source: trunk
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Diff Rev Age Author Log Message
(edit) @314   12 years toby # on 2000/10/12 21:15:58, toby did: optional EXPTOOL output
(edit) @313   12 years toby # on 2000/10/12 21:15:58, toby did: add anchors for on-line help
(edit) @312   12 years toby # on 2000/10/12 21:15:58, toby did: add anchors & more text for …
(edit) @311   12 years toby # on 2000/10/12 21:15:58, toby did: add anchors & more text for …
(edit) @310   12 years toby # on 2000/10/12 21:15:58, toby did: add anchors & more text for …
(edit) @309   12 years toby # on 2000/10/12 21:15:58, toby did: optional EXPTOOL output add …
(edit) @308   12 years toby # on 2000/10/04 20:39:22, toby did: document expgui(bkgcolor1) on …
(edit) @307   12 years toby # on 2000/10/04 20:39:22, toby did: document expgui(bkgcolor1) on …
(edit) @306   12 years toby # on 2000/10/04 20:35:17, toby did: variable expgui(bkgcolor1) …
(edit) @305   12 years toby # on 2000/10/03 23:29:29, toby did: Add definitions and implementation …
(edit) @304   12 years toby # on 2000/10/03 23:29:29, toby did: Add definitions and implementation …
(edit) @303   12 years toby # on 2000/10/03 23:29:29, toby did: Add definitions and implementation …
(edit) @302   12 years toby # on 2000/10/03 23:28:06, toby did: update to reflect latest changes
(edit) @301   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @300   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @299   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @298   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @297   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @296   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @295   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @294   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @293   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @292   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @291   12 years toby # on 2000/10/03 23:27:17, toby did: Add the NIST required ALT= tags to …
(edit) @290   12 years toby # on 2000/10/03 23:18:57, toby did: A batch file used to create a .EXE …
(edit) @289   12 years toby # on 2000/10/02 16:54:10, toby did: remove unneeded raise command in …
(edit) @288   12 years toby # on 2000/10/02 16:52:08, toby did: make phase buttons/title like on …
(edit) @287   12 years toby # on 2000/10/02 16:50:47, toby did: * empty log message *
(edit) @286   12 years toby # on 2000/09/26 17:57:10, toby did: change processing of ' & " for …
(edit) @285   12 years toby # on 2000/09/26 14:51:04, toby did: Various fixes: change data names …
(edit) @284   12 years toby # on 2000/09/25 20:09:50, toby did: Display a message returned by the …
(edit) @283   12 years toby # on 2000/09/25 20:08:45, toby did: Add texture index
(edit) @282   12 years toby # on 2000/09/25 20:07:22, toby did: Add CIF import documentation
(edit) @281   12 years toby # on 2000/09/25 20:07:22, toby did: Add CIF import documentation
(edit) @280   12 years toby # on 2000/09/24 04:41:00, toby did: CIF coordinate import routine, …
(edit) @279   12 years toby # on 2000/08/21 19:37:35, toby did: pretty up page with a table of links
(edit) @278   12 years toby # on 2000/08/21 19:37:09, toby did: pretty up page with table of links
(edit) @277   12 years toby # on 2000/08/21 19:36:29, toby did: pretty up page with table of links
(edit) @276   12 years toby # on 2000/08/21 19:36:29, toby did: pretty up page with table of links
(edit) @275   12 years toby # on 2000/08/21 19:36:29, toby did: pretty up page with table of links
(edit) @274   12 years toby # on 2000/08/21 19:36:29, toby did: pretty up page with table of links
(edit) @273   12 years toby # on 2000/08/21 19:36:29, toby did: pretty up page with table of links
(edit) @272   12 years toby # on 2000/08/21 19:36:29, toby did: pretty up page with table of links
(edit) @271   12 years toby # on 2000/08/21 19:35:43, toby did: update to reflect current progress
(edit) @270   12 years toby # on 2000/08/21 19:33:31, toby did: describe coordinate import routine …
(edit) @269   12 years toby # on 2000/08/21 19:27:43, toby did: describe coordinate import …
(edit) @268   12 years toby # on 2000/08/17 23:49:20, toby did: reformat dialogs for Import …
(edit) @267   12 years toby # on 2000/08/17 23:48:03, toby did: implement Replace Phase error …
(edit) @266   12 years toby # on 2000/08/17 23:46:23, toby did: perform origin shifts for Origin 1 …
(edit) @265   12 years toby # on 2000/08/17 23:44:52, toby did: Fix bug setting gamma
(edit) @264   12 years toby # on 2000/08/17 23:40:38, toby did: space group table for .CEL …
(edit) @263   12 years toby # on 2000/08/14 21:09:21, toby did: Routine to read PowderCell?
