source: trunk
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Diff Rev Age Author Log Message
(edit) @790   12 years toby # on 2004/05/04 17:18:41, toby did: fix ipola buttons ("None" was …
(edit) @789   12 years toby # on 2004/04/27 15:52:46, toby did: more new stuff
(edit) @788   12 years toby # on 2004/04/27 15:46:48, toby did: new number only to track other changes
(edit) @787   12 years toby # on 2004/04/27 15:43:17, toby did: new features: obs-calc/sig, plot …
(edit) @786   12 years toby # on 2004/04/27 14:50:34, toby did: updates & OSX
(edit) @785   12 years toby # on 2004/04/27 14:49:32, toby did: document ability to scan zoom …
(edit) @784   12 years toby # on 2004/04/27 14:49:09, toby did: document ability to scan zoom …
(edit) @783   12 years toby # on 2004/04/27 14:12:04, toby did: update non-modal dialogs to match …
(edit) @782   12 years toby # on 2004/04/27 14:11:04, toby did: add ITYP entry in init
(edit) @781   12 years toby # on 2004/04/27 14:09:07, toby did: remove unused proc flag origin 2 …
(edit) @780   12 years toby # on 2004/04/27 14:07:39, toby did: plot (obs-calc)/sigma Add ability …
(edit) @779   12 years toby # on 2004/04/27 14:07:03, toby did: add O-1
(edit) @778   12 years toby # on 2004/04/26 21:18:57, toby did: Fix bug with OSX BLT (all new …
(edit) @777   12 years toby # on 2004/04/03 22:21:52, toby did: fix sort undefined bug report …
(edit) @776   12 years toby # on 2004/04/03 22:21:01, toby did: fix clock format command
(edit) @775   12 years toby # on 2004/01/30 00:50:00, toby did: Add code to set app/icon in OS X
(edit) @774   12 years toby # on 2004/01/30 00:48:57, toby did: Add code to set app/icon in OS X, …
(edit) @773   12 years toby # on 2004/01/30 00:47:28, toby did: revise to match new version
(edit) @772   12 years toby # on 2004/01/30 00:41:47, toby did: update putontop to match new …
(edit) @771   12 years toby # on 2004/01/30 00:41:19, toby did: update to match new version of …
(edit) @770   12 years toby # on 2004/01/30 00:41:11, toby did: update to match new version of …
(edit) @769   12 years toby # on 2004/01/30 00:39:56, toby did: update to match new version of …
(edit) @768   12 years toby # on 2004/01/12 21:52:23, toby did: a routine to create an index for …
(edit) @767   12 years toby # on 2004/01/12 19:42:37, toby did: work in progress
(edit) @766   12 years toby # on 2004/01/12 19:41:52, toby did: add OSX ref
(edit) @765   12 years toby # on 2004/01/12 19:41:09, toby did: updates
(edit) @764   12 years toby # on 2004/01/12 19:40:18, toby did: toggle tick marks
(edit) @763   12 years toby # on 2003/12/16 18:02:53, toby did: add droplet capability to AppleScript
(edit) @762   12 years toby # on 2003/12/08 22:25:22, toby did: ready for prime time?
(edit) @761   12 years toby # on 2003/12/05 18:56:47, toby did: more AppleScript fixups (find …
(edit) @760   12 years toby # on 2003/12/05 13:00:13, toby did: add file menu command to create …
(edit) @759   12 years toby # on 2003/12/05 12:56:23, toby did: only display peak options for …
(edit) @758   12 years toby # on 2003/12/05 12:54:08, toby did: force bkgedit to always use …
(edit) @757   12 years toby # on 2003/11/22 00:50:56, toby did: advance EXPGUI version number to …
(edit) @756   12 years toby # on 2003/11/21 00:46:52, toby did: add export to grace & .csv options
(edit) @755   12 years toby # on 2003/11/21 00:46:06, toby did: fix "save options" bug
(edit) @754   12 years toby # on 2003/11/21 00:45:38, toby did: fix "replace phase" bug
(edit) @753   12 years toby # on 2003/11/13 17:35:32, toby did: spelling error
(edit) @752   12 years toby # on 2003/11/13 17:34:33, toby did: reassure folks with -me & -xp that …
(edit) @751   12 years toby # on 2003/11/13 17:31:03, toby did: revise to remove info about …
(edit) @750   12 years toby # on 2003/11/13 17:29:20, toby did: add powpref nagging after "SaveAs?" …
(edit) @749   12 years toby # on 2003/11/13 17:21:17, toby did: remove obsolete references to …
(edit) @748   12 years toby # on 2003/11/13 17:21:00, toby did: Resize window for OSX
(edit) @747   12 years toby # on 2003/11/13 17:20:00, toby did: remove obsolete references to …
(edit) @746   12 years toby # on 2003/11/13 17:16:28, toby did: Updates for OSX: window resize & …
(edit) @745   12 years toby # on 2003/11/13 16:05:02, toby did: catch puts output for OSX Resize …
(edit) @744   12 years toby # on 2003/11/13 16:04:10, toby did: Resize window for OSX
(edit) @743   12 years toby # on 2003/11/05 22:18:43, toby did: prepare for OSX -- catch puts
(edit) @742   12 years toby # on 2003/11/05 22:16:55, toby did: add mozilla to browser list fix …
