source: trunk
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Diff Rev Age Author Log Message
(edit) @713   12 years toby # on 2003/05/27 16:09:07, toby did: autoselect 1st phase if none are …
(edit) @712   12 years toby # on 2003/05/24 20:55:52, toby did: fix absorption correction bug
(edit) @711   12 years toby # on 2003/05/22 22:08:14, toby did: new release
(edit) @710   12 years toby # on 2003/05/22 22:07:46, toby did: change to GSAS.CONFIG for Windows
(edit) @709   12 years toby # on 2003/05/22 22:05:22, toby did: change to GSAS.CONFIG for Windows
(edit) @708   12 years toby # on 2003/05/22 22:05:22, toby did: change to GSAS.CONFIG for Windows
(edit) @707   12 years toby # on 2003/05/22 22:05:22, toby did: new link
(edit) @706   12 years toby # on 2003/05/22 22:05:22, toby did: change to GSAS.CONFIG for Windows
(edit) @705   12 years toby # on 2003/05/22 22:05:22, toby did: Document INSTEDIT
(edit) @704   12 years toby # on 2003/05/22 22:05:22, toby did: Document INSTEDIT
(edit) @703   12 years toby # on 2003/05/22 21:46:50, toby did: Implement windows init file as …
(edit) @702   12 years toby # on 2003/05/22 21:45:46, toby did: cleanup ABSCOR usage (blank = type …
(edit) @701   12 years toby # on 2003/05/22 21:43:32, toby did: Workaround for win-XP bug where …
(edit) @700   12 years toby # on 2003/05/22 21:43:04, toby did: Implement windows init file as …
(edit) @699   12 years toby # on 2003/05/22 21:42:14, toby did: remove error message display used …
(edit) @698   12 years toby # on 2003/05/22 21:41:53, toby did: Implement windows init file as …
(edit) @697   12 years toby # on 2003/05/22 21:41:18, toby did: initial tweaking
(edit) @696   12 years toby # on 2003/05/22 21:40:38, toby did: Implement windows init file as …
(edit) @695   12 years toby # on 2003/05/22 21:40:10, toby did: Implement windows init file as …
(edit) @694   12 years toby # on 2003/05/22 21:39:30, toby did: Add instrument parameter file editor
(edit) @693   12 years toby # on 2003/05/22 21:39:17, toby did: Implement windows init file as …
(edit) @692   12 years toby # on 2003/05/22 21:35:52, toby did: export diffraction data to FOX
(edit) @691   12 years toby # on 2003/05/22 21:34:13, toby did: Instrument parameter file editor
(edit) @690   12 years toby # on 2003/05/13 16:21:28, toby did: instrument parm editing
(edit) @689   12 years toby # on 2003/05/13 16:21:28, toby did: Routine to dump profiles from a …
(edit) @688   12 years toby # on 2003/05/13 16:15:55, toby did: save more stuff, use gsas.config …
(edit) @687   12 years toby # on 2003/04/16 15:24:58, toby did: typo
(edit) @686   12 years toby # on 2003/04/16 15:24:28, toby did: warn about updates; lanl->anl
(edit) @685   12 years toby # on 2003/04/16 15:24:10, toby did: fix link
(edit) @684   12 years toby # on 2003/04/16 15:23:34, toby did: minor update
(edit) @683   12 years toby # on 2003/04/16 15:23:10, toby did: extra the
(edit) @682   12 years toby # on 2003/04/16 15:22:37, toby did: minor text changes
(edit) @681   12 years toby # on 2003/04/10 22:26:27, toby did: fix localconfig reference
(edit) @680   12 years toby # on 2003/04/10 22:25:53, toby did: rpm stuff, remove pre-2001 warning
(edit) @679   12 years toby # on 2003/04/10 22:25:03, toby did: autostart GRWND
(edit) @678   12 years toby # on 2003/04/10 22:22:49, toby did: add edit cell doc better formatting
(edit) @677   12 years toby # on 2003/04/10 22:22:32, toby did: more requests
(edit) @676   12 years toby # on 2003/04/10 22:20:43, toby did: new error msg for edit cell
(edit) @675   12 years toby # on 2003/04/10 22:19:24, toby did: use filename rather than arg (why?)
