source: trunk
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Diff Rev Age Author Log Message
(edit) @551   12 years toby # on 2002/01/23 20:00:50, toby did: clean up font references
(edit) @550   12 years toby # on 2002/01/23 20:00:50, toby did: clean up font references
(edit) @549   12 years toby # on 2002/01/23 19:59:56, toby did: reference the self-installer …
(edit) @548   12 years toby # on 2002/01/23 19:59:22, toby did: reference the RPM file cleanup font use
(edit) @547   12 years toby # on 2002/01/23 19:59:05, toby did: thanks John!
(edit) @546   12 years toby # on 2002/01/23 19:58:35, toby did: note reflection labeling request
(edit) @545   12 years toby # on 2002/01/22 23:12:36, toby did: don't dump mm phases
(edit) @544   12 years toby # on 2002/01/22 23:02:55, toby did: writing of real values: if a field …
(edit) @543   12 years toby # on 2002/01/22 22:55:35, toby did: Major changes to add MM …
(edit) @542   12 years toby # on 2002/01/22 22:53:34, toby did: support absplt in widplt routine …
(edit) @541   12 years toby # on 2002/01/22 22:50:33, toby did: add absplt, remove export routines …
(edit) @540   12 years toby # on 2002/01/22 22:45:19, toby did: Major revision Add ABSPLT …
(edit) @539   12 years toby # on 2002/01/22 22:29:18, toby did: Significant change in display of …
(edit) @538   12 years toby # on 2002/01/22 22:28:53, toby did: more complete space group checking
(edit) @537   12 years toby # on 2002/01/22 22:16:51, toby did: Major revision: export to GRACE …
(edit) @536   12 years toby # on 2002/01/22 22:10:48, toby did: support changes MM phases (where …
(edit) @535   12 years toby # on 2002/01/22 21:52:22, toby did: Major revisions add plot of R's & …
(edit) @534   12 years toby # on 2002/01/22 21:51:33, toby did: Add small checkbutton font for …
(edit) @533   12 years toby # on 2002/01/22 21:45:59, toby did: import coordinates from MSI .xtl …
(edit) @532   12 years toby # on 2002/01/22 21:45:59, toby did: import coordinates from PLATON …
(edit) @531   12 years toby # on 2002/01/22 21:45:59, toby did: Export plots to GRACE (aka xmgr & …
(edit) @530   12 years toby # on 2002/01/22 21:45:59, toby did: Export coordinates in MSI .xtl …
(edit) @529   12 years toby # on 2002/01/22 21:45:59, toby did: export coordinates in PLATON …
(edit) @528   12 years toby # on 2002/01/22 21:45:59, toby did: export coordinates in SHELX .INS format
(edit) @527   12 years toby # on 2002/01/22 21:45:59, toby did: example coordinate export routine
(edit) @526   12 years toby # on 2002/01/22 21:12:22, toby did: reference coordinate import …
(edit) @525   12 years toby # on 2002/01/22 21:11:44, toby did: lots of additions
(edit) @524   12 years toby # on 2002/01/22 21:08:12, toby did: add coordinate export section …
(edit) @523   12 years toby # on 2002/01/22 21:06:17, toby did: ABSPLT improve utility section …
(edit) @522   12 years toby # on 2002/01/22 21:05:34, toby did: add newer (mostly MM) programs
(edit) @521   12 years toby # on 2002/01/22 21:05:10, toby did: MM constraints
(edit) @520   12 years toby # on 2002/01/22 21:02:55, toby did: l-s in BKGEDT & support for …
(edit) @519   12 years toby # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style
(edit) @518   12 years toby # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style
(edit) @517   12 years toby # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style
(edit) @516   12 years toby # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style
(edit) @515   12 years toby # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style
(edit) @514   12 years toby # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style
(edit) @513   12 years toby # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style
(edit) @512   12 years toby # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style
(edit) @511   12 years toby # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style
(edit) @510   12 years toby # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style
(edit) @509   12 years toby # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style
(edit) @508   12 years toby # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style
(edit) @507   12 years toby # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style
(edit) @506   12 years toby # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style
(edit) @505   12 years toby # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style
(edit) @504   12 years toby # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style
(edit) @503   12 years toby # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style
(edit) @502   12 years toby # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style
(edit) @501   12 years toby # on 2001/12/16 20:13:10, toby did: make top of window a bit smaller
(edit) @500   12 years toby # on 2001/12/16 20:13:10, toby did: make top of window a bit smaller
(edit) @499   12 years toby # on 2001/12/16 19:40:06, toby did: don't check for excledt file -- …
(edit) @498   12 years toby # on 2001/12/16 19:38:52, toby did: bug fix: ignore update if .EXP …
(edit) @497   12 years toby # on 2001/12/16 18:17:32, toby did: change GSAS version reference Add …
(edit) @496   12 years toby # on 2001/12/16 18:16:37, toby did: note showing .EXP status
(edit) @495   12 years toby # on 2001/12/16 18:15:31, toby did: liveplot: explain the "FORTRAN" error
(edit) @494   12 years toby # on 2001/12/16 18:09:18, toby did: Major revisions: add braces for …
(edit) @493   12 years toby # on 2001/12/16 18:08:28, toby did: Add "D" as a valid element type
(edit) @492   12 years toby # on 2001/12/16 18:06:53, toby did: make -outline BLT version …
(edit) @491   12 years toby # on 2001/12/16 17:31:47, toby did: fix fileinfobox error in open .EXP …
(edit) @490   12 years toby # on 2001/11/19 19:50:58, toby did: include Rfactors on file lookup
(edit) @489   12 years toby # on 2001/11/19 19:50:05, toby did: improve error message deal with …
(edit) @488   12 years toby # on 2001/11/19 19:49:33, toby did: new smallfont default
(edit) @487   12 years toby # on 2001/11/08 16:00:44, toby did: fix update flag after Uiso/Uaniso?
