# # ChangeLog for Examples # # Generated by Trac 1.0.13 # Jun 17, 2025 7:38:51 PM Fri, 25 Aug 2017 21:47:55 GMT odonnell [3028] * Examples/scripts (added) * Examples/scripts/python (added) * Examples/scripts/python/alpha-mno2-new.json (added) * Examples/scripts/python/carbon_output (added) * Examples/scripts/python/carbon_output/MnO2_6X5-00100.gpx (added) * Examples/scripts/python/carbon_output/MnO2_6X5-00200.gpx (added) * Examples/scripts/python/carbon_output/MnO2_6X5-00300.gpx (added) * Examples/scripts/python/carbon_output/MnO2_6X5-00400.gpx (added) * Examples/scripts/python/carbon_output/MnO2_6X5-00500.gpx (added) * Examples/scripts/python/carbon_output/MnO2_6X5-00600.gpx (added) * Examples/scripts/python/carbon_output/MnO2_6X5-00700.gpx (added) * Examples/scripts/python/carbon_output/MnO2_6X5-00800.gpx (added) * Examples/scripts/python/carbon_output/MnO2_6X5-00900.gpx (added) * Examples/scripts/python/carbon_output/MnO2_6X5-01000.gpx (added) * Examples/scripts/python/carbon_output/MnO2_6X5-01100.gpx (added) * Examples/scripts/python/carbon_output/MnO2_6X5-01200.gpx (added) * Examples/scripts/python/carbon_output/MnO2_6X5-01300.gpx (added) * Examples/scripts/python/carbon_output/MnO2_6X5-01400.gpx (added) * Examples/scripts/python/carbon_output/MnO2_6X5-01500.gpx (added) * Examples/scripts/python/carbon_output/MnO2_6X5-01600.gpx (added) * Examples/scripts/python/carbon_output/MnO2_6X5-01700.gpx (added) * Examples/scripts/python/carbon_output/MnO2_6X5-01800.gpx (added) * Examples/scripts/python/carbon_output/MnO2_6X5-01900.gpx (added) * Examples/scripts/python/carbon_output/MnO2_6X5-02000.gpx (added) * Examples/scripts/python/carbon_output/MnO2_6X5-02100.gpx (added) * Examples/scripts/python/carbon_output/MnO2_6X5-02200.gpx (added) * Examples/scripts/python/mno2_refined_873.cif (added) * Examples/scripts/python/myscript.py (added) * Examples/scripts/python/plot_carbon_data.py (added) * Examples/scripts/python/smaller-with-oxygen.cif (added) * Examples/scripts/shell (added) * Examples/scripts/shell/9016667.cif (added) * Examples/scripts/shell/aMnO2-air_T_6x10-01004.chi (added) * Examples/scripts/shell/alpha-mno2-new.json (added) * Examples/scripts/shell/brians_refined_profile.instprm (added) * Examples/scripts/shell/full_example.sh (added) example scripts Fri, 22 Jun 2012 18:56:31 GMT vondreele [653] * Examples/images/tilt-11ID/tilt.gpx (deleted) * Examples/powder data/GARNET.gpx (deleted) Mon, 21 May 2012 15:17:54 GMT vondreele [625] * Examples/single crystal data (deleted) Tue, 24 Apr 2012 21:21:16 GMT vondreele [572] * Examples/single crystal data/IB3.EXP (added) Tue, 24 Apr 2012 21:20:46 GMT vondreele [571] * Examples/single crystal data/Ib3.hkl (added) Fri, 20 Apr 2012 15:04:23 GMT vondreele [562] * Examples/X-ray PDF/quartz.gpx (modified) Fri, 20 Apr 2012 15:04:03 GMT vondreele [561] * Examples/powder data/GARNET.gpx (modified) Fri, 13 Apr 2012 21:15:42 GMT vondreele [545] * Examples/texture/steel/steel small.gpx (modified) Fri, 13 Apr 2012 21:11:00 GMT