source:
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Diff Rev Age Author Log Message
(edit) @4866   4 years vondreele monoclinic indexing returns proper reduced cells
(edit) @4865   4 years vondreele fixes to monoclinic A,C,I centered cell indexing (still need to do P) …
(edit) @4864   4 years vondreele proper fix to bond restraint bug
(edit) @4863   4 years vondreele fix 2 bugs in macromolecular restraints
(edit) @4862   4 years vondreele add A-centered monoclinic to list of indexable lattices. Fix a number …
(edit) @4861   4 years toby fix Bob's RB constraint fix
(edit) @4860   4 years vondreele change titles & labels for shift/esd plot since it plots intiial …
(edit) @4859   4 years vondreele use new symmetry constraint scheme in MakeRBParms
(edit) @4858   4 years vondreele undo "fix" to covariance plot y-axis tick labels
(edit) @4857   4 years vondreele Add new button to Covariance page - Show last shift/esd bar plot Add …
(edit) @4856   4 years toby full CIF fixes
(edit) @4855   4 years vondreele Add new option to AtomModify? in G2phsGUI - 'Uij' - converts Uiso to …
(edit) @4854   4 years vondreele apply scheme used for Uiso symmetry constraints to all other symmetry …
(edit) @4853   4 years vondreele fix to development of Uij constraints for atoms on 3 folds; lines …
(edit) @4852   4 years vondreele clarify text about constraints in ShowLSParms put a wx.Raise in for …
(edit) @4851   4 years toby reformat equivalence pairs as Bob prefers
(edit) @4850   4 years vondreele fix LeBail? test to skip HKLF histograms in G2strMain fix DBW access …
(edit) @4849   4 years toby apply symmetry constraints on rigid body origin; show position vars …
(edit) @4848   4 years vondreele implement the show/hide systematic absences in single crystal …
(edit) @4847   4 years vondreele Add (TBD) hide/showtoggle for single crystal systematic extinctions in …
(edit) @4846   4 years toby save GPX before OnFileSave?
(edit) @4845   4 years toby Tutorial #50 now in web page
(edit) @4844   4 years toby Le Bail tutorial; pretty up tutorial table
(edit) @4843   4 years toby fix Le Bail issues: LB before refinement; bug for combined fits; …
(edit) @4842   4 years toby fix Refine Cell enable after cell copy; misc wx4.1 fixes
(edit) @4841   4 years toby fix bind problem w/Sequential plots; open sequential fit tree item on start
(edit) @4840   4 years toby LeBail? issues: bug on zero cycles fixed; new LeBail? fit menu item; …
(edit) @4839   4 years vondreele change formatting for scale/phase fraction in G2ddataGUI & G2strIO now …
(edit) @4838   4 years vondreele comment out MakeDrawAtom? in G2constrGUI & make the call to …
(edit) @4837   4 years vondreele change line styles in fprme f' & f" plot. add a Raise for the …
(edit) @4836   4 years vondreele Change status bar to show useful message about right click when …
(edit) @4835   4 years toby fix tick animation with weight (w) plot; unable to fix seq plot update …
(edit) @4834   4 years vondreele change 'RBf' to 'RBVf' & 'RBRf' as appropriate.
(edit) @4833   4 years toby popup menu for GSGrids; split off sequential display; rename File menu …
(edit) @4832   4 years vondreele fix gaim map calc to include cylindrical sample absorption fix phase …
(edit) @4831   4 years vondreele Fix SHELX hkl importer to deal with 3 digit hkls
(edit) @4830   4 years vondreele show more places in Absorb output improve image absorption calcs for …
(edit) @4829   4 years toby minor bugs: site sym for wrong RB; GUI stuff; force RB edit before …
(edit) @4828   4 years vondreele another fix to delete vector RB
(edit) @4827   4 years vondreele fix bug deleting vector RB
(edit) @4826   4 years vondreele fix PDF GUI stuff transmission as percent, plot limits for g(r) fix …
(edit) @4825   4 years toby remove unused & deleted hists from seq ref; option to remove hists …
(edit) @4824   4 years vondreele add new refinable RB parameter for atom site fraction - always there; …
(edit) @4823   4 years toby fix naming of new variable constraints; label them & improve …
(edit) @4822   4 years toby Warn if param limits on constrained vars
(edit) @4821   4 years toby new peakfit mode in scripting: allow peak width terms to remain …
(edit) @4820   4 years vondreele remove masks from argument list for MakeGainMap? - not used Tweak gain …
(edit) @4819   4 years toby seq ref: fix & edit phase vars for 1 hist; spyder conveniences; …
(edit) @4818   4 years vondreele Add new routine RBsymCheck to G2lat - it checks RB atom positions for …
(edit) @4817   4 years vondreele fix a contour level bug - crash when there isn't any
(edit) @4816   4 years vondreele fix crash in RepaintRBInfo for Vector RBs
(edit) @4815   4 years vondreele fix problem of shifting RB origin; changed atom fractions!
