# # ChangeLog for branch # # Generated by Trac 1.0.13 # Jun 17, 2025 8:19:49 PM Wed, 02 Aug 2017 13:49:27 GMT vondreele [2959] * branch/2frame/GSASIIpwdGUI.py (modified) a bit more on inst prm GUI - put in column headings Tue, 01 Aug 2017 21:34:13 GMT toby [2958] * branch/2frame/GSASIIpwdGUI.py (modified) minor fmt changes to some histogram data windows Tue, 01 Aug 2017 20:18:41 GMT toby [2957] * branch/2frame/GSASIIdataGUI.py (modified) * branch/2frame/GSASIImath.py (modified) * branch/2frame/GSASIIpwdGUI.py (modified) use grid scroll bars for Peak List and Index Peak List displays; ... Tue, 01 Aug 2017 18:36:41 GMT vondreele [2956] * branch/2frame/GSASIIphsGUI.py (modified) * branch/2frame/GSASIIpwdGUI.py (modified) Put all reverse/copy to next options on all 4 seq fits in G2pwdGUI Tue, 01 Aug 2017 15:34:15 GMT vondreele [2955] * branch/2frame/GSASIIconstrGUI.py (modified) * branch/2frame/GSASIIimgGUI.py (modified) * branch/2frame/GSASIIphsGUI.py (modified) * branch/2frame/GSASIIpwdGUI.py (modified) minor cleanup of RigidBodyDisplay - dashed line too long. make spot ... Mon, 31 Jul 2017 18:42:21 GMT toby [2954] * branch/2frame/GSASIIdataGUI.py (modified) fix minor warning (wrong .SetDataSize called) Mon, 31 Jul 2017 18:34:28 GMT toby [2953] * branch/2frame/GSASIIdataGUI.py (modified) * branch/2frame/GSASIIpwdGUI.py (modified) two scroll fixes: controls had .SetupScrolling; reflection list ... Mon, 31 Jul 2017 00:37:08 GMT toby [2952] * branch/2frame/GSASIIpath.py (modified) * install/bootstrap.bat (deleted) * install/bootstrap.py (modified) GSASII installation: support downloading of all binaries Sun, 30 Jul 2017 21:38:15 GMT toby [2951] * branch/2frame/AllBinaries (added) * trunk/AllBinaries (added) Make directory for all binaries Sun, 30 Jul 2017 20:01:17 GMT vondreele [2950] * branch/2frame/GSASIIconstrGUI.py (modified) * branch/2frame/GSASIIctrlGUI.py (modified) * branch/2frame/GSASIIphsGUI.py (modified) * branch/2frame/GSASIIpwdGUI.py (modified) oops - forgot the SetSizer in SetPhaseWindow make SetScrollRate(0,0) ... Sun, 30 Jul 2017 19:16:54 GMT vondreele [2949] * branch/2frame/GSASIIdataGUI.py (modified) * branch/2frame/GSASIIimgGUI.py (modified) * branch/2frame/GSASIIphsGUI.py (modified) fix window behavior - use wx.ScrolledWindow instead of ScrolledPanel ... Sun, 30 Jul 2017 01:06:56 GMT toby [2948] * branch/2frame/GSASIIstrMath.py (modified) return to version [2935] of GSASIIstrMath.py w/o MP Sun, 30 Jul 2017 00:10:21 GMT toby [2947] * branch/2frame/GSASIIstrMath.py (modified) check in mp fix before reverting Thu, 27 Jul 2017 20:38:36 GMT vondreele [2946] * branch/2frame/GSASIIstrMath.py (modified) force revert to 2943 (2944 has bad multiprocessing) Thu, 27 Jul 2017 20:03:15 GMT vondreele [2945] * branch/2frame/GSASIImath.py (modified) * branch/2frame/GSASIIphsGUI.py (modified) * branch/2frame/GSASIIplot.py (modified) Tue, 25 Jul 2017 23:21:06 GMT toby [2944] * branch/2frame/GSASIIdataGUI.py (modified) * branch/2frame/GSASIImpsubs.py (modified) * branch/2frame/GSASIIstrMath.py (modified) Finally: multiprocessing for refinement Tue, 25 Jul 2017 21:46:10 GMT vondreele [2943] * branch/2frame/GSASIImath.py (modified) * branch/2frame/GSASIIphsGUI.py (modified) fix H-atom placement/view problem Tue, 25 Jul 2017 20:06:04 GMT vondreele [2942] * branch/2frame/GSASIIdataGUI.py (modified) * branch/2frame/GSASIImath.py (modified) * branch/2frame/GSASIIphsGUI.py (modified) cleanup anneal MC/SA routine; remove extraneous parameters add ... Sat, 22 Jul 2017 20:54:17 GMT toby [2941] * branch/2frame/GSASIImpsubs.py (added) * branch/2frame/config_example.py (modified) prepare for multiprocessing implementation Sat, 22 Jul 2017 16:51:59 GMT vondreele [2940] * branch/2frame/GSASIIconstrGUI.py (modified) * branch/2frame/GSASIIdataGUI.py (modified) * branch/2frame/GSASIImath.py (modified) * branch/2frame/GSASIIphsGUI.py (modified) * branch/2frame/GSASIIplot.py (modified) * branch/2frame/GSASIIrestrGUI.py (modified) * branch/2frame/imports/G2phase_GPX.py (modified) fix rigid body GUI display remove an extra SetAutoLayout fix ... Fri, 21 Jul 2017 22:22:13 GMT toby [2939] * branch/2frame/GSASIIctrlGUI.py (modified) improve error messages for writing config.py Thu, 20 Jul 2017 16:59:48 GMT vondreele [2938] * branch/2frame/GSASIIphsGUI.py (modified) * branch/2frame/GSASIIpwdGUI.py (modified) atom reordering problem - draw atoms didn't follow. Now fixed remove ... Wed, 19 Jul 2017 21:14:08 GMT vondreele [2937] * branch/2frame/GSASIIdataGUI.py (modified) * branch/2frame/GSASIImath.py (modified) * branch/2frame/GSASIIphsGUI.py (modified) * branch/2frame/GSASIIplot.py (modified) * branch/2frame/GSASIIpwdGUI.py (modified) put a self.SetAutoLayout(True) in SetDataSize cleanup anneal - ... Sat, 15 Jul 2017 19:31:54 GMT toby [2936] * branch/2frame/GSASIIpath.py (modified) * trunk/GSASIIpath.py (modified) bail out when bin lookup fails Sat, 15 Jul 2017 19:10:22 GMT vondreele [2935] * branch/2frame/GSASIIpwd.py (modified) * branch/2frame/GSASIIstrIO.py (modified) * branch/2frame/GSASIIstrMath.py (modified) "fix" to tabulated TOF profile coeff. in Refine - ignored & alp = ... Sat, 15 Jul 2017 15:37:57 GMT vondreele [2934] * branch/2frame/GSASIIdataGUI.py (modified) * branch/2frame/GSASIIpwdGUI.py (modified) fix display of Substances - wrong mainSizer Fri, 14 Jul 2017 14:16:05 GMT vondreele [2933] * branch/2frame/GSASIIdataGUI.py (modified) forgot last fixes to frame positioning Fri, 14 Jul 2017 14:13:04 GMT vondreele [2932] * branch/2frame/GSASIIdataGUI.py (modified) fix window placement when screens change Thu, 13 Jul 2017 18:08:24 GMT vondreele [2931] * branch/2frame/GSASIIdataGUI.py (modified) * branch/2frame/GSASIIddataGUI.py (modified) * branch/2frame/GSASIIplot.py (modified) remove duplicate code from G2dataGUI lines 5922-3; same thing is done ... Wed, 12 Jul 2017 20:54:39 GMT vondreele [2930] * branch/2frame/GSASIImath.py (modified) * branch/2frame/GSASIIphsGUI.py (modified) * branch/2frame/basinhopping.py (modified) * branch/2frame/config_example.py (modified) tweaks of basinhopping replace more TextCtrl with ValidatedTxtCtrl ... Wed, 12 Jul 2017 18:09:37 GMT toby [2929] * branch/2frame/GSASIIdataGUI.py (modified) fix seq. ref. window; screen positioning bug; read of multiple data ... Wed, 12 Jul 2017 