toby [544] * trunk/Exercises/two phase (moved) new exercise Fri, 13 Apr 2012 21:10:30 GMT toby [543] * trunk/Exercises/kryptonite (moved) new exercise Fri, 13 Apr 2012 20:59:50 GMT vondreele [542] * Examples/powder data/kryptonite/kryptonite.gpx (modified) Fri, 06 Apr 2012 19:39:15 GMT vondreele [532] * Examples/powder data/two phase/11bmb_8341.fxye (added) * Examples/powder data/two phase/11bmb_8341.prm (added) * Examples/powder data/two phase/11bmb_8342.fxye (added) * Examples/powder data/two phase/11bmb_8342.prm (added) Fri, 06 Apr 2012 19:33:21 GMT vondreele [531] * Examples/X-ray PDF/quartz.gpx (modified) * Examples/powder data/GARNET.gpx (modified) * Examples/powder data/kryptonite/kryptonite.gpx (modified) * Examples/powder data/two phase/7652.gpx (modified) * Examples/powder data/two phase/AB-Si3N4.gpx (modified) * Examples/texture/steel/steel small.gpx (modified) Sat, 03 Mar 2012 23:12:31 GMT vondreele [510] * Examples/powder data/GARNET.gpx (modified) * Examples/powder data/kryptonite/KRYPTONITE.EXP (modified) * Examples/powder data/kryptonite/kryptonite.gpx (modified) * Examples/powder data/two phase/AB-Si3N4.gpx (modified) * Examples/texture/steel/steel small.gpx (modified) Wed, 22 Feb 2012 21:13:29 GMT vondreele [488] * Examples/powder data/kryptonite/kryptonite.gpx (modified) * Examples/texture/steel/steel small.gpx (modified) Fri, 10 Feb 2012 17:07:03 GMT vondreele [479] * Examples/powder data/two phase/AB-Si3N4.gpx (modified) * Examples/texture (added) * Examples/texture/steel (added) * Examples/texture/steel/steel small.gpx (added) added texture example Tue, 31 Jan 2012 22:28:58 GMT vondreele [462] * Examples/powder data/GARNET.gpx (modified) * Examples/powder data/kryptonite/kryptonite.gpx (modified) * Examples/powder data/two phase/AB-Si3N4.gpx (modified) Thu, 19 Jan 2012 22:56:40 GMT vondreele [454] * Examples/powder data/two phase/7652.gpx (modified) * Examples/powder data/two phase/AB-Si3N4.gpx (modified) Tue, 03 Jan 2012 18:14:06 GMT vondreele [448] * Examples/powder data/two phase/AB-Si3N4.gpx (modified) Fri, 16 Dec 2011 21:23:36 GMT vondreele [444] * Examples/powder data/GARNET.gpx (modified) * Examples/powder data/kryptonite/kryptonite.gpx (modified) * Examples/powder data/two phase/7652.gpx (modified) * Examples/powder data/two phase/AB-Si3N4.gpx (modified) Fri, 11 Nov 2011 20:25:00 GMT vondreele [412] * Examples/powder data/GARNET.gpx (modified) Fri, 11 Nov 2011 20:09:42 GMT vondreele [410] * Examples/powder data/GARNET.gpx (added) * Examples/powder data/garnet.raw (added) * Examples/powder data/inst_d1a.prm (added) * Examples/powder data/two phase/AB-Si3N4.gpx (modified) Thu, 27 Oct 2011 15:27:22 GMT vondreele [401] * Examples/powder data/two phase/7652.gpx (modified) * Examples/powder data/two phase/AB-Si3N4.gpx (modified) Mon, 17 Oct 2011 16:30:12 GMT vondreele [394] * Examples/powder data/two phase/AB-Si3N4.gpx (modified) Thu, 13 Oct 2011 19:12:31 GMT vondreele [393] * Examples/powder data/kryptonite/kryptonite.gpx (modified) * Examples/powder