(edit) @4814   4 years toby Add 'V' option (vector only) for rigid body fitting -- cleanup
(edit) @4813   4 years toby Add 'V' option (vector only) for rigid body fitting
(edit) @4812   4 years vondreele Add Cycle XYZ button on residue RB GUI & add description to help text …
(edit) @4811   4 years toby more wx4.1 & help button fixes; fix OnLeave? if called when a window is …
(edit) @4810   4 years vondreele fix depreciation warning in G2indx.findMV fix numpy round bug in …
(edit) @4809   4 years toby display more Residue rigid body info; better docs
(edit) @4808   4 years vondreele Correct values in Compton table as pointed out by Laszlo Temleitner.
(edit) @4807   4 years vondreele improvement to excluded region operation - now will immediately …
(edit) @4806   4 years vondreele remove bigSizer from UpdatePWHKPlot - use mainSizer = vertical box …
(edit) @4805   4 years toby start replacing dataWindow.GetSizer? with .SetSizer? since Sizer could …
(edit) @4804   4 years toby fix change in MPL posy & posx to nonpositive
(edit) @4803   4 years toby don't reuse dataWindow sizer for background or PWDR; plotting: reset f …
(edit) @4802   4 years vondreele upon integration add Dark, Background & Gain map info to Comments
(edit) @4801   4 years toby Cleanup deleted hists in Phase/data; improve help button location; …
(edit) @4800   4 years toby finish up docs cleanups
(edit) @4799   4 years toby work on docs
(edit) @4798   4 years toby work on docs
(edit) @4797   4 years toby work on docs
(edit) @4796   4 years vondreele patch for missing 'Gain map' data item
(edit) @4795   4 years toby work on docs
(edit) @4794   4 years toby work on docs
(edit) @4793   4 years toby work on docs
(edit) @4792   4 years toby check in changes to allow cctbx to use DoIndexPeaks and !refinePeaks
(edit) @4791   4 years toby docs chapter numbering
(edit) @4790   4 years vondreele fix aspect for hkl plots - reflections now circles independent of …
(edit) @4789   4 years toby switch to new HessianLSQ; Ouch#4 msg in GUI; misc wx4.1 fixes; docs …
(edit) @4788   4 years vondreele a bit more cleanup of toolbar
(edit) @4787   4 years vondreele cleanup of toolbar handling - for mpl 3.3.2 at least. remove …
(edit) @4786   4 years vondreele use set_box_aspect to make 3D plot scales correct. one in four places. …
(edit) @4785   4 years toby new table for text w/sorting
(edit) @4784   4 years toby more help prose
(edit) @4783   4 years toby wx4.1 updates; new CIF data item; scripting: peak fit details …
(edit) @4782   4 years toby scripting fix; wx4.1 RB fixes
(edit) @4781   4 years vondreele 2D map contouring now fixed for matplotlib 3.3.2 - should work for …
(edit) @4780   4 years toby separate hard & SVD singularities, new code in GSASIImath_new.py not …
(edit) @4779   4 years svnjenkins Build with PKG_full_Win32 on win32-2 win32-x86
(edit) @4778   4 years svnjenkins Build with PKG_full_Win32 on win32-2 win32-x86
(edit) @4777   4 years toby removed unneeded .dll's
(edit) @4776   4 years svnjenkins Build with PKG_full_Win64 on win64-2 windows-x64
(edit) @4775   4 years toby more bootstrap fixes
(edit) @4774   4 years svnjenkins Build with PKG_full_Win64 on win64-2 windows-x64
(edit) @4773   4 years toby fixes for windows g2full
(edit) @4772   4 years svnjenkins Build with PKG_full_Win64 on win64-2 windows-x64
(edit) @4771   4 years toby fixes for windows g2complete
(edit) @4770   4 years vondreele reinstitute final call to Hess after convergence - required for proper esds
(edit) @4769   4 years svnjenkins Build with PKG_full_Win64 on win64-2 windows-x64
(edit) @4768   4 years toby windows installation updates
(edit) @4767   4 years vondreele comment out recalculatin if LS matrix after convergence - faster LS …
Note: See TracRevisionLog for help on using the revision log.