(edit) @674   12 years toby # on 2003/04/10 22:14:21, toby did: more sig figs on small numbers …
(edit) @673   12 years toby # on 2003/04/10 22:13:02, toby did: implement GRWND startup (Win-9x) …
(edit) @672   12 years toby # on 2003/04/10 22:12:41, toby did: fix missing tag
(edit) @671   12 years toby # on 2003/04/10 22:12:18, toby did: change header
(edit) @670   12 years toby # on 2003/04/10 22:03:45, toby did: change header autostart GRWND …
(edit) @669   12 years toby # on 2003/04/10 22:01:33, toby did: change header keep weights (for …
(edit) @668   12 years toby # on 2003/04/10 21:59:03, toby did: leave filenames up for rawplot set …
(edit) @667   12 years toby # on 2003/04/10 21:58:31, toby did: change startup section
(edit) @666   12 years toby # on 2003/04/10 21:55:15, toby did: Major revisions to fix TOF bugs …
(edit) @665   12 years toby # on 2002/12/30 17:14:03, toby did: update pleasewait to include …
(edit) @664   12 years toby # on 2002/12/30 17:00:34, toby did: updated pleasewait implement …
(edit) @663   12 years toby # on 2002/12/30 16:58:18, toby did: new comment; change name of …
(edit) @662   12 years toby # on 2002/12/27 18:25:35, toby did: fix MM read bug
(edit) @661   12 years toby # on 2002/10/31 17:32:06, toby did: trap gsas_config errors & write to …
(edit) @660   12 years toby # on 2002/10/31 17:29:18, toby did: do better job reporting …
(edit) @659   12 years toby # on 2002/10/31 17:28:17, toby did: trap gsas_config errors & write to …
(edit) @658   12 years toby # on 2002/10/31 17:26:56, toby did: trap gsas_config errors prevent …
(edit) @657   12 years toby # on 2002/10/24 19:26:49, toby did: fix broken help link
(edit) @656   12 years toby # on 2002/10/24 19:26:20, toby did: .csv plotting
(edit) @655   12 years toby # on 2002/10/24 19:24:01, toby did: Add export capability to comma …
(edit) @654   12 years toby # on 2002/09/24 20:49:58, toby did: quote reserved "words" (DATA_ …
(edit) @653   12 years toby # on 2002/09/06 19:42:17, toby did: update with recent request & …
(edit) @652   12 years toby # on 2002/09/05 21:18:57, toby did: more updates
(edit) @651   12 years toby # on 2002/09/05 21:18:37, toby did: new msg
(edit) @650   12 years toby # on 2002/09/05 21:03:37, toby did: Major revision. Implement undo …
(edit) @649   12 years toby # on 2002/09/05 20:59:20, toby did: Revise to use updated browsecif: …
(edit) @648   12 years toby # on 2002/09/05 18:29:19, toby did: make sure a phase & histogram is …
(edit) @647   12 years toby # on 2002/09/05 18:28:06, toby did: comments
(edit) @646   12 years toby # on 2002/09/05 18:24:04, toby did: add categories to loops improve …
(edit) @645   12 years toby # on 2002/09/05 18:22:20, toby did: trap error in localconfig and …
(edit) @644   12 years toby # on 2002/09/05 18:21:33, toby did: minor update: eliminate reference …
(edit) @643   12 years toby # on 2002/09/05 18:17:58, toby did: Major rework to use text-based …
(edit) @642   12 years toby # on 2002/09/05 18:16:49, toby did: remove octave stuff
(edit) @641   12 years toby # on 2002/09/05 18:16:00, toby did: why did I do this? Deal with …
(edit) @640   12 years toby # on 2002/08/09 16:44:11, toby did: Used to select distances & angles …
(edit) @639   12 years toby # on 2002/08/09 16:43:35, toby did: Routine to fill ? fields in CIF …
(edit) @638   12 years toby # on 2002/08/09 16:43:07, toby did: CIF support library
(edit) @637   12 years toby # on 2002/08/09 16:40:59, toby did: fix table size sync. add …
(edit) @636   12 years toby # on 2002/08/09 16:39:59, toby did: correct labels on pref. orient. …
(edit) @635   12 years toby # on 2002/07/31 00:33:41, toby did: document CIFselect
(edit) @634   12 years toby # on 2002/07/18 20:52:41, toby did: fix excluded region read error (in …
(edit) @633   12 years toby # on 2002/07/18 20:51:26, toby did: remove iconify from excledt -- …
(edit) @632   12 years toby # on 2002/07/18 20:51:04, toby did: GSAS2CIF & FillCIF changes
(edit) @631   12 years toby # on 2002/07/18 20:50:45, toby did: GSAS2CIF & fillCIF changes
(edit) @630   12 years toby # on 2002/07/18 20:50:04, toby did: fix binding with yet newer …
(edit) @629   12 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @628   12 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @627   12 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @626   12 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @625   12 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @624   12 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @623   12 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @622   12 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @621   12 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @620   12 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @619   12 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @618   12 years toby # on 2002/07/18 20:44:05, toby did: NIST alumina tutorial
(edit) @617   12 years toby # on 2002/07/18 20:44:05, toby did: NIST alumina tutorial
(edit) @616   12 years toby # on 2002/07/18 20:39:14, toby did: Export routine for FOX
(edit) @615   12 years toby # on 2002/07/18 20:27:39, toby did: new tutorial
(edit) @614   12 years toby # on 2002/07/18 20:21:51, toby did: spell out more
Note: See TracRevisionLog for help on using the revision log.
