# ChangeLog for branch
# Generated by Trac 1.0.13
# Jun 17, 2025 8:25:08 AM
Fri, 13 Oct 2017 21:57:09 GMT vondreele [3134]
	* branch/py3gsasii (deleted)
Fri, 13 Oct 2017 21:55:49 GMT vondreele [3133]
	* branch/py3gsasii (added)
Sat, 12 Aug 2017 03:16:14 GMT toby [3002]
	* branch/2frame-old (moved)
	remove 2frame branch
Fri, 11 Aug 2017 19:56:37 GMT toby [2999]
	* branch/2frame (modified)
	one more update
Fri, 11 Aug 2017 19:15:36 GMT toby [2998]
	* Binaries/mac_32_p2.7_n1.6 (modified)
	* branch/2frame/AllBinaries (modified)
	* branch/2frame/GSASII.py (modified)
	* branch/2frame/GSASIIobj.py (modified)
	* branch/2frame/GSASIIpath.py (modified)
	* branch/2frame/GSASIIphsGUI.py (modified)
	* branch/2frame/GSASIIplot.py (modified)
	* branch/2frame/GSASIIstrMain.py (modified)
	* branch/2frame/GSASIIstrMath.py (modified)
	* branch/2frame/exports (modified)
	* branch/2frame/gltext.py (modified)
	merge trunk into 2frame
Fri, 11 Aug 2017 18:24:03 GMT vondreele [2997]
	* branch/2frame/GSASIIpwdGUI.py (modified)
	fix OnSelect in SASD models GUI
	replace imgAx = Img.get_axes() with ...
Fri, 11 Aug 2017 17:16:08 GMT odonnell [2996]
	* branch/2frame/GSASIIscriptable.py (modified)
	fixed background fitting, made GSASIIpath printing optional
Fri, 11 Aug 2017 14:11:21 GMT toby [2995]
	* branch/2frame/GSASIIdataGUI.py (modified)
	fix potential unicode errors in GSASIIdtaGUI; addition parameter ...
Thu, 10 Aug 2017 21:04:56 GMT odonnell [2994]
	revised HAP parameter docs
Thu, 10 Aug 2017 17:59:01 GMT vondreele [2992]
	fix cut-off
Thu, 10 Aug 2017 14:51:29 GMT odonnell [2990]
	fixed KeyError
Thu, 10 Aug 2017 02:59:31 GMT toby [2988]
	* branch/2frame/GSASIIddataGUI.py (modified)
	put unbind back
Wed, 09 Aug 2017 21:39:05 GMT odonnell [2987]
	added some HAP documentation to GSASIIobj
Wed, 09 Aug 2017 21:10:36 GMT vondreele [2985]
	remove that unbind - caused crash when adding a new histogram
Wed, 09 Aug 2017 19:41:58 GMT odonnell [2984]
	added .plot() method to histograms, changed to
	(set|clear)_refinements
Wed, 09 Aug 2017 17:08:10 GMT toby [2979]
	add scriptable option to browse data structure in IPython
Wed, 09 Aug 2017 17:04:24 GMT vondreele [2978]
	* branch/2frame/imports/G2phase_GPX.py (modified)
	fix plot clipping problem
	fix a OnFileClose problem
	fix a import ...
Wed, 09 Aug 2017 16:19:34 GMT odonnell [2977]
	fixed "Simulate a dataset" bug
Wed, 09 Aug 2017 14:37:03 GMT toby [2976]
	fix Linux bug, binding triggers on widget delete, minor fixes
Tue, 08 Aug 2017 21:54:15 GMT toby [2975]
	fix for wx2.8 and null file path
Tue, 08 Aug 2017 21:50:04 GMT odonnell [2974]
	remove prints in LoadDictFromProjFile, SaveDictToProjFile, add dump
	args
Tue, 08 Aug 2017 14:26:44 GMT odonnell [2968]
	More sphinx docstrings, start of command line interface, wrappers ...
Mon, 07 Aug 2017 19:17:51 GMT toby [2967]
	* branch/2frame/GSASIIlattice.py (modified)
	* branch/2frame/GSASIImath.py (modified)
	* branch/2frame/docs/source/GSASIIGUI.rst (modified)
	* branch/2frame/docs/source/GSASIIGUIr.rst (modified)
	* branch/2frame/docs/source/GSASIIscripts.rst (modified)
	* branch/2frame/docs/source/conf.py (modified)
	* branch/2frame/docs/source/index.rst (modified)
	misc changes for sphinx docs
Mon, 07 Aug 2017 13:18:52 GMT vondreele [2964]
	* branch/2frame/GSASIIstrIO.py (modified)
	work on protein validation - not correct yet; gives plot tho.
	fix ...