(edit) @262   12 years toby # on 2000/08/14 16:28:34, toby did: eliminate phase flag box if only 1 …
(edit) @261   12 years toby # on 2000/08/08 23:21:55, toby did: Correct creation of off-diagonal …
(edit) @260   12 years toby # on 2000/08/04 19:26:00, toby did: document phase flags
(edit) @259   12 years toby # on 2000/08/04 19:25:35, toby did: document atom xform/global set
(edit) @258   12 years toby # on 2000/08/04 19:24:50, toby did: expand "shortcut" discussion
(edit) @257   12 years toby # on 2000/08/04 19:24:21, toby did: sort by occ.
(edit) @256   12 years toby # on 2000/08/04 19:23:57, toby did: update with latest
(edit) @255   12 years toby # on 2000/08/04 18:29:16, toby did: Change phase buttons, add "Add …
(edit) @254   12 years toby # on 2000/08/04 18:26:37, toby did: new procs: MakeXformAtomsBox?, …
(edit) @253   12 years toby # on 2000/08/04 18:25:05, toby did: document that temptype can be …
(edit) @252   12 years toby # on 2000/08/04 18:19:37, toby did: redo error msgs phaseinfo: change …
(edit) @251   12 years toby # on 2000/08/04 18:18:18, toby did: add commands to single xtal menu, …
(edit) @250   12 years toby # on 2000/07/28 20:29:34, toby did: add phase flag box to histogram …
(edit) @249   12 years toby # on 2000/07/28 20:28:25, toby did: remove unneeded ref to Win98 for …
(edit) @248   12 years toby # on 2000/07/28 20:27:10, toby did: note latest
(edit) @247   12 years toby # on 2000/07/28 20:20:03, toby did: document profile constraints
(edit) @246   12 years toby # on 2000/07/28 20:18:20, toby did: document change in profile button
(edit) @245   12 years toby # on 2000/07/28 20:17:40, toby did: note sort on header
(edit) @244   12 years toby # on 2000/07/28 20:16:33, toby did: document ODF
(edit) @243   12 years toby # on 2000/07/28 20:15:14, toby did: add CCP14 mirrors for gsas dist.
(edit) @242   12 years toby # on 2000/07/28 20:15:14, toby did: pretty it up
(edit) @241   12 years toby # on 2000/07/28 20:14:41, toby did: new additions andf ideas
(edit) @240   12 years toby # on 2000/07/20 22:13:40, toby did: move MDprefinfo into readexp.tcl
(edit) @239   12 years toby # on 2000/07/20 22:13:40, toby did: correct use R settings in …
(edit) @238   12 years toby # on 2000/07/20 22:13:40, toby did: use file join on notebook.tcl move …
(edit) @237   12 years toby # on 2000/07/20 22:12:18, toby did: select new phase after a phase is added
(edit) @236   12 years toby # on 2000/07/20 22:09:56, toby did: Add odf (spherical harmonic) …
(edit) @235   12 years toby # on 2000/07/20 22:03:39, toby did: Spherical Harmonic implementation
(edit) @234   12 years toby # on 2000/07/06 22:43:40, toby did: Change profile term labeling to …
(edit) @233   12 years toby # on 2000/07/06 21:36:22, toby did: add profile constraint subpage …
(edit) @232   12 years toby # on 2000/07/06 21:31:38, toby did: use short DOS names for adding …
(edit) @231   12 years toby # on 2000/07/06 21:29:24, toby did: Add GetProfileTerms?, GetLaue?, …
(edit) @230   12 years toby # on 2000/07/06 21:28:01, toby did: use MakeHistBox? for histogram …
(edit) @229   12 years toby # on 2000/07/06 20:35:35, toby did: delete the old expmap (except for …
(edit) @228   12 years toby # on 2000/07/06 20:33:55, toby did: alpha test version of the profile …
(edit) @227   12 years toby # on 2000/07/03 21:50:35, toby did: fix aniso atoms in exp2xtl
(edit) @226   12 years toby # on 2000/07/03 21:44:27, toby did: make into multiple pages
(edit) @225   12 years toby # on 2000/07/03 21:43:33, toby did: Menu Contents
(edit) @224   12 years toby # on 2000/07/03 21:41:08, toby did: Preferential Orientation Pane
(edit) @223   12 years toby # on 2000/07/03 21:41:08, toby did: Constraints pane
(edit) @222   12 years toby # on 2000/07/03 21:41:08, toby did: Profile pane
(edit) @221   12 years toby # on 2000/07/03 21:41:08, toby did: Scaling pane
(edit) @220   12 years toby # on 2000/07/03 21:41:08, toby did: Histogram pane
(edit) @219   12 years toby # on 2000/07/03 21:41:08, toby did: Phase Pane
(edit) @218   12 years toby # on 2000/07/03 21:41:08, toby did: Least Squares (LS) Controls Pane
(edit) @217   12 years toby # on 2000/07/03 21:41:08, toby did: template
(edit) @216   12 years toby # on 2000/07/03 21:36:05, toby did: add more environment space
(edit) @215   12 years toby # on 2000/07/03 21:35:33, toby did: add multiplicity
Note: See TracRevisionLog for help on using the revision log.