(edit) @741   12 years toby # on 2003/11/05 22:14:46, toby did: prepare for OSX - remove puts
(edit) @740   12 years toby # on 2003/11/05 22:13:58, toby did: prepare for OSX
(edit) @739   12 years toby # on 2003/11/05 22:13:15, toby did: prepare for OSX -- catch puts
(edit) @738   12 years toby # on 2003/11/05 21:06:59, toby did: add missing cleanup routine …
(edit) @737   12 years toby # on 2003/08/11 20:05:03, toby did: document add multiple hists reformat
(edit) @736   12 years toby # on 2003/08/11 20:04:42, toby did: updates
(edit) @735   12 years toby # on 2003/08/11 19:37:34, toby did: exit LANL
(edit) @734   12 years toby # on 2003/08/11 19:36:54, toby did: exit LANL misc updates
(edit) @733   12 years toby # on 2003/08/11 19:36:42, toby did: exit LANL
(edit) @732   12 years toby # on 2003/08/11 19:36:17, toby did: exit LANL
(edit) @731   12 years toby # on 2003/08/11 19:28:54, toby did: code cleanup -col -> -column
(edit) @730   12 years toby # on 2003/08/11 19:28:27, toby did: code cleanup -col -> -column
(edit) @729   12 years toby # on 2003/08/11 19:27:59, toby did: code cleanup -col -> -column
(edit) @728   12 years toby # on 2003/08/11 19:23:56, toby did: significant revision for CIFTOOLS …
(edit) @727   12 years toby # on 2003/08/11 19:23:12, toby did: code cleanup -col -> -column
(edit) @726   12 years toby # on 2003/08/11 19:22:56, toby did: code cleanup -col -> -column
(edit) @725   12 years toby # on 2003/08/11 19:22:46, toby did: code cleanup -col -> -column
(edit) @724   12 years toby # on 2003/08/11 19:22:04, toby did: code cleanup -col -> -column
(edit) @723   12 years toby # on 2003/08/11 19:21:36, toby did: code cleanup -col -> -column
(edit) @722   12 years toby # on 2003/08/11 19:21:23, toby did: code cleanup -col -> -column
(edit) @721   12 years toby # on 2003/08/11 19:19:37, toby did: add support for adding multiple …
(edit) @720   12 years toby # on 2003/08/11 18:14:54, toby did: remove Bkg functions #3 & #9 since …
(edit) @719   12 years toby # on 2003/08/11 18:13:56, toby did: remove BKG function #3 since it is …
(edit) @718   12 years toby # on 2003/07/18 18:33:29, toby did: web link
(edit) @717   12 years toby # on 2003/07/18 18:33:10, toby did: web link
(edit) @716   12 years toby # on 2003/07/18 18:32:33, toby did: web link
(edit) @715   12 years toby # on 2003/07/18 18:32:08, toby did: clean ups
(edit) @714   12 years toby # on 2003/07/18 18:31:14, toby did: move www link
(edit) @713   12 years toby # on 2003/05/27 16:09:07, toby did: autoselect 1st phase if none are …
(edit) @712   12 years toby # on 2003/05/24 20:55:52, toby did: fix absorption correction bug
(edit) @711   12 years toby # on 2003/05/22 22:08:14, toby did: new release
(edit) @710   12 years toby # on 2003/05/22 22:07:46, toby did: change to GSAS.CONFIG for Windows
(edit) @709   12 years toby # on 2003/05/22 22:05:22, toby did: change to GSAS.CONFIG for Windows
(edit) @708   12 years toby # on 2003/05/22 22:05:22, toby did: change to GSAS.CONFIG for Windows
(edit) @707   12 years toby # on 2003/05/22 22:05:22, toby did: new link
(edit) @706   12 years toby # on 2003/05/22 22:05:22, toby did: change to GSAS.CONFIG for Windows
(edit) @705   12 years toby # on 2003/05/22 22:05:22, toby did: Document INSTEDIT
(edit) @704   12 years toby # on 2003/05/22 22:05:22, toby did: Document INSTEDIT
(edit) @703   12 years toby # on 2003/05/22 21:46:50, toby did: Implement windows init file as …
(edit) @702   12 years toby # on 2003/05/22 21:45:46, toby did: cleanup ABSCOR usage (blank = type …
(edit) @701   12 years toby # on 2003/05/22 21:43:32, toby did: Workaround for win-XP bug where …
(edit) @700   12 years toby # on 2003/05/22 21:43:04, toby did: Implement windows init file as …
(edit) @699   12 years toby # on 2003/05/22 21:42:14, toby did: remove error message display used …
(edit) @698   12 years toby # on 2003/05/22 21:41:53, toby did: Implement windows init file as …
(edit) @697   12 years toby # on 2003/05/22 21:41:18, toby did: initial tweaking
(edit) @696   12 years toby # on 2003/05/22 21:40:38, toby did: Implement windows init file as …
(edit) @695   12 years toby # on 2003/05/22 21:40:10, toby did: Implement windows init file as …
(edit) @694   12 years toby # on 2003/05/22 21:39:30, toby did: Add instrument parameter file editor
(edit) @693   12 years toby # on 2003/05/22 21:39:17, toby did: Implement windows init file as …
(edit) @692   12 years toby # on 2003/05/22 21:35:52, toby did: export diffraction data to FOX
(edit) @691   12 years toby # on 2003/05/22 21:34:13, toby did: Instrument parameter file editor
Note: See TracRevisionLog for help on using the revision log.