Sun, 06 Aug 2017 20:08:30 GMT toby [2963]
	* branch/2frame/GSASIIIO.py (modified)
	* branch/2frame/GSASIIfiles.py (added)
	Incorporate Jackson O'Donnell's gpx_manipulations code
Thu, 03 Aug 2017 00:44:15 GMT toby [2962]
	fix bug in derivative for excluded regions
Thu, 03 Aug 2017 00:38:42 GMT toby [2961]
Wed, 02 Aug 2017 14:30:14 GMT vondreele [2960]
	remove spaces from Instprm GUI display & check & correct special ...
Wed, 02 Aug 2017 13:49:27 GMT vondreele [2959]
	a bit more on inst prm GUI - put in column headings
Tue, 01 Aug 2017 21:34:13 GMT toby [2958]
	minor fmt changes to some histogram data windows
Tue, 01 Aug 2017 20:18:41 GMT toby [2957]
	use grid scroll bars for Peak List and Index Peak List displays; ...
Tue, 01 Aug 2017 18:36:41 GMT vondreele [2956]
	Put all reverse/copy to next options on all 4 seq fits in G2pwdGUI
Tue, 01 Aug 2017 15:34:15 GMT vondreele [2955]
	* branch/2frame/GSASIIconstrGUI.py (modified)
	* branch/2frame/GSASIIimgGUI.py (modified)
	minor cleanup of RigidBodyDisplay - dashed line too long.
	make spot ...
Mon, 31 Jul 2017 18:42:21 GMT toby [2954]
	fix minor warning (wrong .SetDataSize called)
Mon, 31 Jul 2017 18:34:28 GMT toby [2953]
	two scroll fixes: controls had .SetupScrolling; reflection list ...
Mon, 31 Jul 2017 00:37:08 GMT toby [2952]
	* install/bootstrap.bat (deleted)
	* install/bootstrap.py (modified)
	GSASII installation: support downloading of all binaries
Sun, 30 Jul 2017 21:38:15 GMT toby [2951]
	* branch/2frame/AllBinaries (added)
	* trunk/AllBinaries (added)
	Make directory for all binaries
Sun, 30 Jul 2017 20:01:17 GMT vondreele [2950]
	* branch/2frame/GSASIIctrlGUI.py (modified)
	oops - forgot the SetSizer in SetPhaseWindow
	make SetScrollRate(0,0) ...
Sun, 30 Jul 2017 19:16:54 GMT vondreele [2949]
	fix window behavior - use wx.ScrolledWindow instead of ScrolledPanel ...
Sun, 30 Jul 2017 01:06:56 GMT toby [2948]
	return to version [2935] of GSASIIstrMath.py w/o MP
Sun, 30 Jul 2017 00:10:21 GMT toby [2947]
	check in mp fix before reverting
Thu, 27 Jul 2017 20:38:36 GMT vondreele [2946]
	force revert to 2943 (2944 has bad multiprocessing)
Thu, 27 Jul 2017 20:03:15 GMT vondreele [2945]
Tue, 25 Jul 2017 23:21:06 GMT toby [2944]
	* branch/2frame/GSASIImpsubs.py (modified)
	Finally: multiprocessing for refinement
Tue, 25 Jul 2017 21:46:10 GMT vondreele [2943]
	fix H-atom placement/view problem
Tue, 25 Jul 2017 20:06:04 GMT vondreele [2942]
	cleanup anneal MC/SA routine; remove extraneous parameters
	add ...
Sat, 22 Jul 2017 20:54:17 GMT toby [2941]
	* branch/2frame/GSASIImpsubs.py (added)
	* branch/2frame/config_example.py (modified)
	prepare for multiprocessing implementation
Sat, 22 Jul 2017 16:51:59 GMT vondreele [2940]
	* branch/2frame/GSASIIrestrGUI.py (modified)
	fix rigid body GUI display
	remove an extra SetAutoLayout
	fix ...
Fri, 21 Jul 2017 22:22:13 GMT toby [2939]
	improve error messages for writing config.py
Thu, 20 Jul 2017 16:59:48 GMT vondreele [2938]
	atom reordering problem - draw atoms didn't follow. Now fixed
	remove ...
Wed, 19 Jul 2017 21:14:08 GMT vondreele [2937]
	put a self.SetAutoLayout(True) in SetDataSize
	cleanup anneal - ...
