# # ChangeLog for Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit.htm # # Generated by Trac 1.0.13 # May 24, 2022 1:28:00 AM Tue, 02 Jun 2020 14:54:45 GMT toby [4457] * Tutorials/2DCalibration/Calibration of an area detector in GSAS.htm (modified) * Tutorials/2DIntegration/Integration of area detector data in GSAS.htm (modified) * Tutorials/2DStrain/Strain fitting of 2D data in GSAS-II.htm (modified) * Tutorials/2DTexture/Texture analysis of 2D data in GSAS-II.htm (modified) * Tutorials/BkgFit/FitBkgTut.htm (modified) * Tutorials/CFXraySingleCrystal/CFSingleCrystal.htm (modified) * Tutorials/CFjadarite/Charge Flipping in GSAS.htm (modified) * Tutorials/CFsucrose/Charge Flipping - sucrose.htm (modified) * Tutorials/CWCombined/Combined refinement.htm (modified) * Tutorials/CWInstDemo/FindProfParamCW.htm (modified) * Tutorials/CWNeutron/Neutron CW Powder Data.htm (modified) * Tutorials/CalibrationTutorial/CalibrationTutorial.html (modified) * Tutorials/DeterminingWavelength/DeterminingWavelength.html (modified) * Tutorials/FitPeaks/Fit Peaks.htm (modified) * Tutorials/LabData/Laboratory X.htm (modified) * Tutorials/MCsimanneal/MCSA in GSAS.htm (modified) * Tutorials/Magnetic-I/Magnetic Structures-I.htm (modified) * Tutorials/Magnetic-II/Magnetic-II.htm (modified) * Tutorials/Magnetic-III/Magnetic-III.htm (modified) * Tutorials/Magnetic-IV/Magnetic-IV.htm (modified) * Tutorials/Magnetic-V/Magnetic-V.htm (modified) * Tutorials/MerohedralTwins/Merohedral twin refinement in GSAS.htm (modified) * Tutorials/PythonScript/CommandLine.htm (modified) * Tutorials/PythonScript/Scripting.htm (modified) * Tutorials/RMCProfile-I/RMCProfile-I.htm (modified) * Tutorials/RMCProfile-II/RMCProfile-II.htm (modified) * Tutorials/RMCProfile-III/RMCProfile-III.htm (modified) * Tutorials/RMCProfile-IV/RMCProfile-IV.htm (modified) * Tutorials/RietPlot/PublicationPlot.htm (modified) * Tutorials/SAfit/Fitting Small Angle Scattering Data.htm (modified) * Tutorials/SAimages/Small Angle Image Processing.htm (modified) * Tutorials/SAseqref/Sequential Refinement of Small Angle Scattering Data.htm (modified) * Tutorials/SAsize/Small Angle Size Distribution.htm (modified) * Tutorials/SeqParametric/ParametricFitting.htm (modified) * Tutorials/SeqRefine/SequentialTutorial.htm (modified) * Tutorials/SimpleMagnetic/SimpleMagnetic.htm (modified) * Tutorials/Simulation/SimTutorial.htm (modified) * Tutorials/StackingFaults-I/Stacking Faults-I.htm (modified) * Tutorials/StackingFaults-II/Stacking Faults II.htm (modified) * Tutorials/StackingFaults-III/Stacking Faults-III.htm (modified) * Tutorials/StartingGSASII/Starting GSAS.htm (modified) * Tutorials/TOF Calibration/Calibration of a TOF powder diffractometer.htm (modified) * Tutorials/TOF Charge Flipping/Charge Flipping with TOF single crystal data in GSASII.htm (modified) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit.htm (modified) * Tutorials/TOF Single Crystal Refinement/TOF single crystal refinement in GSAS.htm (modified) * Tutorials/TOF-CW Joint Refinement/TOF combined XN Rietveld refinement in GSAS.htm (modified) add data link to tutorials Mon, 06 Aug 2018 13:36:25 GMT vondreele [3556] * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit.htm (modified) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/filelist.xml (modified) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image070.gif (modified) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image071.gif (modified) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image072.gif (modified) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image073.gif (modified) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/props076.xml (modified) small fix (I hope) Sat, 04 Aug 2018 03:51:26 GMT toby [3553] * Tutorials/2DCalibration/Calibration of an area detector in GSAS.htm (modified) * Tutorials/2DIntegration/Integration of area detector data in GSAS.htm (modified) * Tutorials/2DStrain/Strain fitting of 2D data in GSAS-II.htm (modified) * Tutorials/2DTexture/Texture analysis of 2D data in GSAS-II.htm (modified) * Tutorials/CWInstDemo/FindProfParamCW.htm (modified) * Tutorials/DeterminingWavelength/DeterminingWavelength.html (modified) * Tutorials/FitPeaks/Fit Peaks.htm (modified) * Tutorials/MCsimanneal/MCSA in GSAS.htm (modified) * Tutorials/MerohedralTwins/Merohedral twin refinement in GSAS.htm (modified) * Tutorials/SAfit/Fitting Small Angle Scattering Data.htm (modified) * Tutorials/SAimages/Small Angle Image Processing.htm (modified) * Tutorials/SAseqref/Sequential Refinement of Small Angle Scattering Data.htm (modified) * Tutorials/SAsize/Small Angle Size Distribution.htm (modified) * Tutorials/SeqParametric/ParametricFitting.htm (modified) * Tutorials/SeqRefine/SequentialTutorial.htm (modified) * Tutorials/StackingFaults-I/Stacking Faults-I.htm (modified) * Tutorials/TOF Calibration/Calibration of a TOF powder diffractometer.htm (modified) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit.htm (modified) * Tutorials/TOF Single Crystal Refinement/TOF single crystal refinement in GSAS.htm (modified) * trunk/GSASIIctrlGUI.py (modified) * trunk/help/Tutorials.html (modified) finish web tutorials for now Thu, 02 Aug 2018 20:34:21 GMT vondreele [3547] * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit.htm (modified) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/filelist.xml (modified) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image029.gif (modified) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image031.gif (modified) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image033.gif (modified) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image035.gif (modified) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image037.gif (modified) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image039.gif (modified) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image041.gif (modified) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image060.png (modified) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image062.png (modified) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image064.png (modified) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image067.gif (modified) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image069.gif (modified) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/props076.xml (modified) Tue, 17 Jul 2018 22:00:35 GMT vondreele [3476] * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit.htm (modified) set mime type Tue, 17 Jul 2018 21:58:54 GMT vondreele [3475] * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit.htm (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/colorschememapping.xml (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/filelist.xml (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image002.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image003.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image005.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image007.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image009.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image011.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image013.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image015.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image017.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image019.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image021.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image023.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image025.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image027.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image029.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image030.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image031.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image032.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image033.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image034.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image035.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image036.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image037.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image038.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image039.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image040.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image041.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image042.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image043.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image044.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image045.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image046.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image047.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image051.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image053.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image055.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image057.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image060.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image062.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image064.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image066.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image067.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image068.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image069.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image070.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image071.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image072.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image073.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image075.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image077.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image079.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image081.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image083.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image085.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image087.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image089.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image091.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image093.png (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image095.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image096.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image097.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image098.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image099.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image100.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image101.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image102.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image103.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image104.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/image105.gif (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/item0075.xml (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/props076.xml (added) * Tutorials/TOF Sequential Single Peak Fit/TOF Sequential Single Peak Fit_files/themedata.thmx (added) new tutorial for sequential single peak fitting
