# # ChangeLog for install/bootstrap.py # # Generated by Trac 1.0.13 # Jun 14, 2025 10:36:57 AM Mon, 31 Jul 2017 00:37:08 GMT toby [2952] * branch/2frame/GSASIIpath.py (modified) * install/bootstrap.bat (deleted) * install/bootstrap.py (modified) GSASII installation: support downloading of all binaries Thu, 29 Jun 2017 22:54:41 GMT toby [2887] * install/bootstrap.py (modified) * trunk/GSASII.py (modified) * trunk/GSASIIpath.py (modified) setup & use bindist location for downloaded binaries Sat, 17 Jun 2017 22:38:22 GMT toby [2866] * install/bootstrap.py (modified) update bootstrap.py to perform 'svn switch' Sat, 03 Jun 2017 22:43:20 GMT toby [2855] * install/bootstrap.py (modified) * install/g2conda/construct.yaml (modified) * install/g2pkg/meta.yaml (modified) rework bootstrap.py for more diagnostics; require wxpython 3.x for ... Fri, 18 Nov 2016 22:54:14 GMT toby [2535] * install/bootstrap.py (modified) remove g2conda-specific stuff from stand-alone bootstrap Sun, 07 Aug 2016 22:12:26 GMT toby [2410] * install/bootstrap.py (modified) * install/g2conda/construct.yaml (modified) * install/g2conda/g2install.bat (deleted) * install/g2pkg/meta.yaml (modified) * install/g2pkg/post-link.bat (modified) * install/g2pkg/src/bootstrap.py (modified) * install/g2pkg/src/install.bat (deleted) update for new mac build Fri, 10 Jun 2016 23:16:17 GMT toby [2315] * install/bootstrap.py (modified) * install/g2conda/construct.yaml (modified) * install/g2conda/gsas2-welcome.png (added) * install/g2pkg/bld.bat (modified) * install/g2pkg/bootstrap.py (deleted) * install/g2pkg/meta.yaml (modified) * install/g2pkg/post-link.bat (added) * install/g2pkg/src (added) * install/g2pkg/src/bootstrap.py (added) * install/g2pkg/src/install.bat (added) * install/windows_notes.txt (added) seems to work, but problem in updating install.bat Wed, 20 Jan 2016 16:34:07 GMT toby [2128] * install/bootstrap.py (modified) fix quotes on install error Tue, 26 May 2015 22:24:40 GMT toby [1867] * install/GSASIIproxy.zip (added) * install/bootstrap.bat (added) * install/bootstrap.py (modified) new universal installer based on bootstrap.py Wed, 22 Oct 2014 20:42:27 GMT toby [1532] * install/bootstrap.py (modified) allow bootstrap to work with old svn, as in 10.5 Wed, 21 May 2014 16:01:43 GMT toby [1358] * install/bootstrap.py (modified) update bootstrap: no verification, new msg Mon, 17 Mar 2014 16:34:58 GMT toby [1251] * install/bootstrap.py (modified) on mac recommend EPD Thu, 20 Feb 2014 17:19:35 GMT toby [1226] * install/bootstrap.py (modified) change to .xray.aps Fri, 04 Oct 2013 21:19:28 GMT toby [1085] * install/bootstrap.py (modified) installer uses xterm on GNOME shortcut Sun, 07 Jul 2013 15:03:10 GMT toby [983] * install/bootstrap.py (modified) new Mac app Thu, 09 May 2013 04:54:23 GMT toby [901] * install/bootstrap.py (modified) look for svn in path & wandisco location Sun, 01 Jul 2012 01:42:32 GMT toby [672] * install/bootstrap.py (modified) Revise GSAS-II Mac app to run in terminal (fix) Sun, 01 Jul 2012 01:40:27 GMT toby [671] * install/bootstrap.py (modified) Revise GSAS-II Mac app to run in terminal (fix) Sun, 01 Jul 2012 01:37:47 GMT toby [669] * install/bootstrap.py (modified) Revise GSAS-II Mac app to run in terminal Wed, 06 Jul 2011 02:26:10 GMT toby [333] * install/bootstrap.py (added) Add Mac/Linux install script
