# # ChangeLog for Examples/powder data # # Generated by Trac 1.0.13 # Jun 17, 2025 7:08:47 PM Fri, 10 Feb 2012 17:07:03 GMT vondreele [479] * Examples/powder data/two phase/AB-Si3N4.gpx (modified) * Examples/texture (added) * Examples/texture/steel (added) * Examples/texture/steel/steel small.gpx (added) added texture example Tue, 31 Jan 2012 22:28:58 GMT vondreele [462] * Examples/powder data/GARNET.gpx (modified) * Examples/powder data/kryptonite/kryptonite.gpx (modified) * Examples/powder data/two phase/AB-Si3N4.gpx (modified) Thu, 19 Jan 2012 22:56:40 GMT vondreele [454] * Examples/powder data/two phase/7652.gpx (modified) * Examples/powder data/two phase/AB-Si3N4.gpx (modified) Tue, 03 Jan 2012 18:14:06 GMT vondreele [448] * Examples/powder data/two phase/AB-Si3N4.gpx (modified) Fri, 16 Dec 2011 21:23:36 GMT vondreele [444] * Examples/powder data/GARNET.gpx (modified) * Examples/powder data/kryptonite/kryptonite.gpx (modified) * Examples/powder data/two phase/7652.gpx (modified) * Examples/powder data/two phase/AB-Si3N4.gpx (modified) Fri, 11 Nov 2011 20:25:00 GMT vondreele [412] * Examples/powder data/GARNET.gpx (modified) Fri, 11 Nov 2011 20:09:42 GMT vondreele [410] * Examples/powder data/GARNET.gpx (added) * Examples/powder data/garnet.raw (added) * Examples/powder data/inst_d1a.prm (added) * Examples/powder data/two phase/AB-Si3N4.gpx (modified) Thu, 27 Oct 2011 15:27:22 GMT vondreele [401] * Examples/powder data/two phase/7652.gpx (modified) * Examples/powder data/two phase/AB-Si3N4.gpx (modified) Mon, 17 Oct 2011 16:30:12 GMT vondreele [394] * Examples/powder data/two phase/AB-Si3N4.gpx (modified) Thu, 13 Oct 2011 19:12:31 GMT vondreele [393] * Examples/powder data/kryptonite/kryptonite.gpx (modified) * Examples/powder data/two phase/7652.gpx (modified) * Examples/powder data/two phase/AB-Si3N4.gpx (modified) Mon, 10 Oct 2011 21:30:49 GMT vondreele [389] * Examples/powder data/kryptonite/kryptonite.gpx (modified) * Examples/powder data/two phase/7652.gpx (modified) * Examples/powder data/two phase/AB-Si3N4.gpx (modified) Sat, 08 Oct 2011 15:24:22 GMT vondreele [387] * Examples/powder data/two phase/AB-Si3N4.gpx (added) * Examples/powder data/two phase/A_SI3N4.XRA (added) * Examples/powder data/two phase/A_SI3N4X.EXP (added) * Examples/powder data/two phase/B_SI3N4.XRA (added) * Examples/powder data/two phase/B_SI3N4X.EXP (added) * Examples/powder data/two phase/INST_XRY.PRM (added) Wed, 05 Oct 2011 18:39:15 GMT vondreele [382] * Examples/powder data/kryptonite (added) * Examples/powder data/kryptonite/11bmb_6231.fxye (added) * Examples/powder data/kryptonite/11bmb_6231.prm (added) * Examples/powder data/kryptonite/KRYPTONITE.EXP (added) * Examples/powder data/kryptonite/jadarite.cif (added) * Examples/powder data/kryptonite/kryptonite.gpx (added) * Examples/powder data/two phase (added) * Examples/powder data/two phase/11bmb_7652.fxye (added) * Examples/powder data/two phase/11bmb_7652.prm (added) * Examples/powder data/two phase/7652.gpx (added) Thu, 28 Jul 2011 21:43:47 GMT toby [340] * Examples/powder data/11bmb_3844.prm (added) 11-BM LaB6 parameter file Thu, 28 Jul 2011 21:35:54 GMT toby [339] * Examples/powder data/11bmb_3844.fxye (added) 11-BM LaB6 data Tue, 03 May 2011 20:02:16 GMT vondreele [276] * Examples/X-ray PDF (added) * Examples/X-ray PDF/250umNi.gpx (added) * Examples/X-ray PDF/NaCl-azm.gpx (added) * Examples/X-ray PDF/NaCl311.imctrl (added) * Examples/X-ray PDF/NaCl_311.tif (added) * Examples/X-ray PDF/Ni_250um.tif_Azm=_45.00.gr (added) * Examples/X-ray PDF/Ni_250um.tif_Azm=_45.00.sq (added) * Examples/X-ray PDF/Ni_250um.tif_Azm=_63.00.gr (added) * Examples/X-ray PDF/Ni_250um.tif_Azm=_63.00.sq (added) * Examples/X-ray PDF/SiO2_glass.tif (added) * Examples/X-ray PDF/SiO2_quartz.tif (added) * Examples/X-ray PDF/SiO2_zeolite.tif (added) * Examples/X-ray PDF/glass-kapton.G2img (added) * Examples/X-ray PDF/kapton_311.tif (added) * Examples/X-ray PDF/pdf-test.gpx (added) * Examples/X-ray PDF/quartz.gpx (added) * Examples/images (added) * Examples/images/Pilatus (added) * Examples/images/Pilatus/Agbh_003_000.tif (added) * Examples/images/Pilatus/Calibr.doc (added) * Examples/images/Pilatus/CeO2Pilatus.gpx (added) * Examples/images/Pilatus/CeO2_008.tif (added) * Examples/images/Pilatus/Sagbhtilt_064_001.tif (added) * Examples/images/Pilatus/Sagbhtilt_064_001.tif.zip (added) * Examples/images/Pilatus/agla_039_000.tif (added) * Examples/images/tilt-11ID (added) * Examples/images/tilt-11ID/La_hex_+15deg-00013.tif.metadata (added) * Examples/images/tilt-11ID/La_hex_+30deg-00014.tif.metadata (added) * Examples/images/tilt-11ID/La_hex_+45deg-00015.tif.metadata (added) * Examples/images/tilt-11ID/La_hex_-15deg-00016.tif.metadata (added) * Examples/images/tilt-11ID/La_hex_-30deg-00017.tif.metadata (added) * Examples/images/tilt-11ID/La_hex_-45deg-00018.tif.metadata (added) * Examples/images/tilt-11ID/La_hex_0deg-00012.tif.metadata (added) * Examples/images/tilt-11ID/tilt.gpx (added) * Examples/images/tilt-11ID/tilt.txt (added) * Examples/powder data (added) * Examples/single crystal data (added) fill Examples directory
