In
this and subsequent tutorials, we will show how to use GSAS-II in conjunction
with RMCProfile (“RMCProfile:
Reverse Monte Carlo for polycrystalline materials”, M.G. Tucker, D.A. Keen, M.T.
Dove, A.L. Goodwin and Q. Hui, (2007) Jour. Phys.: Cond. Matter, 19, 335218. doi:
https://doi.org/10.1088/0953-8984/19/33/335218)
to fit both powder diffraction data and a pair distribution function (PDF)
created from it with a “large box” disordered model.
Before
getting started you must obtain the most recent Version 6 of the RMCProfile executable (at this writing this is RMCProfile V6.7.6 Beta Serial). Obtain this from www.rmcprofile.org by following the
prompts from Downloads. This version is available for Windows, Mac OSX and
Linux. The download will be a zip file; save it somewhere convenient. Pull from
it only the RMCProfile_package/exe/rmcprofile.exe and place it in the GSASII
main directory or in a new subdirectory (e.g. GSASII/RMCProfile); no other files are needed
although you may wish to also retrieve the contents of the tutorial
subdirectory. It contains rmcprofilemanual.pdf and rmcprofile_tutorial.pdf which may be of interest
since the GSAS-II/RMCProfile tutorials are based on
the latter.
The
process for using RMCProfile begins with a normal
Rietveld refinement of the average structure. For the kind of disordered
materials of interest here, this may give bond lengths that are frequently too
short for the atoms involved and sometimes extreme apparent thermal motion for
some of the atoms. These effects arise because the average structure places
these atoms too close to one another; a more localized view would show
coordinated atom displacements or reorientation of groups of atoms to avoid the
close contacts. RMCProfile is then used to
characterize these local displacements by fitting to the diffraction data and
its Fourier transform as a PDF.
The
material used in this tutorial is the same as described in the RMCProfile tutorial Exercises 1-3, sulfur hexafluoride (SF6).
The average structure of SF6 is a molecular crystal at low
temperatures with the SF6 octahedra arranged in a body centered cubic
lattice with the S-F bonds aligned with the crystal axes. The structural
frustration induced by close F-F contacts forces the octahedra to locally
rotate in different directions and this disorder gives rise to considerable
diffuse scattering. The data used here was obtained at 190K on the GEM
diffractometer at ISIS, Rutherford-Appleton Laboratory, Harwell
Campus, UK.
If you have not done so already, start GSAS-II.
1. Use
the Import/Powder Data/from GSAS powder data file menu item
to read the data file into the current GSAS-II project. This read option is set
to read any of the powder data formats defined for GSAS (angles in centidegrees, TOF in µsec). Other submenu items will read
the cif
format or the xye
format (angles in degrees) used by topas, etc. In those cases, you would change the file type
to cif
format or the xye
format (angles in degrees) used by topas, etc. to see
them. Because you used the Help/Download tutorial menu entry to open this page and
downloaded the exercise files (recommended), then the RMCProfile-I/data/...
entry will bring you to the location where the files have been downloaded. (It
is also possible to download them manually from https://subversion.xray.aps.anl.gov/pyGSAS/Tutorials/RMCProfile-I/data/.
In this case you will need to navigate to the download location manually.)
For this tutorial you should see the data file in the file
browser, but if extensions on data files are not the expected ones, you may
need to change the file type to All files (*.*) to
find the desired file.
2. Select the sf6_190gsas.dat data file in the first dialog and press Open. There will be a Dialog box asking Is this the file you want? Press Yes button to proceed. The data file contain 3 banks of data
Select
only the third one (BANK 3) and press OK. Next will be a file selection dialog for the instrument
parameter file; only one is shown. Select it; the pattern will be read in and
displayed
There
is high background and considerable diffuse scattering at low TOF (high Q)
arising from the molecular SF6 disorder.
Because
the Rietveld refinement will not make use of the diffuse scattering we want to
set the lower limit to just below the first visible Bragg peak; go the Limits entry in the GSAS-II data
tree.
Change
the 1st entry to 7000; the plot will change by moving the green dashed line. The
upper limit is fine.