18:08:49 GMT toby [2928] * branch/2frame/GSASIIpwd.py (modified) * branch/2frame/GSASIIstrMain.py (modified) fix seq. ref. window; screen positioning bug; read of multiple data ... Tue, 11 Jul 2017 21:29:11 GMT vondreele [2927] * branch/2frame/GSASIIdataGUI.py (modified) * branch/2frame/GSASIIimgGUI.py (modified) * branch/2frame/GSASIImath.py (modified) * branch/2frame/GSASIIobj.py (modified) * branch/2frame/GSASIIpath.py (modified) * branch/2frame/GSASIIphsGUI.py (modified) * branch/2frame/GSASIIstrMath.py (modified) * branch/2frame/basinhopping.py (modified) * branch/2frame/config_example.py (modified) set up a local version of basinhopping.py in MCSA routine implement ... Sat, 08 Jul 2017 20:42:02 GMT toby [2924] * branch/2frame/GSASII.py (modified) * branch/2frame/GSASIIctrlGUI.py (modified) * branch/2frame/GSASIIpath.py (modified) * branch/2frame/GSASIIstrMain.py (modified) prevent load of binaries during update Sat, 08 Jul 2017 20:12:16 GMT toby [2923] * branch/2frame/GSASIIctrlGUI.py (modified) * branch/2frame/GSASIIpath.py (modified) add fixes Sat, 08 Jul 2017 20:02:22 GMT toby [2922] * branch/2frame/GSASIIpath.py (modified) add some debug info Sat, 08 Jul 2017 19:57:13 GMT toby [2921] * branch/2frame/GSASIIctrlGUI.py (modified) * branch/2frame/GSASIIpath.py (modified) add switch command to 2frame Sat, 08 Jul 2017 15:19:19 GMT vondreele [2920] * branch/2frame/GSASIIdataGUI.py (modified) * branch/2frame/GSASIIpwdGUI.py (modified) organize all the wxIDs Sat, 08 Jul 2017 05:02:01 GMT toby [2919] * branch/2frame/GSASIIpwdGUI.py (modified) finish ClearData/SetSizeData fixes in pwdGUI Fri, 07 Jul 2017 22:30:18 GMT toby [2918] * branch/2frame/GSASIIdataGUI.py (modified) * branch/2frame/GSASIIpwdGUI.py (modified) wxID w/extra spaces; start on ClearData/SetSizeData pwdGUI fixes Fri, 07 Jul 2017 21:45:18 GMT toby [2917] * branch/2frame/GSASIIconstrGUI.py (modified) * branch/2frame/GSASIIctrlGUI.py (modified) * branch/2frame/GSASIIdataGUI.py (modified) * branch/2frame/GSASIIddataGUI.py (modified) * branch/2frame/GSASIIimgGUI.py (modified) * branch/2frame/GSASIIphsGUI.py (modified) * branch/2frame/GSASIIpwdGUI.py (modified) * branch/2frame/GSASIIrestrGUI.py (modified) massive changes of wxID_ ids & misc to fix undefined vars wanings Fri, 07 Jul 2017 20:17:52 GMT toby [2916] * branch/2frame/GSASIIdataGUI.py (modified) * branch/2frame/GSASIIpwdGUI.py (modified) fix Add Peaks, etc.; document use of dataWindow Fri, 07 Jul 2017 19:37:33 GMT vondreele [2915] * branch/2frame/GSASIIIO.py (modified) * branch/2frame/GSASIIconstrGUI.py (modified) * branch/2frame/GSASIIdataGUI.py (modified) * branch/2frame/GSASIIddataGUI.py (modified) * branch/2frame/GSASIIimgGUI.py (modified) * branch/2frame/GSASIIphsGUI.py (modified) * branch/2frame/GSASIIpwdGUI.py (modified) split status bar in 2; one for tree & the other for data window status Fri, 07 Jul 2017 17:32:09 GMT vondreele [2914] * branch/2frame/GSASIIconstrGUI.py (modified) * branch/2frame/GSASIIctrlGUI.py (modified) * branch/2frame/GSASIIdataGUI.py (modified) * branch/2frame/GSASIIplot.py (modified) * branch/2frame/GSASIIrestrGUI.py (modified) fix