source: trunk
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Diff Rev Age Author Log Message
(edit) @366   12 years toby # on 2000/12/22 21:14:32, toby did: Tcl/Tk? test section revised
(edit) @365   12 years toby # on 2000/12/22 21:14:32, toby did: document new option: autoraise in …
(edit) @364   12 years toby # on 2000/12/22 21:14:32, toby did: document error highlighting new …
(edit) @363   12 years toby # on 2000/12/22 19:44:07, toby did: fix expload error for DOS format …
(edit) @362   12 years toby # on 2000/12/22 19:44:07, toby did: Implement autoraise detect …
(edit) @361   12 years toby # on 2000/12/22 19:44:07, toby did: make POWPLOT a background program
(edit) @360   12 years toby # on 2000/12/22 19:44:07, toby did: Major reworking of routines to run …
(edit) @359   12 years toby # on 2000/12/22 19:44:07, toby did: add autoiconify option require …
(edit) @358   12 years toby # on 2000/12/22 19:37:02, toby did: fix call to RAWPLOT in data load. …
(edit) @357   12 years toby # on 2000/12/22 19:17:42, toby did: testing Tcl/Tk? FAQ added
(edit) @356   12 years toby # on 2000/11/27 21:10:45, toby did: define XYZU+-F
(edit) @355   12 years toby # on 2000/11/27 21:05:56, toby did: define type of XYZU+-F set phase …
(edit) @354   12 years toby # on 2000/11/27 21:05:56, toby did: line up >10 banks in Hist add set …
(edit) @353   12 years toby # on 2000/11/26 17:53:28, toby did: fix grab for choose block window
(edit) @352   12 years toby # on 2000/11/21 21:26:37, toby did: add "open" (same as "expnam")
(edit) @351   12 years toby # on 2000/11/21 21:25:31, toby did: fix font use for customization
(edit) @350   12 years toby # on 2000/11/21 21:25:31, toby did: fix that geometry is spelled …
(edit) @349   12 years toby # on 2000/11/21 21:23:45, toby did: change appearance of negative …
(edit) @348   12 years toby # on 2000/11/21 21:21:57, toby did: more ideas
(edit) @347   12 years toby # on 2000/11/21 21:21:57, toby did: doc how to change fonts
(edit) @346   12 years toby # on 2000/11/21 21:21:57, toby did: use beige for neg contraints
(edit) @345   12 years toby # on 2000/10/23 14:41:11, toby did: more ideas from Lachlan
(edit) @344   12 years toby # on 2000/10/18 00:11:17, toby did: fixup formatting
(edit) @343   12 years toby # on 2000/10/18 00:11:17, toby did: move utilites organize
(edit) @342   12 years toby # on 2000/10/18 00:11:17, toby did: new error msg fixup formatting
(edit) @341   12 years toby # on 2000/10/18 00:11:17, toby did: new error msg fixup formatting
(edit) @340   12 years toby # on 2000/10/18 00:11:17, toby did: fixup formatting
(edit) @339   12 years toby # on 2000/10/18 00:11:17, toby did: new error msg fixup formatting
(edit) @338   12 years toby # on 2000/10/18 00:11:17, toby did: new error msg fixup formatting
(edit) @337   12 years toby # on 2000/10/18 00:11:17, toby did: fixup formatting
(edit) @336   12 years toby # on 2000/10/18 00:11:17, toby did: fixup formatting
(edit) @335   12 years toby # on 2000/10/18 00:11:17, toby did: fixup formatting
(edit) @334   12 years toby # on 2000/10/18 00:11:17, toby did: fixup formatting
(edit) @333   12 years toby # on 2000/10/18 00:11:17, toby did: fixup formatting
(edit) @332   12 years toby # on 2000/10/18 00:11:17, toby did: fixup formatting
(edit) @331   12 years toby # on 2000/10/18 00:11:17, toby did: fixup formatting
(edit) @330   12 years toby # on 2000/10/18 00:11:17, toby did: add more utilities docs fixup …
(edit) @329   12 years toby # on 2000/10/18 00:11:17, toby did: add more utilities docs fixup …
(edit) @328   12 years toby # on 2000/10/18 00:03:58, toby did: Major change in order of routines! …
(edit) @327   12 years toby # on 2000/10/18 00:00:05, toby did: move platform-specific runtime …
(edit) @326   12 years toby # on 2000/10/17 23:59:32, toby did: correct comments w/r focus
(edit) @325   12 years toby # on 2000/10/17 15:20:45, toby did: snapshot with revisions for WWW help
(edit) @324   12 years toby # on 2000/10/12 22:12:21, toby did: fix html bugs for Windows
(edit) @323   12 years toby # on 2000/10/12 21:40:40, toby did: implement optional EXPTOOL output …
(edit) @322   12 years toby # on 2000/10/12 21:36:23, toby did: Add www help support improve …
(edit) @321   12 years toby # on 2000/10/12 21:35:45, toby did: Add www help support implement …
(edit) @320   12 years toby # on 2000/10/12 21:30:14, toby did: Add www help support
(edit) @319   12 years toby # on 2000/10/12 21:30:14, toby did: Add www help support
(edit) @318   12 years toby # on 2000/10/12 21:30:14, toby did: Add www help support