The average structure of SF6 is very simple. Space group Im3m (or Im-3m; same thing), a=5.887 with S at 0,0,0 and F at 0.251,0,0. However, we will save time by importing it from an old gsas experiment file. Use the Import/Phase/from GSAS .EXP file menu item to read the phase information for SF6 into the current GSAS-II project. Other submenu items will read phase information in other formats. Because you used the Help/Download tutorial menu entry to open this page and downloaded the exercise files (recommended), then the RMCProfile-I/data/... entry will bring you to the location where the files have been downloaded. (It is also possible to download them manually from https://subversion.xray.aps.anl.gov/pyGSAS/Tutorials/RMCProfile-I/data/. In this case you will need to navigate to the download location manually.) Select the SF6_190K.EXP file (only one there) There will be a Dialog box asking Is this the file you want? Press Yes button to proceed. You will get the opportunity to change the phase name next (I left it alone; NB: because of restrictions in RMCProfile it is important that the phase name not have any spaces); press OK to continue. Next is the histogram selection window; this connects the phase to the data so it can be used in subsequent calculations.
Select the histogram (or press Set All) and press OK. The General tab for the phase is shown next
Because
there is considerable diffuse scattering, the default background will be
insufficient for reasonable fitting. Select the Background item from the GSAS-II data
tree
Be
sure that “chebyschev-1” is used for the background function; RMCProfile only recognizes that form to compute the
background for the diffraction pattern. Select 15 for the number of terms.
We are
now ready for the first Rietveld refinement; select Calculate/Refine from the main GSAS-II menu.
Before it starts a file selection dialog will appear; select a file name (no
extension). I chose “SF6_190K”; do not use the phase name for this purpose because RMCProfile will use that as the root for the many files it
creates. Also, you should create a new directory for this exercise while in this
dialog box; it will be rapidly filled up with RMCProfile
files which can lead to considerable confusion if mixed in with other files. For
Windows after navigating to a suitable location, a new directory can be made by
a right mouse click and selecting “New/Folder” from the popup menu. It will appear with the name “New
Folder”; change the name and select it (it will be empty). Other operating
systems will have similar methods. Finally press OK to save the GSAS-II project
(SF6_190K.gpx) and start the refinement. It will quickly converge to give a
quite low Rwp (~2.2%) mostly because of the very high
background
It
is evident that the lattice parameter needs adjusting. Go to the General tab for the SF6 phase and
select Refine
unit cell; repeat
Calculate/Refine. The Rwp
will improve (~0.76%) giving
To
finish up add the following parameters:
SF6/Atoms: XU for both atoms (GSAS-II recognizes that the S atom is fixed
in position); the F atom should have anisotropic thermal displacements.
SF6/Data: refine microstrain and set size to 10.
PWDR/Instrument Parameters: refine beta-0, beta-1, sig-0, sig-1 and sig-2 (normally not necessary, but
the available GEM instrument parameter file isn’t current). In any event, the
coefficients difB, beta-q and sig-q must be zero since RMCProfile V6.7.6
Beta Serial does not know how to use them in computing a powder profile.
Do Calculate/Refine from the main menu; the fit
will quickly improve a bit more to Rwp ~ 0.56%.
Select
the Phases/SF6/Draw
Atoms tab;
the list will be shown and the two unique atoms drawn on the plot.
To
improve this do the following:
1)
Double click the Style column heading and select ellipsoids; the figure will be redrawn
showing the 50% ellipsoid surfaces.
2)
Double click the empty upper left box in the Draw Atoms table; both atoms will turn
green and the two table rows will be grey.
3)
Under the menu Edit Figure select Fill unit cell; the figure will be redrawn
showing all atoms in the cell (too many bonds, though).
4)
Double click the Type column heading and select the S atom type
5) Under
the menu Edit
Figure
select Fill
CN-sphere;
the figure will be redrawn with six F atoms about all S atoms (still too many
bonds).
6)
Finally select Draw Options tab and change Bond search factor to 0.7; the figure will be redrawn
to show
which is what one expects for orientational disorder for the SF6 molecules.
Next we will explore this with a RMCProfile
simulation. To keep this drawing, you may want to save the GSAS-II project.
RMCProfile is most effective if a large box is used for the modelling;
this requires very long running times (10-20 hrs for
SF6) before a meaningful result is obtained. However, for the
purposes of this tutorial, we will be using a small box model that converges in
a more reasonable time (~10min). The result will clearly fit the data but the
model is too small to give enough molecular orientations to be meaningful,
however this exercise will show you how to set up RMCProfile
from within GSAS-II.
