# # ChangeLog for Examples/X-ray PDF # # Generated by Trac 1.0.13 # Aug 11, 2022 7:07:04 PM Fri, 20 Apr 2012 15:04:23 GMT vondreele [562] * Examples/X-ray PDF/quartz.gpx (modified) Fri, 06 Apr 2012 19:33:21 GMT vondreele [531] * Examples/X-ray PDF/quartz.gpx (modified) * Examples/powder data/GARNET.gpx (modified) * Examples/powder data/kryptonite/kryptonite.gpx (modified) * Examples/powder data/two phase/7652.gpx (modified) * Examples/powder data/two phase/AB-Si3N4.gpx (modified) * Examples/texture/steel/steel small.gpx (modified) Thu, 09 Jun 2011 21:03:05 GMT vondreele [297] * Examples/X-ray PDF/250umNi.gpx (modified) * Examples/images/Pilatus/CeO2Pilatus.gpx (modified) Tue, 10 May 2011 22:03:16 GMT vondreele [290] * Examples/X-ray PDF/250umNi.gpx (modified) Tue, 03 May 2011 20:18:02 GMT vondreele [279] * Examples/X-ray PDF/glass-kapton.G2img (deleted) Tue, 03 May 2011 20:16:52 GMT vondreele [278] * Examples/X-ray PDF/Ni_250um.tif_Azm=_45.00.gr (deleted) * Examples/X-ray PDF/Ni_250um.tif_Azm=_45.00.sq (deleted) * Examples/X-ray PDF/Ni_250um.tif_Azm=_63.00.gr (deleted) * Examples/X-ray PDF/Ni_250um.tif_Azm=_63.00.sq (deleted) Tue, 03 May 2011 20:16:10 GMT vondreele [277] * Examples/X-ray PDF/Ni_250um.tif (added) Tue, 03 May 2011 20:02:16 GMT vondreele [276] * Examples/X-ray PDF (added) * Examples/X-ray PDF/250umNi.gpx (added) * Examples/X-ray PDF/NaCl-azm.gpx (added) * Examples/X-ray PDF/NaCl311.imctrl (added) * Examples/X-ray PDF/NaCl_311.tif (added) * Examples/X-ray PDF/Ni_250um.tif_Azm=_45.00.gr (added) * Examples/X-ray PDF/Ni_250um.tif_Azm=_45.00.sq (added) * Examples/X-ray PDF/Ni_250um.tif_Azm=_63.00.gr (added) * Examples/X-ray PDF/Ni_250um.tif_Azm=_63.00.sq (added) * Examples/X-ray PDF/SiO2_glass.tif (added) * Examples/X-ray PDF/SiO2_quartz.tif (added) * Examples/X-ray PDF/SiO2_zeolite.tif (added) * Examples/X-ray PDF/glass-kapton.G2img (added) * Examples/X-ray PDF/kapton_311.tif (added) * Examples/X-ray PDF/pdf-test.gpx (added) * Examples/X-ray PDF/quartz.gpx (added) * Examples/images (added) * Examples/images/Pilatus (added) * Examples/images/Pilatus/Agbh_003_000.tif (added) * Examples/images/Pilatus/Calibr.doc (added) * Examples/images/Pilatus/CeO2Pilatus.gpx (added) * Examples/images/Pilatus/CeO2_008.tif (added) * Examples/images/Pilatus/Sagbhtilt_064_001.tif (added) * Examples/images/Pilatus/Sagbhtilt_064_001.tif.zip (added) * Examples/images/Pilatus/agla_039_000.tif (added) * Examples/images/tilt-11ID (added) * Examples/images/tilt-11ID/La_hex_+15deg-00013.tif.metadata (added) * Examples/images/tilt-11ID/La_hex_+30deg-00014.tif.metadata (added) * Examples/images/tilt-11ID/La_hex_+45deg-00015.tif.metadata (added) * Examples/images/tilt-11ID/La_hex_-15deg-00016.tif.metadata (added) * Examples/images/tilt-11ID/La_hex_-30deg-00017.tif.metadata (added) * Examples/images/tilt-11ID/La_hex_-45deg-00018.tif.metadata (added) * Examples/images/tilt-11ID/La_hex_0deg-00012.tif.metadata (added) * Examples/images/tilt-11ID/tilt.gpx (added) * Examples/images/tilt-11ID/tilt.txt (added) * Examples/powder data (added) * Examples/single crystal data (added) fill Examples directory