(edit) @317   12 years toby # on 2000/10/12 21:15:58, toby did: * empty log message *
(edit) @316   12 years toby # on 2000/10/12 21:15:58, toby did: A listing of informational, …
(edit) @315   12 years toby # on 2000/10/12 21:15:58, toby did: optional EXPTOOL output
(edit) @314   12 years toby # on 2000/10/12 21:15:58, toby did: optional EXPTOOL output
(edit) @313   12 years toby # on 2000/10/12 21:15:58, toby did: add anchors for on-line help
(edit) @312   12 years toby # on 2000/10/12 21:15:58, toby did: add anchors & more text for …
(edit) @311   12 years toby # on 2000/10/12 21:15:58, toby did: add anchors & more text for …
(edit) @310   12 years toby # on 2000/10/12 21:15:58, toby did: add anchors & more text for …
(edit) @309   12 years toby # on 2000/10/12 21:15:58, toby did: optional EXPTOOL output add …
(edit) @308   12 years toby # on 2000/10/04 20:39:22, toby did: document expgui(bkgcolor1) on …
(edit) @307   12 years toby # on 2000/10/04 20:39:22, toby did: document expgui(bkgcolor1) on …
(edit) @306   12 years toby # on 2000/10/04 20:35:17, toby did: variable expgui(bkgcolor1) …
(edit) @305   12 years toby # on 2000/10/03 23:29:29, toby did: Add definitions and implementation …
(edit) @304   12 years toby # on 2000/10/03 23:29:29, toby did: Add definitions and implementation …
(edit) @303   12 years toby # on 2000/10/03 23:29:29, toby did: Add definitions and implementation …
(edit) @302   12 years toby # on 2000/10/03 23:28:06, toby did: update to reflect latest changes
(edit) @301   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @300   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @299   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @298   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @297   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @296   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @295   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @294   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @293   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @292   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @291   12 years toby # on 2000/10/03 23:27:17, toby did: Add the NIST required ALT= tags to …
(edit) @290   12 years toby # on 2000/10/03 23:18:57, toby did: A batch file used to create a .EXE …
(edit) @289   12 years toby # on 2000/10/02 16:54:10, toby did: remove unneeded raise command in …
(edit) @288   12 years toby # on 2000/10/02 16:52:08, toby did: make phase buttons/title like on …
(edit) @287   12 years toby # on 2000/10/02 16:50:47, toby did: * empty log message *
(edit) @286   12 years toby # on 2000/09/26 17:57:10, toby did: change processing of ' & " for …
(edit) @285   12 years toby # on 2000/09/26 14:51:04, toby did: Various fixes: change data names …
(edit) @284   12 years toby # on 2000/09/25 20:09:50, toby did: Display a message returned by the …
(edit) @283   12 years toby # on 2000/09/25 20:08:45, toby did: Add texture index
(edit) @282   12 years toby # on 2000/09/25 20:07:22, toby did: Add CIF import documentation
(edit) @281   12 years toby # on 2000/09/25 20:07:22, toby did: Add CIF import documentation
(edit) @280   12 years toby # on 2000/09/24 04:41:00, toby did: CIF coordinate import routine, …
(edit) @279   12 years toby # on 2000/08/21 19:37:35, toby did: pretty up page with a table of links
(edit) @278   12 years toby # on 2000/08/21 19:37:09, toby did: pretty up page with table of links
(edit) @277   12 years toby # on 2000/08/21 19:36:29, toby did: pretty up page with table of links
(edit) @276   12 years toby # on 2000/08/21 19:36:29, toby did: pretty up page with table of links
(edit) @275   12 years toby # on 2000/08/21 19:36:29, toby did: pretty up page with table of links
(edit) @274   12 years toby # on 2000/08/21 19:36:29, toby did: pretty up page with table of links
(edit) @273   12 years toby # on 2000/08/21 19:36:29, toby did: pretty up page with table of links
(edit) @272   12 years toby # on 2000/08/21 19:36:29, toby did: pretty up page with table of links
(edit) @271   12 years toby # on 2000/08/21 19:35:43, toby did: update to reflect current progress
(edit) @270   12 years toby # on 2000/08/21 19:33:31, toby did: describe coordinate import routine …
(edit) @269   12 years toby # on 2000/08/21 19:27:43, toby did: describe coordinate import …
(edit) @268   12 years toby # on 2000/08/17 23:49:20, toby did: reformat dialogs for Import …
(edit) @267   12 years toby # on 2000/08/17 23:48:03, toby did: implement Replace Phase error …
Note: See TracRevisionLog for help on using the revision log.