To
start select the Phases/SF6/RMC tab; if rmcprofile.exe is
within the GSASII directory the data window will show
At
the top is a radio button selection for RMCProfile and fullrmc. The latter is an alternative
big box modeling program (not working – under development); RMCProfile
is selected by default and all below are its setup controls. There are four
major sections (metadata, major controls, restraints & constraints and data
controls); we will work through each of these in turn. The information you
enter here is retained in the GSAS-II project so you can easily try alternative
setups without having to enter everything over again.
The
entries here are for your convenience; there is no explicit use made of any of
these, but they will appear in some of the output files from RMCProfile and of course will show here on subsequent views
of this window. Fill out as many of them as you see fit. I entered some things
for each as the defaults are somewhat nonsensical.
The
running time is defaulted to 10 minutes with a Save interval of 1 minute. At each save time a
number of files are written by RMCProfile; these can
be viewed by using the Operations/View command (more about this later – don’t
bother trying it now, there is nothing to see). For the purposes of this
tutorial leave them at their defaults.
The
big box model used by RMCProfile is described as
multiples of the unit cell axes. In this case we want a 3x3x3 box so enter 3 for each of X-axis, Y-axis and Z-axis.
Next
is to set the order of the atom types in the structure; this is used to
construct atom-atom distance restraints on the modelling. The order here (S followed by F) is appropriate; if changed
the window will repaint updating various entries possibly resetting some
entries to defaults. I suggest you decide the order now and then don’t change
it later. Set the maximum shift for S to be 0.05 (the value for F is OK). When
done the window should look like
Skip
the next item (Atom swap probabilities). This is for cases in which atoms can
exchange sites.
Next
is to set the “Hard” minimum atom-atom separation and the allowed search rage
for each pair. Enter 4, 1.37 and 2 for the S-S, S-F and F-F Hard min. This rejects any proposed atom move that results in a
contact less than that value.
The
search range further restricts the allowed moves; this can maintain bonding
within the structure. Enter 1.37 & 1.74 for the S-F Search from and to values, and 2.0 & 2.42 for the F-F values. The window should
look like
Scroll
down to the bottom of the window for the last section.
We
will be using three different types of SF6 data for the fitting by RMCProfile. The first is the selection of the powder
pattern (“Bragg”) for processing. This is taken from the PWDR entries in the
GSAS-II project and accessed from the pulldown; there is only one “PWDR
sf6_190gsas.dat Bank 3”
that was used earlier in your Rietveld refinement of SF6. If you had
used multiple banks in the Rietveld refinement, all would be shown in the
pulldown, but only one can be selected. Set the weight to 0.1 (NB: smaller numbers means a
heavier weight).
Next
press the Select button for the “Neutron real
space data; G(R)”
line; a FileDialog should appear. Because you
used the
The FileDialog should show
Select
sf6_190k_gr.dat; it will be copied from this
location to your working directory for this tutorial (RMCProfile
requires all its files to be local). The window will be redrawn showing the new
entry; the weight is fine.
Next
press the Select button for “Neutron reciprocal space data: F(Q)”;
the FileDialog will show
Select
sf6_190k_fq.dat; again it will be copied to
your working directory. The window will be redrawn
Change
the weight to 0.01. Your local directory should have just 3 files
You
are now ready to setup the RMCProfile input files.. Do Operations/Setup RMC from the menu; the console
should report that files were written
and your local directory should
now have 8 files
These
text files contain data needed by RMCProfile for the
fitting of SF6. They are:
SF6.back- the 15 coefficients for the
chebyschev-1 function needed to comput the background
for the Bragg pattern
SF6.bragg – the powder pattern used in
SF6.dat – the RMCProfile
controls file; described in full in the RMCProfile
User Manual. It can be edited if need be, but remember it is rewritten each
time Operations/Setup RMC is done.
SF6.inst – the instrument parameter
coefficients for the neutron TOF peak shape function used by GSAS-II and
implemented in RMCProfile for computing the Bragg
pattern.