data/two phase/7652.gpx (modified) * Examples/powder data/two phase/AB-Si3N4.gpx (modified) Mon, 10 Oct 2011 21:30:49 GMT vondreele [389] * Examples/powder data/kryptonite/kryptonite.gpx (modified) * Examples/powder data/two phase/7652.gpx (modified) * Examples/powder data/two phase/AB-Si3N4.gpx (modified) Sat, 08 Oct 2011 15:24:22 GMT vondreele [387] * Examples/powder data/two phase/AB-Si3N4.gpx (added) * Examples/powder data/two phase/A_SI3N4.XRA (added) * Examples/powder data/two phase/A_SI3N4X.EXP (added) * Examples/powder data/two phase/B_SI3N4.XRA (added) * Examples/powder data/two phase/B_SI3N4X.EXP (added) * Examples/powder data/two phase/INST_XRY.PRM (added) Wed, 05 Oct 2011 18:39:15 GMT vondreele [382] * Examples/powder data/kryptonite (added) * Examples/powder data/kryptonite/11bmb_6231.fxye (added) * Examples/powder data/kryptonite/11bmb_6231.prm (added) * Examples/powder data/kryptonite/KRYPTONITE.EXP (added) * Examples/powder data/kryptonite/jadarite.cif (added) * Examples/powder data/kryptonite/kryptonite.gpx (added) * Examples/powder data/two phase (added) * Examples/powder data/two phase/11bmb_7652.fxye (added) * Examples/powder data/two phase/11bmb_7652.prm (added) * Examples/powder data/two phase/7652.gpx (added) Mon, 03 Oct 2011 20:44:41 GMT vondreele [381] * Examples/images/tilt-11ID/tilt.gpx (modified) Thu, 28 Jul 2011 21:43:47 GMT toby [340] * Examples/powder data/11bmb_3844.prm (added) 11-BM LaB6 parameter file Thu, 28 Jul 2011 21:35:54 GMT toby [339] * Examples/powder data/11bmb_3844.fxye (added) 11-BM LaB6 data Wed, 27 Jul 2011 21:45:27 GMT toby [338] * Examples/images/tilt-11ID/La_hex_+45deg-00015.tif (added) add an image file for demo Thu, 30 Jun 2011 16:35:08 GMT vondreele [325] * Examples/Indexing (added) * Examples/Indexing/cubic (added) * Examples/Indexing/cubic/Be3N2-01zero error.txt (added) * Examples/Indexing/cubic/Be3N2-S18-15.txt (added) * Examples/Indexing/cubic/YIG-s18P38.TXT (added) * Examples/Indexing/cubic/methenamine.txt (added) * Examples/Indexing/hex-rhom (added) * Examples/Indexing/hex-rhom/Bi2Se3-S18p16.txt (added) * Examples/Indexing/hex-rhom/LiI3H2O-S10p40.txt (added) * Examples/Indexing/hex-rhom/NH4SnF3.txt (added) * Examples/Indexing/hex-rhom/SrFe12O19-S18p69.txt (added) * Examples/Indexing/hex-rhom/ZninsulinDC.txt (added) * Examples/Indexing/hex-rhom/b-Si3N4-S18p59.txt (added) * Examples/Indexing/hex-rhom/hex-trig.gpx (added) * Examples/Indexing/hex-rhom/silica-S18p61.txt (added) * Examples/Indexing/monoclinic (added) * Examples/Indexing/monoclinic/(NH4)2S2O3.gpx (added) * Examples/Indexing/monoclinic/(NH4)2S2O3.txt (added) * Examples/Indexing/monoclinic/AmmCenitrate-S18p6-P.txt (added) * Examples/Indexing/monoclinic/AmmNiSO4-S17p9-P.txt (added) * Examples/Indexing/monoclinic/AmmSO4-S17p11-C.txt (added) * Examples/Indexing/monoclinic/Carbanazepine-S18p24-p.txt (added) * Examples/Indexing/monoclinic/CdWO4.txt (added) * Examples/Indexing/monoclinic/CeNbO4-S18p25-I.txt (added) * Examples/Indexing/monoclinic/Cinchonine-S17p26-P.txt (added) * Examples/Indexing/monoclinic/Glycine-S17p34-P.txt (added) * Examples/Indexing/monoclinic/HgAcetate-S17p51-A.txt (added) * Examples/Indexing/monoclinic/Hydromolysite-S17p40-C.txt (added) * Examples/Indexing/monoclinic/MgIO3-S17p48-P.txt (added) * Examples/Indexing/monoclinic/NdTiOxide-S18p50-P.txt (added) * Examples/Indexing/monoclinic/Toraya.txt (added) * Examples/Indexing/monoclinic/ZnAcetate-S18p78-C.txt (added) * Examples/Indexing/monoclinic/gypsum-S17p16-C.txt (added) * Examples/Indexing/monoclinic/leocaine.gpx (added) * Examples/Indexing/monoclinic/leocaine.inp (added) * Examples/Indexing/monoclinic/leocaine.ndx (added) * Examples/Indexing/monoclinic/monoC.gpx (added) * Examples/Indexing/monoclinic/monoP.gpx (added) * Examples/Indexing/monoclinic/sucrose.gpx (added) * Examples/Indexing/orthorhombic (added) * Examples/Indexing/orthorhombic/AlBorate-S17p5-Amam.txt (added) * Examples/Indexing/orthorhombic/AsBr3-S18p9-P212121.txt (added) * Examples/Indexing/orthorhombic/BaMnO4-S18p11-Pbnm.txt (added) * Examples/Indexing/orthorhombic/BaNdTiOxide-S18p12 - Amam.txt (added) * Examples/Indexing/orthorhombic/Bassanite-S18p23-Immm.txt (added) * Examples/Indexing/orthorhombic/CaB2O4-S18p17-Pnca.txt (added) * Examples/Indexing/orthorhombic/Cd3(OH)5(NO3)-P.txt (added) * Examples/Indexing/orthorhombic/Cr03-S17p25-Ama2.txt (added) * Examples/Indexing/orthorhombic/FCmmm.gpx (added) * Examples/Indexing/orthorhombic/Immm.gpx (added) * Examples/Indexing/orthorhombic/K4Fe(CN)6-S18p56-Bmmm.txt (added) * Examples/Indexing/orthorhombic/KNb03-S17p62-Cm2m.txt (added) * Examples/Indexing/orthorhombic/NH4B5O8-4H2O-Bba2.txt (added) * Examples/Indexing/orthorhombic/NaNbO3-S18p64-Pbma.inp (added) * Examples/Indexing/orthorhombic/NaNbO3-S18p64-Pbma.ndx (added) * Examples/Indexing/orthorhombic/NaNbO3-S18p64-Pbma.txt (added) * Examples/Indexing/orthorhombic/NbB-S17p54-Cmcm.bak (added) * Examples/Indexing/orthorhombic/NbB-S17p54-Cmcm.txt (added) * Examples/Indexing/orthorhombic/NdTiOxide-S18p52-Fddd.txt (added) * Examples/Indexing/orthorhombic/Pmmm.gpx (added) * Examples/Indexing/orthorhombic/Th-nitrate-S18p72-Fdd2.txt (added) * Examples/Indexing/orthorhombic/ZnammBr-S11p68-Imam.txt (added) * Examples/Indexing/orthorhombic/ZnammCl-S10p59-Imam.txt (added) * Examples/Indexing/orthorhombic/ZrSi2-S17p86-Cmcm.txt (added) * Examples/Indexing/orthorhombic/bNaVO3-S18p68-P.txt (added) * Examples/Indexing/tetragonal (added) * Examples/Indexing/tetragonal/BaTiOxide-S18p10.txt (added) * Examples/Indexing/tetragonal/Sr2Cr2O7.txt (added) * Examples/Indexing/tetragonal/Sr2Cr2O7b.txt (added) * Examples/Indexing/tetragonal/ZrOCl28H2O+01 zero.txt (added) * Examples/Indexing/tetragonal/ZrOCl28H2O-S18p81.txt (added) * Examples/Indexing/tetragonal/tetrag.gpx (added) * Examples/Indexing/triclinic (added) * Examples/Indexing/triclinic/25-16p92.gpx (added) * Examples/Indexing/triclinic/ANAPAITE.EXP (added) * Examples/Indexing/triclinic/BenzidineHCl-S18p14-p1.txt (added) * Examples/Indexing/triclinic/K2S2O8.gpx (added) * Examples/Indexing/triclinic/K2S2O8.txt (added) * Examples/Indexing/triclinic/NBS25-16p92.txt (added) * Examples/Indexing/triclinic/anapaite.gpx (added) * Examples/Indexing/triclinic/dinnebier.txt (added) * Examples/Indexing/triclinic/schenk-I.txt (added) * Examples/Indexing/triclinic/schenk-II.txt (added) Thu, 09 Jun 2011 21:03:05 GMT vondreele [297] * Examples/X-ray PDF/250umNi.gpx (modified) * Examples/images/Pilatus/CeO2Pilatus.gpx (modified) Tue, 10 May 2011 22:03:16 GMT vondreele [290] * Examples/X-ray PDF/250umNi.gpx (modified) Tue, 03 May 2011 20:18:02 GMT vondreele [279] * Examples/X-ray PDF/glass-kapton.G2img (deleted) Tue, 03 May 2011 20:16:52 GMT vondreele [278] * Examples/X-ray PDF/Ni_250um.tif_Azm=_45.00.gr (deleted) * Examples/X-ray PDF/Ni_250um.tif_Azm=_45.00.sq (deleted) * Examples/X-ray PDF/Ni_250um.tif_Azm=_63.00.gr (deleted) * Examples/X-ray PDF/Ni_250um.tif_Azm=_63.00.sq (deleted) Tue, 03 May 2011 20:16:10 GMT vondreele [277] * Examples/X-ray PDF/Ni_250um.tif (added) Tue, 03 May 2011 20:02:16 GMT vondreele [276] * Examples/X-ray PDF (added) * Examples/X-ray PDF/250umNi.gpx (added) * Examples/X-ray PDF/NaCl-azm.gpx (added) * Examples/X-ray PDF/NaCl311.imctrl (added) * Examples/X-ray PDF/NaCl_311.tif (added) * Examples/X-ray PDF/Ni_250um.tif_Azm=_45.00.gr (added) * Examples/X-ray PDF/Ni_250um.tif_Azm=_45.00.sq (added) * Examples/X-ray PDF/Ni_250um.tif_Azm=_63.00.gr (added) * Examples/X-ray PDF/Ni_250um.tif_Azm=_63.00.sq (added) * Examples/X-ray PDF/SiO2_glass.tif (added) * Examples/X-ray PDF/SiO2_quartz.tif (added) * Examples/X-ray PDF/SiO2_zeolite.tif (added) * Examples/X-ray PDF/glass-kapton.G2img (added) * Examples/X-ray PDF/kapton_311.tif (added) * Examples/X-ray PDF/pdf-test.gpx (added) * Examples/X-ray PDF/quartz.gpx (added) * Examples/images (added) * Examples/images/Pilatus (added) * Examples/images/Pilatus/Agbh_003_000.tif (added) * Examples/images/Pilatus/Calibr.doc (added) * Examples/images/Pilatus/CeO2Pilatus.gpx (added) * Examples/images/Pilatus/CeO2_008.tif (added) * Examples/images/Pilatus/Sagbhtilt_064_001.tif (added) * Examples/images/Pilatus/Sagbhtilt_064_001.tif.zip (added) * Examples/images/Pilatus/agla_039_000.tif (added) * Examples/images/tilt-11ID (added) * Examples/images/tilt-11ID/La_hex_+15deg-00013.tif.metadata (added) * Examples/images/tilt-11ID/La_hex_+30deg-00014.tif.metadata (added) * Examples/images/tilt-11ID/La_hex_+45deg-00015.tif.metadata (added) * Examples/images/tilt-11ID/La_hex_-15deg-00016.tif.metadata (added) * Examples/images/tilt-11ID/La_hex_-30deg-00017.tif.metadata (added) * Examples/images/tilt-11ID/La_hex_-45deg-00018.tif.metadata (added) * Examples/images/tilt-11ID/La_hex_0deg-00012.tif.metadata (added) * Examples/images/tilt-11ID/tilt.gpx (added) * Examples/images/tilt-11ID/tilt.txt (added) * Examples/powder data (added) * Examples/single crystal data (added) fill Examples directory Thu, 06 Jan 2011 17:33:46 GMT toby [224] * Examples (added) examples
