@3307
7 years |
vondreele |
provide print tool for magnetic space group operators that can be fed …
@3306
7 years |
vondreele |
remove a debug print & fix mag site sym problem
@3305
7 years |
toby |
fixes for sum data & images
@3304
7 years |
toby |
more improvements for publication exports; backdate code to run on mpl 1.1
@3303
7 years |
toby |
Py3 fixes for svn self-update
@3302
7 years |
vondreele |
mag sym fixes
@3301
7 years |
vondreele |
copy lowest valent magnetic formfactors to missing zero valent …
@3300
7 years |
vondreele |
magnetic phase changes, check importers, read old gpxfiles, etc.
@3299
7 years |
toby |
Add Q to powder CSV export
@3298
7 years |
toby |
add publication quality Rietveld plots
@3297
7 years |
vondreele |
progress on magnetism - BNS system ok for monoclinic, orthorhombic, …
@3296
7 years |
vondreele |
add selection for mustain, size & 3D pole distribution projections
@3295
7 years |
vondreele |
remove superfluous calls to SpcGroup? after SGData has been defined
add …
@3294
7 years |
toby |
more doc fixes
@3293
7 years |
vondreele |
Fix problems with GenAtom?
@3292
7 years |
toby |
rework Scriptable docs
@3291
7 years |
toby |
Make sure General always displays appropriate menus
@3290
7 years |
toby |
scripting doc updates; magnification Py3 updates
@3289
7 years |
vondreele |
add 5d magnetic form factors
@3288
7 years |
toby |
Add plot magnification; misc plot fixes
@3287
7 years |
vondreele |
fix atom transformation issues in modulation drawings.
@3286
7 years |
vondreele |
add modulation movies to structure drawings; makes gif files for both …
@3285
7 years |
vondreele |
start on symmetry constraints for magnetic modulations
add error …
@3284
7 years |
vondreele |
fix auto PDF if no formula given; assumes 'C 1.0'; put in missing …
@3283
7 years |
vondreele |
fix texture plot problem
@3282
7 years |
vondreele |
proper handling of gray group supersymmetry symbols, fix special …
@3281
7 years |
vondreele |
again phase change gui fix
@3280
7 years |
vondreele |
revisit change phase - still have flicker issues
@3279
7 years |
toby |
make sure new phases get selected in tree; call critical bits (what …
@3278
7 years |
vondreele |
undo move to unit cell before modulation
fix (again) General tab display
@3277
7 years |
vondreele |
fix to General phase display issue
@3276
7 years |
vondreele |
fixes to WaveSizer? for individual wavetypes.
fixes to GetSSfxuinel to …
@3275
7 years |
toby |
oops\!
@3274
7 years |
toby |
comment out plot changes in progress
@3273
7 years |
toby |
fixup tab landing for phases
@3272
7 years |
toby |
improve plot docs
@3271
7 years |
toby |
improve plot docs
@3270
7 years |
toby |
revise plot update code; add plotting docs & cleanup; always use last …
@3269
7 years |
vondreele |
fix editing of wave data to account for new waveType definitions
@3268
7 years |
vondreele |
begin work on incommensurate mag SF calcs.
fix problem with fade calc. …
@3267
7 years |
vondreele |
switch RB & LB on frame/polygon help text to match action
@3266
7 years |
vondreele |
change modulated wave type assignments so one for each kind of wave …
@3265
7 years |
toby |
fix multiple typos reported by user
@3264
7 years |
toby |
deal with lack of BackFile? for older GPX files
@3263
7 years |
toby |
redo reflection labeling conversions; fix crash on update of dummy range
@3262
7 years |
toby |
fix tooltip for reflection labeling
@3261
7 years |
vondreele |
implement import of mcif with Crenel site fraction functions
@3260
7 years |
toby |
misc Py3 fixes
@3259
7 years |
vondreele |
modulated mag moment fix
@3258
7 years |
toby |
Apply Dij values to lattice constants
@3257
7 years |
vondreele |
fixes to incommensurate space group symbol handling
@3256
7 years |
toby |
add code to update phase parms from sequential fit
@3255
7 years |
toby |
@3254
7 years |
vondreele |
fix XsSave? names problem (G2IO)
try to get ProgressBar? box to stay on …
@3253
7 years |
toby |
remove extraneous reload; improve scriptable docs
@3252
7 years |
vondreele |
fix GSAS EXP importer to read 1 & 2 phase magnetic structures
@3251
7 years |
toby |
shorten seq. ref. header; misc cleanups
@3250
7 years |
vondreele |
fix for except in GetTypeName?