SF6.rmc6f – the big box set of atom
positions. It is normally not rewritten when Operations/Setup RMC is done
unless the X-axis, Y-axis, or Z-axis lattice multipliers are changed. Most
important is that it will contain the set of big box atom positions as updated by
RMCProfile according to the Save interval (every 1
min in this case).
You
are now ready to run RMCProfile.
To
run RMCProfile from inside GSAS-II, do Operations/Execute. You will first see a “nag”
note asking you to cite the publication describing RMCProfile;
press OK.
The
program will start in a new console window – processing will initially be
pretty fast for this case and then slow down as the modelling proceeds. It
reports Time used and Last saved. Once the latter is
nonzero you can view intermediate results to see its progress. Note that you
can exit GSAS-II and RMCProfile will continue
running. After RMCProfile finishes note that the
project directory now has ~30 files many of which are just temporary ones
created by RMCProfile. We will be looking at just the
*.csv files and the SF6.rmcf6 file; the latter contains the last atom
configuration acceptable by RMCProfile thus
representing a best disordered model.
Do Operations/View; a FileDialog
showing only *.csv files will appear
They
all should have the same prefix in their name, “SF6” which is the phase name
from the GSAS-II project file. Select any one of them – it doesn’t matter. All
of them will be read and their contents displayed as individual plots. For
example the chi^2 plot shows the progress of the RMCProfile
fit
The
inset is the upper 3/4ths of the plot magnified; you can see that RMCProfile is still improving the fit slowly even after 10
minutes of running.
The
G(R) partials plot shows the identity of each feature; the first 2 sharp peaks
arise from S-F (1.58Å) and F-F (2.20Å) distances within the SF6
octahedron (cf. 1.457Å and 2.06Å, respectively, for the average structure) while
the broader one at 2.8-3.1 are from F-F intermolecular contacts.
Comparing the Bragg plot with the PWDR plot shows that the
RMCProfile fit is very similar to the Rietveld fit
This
plot was made by dragging one plot tab to the bottom of the screen to create
the second frame.
Next,
we can view the resulting big box structure. Do Import/Phase/from RMCProfile .rmc6f file; a FileDialog box with one entry
will show the required file, SF6.rmc6f. You will first see a Is this the
file you want
popup window; select Yes. Next will be an Edit phase name popup. The proposed name is
the same as the existing one; GSAS-II will rename this one by adding ‘_1’ to
the end. Next will be a popup for Add histograms; respond Cancel because you don’t want this
phase to be in any subsequent Rietveld refinement. Looking at the General tab
for this phase we see it is 3X in all three axes relative to the original and
has no symmetry (space group P 1).
Select
the Draw
Atoms tab
for this phase; a van der Waals ball model will be drawn. You can select the S atoms & fill the CN-sphere for them (does take time –
be patient) and then change all the atoms to ball and stick style. The
CN-sphere filling works because the RMCProfile
structure still has translational symmetry across its 3x3x3 lattice. You should
see something like
Notice
the rotational disorder as well as some positional shifting of the SF6
molecules. The stray F atoms are bound to SF6 molecules in
neighboring boxes.
We
can compress the big box result back into the original average crystal structure
to see how the disordered sites compare with the average ones. Select the General tab for the big box phase
(SF6_1) and then do Compute/Transform. A popup dialog will appear
This
is the general tool inside GSAS-II for all sorts of structure transformations.
Here we will use it to push all the big box atoms back into the average
structure unit cell. Recalling that the big box model is 3x3x3 the original
unit cell, we simply want to reverse the process. Enter 1/3 into the diagonal elements
of the M matrix. The GUI will convert them to the decimal equivalent (0.333…).
The target space group should be P 1. You should see
Press
Ok to do the transformation. A
new phase, “SF6_1 abc” will be formed as triclinic
with cell axes that match the original cubic ones. Select Draw Atoms; a van der Waals model will
appear.
Select
the Draw
Options tab
and reduce the van der Waals scale to about 0.05.
This
compares pretty well with the original structure with the ellipsoids drawn at
90% probability.
This
completes this RMCProfile tutorial; you should save
the project.
A
production run with enough atoms to give decent statistics would be for a box
that is 10x10x10 the original unit cell and would require a 10-20 hour run
time. It would contain ~14000 atoms instead of 377 as used here.
