source:
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Diff Rev Age Author Log Message
(edit) @4802   9 months vondreele upon integration add Dark, Background & Gain map info to Comments
(edit) @4801   9 months toby Cleanup deleted hists in Phase/data; improve help button location; …
(edit) @4800   9 months toby finish up docs cleanups
(edit) @4799   9 months toby work on docs
(edit) @4798   9 months toby work on docs
(edit) @4797   9 months toby work on docs
(edit) @4796   9 months vondreele patch for missing 'Gain map' data item
(edit) @4795   9 months toby work on docs
(edit) @4794   9 months toby work on docs
(edit) @4793   9 months toby work on docs
(edit) @4792   9 months toby check in changes to allow cctbx to use DoIndexPeaks and !refinePeaks
(edit) @4791   9 months toby docs chapter numbering
(edit) @4790   9 months vondreele fix aspect for hkl plots - reflections now circles independent of …
(edit) @4789   9 months toby switch to new HessianLSQ; Ouch#4 msg in GUI; misc wx4.1 fixes; docs …
(edit) @4788   9 months vondreele a bit more cleanup of toolbar
(edit) @4787   9 months vondreele cleanup of toolbar handling - for mpl 3.3.2 at least. remove …
(edit) @4786   9 months vondreele use set_box_aspect to make 3D plot scales correct. one in four places. …
(edit) @4785   9 months toby new table for text w/sorting
(edit) @4784   9 months toby more help prose
(edit) @4783   9 months toby wx4.1 updates; new CIF data item; scripting: peak fit details …
(edit) @4782   9 months toby scripting fix; wx4.1 RB fixes
(edit) @4781   9 months vondreele 2D map contouring now fixed for matplotlib 3.3.2 - should work for …
(edit) @4780   9 months toby separate hard & SVD singularities, new code in GSASIImath_new.py not …
(edit) @4779   9 months svnjenkins Build with PKG_full_Win32 on win32-2 win32-x86
(edit) @4778   9 months svnjenkins Build with PKG_full_Win32 on win32-2 win32-x86
(edit) @4777   9 months toby removed unneeded .dll's
(edit) @4776   9 months svnjenkins Build with PKG_full_Win64 on win64-2 windows-x64
(edit) @4775   9 months toby more bootstrap fixes
(edit) @4774   9 months svnjenkins Build with PKG_full_Win64 on win64-2 windows-x64
(edit) @4773   9 months toby fixes for windows g2full
(edit) @4772   9 months svnjenkins Build with PKG_full_Win64 on win64-2 windows-x64
(edit) @4771   9 months toby fixes for windows g2complete
(edit) @4770   9 months vondreele reinstitute final call to Hess after convergence - required for proper esds
(edit) @4769   9 months svnjenkins Build with PKG_full_Win64 on win64-2 windows-x64
(edit) @4768   9 months toby windows installation updates
(edit) @4767   10 months vondreele comment out recalculatin if LS matrix after convergence - faster LS …
(edit) @4766   10 months vondreele modify atom labeling routine to allow specified offset as wx.RealPoint?
(edit) @4765   10 months toby MPL 3.3.x fix; scripting docs
(edit) @4764   10 months toby HessianLSQ: force vars to float; small wx 4.1 fixes; scriptable: more …
(edit) @4763   10 months vondreele cleanup tif import for PIL use - remove commented lines move …
(edit) @4762   10 months vondreele fix TIF importer for bad images that use PIL/pillow instead.
(edit) @4761   10 months toby refinements with no variables or no cycles
(edit) @4760   10 months toby fix zero cycle bug
(edit) @4759   10 months toby wx4.1 & mpl3.3 fixes
(edit) @4758   10 months svnjenkins Build with Build_Mac_py3.9 on mac mac-1
(edit) @4757   10 months svnjenkins Build with PKG_full_MacX86 on mac mac-1
(edit) @4756   10 months toby more mac work
(edit) @4755   10 months svnjenkins Build with PKG_full_MacX86 on mac mac-1
(edit) @4754   10 months toby new approach for MacOS AppleScripting?