Sat, 15 Jul 2017 19:31:54 GMT toby [2936]
	* trunk/GSASIIpath.py (modified)
	bail out when bin lookup fails
Sat, 15 Jul 2017 19:10:22 GMT vondreele [2935]
	* branch/2frame/GSASIIpwd.py (modified)
	"fix" to tabulated TOF profile coeff. in Refine - ignored & alp = ...
Sat, 15 Jul 2017 15:37:57 GMT vondreele [2934]
	fix display of Substances - wrong mainSizer
Fri, 14 Jul 2017 14:16:05 GMT vondreele [2933]
	forgot last fixes to frame positioning
Fri, 14 Jul 2017 14:13:04 GMT vondreele [2932]
	fix window placement when screens change
Thu, 13 Jul 2017 18:08:24 GMT vondreele [2931]
	remove duplicate code from G2dataGUI lines 5922-3; same thing is done ...
Wed, 12 Jul 2017 20:54:39 GMT vondreele [2930]
	* branch/2frame/basinhopping.py (modified)
	tweaks of basinhopping
	replace more TextCtrl with ValidatedTxtCtrl ...
Wed, 12 Jul 2017 18:09:37 GMT toby [2929]
	fix seq. ref. window; screen positioning bug; read of multiple data ...
Wed, 12 Jul 2017 18:08:49 GMT toby [2928]
Tue, 11 Jul 2017 21:29:11 GMT vondreele [2927]
	set up a local version of basinhopping.py in MCSA routine
	implement ...
Sat, 08 Jul 2017 20:42:02 GMT toby [2924]
	prevent load of binaries during update
Sat, 08 Jul 2017 20:12:16 GMT toby [2923]
	add fixes
Sat, 08 Jul 2017 20:02:22 GMT toby [2922]
	add some debug info
Sat, 08 Jul 2017 19:57:13 GMT toby [2921]
	add switch command to 2frame
Sat, 08 Jul 2017 15:19:19 GMT vondreele [2920]
	organize all the wxIDs
Sat, 08 Jul 2017 05:02:01 GMT toby [2919]
	finish ClearData/SetSizeData fixes in pwdGUI
Fri, 07 Jul 2017 22:30:18 GMT toby [2918]
	wxID w/extra spaces; start on ClearData/SetSizeData pwdGUI fixes
Fri, 07 Jul 2017 21:45:18 GMT toby [2917]
	massive changes of wxID_ ids & misc to fix undefined vars wanings
Fri, 07 Jul 2017 20:17:52 GMT toby [2916]
	fix Add Peaks, etc.; document use of dataWindow
Fri, 07 Jul 2017 19:37:33 GMT vondreele [2915]
	split status bar in 2; one for tree & the other for data window
	status
Fri, 07 Jul 2017 17:32:09 GMT vondreele [2914]
	fix G2constrGUI; dataDisplay --> rbBook & fix a parent issue ...
Thu, 06 Jul 2017 20:09:41 GMT toby [2913]
	implement restraint tab selection menu; fix restraint scroll bar ...
Thu, 06 Jul 2017 00:13:15 GMT toby [2912]
	more Bind()'s to dataWindow; better error msg on bindist problem
Wed, 05 Jul 2017 23:57:25 GMT toby [2911]
	* branch/2frame/GSASIIlog.py (modified)
	fix menu binds to dataWindow; fix Help menu for non-mac; dataFrame ...
Wed, 05 Jul 2017 20:41:45 GMT vondreele [2910]
	fix G2 includes
Wed, 05 Jul 2017 18:30:37 GMT toby [2909]
	improve window title; still working on help
Wed, 05 Jul 2017 04:33:37 GMT toby [2908]
	Scroll bars work for Phase & Histogram windows; Constraints, ...
Tue, 04 Jul 2017 23:19:31 GMT toby [2907]
	tabbed phase panel done. More to go...
Tue, 04 Jul 2017 19:14:54 GMT toby [2906]
	more refactoring while debugging dataWindow
Tue, 04 Jul 2017 17:11:29 GMT toby [2905]
	use GPXtree in place of PatternTree
Tue, 04 Jul 2017 14:37:13 GMT toby [2900]
	* branch/2frame/GSASIIctrlGUI.py (moved)
	* branch/2frame/GSASIIdataGUI.py (moved)
	* branch/2frame/GSASIIexprGUI.py (modified)
	* branch/2frame/exports/G2export_CIF.py (modified)
	* branch/2frame/exports/G2export_PDB.py (modified)
	* branch/2frame/exports/G2export_examples.py (modified)
	* branch/2frame/exports/G2export_map.py (modified)
	* branch/2frame/testSSymbols.py (modified)
	reorg for GUI separation pretty much complete (GSASIIIO.py still ...
