source:
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Diff Rev Age Author Log Message
(edit) @4856   7 months toby full CIF fixes
(edit) @4855   7 months vondreele Add new option to AtomModify? in G2phsGUI - 'Uij' - converts Uiso to …
(edit) @4854   7 months vondreele apply scheme used for Uiso symmetry constraints to all other symmetry …
(edit) @4853   7 months vondreele fix to development of Uij constraints for atoms on 3 folds; lines …
(edit) @4852   7 months vondreele clarify text about constraints in ShowLSParms put a wx.Raise in for …
(edit) @4851   7 months toby reformat equivalence pairs as Bob prefers
(edit) @4850   7 months vondreele fix LeBail? test to skip HKLF histograms in G2strMain fix DBW access …
(edit) @4849   7 months toby apply symmetry constraints on rigid body origin; show position vars …
(edit) @4848   8 months vondreele implement the show/hide systematic absences in single crystal …
(edit) @4847   8 months vondreele Add (TBD) hide/showtoggle for single crystal systematic extinctions in …
(edit) @4846   8 months toby save GPX before OnFileSave?
(edit) @4845   8 months toby Tutorial #50 now in web page
(edit) @4844   8 months toby Le Bail tutorial; pretty up tutorial table
(edit) @4843   8 months toby fix Le Bail issues: LB before refinement; bug for combined fits; …
(edit) @4842   8 months toby fix Refine Cell enable after cell copy; misc wx4.1 fixes
(edit) @4841   8 months toby fix bind problem w/Sequential plots; open sequential fit tree item on start
(edit) @4840   8 months toby LeBail? issues: bug on zero cycles fixed; new LeBail? fit menu item; …
(edit) @4839   8 months vondreele change formatting for scale/phase fraction in G2ddataGUI & G2strIO now …
(edit) @4838   8 months vondreele comment out MakeDrawAtom? in G2constrGUI & make the call to …
(edit) @4837   8 months vondreele change line styles in fprme f' & f" plot. add a Raise for the …
(edit) @4836   8 months vondreele Change status bar to show useful message about right click when …
(edit) @4835   8 months toby fix tick animation with weight (w) plot; unable to fix seq plot update …
(edit) @4834   8 months vondreele change 'RBf' to 'RBVf' & 'RBRf' as appropriate.
(edit) @4833   8 months toby popup menu for GSGrids; split off sequential display; rename File menu …
(edit) @4832   8 months vondreele fix gaim map calc to include cylindrical sample absorption fix phase …
(edit) @4831   8 months vondreele Fix SHELX hkl importer to deal with 3 digit hkls
(edit) @4830   8 months vondreele show more places in Absorb output improve image absorption calcs for …
(edit) @4829   8 months toby minor bugs: site sym for wrong RB; GUI stuff; force RB edit before …
(edit) @4828   8 months vondreele another fix to delete vector RB
(edit) @4827   8 months vondreele fix bug deleting vector RB
(edit) @4826   8 months vondreele fix PDF GUI stuff transmission as percent, plot limits for g(r) fix …
(edit) @4825   8 months toby remove unused & deleted hists from seq ref; option to remove hists …
(edit) @4824   8 months vondreele add new refinable RB parameter for atom site fraction - always there; …
(edit) @4823   8 months toby fix naming of new variable constraints; label them & improve …
(edit) @4822   8 months toby Warn if param limits on constrained vars
(edit) @4821   8 months toby new peakfit mode in scripting: allow peak width terms to remain …
(edit) @4820   8 months vondreele remove masks from argument list for MakeGainMap? - not used Tweak gain …
(edit) @4819   8 months toby seq ref: fix & edit phase vars for 1 hist; spyder conveniences; …
(edit) @4818   8 months vondreele Add new routine RBsymCheck to G2lat - it checks RB atom positions for …
(edit) @4817   8 months vondreele fix a contour level bug - crash when there isn't any
(edit) @4816   8 months vondreele fix crash in RepaintRBInfo for Vector RBs
(edit) @4815   8 months vondreele fix problem of shifting RB origin; changed atom fractions!
(edit) @4814   8 months toby Add 'V' option (vector only) for rigid body fitting -- cleanup
(edit) @4813   8 months toby Add 'V' option (vector only) for rigid body fitting
(edit) @4812   8 months vondreele Add Cycle XYZ button on residue RB GUI & add description to help text …
(edit) @4811   8 months toby more wx4.1 & help button fixes; fix OnLeave? if called when a window is …
(edit) @4810   8 months vondreele fix depreciation warning in G2indx.findMV fix numpy round bug in …
(edit) @4809   8 months toby display more Residue rigid body info; better docs
(edit) @4808   8 months vondreele Correct values in Compton table as pointed out by Laszlo Temleitner.