@3249
7 years |
vondreele |
fix sequential results display for python 3. see GetTypeName? in …
@3248
7 years |
vondreele |
fix powder peaks input/display/indexing
fix issue with hkl display on …
@3247
7 years |
vondreele |
implement pick of protein validation bar - new view point on structure …
@3246
7 years |
toby |
cif export: use sig for x,x,x positions etc; column order for seq …
@3245
7 years |
vondreele |
fix problem with incommensurate magnetic structures from CIFhklReader …
@3244
7 years |
vondreele |
deal with incomplete residues in residue rigid body assign - they are …
@3243
7 years |
vondreele |
G2ctrlGUI: comment about PyGridTableBase? - python 3?
move VALIDPROTEIN …
@3242
7 years |
vondreele |
implement calc of mean mustrain from generalized mustrain coefficients
@3241
7 years |
vondreele |
Add Nobs to print from Hessian LS
fix bug in setting global TLS …
@3240
7 years |
vondreele |
fix single crystal refine print bug
fade user excluded reflections in …
@3239
7 years |
vondreele |
implement use of 2-site disordered amino acid residues in proteins: …
@3238
7 years |
toby |
doc/tutorial updates
@3237
7 years |
toby |
fix URL
@3236
7 years |
toby |
New simulation tutorial, fix
@3235
7 years |
toby |
@3234
7 years |
vondreele |
new G2spc.SSChoice routine finds all allowed super space group symbols …
@3233
7 years |
toby |
Update ddata after change of phase fraction; Py3 fix for guess format; …
@3232
7 years |
vondreele |
fix magnetic math in G2strMath
@3231
7 years |
vondreele |
fix bug in IndexPeaks? display
fix import pypowder issue in G2math
fix …
@3230
7 years |
toby |
change stacked CSV header
@3229
7 years |
vondreele |
fix map export for python 3
@3228
7 years |
toby |
fix rename of PWDR entries
@3227
7 years |
vondreele |
incommensurate ndexing changes & fixes
@3226
7 years |
toby |
Add error for fixed point fit w/no points
@3225
7 years |
vondreele |
fix modulation phase
@3224
7 years |
vondreele |
fix phase offset in modulations
mark places to fix mag structure …
@3223
7 years |
toby |
fix histogram export file naming
@3222
7 years |
vondreele |
fix missing SGGray in incommensurate structures
@3221
7 years |
vondreele |
fix import of magnetic structures from .EXP files
complete list of pre …
@3220
7 years |
vondreele |
minor fixes to commensurate magnetic cif import & display
@3219
7 years |
vondreele |
fix import mag commensurate structures - all drawn correctly now …
@3218
7 years |
toby |
add new stuff to simulate tutorial
@3217
7 years |
toby |
request file/dir name before saving a PDF
@3216
7 years |
toby |
add data & parameter access in scripting
@3215
7 years |
vondreele |
mag incommensurate stuff
@3214
7 years |
toby |
add 32-bit windows builds w/conda m2w64-toolchain & libpython
@3213
7 years |
toby |
fix EXP import with extra chars on line
@3212
8 years |
vondreele |
fix problem of missing rd.MPhase in phase imports
work on display of …
@3211
8 years |
vondreele |
fix integer divide in wave display
some fixes to mcif import
@3210
8 years |
vondreele |
some fixes for magnetic incommensurate cifs - dealing with 2 different …
@3209
8 years |
toby |
Add simulation to scriptable & add to tutorial; add sphinx index to …
@3208
8 years |
vondreele |
fix transformation bug abc -> abc* needed transform of matrix - …