Mon, 03 Jul 2017 21:12:45 GMT toby [2899]
	* branch/2frame/GSASIIctrls.py (modified)
	* branch/2frame/GSASIIgrid.py (modified)
	partial reorg
Mon, 03 Jul 2017 19:12:22 GMT toby [2898]
	fix scroll bars on tree panel, start debugging on data panel
Mon, 03 Jul 2017 17:29:33 GMT toby [2897]
	* trunk/exports/G2export_CIF.py (modified)
	fix full CIF export bug
Mon, 03 Jul 2017 00:29:26 GMT toby [2896]
	* branch/2frame/binlinux2.7 (deleted)
	* branch/2frame/binlinux64-2.7 (deleted)
	* branch/2frame/binmac2.7 (deleted)
	* branch/2frame/binmac64-2.7 (deleted)
	* branch/2frame/binwin2.7 (deleted)
	* branch/2frame/binwin64-2.7 (deleted)
	get rid of bin<platform> directories
Mon, 03 Jul 2017 00:27:09 GMT toby [2895]
	* branch/2frame/ElementTable.py (copied)
	* branch/2frame/FormFactors.py (copied)
	* branch/2frame/GSASIImapvars.py (copied)
	* branch/2frame/GSASIIobj.py (copied)
	* branch/2frame/GSASIIpath.py (copied)
	* branch/2frame/GSASIIpy3.py (copied)
	* branch/2frame/GSASIIscriptable.py (copied)
	* branch/2frame/GSASIIspc.py (copied)
	* branch/2frame/GSASIIstrMain.py (copied)
	* branch/2frame/GSASIIstrMath.py (copied)
	* branch/2frame/GSASIItestplot.py (copied)
	* branch/2frame/ImageCalibrants.py (copied)
	* branch/2frame/ReadMarCCDFrame.py (copied)
	* branch/2frame/Substances.py (copied)
	* branch/2frame/atmdata.py (copied)
	* branch/2frame/basinhopping.py (copied)
	* branch/2frame/bindist (added)
	* branch/2frame/makeBat.py (copied)
	* branch/2frame/makeMacApp.py (copied)
	* branch/2frame/scanCCD.py (copied)
	* branch/2frame/testDeriv.py (copied)
	* branch/2frame/testSSymbols.py (copied)
	merge trunk changes to 2984
Sun, 02 Jul 2017 14:33:22 GMT vondreele [2893]
	fixes to window resize issues
Sat, 01 Jul 2017 19:58:01 GMT vondreele [2892]
	ddataGui fix & np.fmax --> np.amax (wrong  max function) in phsGUI
Sat, 01 Jul 2017 19:02:11 GMT vondreele [2891]
	fix atom picking from plot stuff
Sat, 01 Jul 2017 16:17:10 GMT vondreele [2890]
	Constraints now displayed
	fix TopLevel references
	fix display ...
Sat, 01 Jul 2017 11:22:10 GMT vondreele [2888]
	* branch/2frame (copied)
Thu, 02 Oct 2014 00:12:29 GMT toby [1511]
	* branch/logging/GSASIIlog.py (modified)
	* branch/logging/GSASIIpath.py (modified)
	* branch/logging/config.py.example (added)
	add config file support
Wed, 01 Oct 2014 21:14:25 GMT toby [1510]
	* branch/logging/GSASII.py (modified)
	* branch/logging/GSASIIgrid.py (modified)
	* branch/logging/GSASIIlog.py (moved)
	logging pretty well ready to roll
Mon, 29 Sep 2014 19:31:04 GMT toby [1509]
	* branch/logging/log.py (modified)
	logging refactored, and much cleaner\!
Sun, 21 Sep 2014 01:27:59 GMT toby [1505]
	track with relative phase & histogram numbers
Tue, 16 Sep 2014 19:28:31 GMT toby [1497]
	* branch/logging/GSASIIconstrGUI.py (modified)
	* branch/logging/GSASIIphsGUI.py (modified)
	logging more complete
Mon, 25 Aug 2014 01:57:46 GMT toby [1477]
	* branch/logging/GSASIIpwdGUI.py (modified)
	* branch/logging/log.py (added)
	variable change logging finally works
Mon, 04 Aug 2014 22:44:06 GMT toby [1458]
	* branch/logging (copied)
	create logging branch
Mon, 04 Aug 2014 22:43:11 GMT toby [1457]
	* branch/MPbranch (moved)
	use branches properly