(edit) @486   12 years toby # on 2001/11/07 19:02:53, toby did: new release (1.51)
(edit) @485   12 years toby # on 2001/11/07 18:22:57, toby did: remove echo in archive add get …
(edit) @484   12 years toby # on 2001/11/07 18:17:37, toby did: get rid of echo command
(edit) @483   12 years toby # on 2001/11/07 18:12:46, toby did: change filename to avoid liveplot …
(edit) @482   12 years toby # on 2001/10/31 20:13:17, toby did: new shortcuts: next histogram and …
(edit) @481   12 years toby # on 2001/10/31 20:12:15, toby did: major revision for in-line routine
(edit) @480   12 years toby # on 2001/10/31 20:08:54, toby did: support excledt
(edit) @479   12 years toby # on 2001/10/31 20:07:41, toby did: change excledt to run "in-line"
(edit) @478   12 years toby # on 2001/10/31 20:06:10, toby did: fix .Oxx bug when no files are …
(edit) @477   12 years toby # on 2001/10/31 20:04:21, toby did: add next histogram feature
(edit) @476   12 years toby # on 2001/10/31 20:02:37, toby did: manual zoom option
(edit) @475   12 years toby # on 2001/10/31 19:28:03, toby did: Very major rewrite make excledt …
(edit) @474   12 years toby # on 2001/10/31 19:25:44, toby did: initialization routine for EXCLEDT
(edit) @473   12 years toby # on 2001/10/31 19:24:11, toby did: unsuccessful Win95 fixes
(edit) @472   12 years toby # on 2001/10/19 19:27:58, toby did: Change use of $newhist(setnum) for …
(edit) @471   12 years toby # on 2001/10/19 19:27:09, toby did: remove string replace for 8.0 …
(edit) @470   12 years toby # on 2001/10/18 23:30:15, toby did: fix web page display problem in …
(edit) @469   12 years toby # on 2001/10/18 23:27:59, toby did: describe new archiving
(edit) @468   12 years toby # on 2001/10/18 23:27:12, toby did: remove unix support for compressed …
(edit) @467   12 years toby # on 2001/10/18 23:23:58, toby did: add new peak labeling options
(edit) @466   12 years toby # on 2001/10/18 23:22:57, toby did: update archiving
(edit) @465   12 years toby # on 2001/10/18 23:17:12, toby did: updates
(edit) @464   12 years toby # on 2001/10/18 23:17:12, toby did: new key bindings for reflection labels
(edit) @463   12 years toby # on 2001/10/18 23:17:12, toby did: update archiving
(edit) @462   12 years toby # on 2001/10/18 23:17:12, toby did: update archiving
(edit) @461   12 years toby # on 2001/10/18 23:17:12, toby did: update archiving
(edit) @460   12 years toby # on 2001/10/14 05:37:32, toby did: use dumpexp.tcl to import …
(edit) @459   12 years toby # on 2001/10/14 05:37:32, toby did: dump coordinates from a .EXP file
(edit) @458   12 years toby # on 2001/10/14 05:36:29, toby did: blank out dummy histogram ranges …
(edit) @457   12 years toby # on 2001/10/14 05:34:23, toby did: bug fix: fix so that new histogram …
(edit) @456   12 years toby # on 2001/10/14 05:33:15, toby did: plug mailing list
(edit) @455   12 years toby # on 2001/10/14 05:32:26, toby did: .EXP coord import
(edit) @454   12 years toby # on 2001/10/14 05:32:26, toby did: .EXP coord import
(edit) @453   12 years toby # on 2001/09/25 23:35:54, toby did: Add "D" to all dummy histogram …
(edit) @452   12 years toby # on 2001/09/25 23:35:04, toby did: resize all plot axes
Note: See TracRevisionLog for help on using the revision log.