G2constrGUI; dataDisplay --> rbBook & fix a parent issue ... Thu, 06 Jul 2017 20:09:41 GMT toby [2913] * branch/2frame/GSASIIconstrGUI.py (modified) * branch/2frame/GSASIIctrlGUI.py (modified) * branch/2frame/GSASIIdataGUI.py (modified) * branch/2frame/GSASIIphsGUI.py (modified) * branch/2frame/GSASIIplot.py (modified) * branch/2frame/GSASIIpwdGUI.py (modified) * branch/2frame/GSASIIrestrGUI.py (modified) implement restraint tab selection menu; fix restraint scroll bar ... Thu, 06 Jul 2017 00:13:15 GMT toby [2912] * branch/2frame/GSASIIpath.py (modified) * branch/2frame/GSASIIphsGUI.py (modified) * branch/2frame/GSASIIpwdGUI.py (modified) * branch/2frame/GSASIIrestrGUI.py (modified) more Bind()'s to dataWindow; better error msg on bindist problem Wed, 05 Jul 2017 23:57:25 GMT toby [2911] * branch/2frame/GSASIIconstrGUI.py (modified) * branch/2frame/GSASIIctrlGUI.py (modified) * branch/2frame/GSASIIdataGUI.py (modified) * branch/2frame/GSASIIddataGUI.py (modified) * branch/2frame/GSASIIimgGUI.py (modified) * branch/2frame/GSASIIlog.py (modified) * branch/2frame/GSASIIobj.py (modified) * branch/2frame/GSASIIplot.py (modified) fix menu binds to dataWindow; fix Help menu for non-mac; dataFrame ... Wed, 05 Jul 2017 20:41:45 GMT vondreele [2910] * branch/2frame/GSASIIdataGUI.py (modified) fix G2 includes Wed, 05 Jul 2017 18:30:37 GMT toby [2909] * branch/2frame/GSASIIIO.py (modified) * branch/2frame/GSASIIconstrGUI.py (modified) * branch/2frame/GSASIIctrlGUI.py (modified) * branch/2frame/GSASIIdataGUI.py (modified) * branch/2frame/GSASIIphsGUI.py (modified) * branch/2frame/GSASIIpwdGUI.py (modified) * branch/2frame/GSASIIrestrGUI.py (modified) improve window title; still working on help Wed, 05 Jul 2017 04:33:37 GMT toby [2908] * branch/2frame/GSASIIconstrGUI.py (modified) * branch/2frame/GSASIIdataGUI.py (modified) * branch/2frame/GSASIIddataGUI.py (modified) * branch/2frame/GSASIIphsGUI.py (modified) * branch/2frame/GSASIIplot.py (modified) * branch/2frame/GSASIIpwdGUI.py (modified) * branch/2frame/GSASIIrestrGUI.py (modified) Scroll bars work for Phase & Histogram windows; Constraints, ... Tue, 04 Jul 2017 23:19:31 GMT toby [2907] * branch/2frame/GSASIIIO.py (modified) * branch/2frame/GSASIIctrlGUI.py (modified) * branch/2frame/GSASIIdataGUI.py (modified) * branch/2frame/GSASIIobj.py (modified) * branch/2frame/GSASIIphsGUI.py (modified) * branch/2frame/GSASIIplot.py (modified) tabbed phase panel done. More to go... Tue, 04 Jul 2017 19:14:54 GMT toby [2906] * branch/2frame/GSASII.py (modified) * branch/2frame/GSASIIdataGUI.py (modified) * branch/2frame/GSASIIpwdGUI.py (modified) more refactoring while debugging dataWindow Tue, 04 Jul 2017 17:11:29 GMT toby [2905] * branch/2frame/GSASIIIO.py (modified) * branch/2frame/GSASIIconstrGUI.py (modified) * branch/2frame/GSASIIctrlGUI.py (modified) * branch/2frame/GSASIIdataGUI.py (modified) * branch/2frame/GSASIIimgGUI.py (modified) * branch/2frame/GSASIIlog.py (modified) * branch/2frame/GSASIIobj.py (modified) * branch/2frame/GSASIIpath.py (modified) * branch/2frame/GSASIIphsGUI.py (modified) * branch/2frame/GSASIIplot.py (modified) * branch/2frame/GSASIIpwdGUI.py (modified) use GPXtree in place of PatternTree Tue, 04 Jul 2017 14:37:13 GMT toby [2900] * branch/2frame/GSASII.py (modified) * branch/2frame/GSASIIIO.py (modified) * branch/2frame/GSASIIconstrGUI.py (modified) * branch/2frame/GSASIIctrlGUI.py (moved) * branch/2frame/GSASIIdataGUI.py (moved) * branch/2frame/GSASIIddataGUI.py (modified) * branch/2frame/GSASIIexprGUI.py (modified) * branch/2frame/GSASIIimgGUI.py (modified) * branch/2frame/GSASIIlog.py (modified) * branch/2frame/GSASIIphsGUI.py (modified) * branch/2frame/GSASIIplot.py (modified) * branch/2frame/GSASIIpwdGUI.py (modified) * branch/2frame/GSASIIrestrGUI.py (modified) * branch/2frame/GSASIIstrMain.py (modified) * branch/2frame/exports/G2export_CIF.py (modified) * branch/2frame/exports/G2export_PDB.py (modified) * branch/2frame/exports/G2export_examples.py (modified) * branch/2frame/exports/G2export_map.py (modified) * branch/2frame/testSSymbols.py (modified) reorg for GUI separation pretty much complete (GSASIIIO.py still ... Mon, 03 Jul 2017 21:12:45 GMT toby [2899] * branch/2frame/GSASII.py (modified) * branch/2frame/GSASIIctrls.py (modified) * branch/2frame/GSASIIexprGUI.py (modified) * branch/2frame/GSASIIgrid.py (modified) * branch/2frame/GSASIIphsGUI.py (modified) * branch/2frame/GSASIIstrMain.py (modified) * branch/2frame/exports/G2export_CIF.py (modified) partial reorg Mon, 03 Jul 2017 19:12:22 GMT toby [2898] * branch/2frame/GSASII.py (modified) * branch/2frame/GSASIIgrid.py (modified) fix scroll bars on tree panel, start debugging on data panel Mon, 03 Jul 2017 17:29:33 GMT toby [2897] * branch/2frame/exports/G2export_CIF.py (modified) * trunk/exports/G2export_CIF.py (modified) fix full CIF export bug Mon, 03 Jul 2017 00:29:26 GMT toby [2896] * branch/2frame/binlinux2.7 (deleted) * branch/2frame/binlinux64-2.7 (deleted) * branch/2frame/binmac2.7 (deleted) * branch/2frame/binmac64-2.7 (deleted) * branch/2frame/binwin2.7 (deleted) * branch/2frame/binwin64-2.7 (deleted) get rid of bin<platform> directories Mon, 03 Jul 2017 00:27:09 GMT toby [2895] * branch/2frame/ElementTable.py (copied) * branch/2frame/FormFactors.py (copied) * branch/2frame/GSASII.py (modified) * branch/2frame/GSASIIctrls.py (modified) * branch/2frame/GSASIIgrid.py (modified) * branch/2frame/GSASIImapvars.py (copied) * branch/2frame/GSASIIobj.py (copied) * branch/2frame/GSASIIpath.py (copied) * branch/2frame/GSASIIphsGUI.py (modified) * branch/2frame/GSASIIplot.py (modified) * branch/2frame/GSASIIpy3.py (copied) * branch/2frame/GSASIIscriptable.py (copied) * branch/2frame/GSASIIspc.py (copied) * branch/2frame/GSASIIstrMain.py (copied) * branch/2frame/GSASIIstrMath.py (copied) * branch/2frame/GSASIItestplot.py (copied) * branch/2frame/ImageCalibrants.py (copied) * branch/2frame/ReadMarCCDFrame.py (copied) * branch/2frame/Substances.py (copied) * branch/2frame/atmdata.py (copied) * branch/2frame/basinhopping.py (copied) * branch/2frame/bindist (added) * branch/2frame/makeBat.py (copied) * branch/2frame/makeMacApp.py (copied) * branch/2frame/scanCCD.py (copied) * branch/2frame/testDeriv.py (copied) * branch/2frame/testSSymbols.py (copied) merge trunk changes to 