# # ChangeLog for softGlue_examples/make.bat # # Generated by Trac 1.0.13 # Jun 17, 2025 11:39:41 AM Wed, 13 Jun 2012 17:11:59 GMT jemian [923] * softGlue_examples/Makefile (modified) * softGlue_examples/build/html/_sources/adding_examples.txt (modified) * softGlue_examples/build/html/_sources/index.txt (modified) * softGlue_examples/build/html/_sources/programmable_pulse_train/index.txt (modified) * softGlue_examples/build/html/_static/basic.css (modified) * softGlue_examples/build/html/adding_examples.html (modified) * softGlue_examples/build/html/coaching.html (modified) * softGlue_examples/build/html/genindex.html (modified) * softGlue_examples/build/html/index.html (modified) * softGlue_examples/build/html/programmable_pulse_train/index.html (modified) * softGlue_examples/build/html/search.html (modified) * softGlue_examples/build/html/searchindex.js (modified) * softGlue_examples/make.bat (modified) * softGlue_examples/source/adding_examples.rst (modified) * softGlue_examples/source/index.rst (modified) tweaked the instructions for publishing from the SVN server Tue, 05 Jun 2012 19:59:56 GMT jemian [871] * softGlue_examples (moved) this is the actual intent, may relocate this repo to ... Tue, 05 Jun 2012 07:20:49 GMT jemian [863] * pulse_train_doc/Makefile (modified) * pulse_train_doc/build (modified) * pulse_train_doc/build/html/_static/basic.css (modified) * pulse_train_doc/build/html/_static/default.css (modified) * pulse_train_doc/build/html/_static/doctools.js (modified) * pulse_train_doc/build/html/_static/jquery.js (modified) * pulse_train_doc/build/html/_static/pygments.css (modified) * pulse_train_doc/build/html/_static/searchtools.js (modified) * pulse_train_doc/build/html/_static/sidebar.js (modified) * pulse_train_doc/build/html/_static/underscore.js (modified) * pulse_train_doc/build/html/_static/websupport.js (modified) * pulse_train_doc/build/html/searchindex.js (modified) * pulse_train_doc/make.bat (modified) * pulse_train_doc/source/coaching1.rst (modified) * pulse_train_doc/source/conf.py (modified) * pulse_train_doc/source/index.rst (modified) properties
