pkg/post-link.sh (added) single-step installer, as implemented for Mac Sun, 13 Mar 2016 21:56:43 GMT toby [2169] * install/g2conda-0.1.1-MacOSX-x86_64.sh (added) upload 1-step installer for Mac Sun, 13 Mar 2016 21:50:35 GMT toby [2168] * install/g2conda-0.1.1-MacOSX-x86_64.sh (added) upload 1-step installer for Mac Wed, 20 Jan 2016 16:34:07 GMT toby [2128] * install/bootstrap.py (modified) fix quotes on install error Tue, 26 May 2015 22:24:40 GMT toby [1867] * install/GSASIIproxy.zip (added) * install/bootstrap.bat (added) * install/bootstrap.py (modified) new universal installer based on bootstrap.py Thu, 12 Mar 2015 17:35:50 GMT toby [1697] * install/GSASIIsvn.zip (modified) * install/GSASIIsvn17.zip (added) prepare new windows kit with svn 1.7.19 Wed, 22 Oct 2014 20:42:27 GMT toby [1532] * install/bootstrap.py (modified) allow bootstrap to work with old svn, as in 10.5 Wed, 21 May 2014 16:01:43 GMT toby [1358] * install/bootstrap.py (modified) update bootstrap: no verification, new msg Mon, 17 Mar 2014 16:34:58 GMT toby [1251] * install/bootstrap.py (modified) on mac recommend EPD Thu, 20 Feb 2014 17:19:35 GMT toby [1226] * install/bootstrap.py (modified) change to .xray.aps Fri, 04 Oct 2013 21:19:28 GMT toby [1085] * install/bootstrap.py (modified) installer uses xterm on GNOME shortcut Sun, 07 Jul 2013 15:03:10 GMT toby [983] * install/bootstrap.py (modified) new Mac app Thu, 09 May 2013 04:54:23 GMT toby [901] * install/bootstrap.py (modified) look for svn in path & wandisco location Sat, 25 Aug 2012 23:31:04 GMT toby [737] * install/GSASIIsvn.zip (modified) update windows dist with proxy-using batch file Sun, 01 Jul 2012 01:42:32 GMT toby [672] * install/bootstrap.py (modified) Revise GSAS-II Mac app to run in terminal (fix) Sun, 01 Jul 2012 01:40:27 GMT toby [671] * install/bootstrap.py (modified) Revise GSAS-II Mac app to run in terminal (fix) Sun, 01 Jul 2012 01:37:47 GMT toby [669] * install/bootstrap.py (modified) Revise GSAS-II Mac app to run in terminal Wed, 06 Jul 2011 02:26:10 GMT toby [333] * install/bootstrap.py (added) Add Mac/Linux install script Tue, 05 Jul 2011 19:00:14 GMT toby [332] * install (added) * install/GSASIIsvn.zip (moved) move to install directory