(edit) @4807   8 months vondreele improvement to excluded region operation - now will immediately …
(edit) @4806   9 months vondreele remove bigSizer from UpdatePWHKPlot - use mainSizer = vertical box …
(edit) @4805   9 months toby start replacing dataWindow.GetSizer? with .SetSizer? since Sizer could …
(edit) @4804   9 months toby fix change in MPL posy & posx to nonpositive
(edit) @4803   9 months toby don't reuse dataWindow sizer for background or PWDR; plotting: reset f …
(edit) @4802   9 months vondreele upon integration add Dark, Background & Gain map info to Comments
(edit) @4801   9 months toby Cleanup deleted hists in Phase/data; improve help button location; …
(edit) @4800   9 months toby finish up docs cleanups
(edit) @4799   9 months toby work on docs
(edit) @4798   9 months toby work on docs
(edit) @4797   9 months toby work on docs
(edit) @4796   9 months vondreele patch for missing 'Gain map' data item
(edit) @4795   9 months toby work on docs
(edit) @4794   9 months toby work on docs
(edit) @4793   9 months toby work on docs
(edit) @4792   9 months toby check in changes to allow cctbx to use DoIndexPeaks and !refinePeaks
(edit) @4791   9 months toby docs chapter numbering
(edit) @4790   9 months vondreele fix aspect for hkl plots - reflections now circles independent of …
(edit) @4789   9 months toby switch to new HessianLSQ; Ouch#4 msg in GUI; misc wx4.1 fixes; docs …
(edit) @4788   9 months vondreele a bit more cleanup of toolbar
(edit) @4787   9 months vondreele cleanup of toolbar handling - for mpl 3.3.2 at least. remove …
(edit) @4786   9 months vondreele use set_box_aspect to make 3D plot scales correct. one in four places. …
(edit) @4785   9 months toby new table for text w/sorting
(edit) @4784   9 months toby more help prose
(edit) @4783   9 months toby wx4.1 updates; new CIF data item; scripting: peak fit details …
(edit) @4782   9 months toby scripting fix; wx4.1 RB fixes
(edit) @4781   9 months vondreele 2D map contouring now fixed for matplotlib 3.3.2 - should work for …
(edit) @4780   9 months toby separate hard & SVD singularities, new code in GSASIImath_new.py not …
(edit) @4779   9 months svnjenkins Build with PKG_full_Win32 on win32-2 win32-x86
(edit) @4778   9 months svnjenkins Build with PKG_full_Win32 on win32-2 win32-x86
(edit) @4777   9 months toby removed unneeded .dll's
(edit) @4776   9 months svnjenkins Build with PKG_full_Win64 on win64-2 windows-x64
(edit) @4775   9 months toby more bootstrap fixes
(edit) @4774   9 months svnjenkins Build with PKG_full_Win64 on win64-2 windows-x64
(edit) @4773   9 months toby fixes for windows g2full
(edit) @4772   9 months svnjenkins Build with PKG_full_Win64 on win64-2 windows-x64
(edit) @4771   9 months toby fixes for windows g2complete
(edit) @4770   9 months vondreele reinstitute final call to Hess after convergence - required for proper esds
(edit) @4769   9 months svnjenkins Build with PKG_full_Win64 on win64-2 windows-x64
(edit) @4768   9 months toby windows installation updates
(edit) @4767   9 months vondreele comment out recalculatin if LS matrix after convergence - faster LS …
(edit) @4766   9 months vondreele modify atom labeling routine to allow specified offset as wx.RealPoint?
(edit) @4765   9 months toby MPL 3.3.x fix; scripting docs
(edit) @4764   9 months toby HessianLSQ: force vars to float; small wx 4.1 fixes; scriptable: more …
(edit) @4763   9 months vondreele cleanup tif import for PIL use - remove commented lines move …
(edit) @4762   9 months vondreele fix TIF importer for bad images that use PIL/pillow instead.
(edit) @4761   9 months toby refinements with no variables or no cycles
(edit) @4760   9 months toby fix zero cycle bug
(edit) @4759   9 months toby wx4.1 & mpl3.3 fixes
(edit) @4758   9 months svnjenkins Build with Build_Mac_py3.9 on mac mac-1
(edit) @4757   9 months svnjenkins Build with PKG_full_MacX86 on mac mac-1
Note: See TracRevisionLog for help on using the revision log.