2984 Sun, 02 Jul 2017 14:33:22 GMT vondreele [2893] * branch/2frame/GSASII.py (modified) * branch/2frame/GSASIIconstrGUI.py (modified) * branch/2frame/GSASIIgrid.py (modified) * branch/2frame/GSASIIimgGUI.py (modified) * branch/2frame/GSASIIphsGUI.py (modified) * branch/2frame/GSASIIpwdGUI.py (modified) * branch/2frame/GSASIIrestrGUI.py (modified) fixes to window resize issues Sat, 01 Jul 2017 19:58:01 GMT vondreele [2892] * branch/2frame/GSASIIddataGUI.py (modified) * branch/2frame/GSASIIphsGUI.py (modified) ddataGui fix & np.fmax --> np.amax (wrong max function) in phsGUI Sat, 01 Jul 2017 19:02:11 GMT vondreele [2891] * branch/2frame/GSASIIplot.py (modified) fix atom picking from plot stuff Sat, 01 Jul 2017 16:17:10 GMT vondreele [2890] * branch/2frame/GSASII.py (modified) * branch/2frame/GSASIIconstrGUI.py (modified) * branch/2frame/GSASIIctrls.py (modified) * branch/2frame/GSASIIgrid.py (modified) * branch/2frame/GSASIIpwdGUI.py (modified) * branch/2frame/GSASIIrestrGUI.py (modified) Constraints now displayed fix TopLevel references fix display ... Sat, 01 Jul 2017 11:22:10 GMT vondreele [2888] * branch/2frame (copied) * branch/2frame/GSASII.py (modified) * branch/2frame/GSASIIconstrGUI.py (modified) * branch/2frame/GSASIIctrls.py (modified) * branch/2frame/GSASIIddataGUI.py (modified) * branch/2frame/GSASIIgrid.py (modified) * branch/2frame/GSASIIimgGUI.py (modified) * branch/2frame/GSASIIphsGUI.py (modified) * branch/2frame/GSASIIplot.py (modified) * branch/2frame/GSASIIpwdGUI.py (modified) * branch/2frame/GSASIIrestrGUI.py (modified) * branch/2frame/gltext.py (modified) Thu, 02 Oct 2014 00:12:29 GMT toby [1511] * branch/logging/GSASIIlog.py (modified) * branch/logging/GSASIIpath.py (modified) * branch/logging/config.py.example (added) add config file support Wed, 01 Oct 2014 21:14:25 GMT toby [1510] * branch/logging/GSASII.py (modified) * branch/logging/GSASIIgrid.py (modified) * branch/logging/GSASIIlog.py (moved) logging pretty well ready to roll Mon, 29 Sep 2014 19:31:04 GMT toby [1509] * branch/logging/GSASII.py (modified) * branch/logging/GSASIIgrid.py (modified) * branch/logging/log.py (modified) logging refactored, and much cleaner\! Sun, 21 Sep 2014 01:27:59 GMT toby [1505] * branch/logging/GSASII.py (modified) * branch/logging/log.py (modified) track with relative phase & histogram numbers Tue, 16 Sep 2014 19:28:31 GMT toby [1497] * branch/logging/GSASII.py (modified) * branch/logging/GSASIIconstrGUI.py (modified) * branch/logging/GSASIIgrid.py (modified) * branch/logging/GSASIIphsGUI.py (modified) * branch/logging/log.py (modified) logging more complete Mon, 25 Aug 2014 01:57:46 GMT toby [1477] * branch/logging/GSASII.py (modified) * branch/logging/GSASIIgrid.py (modified) * branch/logging/GSASIIphsGUI.py (modified) * branch/logging/GSASIIpwdGUI.py (modified) * branch/logging/log.py (added) variable change logging finally works Mon, 04 Aug 2014 22:44:06 GMT toby [1458] * branch/logging (copied) create logging branch Mon, 04 Aug 2014 22:43:11 GMT toby [1457] * branch/MPbranch (moved) use branches properly Wed, 27 Jan 2010 16:48:41 GMT vondreel [3] * branch (added) initial setup