(edit) @4753   10 months toby new approach for MacOS AppleScripting?
(edit) @4752   10 months vondreele add scattering density to status bar when P/N are selected for …
(edit) @4751   10 months svnjenkins Build with PKG_full_Linux64 on linux64 master
(edit) @4750   10 months svnjenkins Build with PKG_full_MacX86 on mac mac-1
(edit) @4749   10 months toby fine-tune Mac installer for 11.0
(edit) @4748   10 months toby still more work on install for OSX
(edit) @4747   10 months toby more work on install for OSX
(edit) @4746   10 months svnjenkins Build with PKG_full_MacX86 on mac mac-1
(edit) @4745   10 months toby more work on install for OSX
(edit) @4744   10 months svnjenkins Build with PKG_full_MacX86 on mac mac-1
(edit) @4743   10 months toby deal with install python not matching target system
(edit) @4742   10 months toby deal with install python not matching target system
(edit) @4741   10 months toby deal with install python not matching target system
(edit) @4740   10 months toby more install work
(edit) @4739   10 months toby more install work
(edit) @4738   10 months toby more install work
(edit) @4737   10 months toby more install work
(edit) @4736   10 months toby more install work
(edit) @4735   10 months vondreele reduce printed precision of bon valence sum from 3 to 2. connect +/- …
(edit) @4734   10 months svnjenkins Build with PKG_full_MacX86 on mac mac-1
(edit) @4733   10 months toby add placeholder
(edit) @4732   10 months toby workarounds for missing files
(edit) @4731   10 months toby add file to binary directories so that conda-build keeps them
(edit) @4730   10 months svnjenkins Build with PKG_full_MacX86 on mac mac-1
(edit) @4729   10 months toby more work on OSX build/pkg
(edit) @4728   10 months svnjenkins Build with PKG_full_MacX86 on mac mac-1
(edit) @4727   10 months toby show needed OSX libraries
(edit) @4726   10 months toby bypass buggy conda python.app
(edit) @4725   10 months toby add ScriptEditor? save to makeMacApp
(edit) @4724   10 months toby add Big Sur patch for OpenGL.GL bug
(edit) @4723   10 months vondreele add automatic valence bond sum calculator to dist/angle calculator in …
(edit) @4722   10 months svnjenkins Build with PKG_full_Linux64 on linux64 master
(edit) @4721   10 months toby add binary cleanup step
(edit) @4720   10 months vondreele trimmed some plot k-box commands; they blocked the 2nd status line box
(edit) @4719   10 months vondreele add number/cell to site fraction apportion routine
(edit) @4718   10 months svnjenkins Build with PKG_full_Linux64 on linux64 master
(edit) @4717   10 months toby remove mpl 3.3 warning
(edit) @4716   10 months svnjenkins Build with PKG_full_Linux64 on linux64 master
(edit) @4715   10 months toby install: add postinstall for g2full & cleanup
(edit) @4714   10 months svnjenkins Build with PKG_full_Linux64 on linux64 master
(edit) @4713   10 months toby more installer work; xmgrace enhance from Carlo
(edit) @4712   10 months vondreele fix plotting of image limit ellipses - wrong call (GetDetectorXY) …
(edit) @4711   10 months toby remove fellipse, not used for a long time
(edit) @4710   10 months toby set package versions from conda versions
(edit) @4709   10 months vondreele new (BT mostly) version of HessianLSQ & additions; fix nan problem in …
(edit) @4708   10 months toby g2full tests
(edit) @4707   10 months toby more work on g2complete
(edit) @4706   10 months toby more work on g2complete
(edit) @4705   10 months toby now work on g2complete
(edit) @4704   10 months toby now work on g2complete
(edit) @4703   10 months toby gsas2pkg cannot be noarch
Note: See TracRevisionLog for help on using the revision log.
